This interest rate is for certain models and the HHR is one of them but they don't say if it's for all the HHR models (LS, LT and SS) or if it's only for the base model (LS).
Anyone out there can help with this?
Are they suppose to come with a "cargo net" that you attach on both sides near the tailgate?
The anchors are there on both sides and would imagine it's for attaching a "cargo net"?
The 2010 HHR doesn’t come standard with the cargo net. You can however, get is as an accessory. You can go to this website: http://www.gmaccessorieszone.com/Chevrolet/2010/HHR/Cargo%20Net/?src=chevrolet&t- x_gmshopb2b_pi1%5Btype%5D=gm
It will give you the MSRP of the cargo net as well. You will have to order it through your dealership. Thank you,
Mariah GM Customer Service
Thanks again.
Thank you so much for the compliment!! I really appreciate it. Thank you,
It's been 2 days now that my exterior temperature in my dash reads 36 F and it seems to be stucked there although the temperature yesterday was 62 F. and today 59 F.
On sunday it read 61 F. and 5 minutes later 52 F. but the real temperature was the same on the Weather channel.
It's a shame.... I only have 90 miles on it.
Could it be defective so soon?
Went to the dealer and they said it was the "stick shift's celenoid" and they had to change the entire "stick shift assembly" because it's all in one piece, they can't chance only the celenoid.
I can't believe this, my HHR has only 90 miles on it and I'm trying to be as religious as can be to go trough my "break-in" and this happens.
Anyone esle had this happened to them?
I cant believe that Chevey can make a car where you have to change whole units rather than the faulty part!
Dont break an inside dorr handle! $375 for a 20 cent plastic piece as they have to replace the whole door panel.
Nothing like creating 15 pounds of wast to reple a 3 oz piece.
Good job chevy!!!! not
I couldn't get the stick shift out of Park remember? (read posts above)
The dealer changed the "Shifter Lockout solenoid".
When I went to the dealer to pick it up everything seemed to work well. After dinner I went to one of my friend's house to watch the hockey game. When I was ready to leave, I started the engine with my remote, got in the car, put the key in the ignition, turned it to run position, press on the brake pedal and.....couldn't get it out of Park.
Hey! Only 6 hours after I went to pick it up.
Shut the engine, start it up again and it got out of Park.
Went home and tried it again manually and with the remote...no problem, it worked well.
What could be the problem? and What should I do.
The first time it happened My HHR had 90 miles on it, it's doing it again with 120 miles.
Usually when I started my cars with the remote and got in the car and forgot to turn the key to "RUN" position in the ignition, as soon as I pressed on the brake pedal the engine would stop, but on my 2010 HHR it doesn't seem to work like this. Normal?
When the engine is turned off and you press on the brake pedal, the brake light don't light up. Normal?
Not sure but I think that my other vehicles brake lights came on when pressing on the brake pedal even if the engine wasn't running.
I apologize that the first fix didn't repair the vehicle. When you take it back and have them look at it again, please keep me informed on how everything goes. If you experience the concern again after the second fix then I am going to look into it further for you. Thank you,
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
The "HHR" is kind of a special car, that's why you always see a bunch of them in dealer's car lots and not to many on the road (more or less).
The "HHR" is a car/truck that you either "Love it" or "Hate it".
Mine is a 2010 2LT and so far for my necessity it's the best of all my vehicles that I ever owned. Economical, small, nice design, good cargo space, well equipped and fun to drive...I love it very much.
What is your mpg rating city / hwy?
Is it a 2.2 L or 2.4 L?.... automatic or standard?
They say in the owner's manual to stop for gas as soon as this happens but sometimes you don't have gas stations near.
The sound comes from the head liner on the passenger's front side because when I put my fingers between the sunroof and the head liner it stops.
The sound can be heard just by slightly pushing and pulling on the head liner's front right side, when I pull and push on the front left there's no sound.
When the panel is closed, you can still hear it but less.
What can be done to eliminate this annoying sound.
Sometimes the noise is very minimal and the next day...I could pull all my hair off my head because the slightest crack in the road makes that noise unbearable.
I'll let you know if ever they can fix it and how they did it.
I don't see any GM emblem on the bottom of the front door on mine.
I open it completely and then close it immediately the sound seems to diminish a bit but is still there.
When it's only the back part of the glass that's open the sound doesn't go away.
I went to the dealer and they said that they don't hear a thing. Are they all deaf or they just don't want to hear it?
Sometimes it sounds like metal bars knocking together.
Some days it's worst and other better.
I can't pin point the origin of that noise.
Anyone else with this problem?
That rattling sunroof of mine (see posts # 1477 & 1478) is giving me headaches.
This morning I, neither the mecanic could duplicate the rattle but yesterday it rattled like hell, like 2 screwdrivers knocking together.
The mechanic drove it for 3 miles hitting every holes, bumps, cracks that he could find...nothing.
He made a visial check and told me that he had tighten 4 screws about 1/2 to 3/4 turn.
I surelly hope that it fixed the problem.
I apologize that you are experiencing an issue with your vehicle. Have you had anyone look at the concern you have present in the vehicle? Can you please email me your VIN and current mileage? You can get my email by clicking on gmcustsvc. Thank you,
Well, I guess those 4 screws that the mechanic gave 1/2 to 3/4 turn did the trick.
Can hear that metal rattling sound no more, it's finally gone.
But I can't figure out where the heck are those screws?
Thanks!!!
Please let let me know as I'm purchasing in the next couple of days. It seems like your customer service is great and follow through is great on encountering any problems. Please advise.
Thanks!!
I often travel to the U.S.A. and would like to know how can I change the "Metric units" to "Imperial units".
Ex: Exterior Temperature from "Celsius to Fahrenheit", Fuel Economy from "Kms/p/h to m/p/h, Driving Range, --- kilometers to --- miles, ect...
The mechanic inflated my tires at 30 p.s.i and I checked on the driver door panel an it says 35 p.s.i. so I re inflated them to 33 p.s.i.
Who's right ... 30 psi (dealer), 33 (mine) or 35 (door label)?
Also, I was trying the check my coolant level in the tank but can't find any cool/hot line on it like it should have. It's the first time I see such a place to put a coolant reservoir, can't see any level line.
Is there one? and where?
Left home with our new 2010 HHR 2LT, did my first oil change at 1,300 miles before leaving.
Now we're on the west coast, with 4,300 miles. Planning to leave to go back home with 4,800 miles. Since I'll have done 3,500 miles on my 1rst oil change, should I do a oil change before leaving?
I still have 3,000 miles to do before getting home.
My HHR 2LT has 17 inch tire.
Can I install 16 inch rims so I could buy 16 inch snow tires?
They would probably be less expensive.
If so, what size of snow tire could fit on a HHR?
The HHR was super.
Driving 65 - 75 mph most of the way. Fuel range, lowest 450 miles, highest 485 miles. We like it. Went across the Rockies without problems. Total mileage 6,000 miles and started with the oil at 100%, after 6,000 miles still 62%
But we had to cut our vacation short...on the 13th of sept we had a phone call that my wife brother had died (55 yrs old).
So packed up in a hurry and left Victoria on the 14th to get back home, we had 3,000 miles to drive.
Arrived home on the 19th, called my Mom and Dad as soon as we arrived, finish talking to my Dad at 7:00 p.m.
The next morning at 8:00 a.m. I had a phone call that my Dad had just died at home in the bathroom.
My brother in law died on the 13th and 1 week later on the 20th day for day it's my father.
Buried my brother in law on friday the 24th sept and my Dad on the 27th
