http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm
TSB #04405 (at some sites it is EG044-05)
NHTSA #10016963
I believe and hope the 2006 4Runner should not have rotor issues (most bugs worked out as it is 4th year production since 2003 model), as I have been doing a lot of research and have not found any issues with the generation of 2003 year model.
I drove other SUVs compact/medium size but nothing can compare to the beast (I call the 4Runner)...
Good luck...
I've tried everything to remedy this issue, including new tires, but no success.
Thank you in advance,
linacjsdad.
Thank you, linacjsdad.
Been there, done that. Have them hanging already. Seems to be a tough problem to resolve, especially when others that I know of are not having this issue.
Thanks. linacjsdad.
I've got a transmission issue on an '03 V8 4Runner where I was on a 3 hour drive where all of a sudden the Xmission would not go into 4th or 5th gear. I had to drive the rest of the way going slow since I didn't want to red line it in 3rd. I went and read the DTC code and got the following:
P0776 "Pressure Control Solenoid B Performance or Stuck Off"
But after the car sat for a little while I drove it again and the problem had gone away, so it's intermittent. Looking at the shop manual, the first thing it says to check is a specific solenoid. It seems plausible that the solenoid that they refer to was simply stuck due to the intermittent nature of the failure.
Checking the solenoid requires dropping the pan on the tranny. But at this point I'm pretty sure that no problem would show up, since the issue went away. I know the problem will come back at the most inconveinient time, so hoping that "it fixed itself" is usually not wise. I'd be inclined to simply replace the solenoid once I bother dropping the tranny pan since messing with tranny fluid and gasket sealer is such a pain.
Before I go to all the trouble though, has anyone else seen this?
I've got 65,000 miles on it already, so I'm out of the warranty. I got a Toyota because I wanted reliability. I'm not that impressed to be seeing issues in the Xmission already. This feels too much like something that would be expected on a Chrysler and not on a Toyota.
Eric
linacjsdad.
As I recall, when I used to wrench for the Toyota dealer, we had that same problem in the Camry's a few years back. They did have a TSB out for that. Regardless, Toyota is very good at covering warranty work even after your warranty expires. If the dealer still does not do it out of good will after giving them a little pressure, ask for the Corporate 1-800 number and they should be more than happy to do "Good Will" warranty work. Toyota Corp. grades the dealership heavily on customer survey reports. I've done it many times when I wrenched.
linacjsdad
All have been taken into consideration. I live in sunny Southern California. Of course, I expect to receive my dose of static shock during cold dry winter mornings due to temp. and low humidity, but I still get it just as bad, if not worse during 90 + temp high humidity So. Cal. days. It's a problem 365 days a year. I have done comparison research with other owners of the same vehicle. C
o-workers and family members. None have the same problem. It's just my runner. Those who drive my vehicle experience the same phenomena. (ZAPPP!!!! CRACK!!!) Really, it's a serious, loud audible POP!!! I work at a Space and Airborne facility at this time, and I have consulted a few engineers regarding this problem. I've also changed out my tires to brand which I've used for years on my other 4 Runners that are not high on silica(more carbon) content. No change. And I've also did the OCD method of exiting the car, like you mentioned. Once you roll your hand, even though you are touching metal. ZAPP!!! Sorry to sound like a whiner, but it's been a problem for 3 yrs, and I still owe, so I really don't want to take a major hit on the loss by trading in the vehicle (poor resale currently on V8 Vehicles). I might just let my old buddies at the dealer have it for a few weeks and see what they can find. Man, I hate to leave my car at the dealer(even though I am a former wrencher there). I'm not sure if they can do anything about it though. I've tried once already. I'm hoping to find someone with the same or similar problem who can give me a permanent effective solution.
Thanks again, linacjsdad.
Apparently, the danger is really during fueling. Re-entering the vehicle before the pump shuts off is a no-no. Watch the video.
Seems as though the friction of the passenger against the seat is what results in the charge being established on the person. Holding a metal object and touching it to the frame makes some sense.
I suppose someone might want to try spraying the seats with an anti-static treatment. Perhaps someone might go so far as to wear a wrist strap that is attached to a metal part on the frame of the vehicle. Maybe something could be rigged on the steering wheel to constantly dissapate charge from building up on the body, or design a seat cover that sinks the charge to the frame.
linacjsdad
Thanks for the reply.
I did check all the current TSBs and there's nothing for anything related to this yet.
The dealer quoted me $718.00 to swap out the solenoid but there would be no guarantee that the solenoid was really the problem. It could be an intermittent open in the wiring or maybe an intermittent issue in the controller.
Their advice was to ignore it and wait for it to become a hard failure; not too re-assuring since Murphy's Law dictates that it WILL fail again. And it will fail again at the worst possible time.
Anyway, I'll try the 800 number and see what they say.
Eric
When you study the differences of the 3 when you go to the Toyota.com web site you will see a lot of similarities in all 3. So, it's really according to how important certain things are for you. I have five extra options on mine that I like. When you study the comparison of the 3 it will become clear to you which you would like better.
As for sport, limited, SR5, it all depends upon what options you want. You'll have to look through the option packages and decide what you require versus what you can live without. Personally, I could not live without side-curtain airbags and heated seats. As a result, I ended up with a limited. YMMV.
Thanks for the help
Are you asking about the flat gray fender flares versus the body color painted fender flares? If so, I believe the flat gray unpainted fender flares have been discontinued. In the first year or so, the Limited came with the fender flares painted the body color. The SR5 (and the SE?) came with unpainted fender flares. They've since changed that.
Toyota wants 350.00, you can purchase the same spoiler for 76.00 + shipping from spoilersmart.com with the rear light.
unpainted of course..any decent body shop can paint it..
Spiders - Lithium base chassis grease NLGI No.2
Slide Yokes - Mloybdenum disulfide lithium base chassis grease or Lithium base multi purpose grease NLGI N0.2
All the TOYOTA dealerships I talked to, offered "General Purpose Wheel Bearing chassis grease" C0009-00032.
They say this is stuff their mechanics use.
Can anyone run into this tell me what to use. :confuse:
more in winter time..
I have checked that no leak on heater coil, new radiator & oil level is just right (so, it is not the head gasket blown)..
any other suggestion to look at it???
Toyota apparently decided that the unpainted plastic was reducing sales, so they discontinued it. All trim levels, SR5, SE, and Limited now have painted bumper covers and fender flares.
I haven't seen the FJ Cruiser in person. I'm a bit worried about the reduced visibility caused by the C-pillars and the large mirrors. I'm not a fan of swing-out rear doors -- I prefer a hatch like the 4Runner.
I like the looks of the FJ Cruiser, but it's too small for me. It will certainly be better offroad than the 4Runner (better clearance and better angles), but the 4Runner is more than capable of handling the offroading that I do. Also, I like the luxury features of my Limited, like leather seats, automatic headlights, and heated seats.
Sulfur from 2003 4Runner
