Thank You!
Chas
Has 85,000 miles on it and three months ago, it died due to a failed fuel pump. Cost $350 to replace that. Now the gas gauge has died and the rubber tube for the gas filler is cracked. That's $450 for the tube replacement and $200 for the fuel gauge. Talked to two Ford (Mazda) dealers and one independent. All three stated replacing the fuel pump would not have caused the gauge or tube to break - "old age" did it.
Sell it before you get 50,000 miles on it.
I have a 2000 Mazda B3000 truck and the gas flap says that it may be able to use ethanol(E85) fuel, but that I should look at the users manual for details. The users manual says that some models are Flex Fuel Vehicles (FFV). Does anybody know how I can tell for sure if my truck is a FFV. Thank you.
I'm looking for some tailgate hardware..EX:...support cable..latches and latch bolts, etc;
Is there a web site where I can go too?...much appreciated if anyone can help.
Thanks....Ken
2015 Mazda 3 Skyactive 6spd. auto 2008 Mazda Tribute S 4spd auto.
Mazda has no plans at this time to sell the new version. The compact truck market will have to significantly improve for Mazda to consider a truck offering.
So, far I've had to get new brakes and a couple of other things done to it which cost @$500 total.
But the truck runs great. It can really take all of the running around I do in it.
The only problem is that it does not have the "out of gas warning light" that comes with the newer cars; so, I ran out of gas the other day and when after I finally got the tank filled up again, the car stalls out. Now it keeps stalling if I idle in it for more than 5 seconds.
It's a shame because I REALLY like that little truck.
Most mechanics won't even bother working on it because it is so old and they just don't know that much about it. I believe that once an older car runs out of gas, you have to fill up the gas tank and add gas to the carburetor in order to get it running again, but since I don't know that much about cars, I can't add the gas to the carburetor myself and the mechanics just tell me that you only need to add gas to the carburetor if it is a new car that is coming off of the lot.
Anyway, I'd really appreciate some suggestions you might have.
Good luck with finding a mechanic
Richard
1. Where does the choke wire go? I have heard that it connects to the alternator, but have not found any empty wires or spots for it to go.
2. I had two carbs and two intakes when I started (came w/ the truck). One of the plates under the carb had a wire coming off of it. Anyone know where this wire goes?
3. I have the truck so that it will idle now, but at over 1000 rpm. If I put it lower, it dies (no choke hooked up on a warm/hot day). If I put the truck in reverse (oh, it is an automatic), it dies if I hold the brake. If I hit the gas, it usually stays running. Some of the time I put it in forward it will stay running, otherwise it dies. If I am driving and slow down to turn, the truck dies.
The truck had a blown head gasket before I got it. Would the o2 sensor cause any of these issues? The wire for it is beat up, but I am pretty sure the wire is still ok. Would one of the catalytic converters cause an issue like this? I think the truck has two if memory serves (I put it together a LONG time ago, and now finally have the time to mess with it).
Oh, just remembered another issue. A previous owner must have had the fuel pump (in-tank on automatics) go out and not wanted to pay the 100 plus to buy a replacement, so he put a manual pump in it. It doesn't seem to deliver a lot of fuel. I put a filter on one of the hoses by the carb and you can see fuel spray into it, but it never has any sitting in it. Of course, there is always the chance that I hooked something up wrong way back when... but if I did, I doubt it would run at all. I replaced the filter below the tank this morning and now it idles, it didn't before. I also don't have a lot of gas in the tank. Would a very low/mostly old amount of gas cause idling probs? I guess i should go grab a few gallons of gas and see. I just don't want to fill it up much if I am going to have to pull the tank and replace the pump.
Any help would be appreciated. I don't have a huge amount of funds (layed off atm), but a lot of time. I really like this truck and want to start driving it. I just don't want to have it die on me all the time.
My truck used to shut off when it idled also, but once I got a tune up, it was fine.
My truck has overheated and because I was too much of a dumbass to have it checked right away, the head gasket became warped and I had to have to have that replaced. But I also had to have a new carburetor put in.
Regarding the fuel tank issues, at one point I ran out of gas and as another poster indicated, that created havoc on my fuel system. So, my suggestion is not to let your fuel get too low & if the car has been sitting for a while, that may well be your problem.
I, too, don't have much money so it really helped me that I was able to go to craigslist and find a low price mechanic who would do the work and let me pay him later. His name is Larry, 215-743-2914 & he might even give you free advice over the phone about your truck. It can't hurt to ask. If you can do the work yourself, you might want to barter for the parts, etc.
Sorry, if I wasn't much help. Good luck!
I was billed $1003.29 for Fuel pump,filter, and installation. My truck died and would not restart. I had it towed to the shop, and it was fixed by the end of the next day. Can you give me an idea of average ball-park cost for this repair?
Thanks for your time & expertise!
Now seriously broke in Denver, Colorado
I called the company and described the problem and a person there said it probably was a solenoid not working, which by default would then let gas go through without enough air to mix with it.
So I swapped out the old solenoids from the previous carburetor and found that the "slow fuel cut solenoid valve" in the new one was missing the heart of its reason for being: an inch-and-a-half-long nail-like pin that pushed in and out to permit or stop the flow of fuel. I put in that pin from the old one.
It runs better.
But.....it just failed emissions. For years it had been passing with lots to spare. Now the CO% is far too high:
15 mph reading is 6.65 and should be no more than 01.69
25 mph reading is 8.32 and should be no more than 02.20
So the thing is burning too rich.
How can I adjust that down?
The Problems- When I shift the transfer case into 4hi and start to drive (wether forward in any gear or in reverse) the truck starts making a loud clanking sound from under the truck. The sound resignates somewhere from the transfercase forward. I think it is either in the clutch or t-case itself thats making the sound because it does NOT make the sound when the clutch pedal is pushed in and It ONLY makes this sound in 4hi, NOT 2hi and NOT 4low. When the clanking starts I feel the clanks in the clutch pedal very softly and if I dont hold the tranny shifter tightly in gear (ie. 1st gear must be pushed up very hard and reverse pulled down very hard) it makes a sound like the gear has come out of gear and the n you feel in the shifter the gears spinning as if its the gears were scraping but not going into eachother fully. I also notice when I am driving that when ever I stop and shut the truck down then go back to it with in a short period of time I can smell the smell of a slipping clutch
The Questions- could my tranny or transfercase be somehow getting hot while driving and burning the clutch fluid or could the smell be coming from an incorrectly adjusted clutch? I was told the cluch master cylinder was recently replaced so is there an adjustment on a hydraulic clutch system or could i need to rebleed the system?
Is this my transfer case having a broken tooth thats only on the 4hi gear or could the clutch have something to do with it? Just wondering because it never clanks in 2hi nor 4low nor when the clutch pedal is pushed in.
I can perform adjustments and bleed the system and thats all I know, So, Does the issues sound like adjustments or should I just take it to a tranny shop?
Second question. I bought a fuel filter. It stated that I need to depressurize my fuel system. How do I go about that?
Thanks for your help. I appreciate this a whole lot.
Though I have read on a few forums that people have replaced their ECU... I have not read that anyone suggests performing specific tests BEFORE installing the ECU.
The reason I am concerned is that I received back an ECU that stated that the solenoids/relays must have a resistance value of no less than 20 ohms or it could damage the ECU.
I called Mazda about this and they seemed clueless, but... they said that they do perform tests on the connector to see if there are any shorts, etc. prior to installing the ECU (so I assume this is probably what it is).
Mazda also said that they MUST reprogram the ECU after it is reinstalled for it to function properly.
No where have I read that this is necessary.
Mazda said that they charge $99 to 'reprogram' the ECU and if they have to diagnose it after that it would be an additional $99.
Does this seem correct or are they doing things that are unnecessary?
Any advice would be greatly appreciated.
Ron
I have a 1983 Mazda b2000 pickup manual 5 speed and when I run it sounds like it’s not getting enough air or gas to the engine and I don’t know where to start to fix the issue
