Mack
2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
On another note, I took the same car out for a test drive and I'm still recovering from the excitement. This six speed tranny is a beauty! I took an Indigo ink Limited on a 20 mile ride. I had the car up to 95mph before it engaged the sixth gear! The shifts from fourth to fifth, to sixth were so smooth the only way I felt them was by looking at the tachometer's rpms. I slowed down in a hurry. I don't need a speeding ticket around here. I am definitely stoked with this car!
Mackabee
The text button works for only the cd's. Not having it with the FM bums me out a little.
From Toyota:
"Voice-activated DVD navigation system [7] with JBL Synthesis® AM/FM 6-disc in-dash CD changer with satellite radio capability [8], MP3/WMA playback capability, auxiliary audio jack, hands-free phone capability via Bluetooth® [9] wireless technology, 360 watts (maximum output) with 12 speakers including subwoofer, Radio Data System (RDS), in-glass antenna and FM diversity reception"
OR
"JBL Synthesis® AM/FM 6-disc in-dash CD changer with satellite radio capability [8], MP3/WMA playback capability, auxiliary audio jack, hands-free phone capability via Bluetooth® [9] wireless technology, 360 watts (maximum output) with 12 speakers including subwoofer, Radio Data System (RDS), in-glass antenna and FM diversity reception"
Mackabee
Mackabee
Actually air has 78.08% nitogen. When you replace air with nitrogen, depending how it is separated, you only get maybe 22% inert gas. Some nitrogens are not pure and contain oxygen. It is dangerous, people have died in industries where nitrogen is used for purging lines. The properties of air and nitrogen are very close. The specific heat and volume are similiar at given temperature in a source I found.
Removing oxygen from tires may reduce the oxidation that slowly takes place with rubber tires. Some tires that are recapable many times may see control over oxidation. Since some people want every last bit of benefit that they can get, they do things.
If there was a positive benefit for the car owner why do the car manufacturers still add air? I guess air is still free.
ange3
No matter what, at least an effort is finally being made to fix the shifts.
I'll take the info from these posts and see if the TSBs are the same. Tnx for info on these.
BTW, any pics of the 08 out there.
TedJ
His statement makes me wonder if your mechanic only did part of the job.
TedJ
Mackabee
Yes this the factory representative drove the vehicle and concurred.
No, the regional factory engineer knows of no “fix”.
Somewhere in these forums there are discussions of new software, bulletins, etc.
Yes, my vehicle has the all latest software.
So what is the issue?
The drive train has a mind of its own, actually Toyota’s mind.
If I remove my foot from the accelerator to coast to a stop, the following abnormal behavior occurs at every shift point.
• The engine RPM increases as the vehicle shifts down.
• Therefore, because of the increased RPM, the vehicle surges forward.
In some cases it feels as if the car’s cruise control in engaged (it is not).
Thus, if one expects to decelerate, in point of fact, the car encroaches on the space between ones own vehicle and the vehicle ahead. Oftentimes, I have the sensation that a rear end collision will occur. Therefore my required reaction is to activate the brakes.
This is disconcerting and entirely unexpected on a level roadway. When it occurs on a decline the cr feels as if it is running away.
Now one needs to be careful in interpreting my words as the shift points for the higher gears the anomaly (or aberrant drive train behavior) is less noticeable, but nevertheless is present.
It is of no consequence as to whether the AC is active or not.
Unlike others who have posted in this forum, the car does not have a hesitation issue.
So I will prematurely wear my brake pads and use a bit extra gas as the RPM’s increase.
These postings seem to capture perhaps Toyota’s intent:
wwest, "Toyota Avalon 2005+" #13763, 3 Jul 2007 9:33 am
wwest, "Toyota Avalon 2005+" #13773, 8 Jul 2007 12:39 pm
Bottom line, per Toyota, need to live with the anomaly as it is not corrected until the six gear 2008 Avalon, and there is no fix.
:confuse:
What you say sounds similar to the condition they returned my 2005 Av after the TSB fix that presumably brought its hardware and firmware at par with the 2007. I took it back right away, they reprogrammed it and since then it's been shifting very well. As I reported in #13921,
"When I got the car back I was shocked at how badly it shifted, right out of the service lot -- far worse than ever before! It held every gear too long, and while shifting the engine surged at least 1000 RPM so when the next gear engaged it jumped forward. It was scary how far from spec it shifted, and surprising that it was returned in that state. But once they erased the memory and re-programmed, the result was great. It obviously needed both the software and hardware updates."
I'd take your 2007 to the dealer and insist that they erase and reprogram the ECM. Now that these TSBs are out, the problem you have is no longer "normal".
Yes, it is common sense, knowledge, that upon a downshift for/during coastdown the engine RPM will rise as will the engine compression "braking" force.
Look in your FWD or F/AWD owners manual for the section that addresses the hazards arising from disparate traction at the front vs the rear on low-traction surfaces. Braking ALWAYS results in higher "traction" at the front vs the rear. With the additional traction already provided by FWD or F/AWD the braking equation can more readily, more quickly, reach a disastrous level.
And keep in mine that unlike the brake fluid pressure ABS cannot "release" engine compression braking force. So if you should apply the brakes you might find the engine RPM rising even farther so as not to interfere with ABS activity.
The Ford patent calls for disabling the regenerative braking aspect of the FWD or F/AWD FEH/MMH vehicles the INSTANT ABS activates.
What has now changed is that the engine/Transaxle ECU will control, raise, the engine RPM during this event such that a significant level of engine braking does not result in a loss of directional control should the roadbed be too slippery to support that level of "braking".
Noticed several posts on this point on the new Suzuki SX4 with stick shift...
Also, Ford actually has a US patent involving a technique wherein braking due to regenerative hybrid battery charging in the FEH/MMH vehicles is significantly reduced if the OAT is hovering around freezing.
The technologically ENHANCED future has arrived, get used to it, it's only going to get BETTER ("worse"??)..!!
I have not checked the transmission behavior very much. Must do though to be able to enjoy driving this car. I don't remember the transmission acting this way before the TSB was done on my 2005. Someone mentioned toyota wanted to extend the transmission life by changing the shifting.
Right now I feel I made a mistake getting the fix done. I had no complaints about slowing down, only jerky shift from 1st to 2nd in slow moving traffic.
I did notice now the 1st to 2nd shifting is less annoying then when it was first done. The memory thing must have someting to do with slightly better shifting. Maybe another 500 miles will make it right.
ange3
Maybe the new TSB has changed the previous UPSHIFT upon lift-throttle coastdown to a downshift but with a rise in engine RPM to alleviate any significant, potentially DANGEROUS, engine compression braking.
But maybe both are in play.
Lower capacity ATF pump to extend FE.
Originally used the upshift technique to accomomdate lower ATF capacity.
With too much public outcry over the "flare" and "hesitation" symptoms maybe Toyota has now adopted the Suzuki originated technique of raising engine RPM to match roadspeed based on current gear ratio. Apparently the Suzuki SX4 will up-rev the engine to match roadspeed to prevent instances of loss of control and/or interference with ABS even with, upon, a driver initiated, stick shift, downshift.
TedJ
A strange question, allright! But you are saved because the 2007 is still a 5-speed. The 2008 has the 6-speed.
havalong
The '05 thru '07s are all five speeds and have now presumably been fixed (the ones that needed it) and the 2008 forward are all six speeds... so, do we, with '05 to '07's, get higher than expected resale dollars because the problem is solved and the six speeds are unknown, or, do we not because the six speed is an valuable improvement? Comments... ???
Please NO CVTs. I repeat no CVTs, they make the car seem completely lifeless. Just my opinion of course
My '06 has been completely trouble free through 15K. I think the biggest problems with the Avalon have been the steering column knock, oil leaks, and rattles in a few early '05s.
I agree. They remind me of trolleybuses.
"I think the biggest problems with the Avalon have been the steering column knock, oil leaks, and rattles in a few early '05s."
Right, and with respect to the steering column knock, has anyone had it return after it was fixed? I'm afraid I'm starting to feel light tapping noises through the steering wheel, upon starting and stopping...
Mack
One thing though, next time your sitting in your car, wiggle your "rump" in the seat. I had a new ticking noise develop that sure sounded like it was coming from the steering column but it turned out to be a loose connection under the front of the drivers seat.
Hope this helps.
Laura
TedJ
No need to shout! If your car doesn't have hesitation leave it alone.
Mackabee
In our case, the transmission continues to shift smoothly without any hint of surges or gear searches. I would define the shift pattern as a little bit below our Mercedes but noticeably better than our Volvo or Jeep (which are both fine). All in all, a wonderful improvement.
I remain soooo grateful to this board for bringing it to my attention and consider the car to be near-flawless at this point. I now know how those folks who never experienced the transmission shift problem feel - the rig is a real treat.
We have nearly 50,000 km (~30,000 miles) on the car and it has restored my faith in Toyota. Thanks guys for this site and your advice.
John
Our usual Vancouver fall rains have returned, snow will soon be falling on mountain roads you drove here (probably to Whistler, site of the next winter Olympics in 2010) and by now my OM Michelins are past 50,000 km and looking fairly worn. Back in May you told us about your new Toyo Versado tires, how have they been doing since then? I suppose you haven't yet had any chance to test them on snow or ice, but any info about their expected winter performance will be helpful.
Any other comments about alternate replacement tires, also welcome.
Cheers,
havalong
Thanks for any suggestions. I do plan on taking the car down tomorrow and getting new batteries for both key fobs. Hope that solves the problem!
I do not and have not been following the "3 ft" rule and I never have any problem before.
At least you can get in the car with the key, I would be really ticked in the middle of a snow storm.
I want to replace the high beams in my Avalon with Sylvania Silverstar 9005ST. The Sienna manual shows how to replace the headlamps. The Avalon manual says to have the dealer replace them. But it seems quite easy to take off the cover over the back of the high beam lamp and pull out to replace. It looks like I may need to remove the battery to reach in on the driver side. Am I missing something why the Avalon manual doesn't want you changing the bulbs?
A lot of people are simply incapable of doing what some of us consider simple and are lacking in common sense, many are politicians and use us as the Morlocks did the Eloi. If you are capable of maintainance on your vehicle or simply changing a headlight do so BUT I would check the lumens output of the original headlights versus the Sylvania prior to doing so.
