Fluid Change Question, 1997 Jeep Cherokee
Just wondering if anyone has some advise on changing the rear differential fluid? It seems easy enough, but wondering if anyone had run into problems doing this?
Also, my transmission fluid needs changing as well. Should I leave this for a trained mechanic, or is it something simple enough to do myself? I'm fairly mechanically inclined, but have never touched transmissions.
1997 Jeep Grand Cherokee with 54k miles.
Mike
Mike
The ATF is easy if it has a plug also, some makes do not and it means dropping the pan, a pain, or syphon the fluid via the dipstick which is fine if you have a fluid pump. Some makes (Isuzu) do not have a disptick though.
DIFFERENTIAL FLUID CAPACITY
181FBI 1.2 L (2.5 pts.)
194RBI 1.66 L (3.5 pts.)
with TRAC-LOK include 4 oz. friction modifier
216RBA 2.25 L (4.75 pts.)
DIFFERENTIAL FLUID TYPE
A multi-purpose, hypoid gear lubricant which conforms to the following specifications should be used:
MIL-L-2105C and API GL-5 quality specifications
Lubricant is a thermally stable SAE 80W-90 gear lubricant
Vehicles intended for heavy-duty or trailer tow use SAE 75W-140 SYNTHETIC gear lubricant
Differentials equipped with TRAC-LOK or VARI-LOK require the specified amount of friction modifier.
CAUTION: If axle is submerged in water, lubricant must be replaced immediately to avoid possible premature axle failure.
Raise and support the vehicle.
Remove the lubricant fill hole plug from the differential housing cover.
Remove the differential housing cover and drain the lubricant from the housing.
Clean the housing cavity with a flushing oil, light engine oil, or lint free cloth. Do not use water, steam, kerosene, or gasoline for cleaning.
Remove the original sealant from the housing and cover surfaces.
Apply a bead of Mopar(R) Silicone Rubber Sealant, or equivalent, to the housing cover. Install the housing cover within 5 minutes after applying the sealant.
Install the cover and any identification tag. Tighten the cover bolts to 41 Nm (30 ft. lbs.) torque.
Fill differential with Mopar (R) Hypoid Gear Lubricant, or equivalent, to bottom of the fill plug hole. CAUTION: Overfilling the differential can result in lubricant foaming and overheating.
Install the fill hole plug and lower the vehicle.
Trac-lok differential equipped vehicles should be road tested by making 10 to 12 slow figure-eight turns. This maneuver will pump the lubricant through the clutch discs to eliminate a possible chatter noise complaint.
Rear differential fluid change.
Apply a bead of Mopar (R) Silicone Rubber Sealant, or equivalent, to the housing cover. NOTE: Install the housing cover within 5 minutes after applying the sealant.
For Trac-lok differentials, a quantity of Mopar (R) Trac-lok lubricant (friction modifier), or equivalent, must be added after repair service or a lubricant change.
and at slow acceleration from stop, there is a high rev and slip between 2nd and 3rd. Funny thing though, it does not do this from a fast acceleration. And only does this occasionally.
Am I being warned about a big repair problem? or just some badly need maintenance.
