No they didn't do any of this. They took me to see the car and show me the wheel. The car was lift in the air and with the tire spinning their was a complete wobble while the tire was turning. They told me then my rim was bad and most of my vibration was coming from this particular rim. They then showed me the other rim but said I could hold off and see if the vibration was still too much. If it was then to come back, if not then I would need to replace that rim the next time I had my car serviced and tired rotated because the 2nd rim is currently on the back but will move to the front.
I'll admit, I have some knowledge of cars but not the specifics so maybe I should have made them do those things had I know about them. I wonder now if I just got ripped off.
Sounds like you replaced one rim and still have another that has a slight flutter. Go ahead and get that wheel balanced and I am sure you will see an improvement. Remember....even if you get it rebalanced...it will not be absolutely stone perfect...there will always be a slight movement.
Also...another thing to keep in mind for the future...since we are talking about maintenance. When replacing brakes in the future...don't just change the brake pads...but have the rotors resurfaced. Reason is that if there is an imperfection on the rotor...it will immediately create an issue where you will feel a vibration from etching an imperfection on the brake pad surface.
You might want to consider taking your car to an alternate Acura dealership for future servicing. They aren't that great at troubleshooting.
One thing that doesn't seem to work correctly is the outside temperature sensor, or some part of that circuit. Mine consistantly reads 10+ degrees high. Today, after about 30 minutes on the highway it was still reading 95 degrees when the OAT was 83 degrees. Any suggestions? Dealer tells me this is within acceptable limits, but I've never seen another car that was this far off.
Steve
Look at your owners manual...and you can adjust and recalibrate your temp readings. If you are consistently 10 degrees off...then adjust your readout by the same then you will be all fixed-up and ready to go.
Glad you are enjoying your TL.
Hmmmm, sounds like another version of, "that's normal" which Acura dealers are trained to say (LOL).
1) what's the chance my wife did any meaningful damage to the engine or transmission running at high revs for so long?
2) is it possible that the high revs just overheated the A/C compressor and that's why it died on her but seems to work now?
All thoughts appreciated!
By the way - I took the time tonight to more fully explain the transmission to her. Her MDX does not have the "manual" option.
I looked at the airbag compartment on a TSX and it was perfect no marks, etc... What's up?
Steering resistance (effort) is much higher when turning right than when turning left at steady speed (i.e., not a torque steer problem). Right turns can be so heavy I really have to pull the car around, whereas the car just falls into left turns. Tires -- Bridgestone EL42s -- have been rotated and subsequently relaced with similar. Handling balance (oversteer/understeer) and roadholding seem to be unaffected -- it's a matter of feel. All alignment readings including caster are normal. The dealer states over the phone that a problem exists, but that it is not severe enough to fall outside normal operating parameters. They won't back me up in getting the Acura regional rep to replace any parts to remedy the problem -- won't commit to writing, although there was some mention of replacing the power steering rack if they could swap one out of a demonstrator. The car, bought new, is now 13 months old. Anyone any ideas? Otherwise I love the car.
Many thanks.
But I don't think any serious damage was done in any case. I don't even think running the engine at high revs would overheat the AC compressor.
As for the A/C blowing hot air...it could be very possible that 1) she has demonstrated she was not aware how to use the gear shifter 2) not knowing how to use the gear shifter may also bode that she does not know how to operate your A/C.
Good luck...
Happy posting! :shades:
This is the second time I have read a post that says you can recalibrate the outside temperature setting with instructions from the owners manual. I have an '04 TL and I have not been able to find the instructions. :confuse: Please tell me which page, or maybe post the instructions. Thanks!
Secondly, most performance cars will cut off the air conditioning compressor when you are running at the upper end of RPMs. The reason is, if you are at the upper end of RPMs, it is obvious you are looking for maximum power, so the compressor is temporarily cut off to prevent that power drain. I wonder if the combination of maual mode and high RPM cut off the a/c compressor. If so, it should act normal now.
A variety of safety features help protect the engine and drivetrain from damage. The transmission will upshift from first to second automatically if the driver doesn't command an upshift in time. In second, third and fourth, the transmission won't upshift without a command from the driver; the ECU cuts off fuel flow to the engine if there is danger of over-revving the engine. The transmission will upshift itself to prevent engine damage in the rare situation where the fuel cutoff alone is unable to prevent further engine over revving (as could happen on a steep downhill). When downshifting, the transmission won't execute a driver-commanded downshift that would send the engine beyond redline in the lower gear. To prevent lugging away from a stop in a high gear, the Sequential SportShift transmission will automatically downshift to first gear as it comes to a stop, even in manual mode.
Sure explains a lot, though I have no idea how she failed to notice. When she called me from the road she was asking about the A/C. It was only after I got home that night that she mentioned it was shifting funny!
THANKS, Steve
Do you think the sales guy recommended regular because he was attempting to close the deal when he heard your preference for a lower cost fuel source?
Mine opens and stays up as it should. I can't recall if I have been on an incline, but it certainly shouldn't close on you.
However, I do notice the 'balance' is pretty light (IE, easy to overcome and close), so perhaps too high an incline can sent it past the balance point. But, not at slight inclines.
Have you called Acura (not the dealer)?
Thanks for your help. I will try that tonight, but I don't think that -3 degrees is going to get me where I need to be. Is everyone else's temp's reading correctly???
You do if you're walkin' barefoot!!! Seriously though, folks, I believe what he is saying is that the sun "bakes" the car, much like it bakes the asphalt, so it's going to be hotter than actual.
the temperature was showing just three dashes
How hot would you estimate it to be? I could see that happening if the temp only goes to 110 and the actual temp was over 110.
As far as the 3 dashes, I have only seen that once in my TL. That was in 100 degree temps and I was stuck in traffic for an hour. I watched the temp move from 100 all the way to 114 and then it showed me the 3 dashes. When I got back up to cruising speed it came back on at about 112 degrees.
IMO the 3 dashes come on when the computer knows that it is not accurate.
I've had outside temperature monitors on Lincolns and Buicks for years and have never had this problem.
Good point. I tried various things to compensate for that possibility, including left and right turns using just my my left hand, just my right, just a couple of fingers on the wheel, etc.. It does seem that the problem is intermittent in severity. Some days it's not really noticeable, some days very pronounced.
Other comments: One characteristic of the car is that the steering does naturally load up in turns at speed. Some cars load up as you move into the turn and then tend to neutralize as the turn becomes steady state -- the Acura is not like that. There's also some lightness, nervousness and instability around dead center (as opposed to in turns) at speed. To drive the car fast you must stay on top of it -- don't mess with coffee cups, cell phones or CDs or you'll likely find yourself in a ditch. With electronic throttle, manual transmission, steering you have to stay on top of, snatchy clutch and front-heavy front wheel drive, it's not an easy car to drive cleanly and smoothly. It rewards technique.
I find that to be true at city speed, as I did with my previous CL-S. It just feels a little "isolated", a little "disconnected", so to speak. However, it seems to tighten up nicely at highway speed, with good road feel.
I believe what you were referring to is a cushy ride like what you will find in an Avalon. Nah...you won't with the correct Michelins. If you get the Michellin Pilot Sport A/S you are getting a high performance "Y" speed rated (the original tires are "W" rated...so you are already getting a benefit)....and from what I understand it should last about 35,000+ versus so many others that may only last a lot less.
Now...I haven't purchased these yet....but that is based upon my research when I was buying the TL (I was thinking ahead and didn't want to get stuck with dud tires).
Also...the EL42 haven't been too bad for me either. However...I live near San Diego CA and it is dry and warm....so less issues with harsh wet pavement or possibility of flat spots. Me...been ok with the tires. Future....the tires mentioned above (but willing to consider suggestions from others).
http://www.bellautomotive.com/asp/product_details.asp?id=22685
