Toyota Tundra: Problems & Solutions
I still don't buy the idea that it is solely an exhaust problem. I feel and HEAR a vibration. You shouldn't hear a exhaust vibration in this truck at any speed other than possibly at lower intown speeds. I'm also getting a slight shimmy/shake when taking off from a stop.
My next stop is at the dealer to test drive another Tundra. From there, depending on what happens on the test drive, I guess the factory reps are going to get a call.
The symtoms. I the truck was running fine then all of sudden in the morning it started to have a slight vibration every so often as if it was miss firing. Then at stops it would give a periodic jerk as if it is about to die and the rpm would drop, but then it would recover. Then later in the morning after driving maybe another 15 miles, the engine started to shake real violently and sounded real bad. Had it towed to the dealer.
They are telling me that they found a loose nut in the #8 cylinder and that got wedged in the valve for all this to happen. This story is kind of similar to another post here. All inputs would be greatly appreciated.
Thanks for your consideration,
Jeannine Fallon
Corporate Communications
Edmunds.com
If you have the same symptoms on your 2005 Tundra, please respond with your experiences. I would like to get an idea of how widespread the dissatisfaction is regarding this problem.
Reply | E-mail Msg
HEY GUYS! Toyota finially has a TSB for the squeaks in 2004/2005 Tundras. See TSB SU003-04 dated 12/24/2004. Problem is with upper shock mount systems; field fix kit has been developed. Looking forward to my next service visit!! I knew it wasn't in my mind!!
Bookmark | Reply | E-mail Msg
I just got sick and tired of taking my truck back to the dealer for brakes. I finally had the front rotors turned again and install CarbonMetallic pad from "Performance Friction" and cured my brake problem. I now haul a camper and tow my 15ft boat behind me and have no brake problem. I've put on 50,000 miles with this set up and no rotor shake and pad's still look good. Very little dust also. About the transmission. I tried to talk to Toyota since I was a transmission rebuilder and told them about the slip into third gear under throttle and a severe bad you got which is very hard on all the bearing inside and also about the coasting problem you get going around a corner slow. The vehicle would go back into first gear and the overrun clutch would coast and slam back into gear when you applies throttle. They though I was some kind of dope. These so called engineers really don't know what the real world is like and that's why they have so many design changes as the public finds these faults. You think they would listen sometimes. You can't do anything about the transmission because is electronic but, what you can do is ease back into the throttle when you feel that coast feeling and also back off the throttle when going into third gear under heavy throttle. This will ease the hard shift into third. I'm going to go into my transmission one day the replace the third accumulator spring and drill out the third clutch apply hole. You know us mehanic's, we always wait til the last minute.
This is in reply to message # 97. I have this exact problem with my tranny but it seems that it is when shifting to 2nd. But like you said, if I control my throttle a little then it doesn't shift hard. Anyway, I have 89K and it tore one rear end up and going on number 2. I am debating getting it rebuilt or I can get a new tranny for 3200 with a 1K core from toyotapartsales.com . How much can I expect to pay for a rebuild and do you think I would have future problems?
Dustin
If toyota makes another independent front suspension truck, I believe I will change.
1993 Truck Std. Regular Cab 2.4L
1994 T-100 Std. Regular Cab 2.7L
2000 Tundra Std. Regular Cab 3.4L
2002 Tundra SR5 Extended Cab 4.7L
doing our first oil change on our 2005 Tundra. Now we'd like to replace
the transmission fluid we accidently drained. The 2005 Tundra doesn't have
a dipstick. There are no diagrams or explanations provided in the owner's
manual or online. Please explain the steps we need to take to do this
ourselves.
Thanks, Desperate and Clueless
kcram - Pickups Host
Does this sound familiar to anyone? It is more of an embarassing problem than a problem that effects the operation of the truck. Everyone looks at me like my truck is going to fall apart when they hear me coming.
I actually had to chop down the intake tube.
This was necessary because my fan was hitting it.
From time to time my intake tube vibrates down and I hear a rattling.
At first it's only a rattling while in gear.
This was due to engine torque shifting.
So I loosened the clamp, re-positioned the intake, and tightened the clamp like crazy.
I wonder if you have the same problem... there is not much clearance there.
Has anyone heard anything about Toyota putting diesel engines into Tundras?
Ken
Ron
Mish
Had a GM before and got tierd of replacing 300 dollar wire harnesses because GM sucks. Just bought a 27ft camper dry weight is 5900 pounds I know the Tundra does not have the horsepower, but seems to tow it ok.I have come to the conclusion that no matter what type of vehicle we the consumer buy they all have some type of bugs in them which is a shame because of what we now have to pay for a new or used vehicle.
Ken
The truck seemed to shift ok when towing but that 4.7 engine just doesn't have the power. But I'll take my Toyota over GM, FORD OR DODGE. My GM buddy said I should have gotten what he is now driving 6.0 desial duramax HD 2500 because he hauls his race car trailer. But I'm going with what consumer reports says and that would be TOYOTA TUNDRA IS THE MOST RELIABLE TRUCK OUT THERE !!!
I just won't push no more then a 3-4 hour drive to the camp grounds. THANKS AGIAN !! RVBOY SAY'S TOYOTA RULES !!!
When I asked a buddy of mine's father who works at a Lexus dealership as a mechanicI should go with a Ford 150 or a Tundra he said no matter what the Tundra is the truck to go with. It's not a tow beast though.
When we trade my wife's
Ford Explorer in down the road I hope they have a heavy duty version of the Tundra with a bigger engine. For now I'm glad I own the Tundra I have.
About 2 months ago, at 80,000 miles I noticed the hard shift into 3rd gear seemed to be getting worse. I took the truck to the dealer and they had 2 people drive it and said there was nothing wrong. It has continued to be increasingly pronounced and today I noticed a vibration when accelerating. I was 20 miles from home when I lost forward momentum (sorry my girl interpretation) and I ended up calling for a tow. Don't know what the problem is yet...but seems to be the transmission.
Aside from these two issues...it has run perfectly for 90,000 miles. I think the dealers could be more helpful, though, with the problems they obviously are aware of.
