BMW 7-Series Maintenance and Repair
11112141617
    well it's a trade-off. No Lexus equivalent model so far drives anything like a BMW 7 Series. Not even close.
    zenithfaczenithfac Member Posts: 4
    Hi, im new to this forum and I'm very close to buying a 98 740i with 105,632 miles. however, how does this car handle in the snow, bcoz i plan on moving to Minnesota after this summer...Thanks.
    Should be fine with 4 snow tires and a good snow driver---the driver is at least 50% of the equation of what we call "good in snow".
    Of course, you aren't going through snow drifts like a jacked-up 4X4, so be realistic as to what you attempt.
    eric312eric312 Member Posts: 71
    I used to have 2001 740 with sports rims/tires. In NY snow the car was very difficult to drive. Not sure how it would have been with snow tires.
    Also, with 100k+ miles i would be VERY careful. Repairs on this car are very expensive.
    Well sport rims and tires would be the worst possible combo for snow, so I'm not surprised you had difficulty. I applaud your ability to get around at all on a setup like that.
    With 4 snows, this big heavy car should be okay, but ground clearance could be a problem.
    As for repair and maintenance, I presume the buyer already knows about that and is ready to deal with it.
    Like i said b4 I want to get one of these cars. I have test driven the 98 740i with 105,632 miles. everything works perfectly, although the engine sounds like that of a motorcycle from the outside, bt like a V8 from the inside.
    The 00 740il has 60,362 miles, bt needs engine work (oil pump is spoilt). Which do u think i should go for, mind you the 98 has a flood record.
    The engine overhaul will cost you more than the entire car is worth, so forget that one. Free wouldn't be cheap enough, sorry. :cry:
    I think you should pass on both cars given what you've presented to us. My two cents.
    bobmc4bobmc4 Member Posts: 2
    Just looked at a 92 w/157k. Warning message Tacho. No service records. Body and interior in good shape. Owner says there was a small fluid leak in the interior of driver side.(his freing "bypassed" the leak. He wants $2500. What do you think?
    Okay so it's got a leaking heater core. This is a 735 right?
    So that's about $175 for the heater core.
    Labor to R&R is 8.0 hours
    Labor to evacuate and replace AC freon --- not sure about this.
    Anyway, total cost where I live would be about $1350.
    This presumes that the AC system is okay....or you can just skip fixing the AC part and just do the heater core for maybe $1200.
    We assume you want the car to have at least heat/defrost?
    Your call on that. My impression is that you can buy a very nice clean 735i with no major problems for about $3000--$3500.
    If I were buying it, to cover my butt, I'd offer $1500 tops.
    sysadb420sysadb420 Member Posts: 12
    Update on trying to epoxy the radiator neck: It's a no-go. I loosened the overflow cap to relieve pressure, let it sit a couple days after 2 applications so it could cure, and after one dry day I saw a coolant drop on the second day - before starting it or resuming pressure in the system. I then drove it about 20 miles and it seems to be retarding the leak, but it's still leaking.
    I'd say a new radiator is in my future.
    Well that's a tough spot to epoxy because you get FLEX in there. When I did the heater core inlet pipe with J&B weld, it worked great because nothing is moving.
    This is why they crack in the first place.
    To make it worse the leak appears to be on the inside of the elbow bend which is hardest to reach/ treat. I used a tiny artist's brush to apply the epoxy. As for flex it seems it would flex to whatever degree the radiator does, since it is integral.
    Oddly, the leak has now stopped, but I'm expecting that's just temporary relief.
    jimijakkkjimijakkk Member Posts: 2
    hi everyone,
    i'm new here and hope to get some advice. i need to have the a/c blower motor and relay replaced in my 1996 740IL. i purchased oem replacement parts. i live in boynton beach florida (palm beach county) and haven't found anyone willing to do the work.
    anyone know a mechanic who is capable in my area? also what should it cost? thank you for any suggestions.
    jim
    speedy99speedy99 Member Posts: 2
    Does anyone know an experienced and knowledgeable auto shop in the San Francisco Bay Area to work on a 8 series BMW? I have been having a hard time to find someone who is familiar with the 8 series and is willing to work on the car.
    Truly appreciate any comments or suggestions in advance.
    Speedy99
    BILL ARNOLD in San Rafael might be a good bet:
    Bill Arnold BMW Repair
    Thank you! Just read some nice reviews on yelp regarding Bill Arnold BMW. Will give a try.
    Many thanks again.
    dougmcdougmc Member Posts: 4
    I bought this car on ebay, for $4700. It has 178000 miles, but has been very well maintained. No body damage, paint excellent, interior very good to excellent. I had the pcv valve gaskets replaced, all fluids changed including transmission and it still idles very rough when first started and surges, but not bad after it warms up. It runs better on 91 grade gasoline. Is that the answer? The highest grade gas available? Other than that, I am very happy with it. But the interior smells like old leather that hasn't breathed much. Thanks, in advance.
    Might be a small vacuum leak somewhere in the intake manifold that seals up once warm. Or a leaky injector which fouls the plugs as the car sits. Is your oil level higher than usual by any chance? (suggesting fuel contamination).
    Also you could have a faulty idle air control valve. Surging might be caused by that. You can scan the car's computer for trouble codes to indicate this possibility.
    Just throwing out blind thoughts here, without a car in front of me.
    Oh yeah, you should use 91 octane, but I don't think this would cause a rough idle that clears up.
    Thank you for your interest. I installed a new air intake sensor that the previous owner had given me, and that cleared it all up just about 99%. Surge is gone as is the rough idle. Now it just occasionally dies at idle. I will run 91 octane from now on, too. Thanks very much.
    Hmmm....don't know what that is. You mean a Mass Air Flow Sensor? There are two of them. I wonder if you had a vacuum leak after all....oh well, no matter. If it's fixed, it's fixed!
    wishmeluckwishmeluck Member Posts: 6
    I am not able to find in my owners manual how to reset my service indicator after I do an oil change. Does a cert. tech. have to reset it? Thanks. Mr. Luck
    Tell us the year and model and we'll try to find that out for you.
    i have a 1996 740IL. the reset mechanism is part of the dash settings, like setting the time or date. i forget the exact sequence but, if you search until you see "days left oil change" (or words to that effect) that where you reset the days. i reset to 100 days. hope this helps.
    My car in question is a '94 740i and it has 198K on it. They'll be more ?'s on this 'interesting' car. Like this '?' What syn. oil do you like, or what syn. oil should I avoid? Mr. Luck
    You're going to need a service reset tool I'm afraid.
    Here's one I found on eBay:
    RESET TOOL
    As for synthetic oil, I use Mobil 1 and I think that's fine for your application.
    Thanks for the link. Soooo, every 8,000 miles I'll be able to use this 25 dollar device! And I'll bet that is peanuts compared to what the up-coming problems are.
    Mr. Luck
    Well cross your fingers. The car must have had decent care or it would never have reached that mileage! As for the reset tool, that pays for itself first time you use it.
    Why do you think my interior light won't come on when the door opens. The three position switch by the ceiling light seems to work. I've got 'always on', 'always off' and then nothing while opening and closing the doors. ('94 740i) Mr. Luck
    Probably a funky door jamb button--bad ground, pulled wire, something like that.
    patpat Member Posts: 10,421
    Join Consumer Advice Editor, Phil Reed, and other Edmunds staff for an auto industry chat TONIGHT, Wednesday, 9:00 -10:00 pm/et (6:00 -7:00 pm/pt). To enter the chat, click on the banner at the top of the page.
    See you there!
    shybirdshybird Member Posts: 1
    (1999 740i, 103,000 miles)
    First query: A very faint alarm sound (hardly noticeable, moreso when the radio is on) is barely audible when the ignition key is turned on. I'm clueless, any guess on where this is coming from?
    Second query: By changing the O2 sensor at 100,000, is there a real, significant improvement in fuel consumption/performance? Car passed recent smog test.
    pfreak76pfreak76 Member Posts: 17
    Guys - I am looking at a 2006 750Li CPO with 26K miles. The CPO expires 2yrs after the OEM warranty by EO 2011. Now there is another car dealer out in CA (the one with 26K miles is instate) selling a 2007 750Li with about 30K miles. Price delte is about $1.4K (2007 more than 2006 ofcourse). Featurewise they seem to be fairly similar. But 2006 has a financing incentive versus 2007, which will run regular used car financing rates.
    Question is - which one is a better buy? I know this is a personal preference but the instate car warranty expires EO 2011 and the one on the car in CA expires March 2013. Is it worth pursuing the out of state car? The out of state car will run about 3-4K more - considering more taxes and higher interest rate (2006 CPO is at 3.9%)..
    Looking for some recommendations here. I have seen a lot of mixed messages on 750Li long term reliability. Any pointers?
    Is there such a thing as BMW warranty beyong 6yrs 100,000?
    Shoot, you could run up a $4000 bill on a 750iL with a snap of your fingers. Presuming the CA dealer is reputable and that you can view the car personally, I''d go with the car with the longer warranty. You never EVER want to be in a 750iL without warranty coverage of some sort. By 2013, you may want to buy another one anyway, so you'll be transitioning from one warranty to another....or, if the 750 you bought turned out to be a very well-behaved example, you can keep it after 2013 with some confidence.
    Thank you for the response:
    So the warranty should be the first criteria then?
    The CA cars have comparable mileage - ~30K. I do plan to keep this car long and usage is going to be limited to about 600-800 miles a month. The 2006 with 27K miles (whose warranty expires end of 2011) is driven about the same miles - ~9k/year.
    The 2007 used car financing rates are at about 6.79%. Its almost as if they're charging you for stuff that will break, in advance. In comparison the 2006 is at a 3.9%.
    Is there no warranty after the CPO expires? Or am I just too hopeful?
    I guess the real question is that should we expect a lot of issues for the 1 year coverage that the 2007 car provides. Because once that one year is elapsed, that car is going to cost a bunch of $$ too..right?
    The cars as they are listed:
    The 2006: (Negotiated down to 43.5 @ 3.9% APR)
    http://www.bmwnorthscottsdale.com/detail-2006-bmw-7_series-750li-4195607.html
    The 2007: (Not negotiated yet - but listed at 44.9K @ maybe a 6.5% APR)
    http://www.sterlingbmw.com/certified-inventory/vehicle-details.htm?vehicleId=1a8- 8bae04046381e0059c8b52f6d8b92&useHistory=true
    Based on what you said about the 2007 having a CPO warranty good to 2013, and given the prices of the two cars, the 2007 seems like a better deal all around. I think the 2006 is overpriced by at least another $5000.
    You can bargain hard on a 7 series right now.
    Okay - I am going to checkout the 2007 I mentioned above. Thanks for all the tips so far.
    BTW - is the 750Li really as bad as some people refer to? I see sharply contrasting responses from people. It seems like some peope have had no issues, while others see frequent transmission/engine problems. I wonder why this car would have so many more issues compared to a high end 5-series with the same engine? I know electrical complexity is higher due to iDrive and in general rule of thumb is that the more complex system you develop poorer the reliability expected, since you now have more parts that could potentially fail.
    I know that the 2002 745's had major issues - a friend told me that he owned it and had issues. But I also hear BMW fixed these in upcoming models.
    Since you're the expert, it would be great to hear your perspective.
    I hate to blanket a car with a bad reputation, because things change year to year.
    What I can say with assurance is that earlier 750s have been problem-ridden and sometimes make it to the "worst used cars" lists. Part of this came from the V-12 engine, which now of course is a 760 option, not a 750 option.
    How much of all the earlier issues BMW has squared away by 2007, I have no idea. The reliability ratings for the newer cars seem quite improved--but there are still issues.
    People "love" them because they are GREAT cars to drive, not necessarily because they are dead-reliable or cheap to own. Also depreciation rates are higher than normal.
    My 1998 BMW 740il has 198k miles on it, and will stall intermittently. You never know when it will happen. Could be when I start it,and it acts like it's flooded, could happen at a stop light or when I'm driving it. When I restart it, I have to rev it up. But never dies totally when it is being driven. The mechanic thought it needed a new crankshaft sensor, but that hasn't helped. Otherwise, it runs great. I would appreciate any ideas. Thanks in advance.
    Would you know how much a maintainence plan would run to cover the BMW 750Li, past the 4yrs/50K miles? I talked to a dealer and he was offering it for 3K and I thought that sounded excessive.
    I have heard different numbers... When is it best to buy the maintainence plan? The car I am looking at has 18K miles left on it and about 20months of the original warranty, after which the extended warranty kicks in (valid through 2013).
    Maintenance plans are a profit item for the dealers so some may mark them up more than others. if you have more than one dealer, shop around. The problem with maintenance plans is that they are sometimes hard to compare, as they include and exclude different items. You have to read them over very carefully. Also deductibles will vary as well, and rules for deductibles also vary.But by all means, get something.
    ok. so the maintenance plans are different than extended warranty - right? The car comes with a certified pre-owned warranty valid until 2013. The maintenance expires at 50K miles or mid-2011.
    I'll send out requests to multiple dealers. Is it advisable to buy this as soon as possible or should I wait until I get closer to expiration?
    Can you post what they are giving you and how much it costs? It's kind of hard for me to know what the maintenance plan involves. If it has a lot of "packing" in it, I might say no. I'm really not familiar with this plan so I hesitate to influence you too much.
    so you have a CPO warranty until 2013, right? (GOOD!) And I presume you'll keep the car until then....so we need to figure out (seems to me) the cost of about 4 years of maintenance with NO plan at an independent BMW shop vs. 4 years of maintenance at dealership prices.
    Much as I hate to say it, you may find that not a lot of independent BMW shops are not that comfortable with a 7 series car.
    Hi -
    I have asked for the breakup of the maintainence plan - its called "BMW Ultimate or Elite". Now I do have this maintainence plan until mid-2011 since the original warranty does not expire until then (this is a 2007 750Li). The pre-owned warranty kicks in after 2011 but the maintainence plan expires mid-2011 and will need to be bought for the period 2011 to 2013 (2013 is when the pre-owned warranty expires). Depending on how this car works out I plan to keep it - but first pass want to see how it runs through atleast the warranty period.
    Now this car also happens to be a demo car - and the basic warranty is available until 55K miles (it has 33K miles on it right now). But maintainence still expires at 50K.
    This is one of the two cars that this dealer had on their lot for 113 days and they lowered the prices down almost 10K to clear out their inventory. So I think I have a pretty decent deal and would hence not mind paying a little bit more for the maintainence plan from BMW. I do hear that third party options are pretty unreliable.
    Well what if we do this---let's estimate that to maintain a 750, not REPAIR it necessarily, but maintain it...might cost $150 a month. How does that square up with the cost of the extended maintenance plan?
    I am still hoping someone will help me with this 1998 BMW 740il and it's stalling problem, as originally described above. Thanks.
    airmailmillerairmailmiller Member Posts: 4
    found a 98 740i with 126,000 miles, everything works, new trans, excellent condition body wise, idles rough, shakes going down the road, guy will take 3000.00 for it, is :) it a good deal, will need a battery :)
    ">Yea - you asked the right question.
    Now what the guy offered to be was $2999 for a 2 year maintaince plan post the 50K maintainence expiration. That covers me through 2013. Now I hear that the brakes, rotors, oil change and windshield wipers cost a fortune for the 750. They should easily exceed 2999 if they break - which I am guessing they will.
    So its a no brainer. But I also hear that you can shop around for the best price. To answer your question on the specifics - the maintainece plan through BMW has no deductibles.
    I have plenty of time to buy and negotiate this maintainence plan. The car is working out great btw and I believe this one was a pretty good buy - thanks to this one and another one of these being on the market for like 100 days plus, the dealer shot down the price about 8K below the first advertised price. I believe a 44K price for a 2007 750Li with pre-owned warranty until 2013 - is a pretty decent deal.
    polljimmypolljimmy Member Posts: 6
    In many cases its possible to unlock the engine in 740 trunk.When you try more and more you are specially go through the manually trunk.
