fuel system problem
Iam a owner of a 1988 chevrolet camero. It is equipted with a v-8 305cu in motor with throttle body fuel injection. The engine will only start and stay running with the aid of starting fluid. I check the electric fuel pump with a pressure gauage and the reading was 13-14 psi. I also allowed the fuel to pump into a glass jar to inspect the volume and quality of gas both appear to be sufficiant. What should I try next. Thanks
Not to mention it will also turn your engine into a hand grenade if over used.
