Buick Century Maintenance and Repair
17810121319
  • pops86pops86 Posts: 4
    I certainly have no problem with changing oil as often as anyone likes, but in my opinion 3000 miles for my vehicles is a little too soon. The oils and filters are so much better than they were back in the 60's and 70's. I change the oil in my vehicles as recommended by the maker, anywhere from 5000 to 7500 miles, changing the filter with the best filter, any of the major oil brands, and have gotten well over 200,000 miles per vehicle. As mentioned by others, keep oil/filter changed, especially in dusty/sandy conditions, change the AIR FILTER regularly, do not allow the vehicle to run low on coolant, and these engines these days will last many years.
  • I have the same problem for my Buick 99. Have you got the answer?
    Boris
  • fmroczkafmroczka Posts: 5
    Can anyone help me with my wife,s 2001 Buick Century. I have checked the coolant both in the radiator and the overflow container, and both are at proper levels. I.m thinking this could be a sensor, and if so where is it located and is it easily replaced? Any help would be appreciated. Thank You
  • If Diesel engine, do not do this, or check approval for use if new diesel engine. May not be approved for rotary or diesel engines. Check owner manual first. Check it out first!
    I just want to say that we switched to all synthetic oil, and cannot believe the difference in the mileage and overall performance of our car (1996 Century.) I believe this applies to all vehicles, except diesels and rotary engine. You can buy it by the 5 qt. container. Do not be fooled by the difference in price. In my opinion, you will save in the long-run. The engine runs much cooler thru the summer, even when sitting idle in 95 degree weather, without "asphaltizing the oil". This is true in cold weather as well. Engine will last longer and endure more. Lubricity is awesome, and oil changes are fewer. My husband first learned about it in industry on heavy equipment and we finally tried it on our own car. We will never go back to petroleum based oil. Oil changes last longer but they are so important. Ideally, you do not want to see the oil light, or the come on. Also, before trips and with oil changes, we are adding the fuel injector/carburetor cleaner. Mileage has improved 25% since we bought our vehicle, and that is after 165k miles. Running better than ever! The synthetic is compatible with the petroleum based, so you can add to engine either way. A good rule of thumb is to change your oil every 3k miles, but you can last longer with the synthetic between changes. With the price of gas, you need to consider changing. Nothing you read about it is gimmicky! Had we not changed, we could not have made the trips trips that we have made in the last few years. Please read about it first and use your own judgement.
  • You could have thermostat failure. Generally a simple, low cost fix.
  • Thanks for your feedback. I want to know the locations for this thermostat and if I can fix it myself.
  • rockyfanrockyfan Posts: 1
    Good morning, I have a 2001 Century, just purchased from family member two weeks ago, it has since been driven over 3,000 miles, I got stuck in traffic and noticed the temp gauge riding up a bit, not past the middle but up enough to cause me concern,, I simply lowered the windows and put the heat on full blast till traffic eased. When stopped for the night I noticed the coolant overflow was at a proper level but the coolant looked kinda thick, I removed the radiator cap and it had grey goo in the throat.. I checked the oil and the level was good, and there was no sign of water/coolant... I purchased radiator flush and I am going to clean out the system,, but I can't find the drains, should I just remove the radiator hose (lower) and deal with it? Suggestions?? Thanks In Advance...
  • redbird48redbird48 Posts: 17
    ROCKYFAN.....GO TO MESSAGE #98 AND #99. THIS SAME THING HAPPENED TO ME AND AFTER THE FLUSH AND ABOUT 20,000 MILES LATER I HAVE NO OIL IN THE RADIATOR. I CARRIED MY CAR TO A QUICK LUBE AND HAD THEM TO DRAIN ENOUGH COOLANT OUT TO PUT THE BOTTLE OF CASCADE IN THEN BLED THE AIR OUT OF THE SYSTEM WITH THE BLEED VALVE. AFTER I DROVE IT FOR A FEW DAYS I DRAINED IT AGAIN AND FILLED IT BACK UP WITH DEXCOOL. HOPE THIS HELPS. ABOUT THE DRAIN PLUG NOW I COULD FEEL IT , BUT COULD NOT SEE IT UNLESS THE CAR IS ON A LIFT. THAT'S WHY I CARRIED IT TO A QUICK LUBE.
  • elprezelprez Posts: 2
    hi y'all, i have a 1990 pontiac safari wagon w/a 3.1 6cyl engine - same as the buick century...135kmi...recently it began to hesitate and buck when backing off the accelerator at highway speed...i had "woody" tuned up and the gas filter changed, but the problem persists and has gotten more dramatic...he has begun to idle roughly...would a 1990 have a engine diagnosis hookup...? if so would it be best to have a dealer track the problem... ? the wagon is in puerto rico and i am going to visit it soon and would love to eliminate this problem...
    thanks for any advice,
    steve clark
  • I'm having a problem with my blinkers. They come on, but stay solid, no blinking. Before they stopped blinking completely, they began getting really slow about a month before they died. I'd say, 1 blink for every 10 blinks normally. Anyway, I was just wondering what the problem may be. Is it possibly the bulbs? or does this sound more like an electrical problem?
    Any help is most appreciated, since I have to get my car in order to pass inspection :)
  • doggaldoggal Posts: 17
    Hi:
    Same car, same year.Had the same problem last year (first slow blinking, then no blinking), but only one side. Took it to Pep boys and all they did was replace the bulb and it worked fine after that. Hope this helps.
  • Ok so I have a 96 Buick Century. None of the light are working! Well the blinkers are but thats IT! No head lights, tail lights, brake lights, interior lights? Nope not those either! I've got NOTHING! I have tried resetting the computer, replacing the head light switch, andchecked all wires. Nothing has fixed it. Has anybody else had this problem? What would fix it? PLEASE HELP!
    THANK YOU!!! :confuse: :sick:
  • ripsrips Posts: 3
    The heater/air conditioning fan squeals like crazy so she can't even use it. The dealership claims they would have to tear the dash apart to fix it and it will cost hundreds of dollars which she does not have. Does anyone have any other ideas on how to repair this?
    Rips
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 51,065
    Sounds like a bad or "dry" bearing in the "cage fan" that forces air around. If you can somehow at least reveal the cage, you might be able to lubricate the shaft that the fan spins around; otherwise you'll have to excavate like the dealer says. You or someone needs to crawl under there with a flashlight, and maybe you'll be lucky enough to be able to wiggle a can of lubricant with a long "straw" attached, and soak that shaft.
    Even if you do manage to lubricate it, it might need to be done periodically. Sometimes you can remove or unsnap various panels to get a better shot at that heater cage.
    MODERATOR --Need help with anything? Click on my name!
  • I had a similar problem with wipers frozen to the windshield...
    Did you figure out your problem?
    I thought the guts of the wiper/turn signal lever shorted but that was not the problem. Now I am wondering if it is the switch in the steering column or the wiper motor or somewhere in between...
    Any advice would be much appreciated!!!
  • joejbjoejb Posts: 4
    I have This Exact problem on my 2000 Century. All dash lights are OK except the odometer/gear select indicator
    is invisible. I tried to follow the discussion thread
    and see no help. Please, has anyone had this problem and
    knows the fix?
  • ginahillginahill Posts: 1
    I have a 2001 Century that does the same thing. Were you able to have the problem corrected? Thanks.
  • kneeachekneeache Posts: 5
    I had exactly the same issue. To access the fan on the Century, remove the underdash panel on the passenger side of the dash. You can then see the fan motor, and it is held in by 3 bolts (10mm, I think). Then the whole thing drops down into the passenger compartment floor. I lubed the fan bearings, and cleaned everything up, and it helped, but then replaced the whole thing with a motor/fan
    assembly from Ebay for 20 bucks. Been working fine ever since. I kept the old one in case the new one dies.
  • rangerironrangeriron Posts: 1
    My passenger side front signal keeps working then not working. It will work one day for a while then stop working. Then another day it will not be working then all of the sudden it will work again. I checked the fuse and its not that. Anyone know where i can check the connection or have any other ideas.
  • johnnyspotjohnnyspot Posts: 3
    Replace the bulb... It may be going bad. Hopefully that's all it is.
    HELP! Started my daughter's 95 Century last February only to discover that she had left the wipers on and that they had frozen to the windshield.
    There was a tiny puff of smoke that came from the turn signal lever (multi-function switch). I have replaced the lever and everything works except the wipers. Checked the fuse in the fuse box and it is good.
    Then I removed the wiper motor to make sure that the linkage wasn't stuck and tested for power to the motor. It doesn't seem to be getting any power. Had to remove the motot to get at the harness plug on the bottom. Does the motor need to be mounted to test for power? Is there another fuse in this circuit?
    Can someone give me a suggestion on where to look next? Could the problem be in the switch inside the steering column? I am ready to throw the towel in and take it to a pro!
    Any thoughts will be greatly appreciated.
    JOhn
  • gsharp1gsharp1 Posts: 1
    I have a 98 Century that has a strange problem. When I turn the ignition to start the car, the drivers' window will automatically go down! This happens every time, and when I try to close it, it just inches up a little at a time. I'm gettin' wet here!
    Help!
  • I had the same problem couple of weeks ago. I found www.autopartsway.com, called them and they gave me a great advise. I got the lubricant from them and it works great. You should try them. Try them for your auto parts
  • dhanndhann Posts: 1
    Did any one every find out what the problem was with century's digital odometer when everything works but the gear shift and odometer light?? dhann
  • gmabcdgmabcd Posts: 2
    I have a 98 buick century and the power windows are no longer operational. I checked the fuse, but it is still intact. Any ideas what could be keeping them from working and what steps I can take to repair?
    My bad. I meant power MIRRORS! Please help!?!?
  • edbeardedbeard Posts: 2
    I have a 2000 Buick Century, 100,000 miles, 3.1 liter engine. The service engine lite is on. I took it to Advanced Auto Parts to get the codes read. They said that the EGR Valve has insufficient flow. I replaced the EGR Valve and per their advice tried to clean out the pipe from the EGR Valve to the exhaust manifold with brake cleaner. But the service engine lite is still on, and their code reader still hits for the EGR Valve having insufficient flow. Any suggestions would be appreciated. The code on their print out is P0401 EGR Flow Insufficient.
    2000 Buick Century, 100,000 miles, 3.1 liter engine. Took the car to Advanced Auto Parts to get the codes read because the service engine lite is on. It hit for Torque Converter CKT Performance or Stuck Off, code P0741. On their suggestion I changed the automatic transmission fluid and filter. I had the battery disconnect while changing the fluid and filter. The service engine lite is still on, and their code reader still reads the same. Any help would be appreciated.
  • It's a fair price and if you are in a city where highway driving is a must then it's a good buy. The KBB seems high though because I bought my custom 00Century in 2005 for $4,500 and KBB was about the same. This was under good condition...did you put excellent? Yours has more features and the miles for a 6 1/2 year old car is relatively low.
    It's a great car but have him install a new windshield....NEW...not wrecking yard for the same price.
    00Centuries have trannie possible problems and there are 3 or 4 recalls, seat belts and more small things but one is rear drum/bolts...can't remember but go to gov't recalls on cars online. You can always have the recalls done when and if you buy the car. How many owners have there been?
    Let me know what you decided.
    Phoenixbarb
  • Yes. I have this problem been fixed. I changed the highlamp switch which is the one to control the light from min. to max. and is located on the driver side and beside the odometer. In my case, the digital odometer background light and the shift lights were not working.
Buick Century Maintenance and Repair - Page 10 - Car Forums at Edmunds.com
