Engine Surge When Braking--I have a 2006 Lincoln Towncar...
The answer also includes mention of disconnecting the booster for troubleshooting. He's right, but it's VERY hard to brake without the booster, so be forewarned.
The same fellow who got paid for that, also offered the suggestion to disable the brake booster. That could help eliminate it as the culprit, but it's very hard to brake without the booster.
The diagnostic test I just did confirmed the actuator is bad. It's already gone to "all cold air" after giving me the clicking and tapping as it tried to close/open these past few days. Otherwise it's time to dig up about $800 or so and get her to the dealership. My fear is that will all the bolts and screws that are involved I'll end up with a good actuator and multiple rattles & squeaks that have nothing to do with the original problem. Thanks for any input!
I read there was a recall for "Fleet" versions of the Town Car L editions - but not for the ones sold in dealerships. Kinda silly - considering they are essentially built the same. I filed a complaint from Ford.
The next day, I put a new positive cable connector on the 2-3 yr old battery b/c the old one was corroded. After doing that, it started up fine and I had no problems starting until yesterday. Let me explain, I don't drive much. Usually short trips, one or two stops about 6 miles total but yesterday I made several stops for a longer trip. On the next to the last stop it barely cranked but started then stupid me made another stop and then it wouldn't do anything when I tried to restart it.
After waiting about 20 min. and trying several times with no crank, it started but not with a regular sounding crank. I got home. Tried to restart and nothing. Fast forward to this morning.
Started right up like nothing wrong. Drove 3 miles to store, after 20 min. started like nothing wrong. Drove 3 miles home. Turned off ignition. Immediately tried to restart. Started but didn't sound 100%. Shut down and tried to restart. Started to crank for a second then stopped cranking. Tried to restart - Nothing.
It seems when the engine is cold - there's no problem starting. I bought the car in 2004 with 93000 mi and it now has 160. I haven't replaced any electrical except for the battery. Sorry for the length but, this way you know what I know. Anyone have any ideas?
Maybe you think its funny lol. I can think of alot more ways to have fun.lol
http://www.928oc.org/tip/tip567.htm
Here's an article referring to starter problems. I'm sure I'll find the problem. Once I know the problem I won't get ripped off if I have to have someone do the labor.
Thanks everyone. Honk if I see you.
http://www.2carpros.com/first_things/car_will_not_crank.htm
No dim? Starter not getting current. Check battery connections. Then check connection at the starter solenoid. This is the small wire connection. Take off and clean and replace. This was my problem. This requires getting under the vehicle which has to elevated. Be careful. Get it on ramps or better a rack. Don't get under with just the jack. If you can test for voltage at this connection and it is present when trying to start and it doesn't crank after cleaning the connection with current present replace starter/solenoid.
If there is no current present at the solenoid when trying to crank you have backtrack the wiring and check ignition switch, neutral safety switch, relay (never did find it- maybe inside) ugh!
http://www.lincolnsonline.com/tech/00260.html
2000 Town Car: Does anyone have a remedy for random turn signal clicking?
2000 Town Car: Does anyone have a remedy for a heat/ac blower motor that won't turn on?
2000 Town Car: I had water collecting in the passenger side footwell as well. Water was leaking through the fresh air intake gasket just underneath the windshield on the passenger side. I fixed this with a homemade rubber gasket and silicone caulk.
Bad solder was the source of the resistor failure on my TC as well. Airtex should improve the product! The driver's window switch module (Airtex) failed on my car last year too!
charlie
