Congratulations lagerman. That was a great comparison to your GMC.
I am lucky enough to be a driver this weekend, but I won't be an owner until late this year, so I am not yet a waiter either.
Got to test one out last weekend on a prove it course. It was towing 10,500 pounds of trailer plus barbell weights. Handled like a dream on the course lots of torque at a wide range of RPM. Didn't go highway driving with it, but I have heard enough accounts to know it would do well.
Owners:
1. doggboys
2. dmorrell
3. usvet92
4. finallyat150
5. a47chuck
6. bugchucker
7. conwaychevy
8. wileetundra
9. cbuellgo
10. lagerman72
11. ackboater
Waiters:
1. joe140
2. abrascal'08
3. ltdan2
4. crazycanuck4
5. bigken
Snuffy
A very fine truck. Why would anyone even consider any other brand? I am very glad I finally stepped out of the Chevy box.
My first half of tank of gas was all city driving and I got 15 mpg. Gotta admit though, I was "testin" her out here and there, so that ate some petro. Plus, I bedded in my brake which I am sure uses lots of gas with all the stopping and going involved with that process.
What I don't like about the truck (but will enjoy living with)?
1) SR5 does not have daytime running lights. That is not a problem, but if I turn my parking lights on during the day time, the readout on the dash (time, outside temp, mpg, etc.) gets pretty dim and difficult to read.
2) Don't like the emergency brake setup. You have to "push" to set AND "push" to release. Seems odd to me. The dang thing should just releas when you put the truck in drive. I'll get used to it though.
Other than that, this is a fine vehicle that is sure to become extremely popular.
I tell you one thing for sure, the 5.7 is very very strong, period. And the 6 speed tranny is smooth as a bone.
uh....did I mention that this is one bad [non-permissible content removed] truck, lol.
I would think it is wheel bearings, but I get no shake from the disc with the tire off. I am at a loss. I took it back to the mechanic in S.C. who did the work, and he told me he found out that the front tires should be lower in pressure than the stated pressure from the tire manufacturer. He was giving me the slip because he knew I was leaving to head back to Canada. Told me that it would 'wear out' after a couple hundred miles. I knew better, but didn't have time for an exhibition.
Anyhow, I know this isn't really the purpose of this thread, but I can't really find a thread dedicated to it. I will start a new one, but I hoped maybe you would know something.
After making all the corrections, I had two off-road tanks in Moab: one was 13.7, the other 17. Highway cruising was a bit disappointing, as 70 mph only yielded just over 16mpg. The stock tires would have been closer to 17.
Besides upgrading the tires, I installed the RevTek spacer lift. I haven't crawled underneath to measure it yet, but I suspect the ground clearance is around 13." Overall performance in Moab was great, but I didn't think there was enough ground clearance to try Potato Salad Hill without risking damaging the bottom.
Power for passing at 70mph is truly amazing. 5.7 engine is a winner.
Agreed! Punch that pedal to the floor at 70 and you will feeeeeeeeeeeeeeeeeeellllllllll the power. I mean, that 5.7 passing gear will kick in and you'll think, "wow, that was powerfull,,,,,then,,,,,,,the horses start comin in, and I mean it is like the motor gets MORE powerfull as the rpm's climb. Incredible feeling for sure. :shades:
Try it, you'll like!
Sure would like to see pictures of your modified rig with this combonation.
One word of caution: with the stock wheels plus the Revtek spacer lift, 305/65-18's will rub the front center air dam when turned to full lock. It's pot-metal and only took a minute to bend the offending edge about 1/4" with a crescent wrench to eliminate the rubbing. I do not know how much interference there would have been without the lift, but I suspect it would have been a little worse.
The lift is defintely the most bang for the buck to increase ride height and ground clearance. The tires were expensive, but the stock tires looked dinky after the lift. Plus, my last truck (05 Frontier) had Rugged Trails from the factory; after three blowouts (two off-road and one on the highway), I dumped them for more durable Yokohamas. The only tire I could find in a 305/65-18 was the BFG A/T, so that's what I have on the Tundra.
FYI I test-fitted a 325/65-18, but it rubbed the upper suspension arm on the front end. Plenty of clearance in the wheel well, but it would take offset rims to clear the suspension. I don't like tires that stick out beyond the sides, so I'll be staying with the stock TRD wheels and 305/65-18's.
Word to the wise, you should never fill a vehicle "to the brim" The evaporative emissions system uses a charcoal canister to absorb the vapors that form off the fuel. When you overfill the tank beyond the point where the pump shuts off you run the high risk of flooding the charcoal canister with strait fuel. Its obviously damaging to the emissions system but it hurts fuel economy as well.
sign in at that forum and you can easily post pics of your tundra right on the thread you are in. very easy, many ways to post a pic there. the tundra owners on that forum would be very glad to have you participate.
there are lots of pics of new tundras on that forum, and many many usefull tips (not that there is anything wrong with this forum). But they are all different. I post on both.
Ordered them via internet Easter Sunday and they were at my door after work on Tuesday.
autoanything.com
that's the second time i've called it autoeverything.
I see I am not the only one who has them from autoanything
they are fast, and husky liners are good. Looks like you could spill a 32 ounce drink in them and none would excape the mat.
they will be great for hunting and getting back to truck with muddy boots. take em out, spray em clean. interior carpet should be new for a long time.
BTW wilee. got my bed sprayed by linex. very nice huh?
It is not necessary to top off your tank to do the manual calcs for MPG. all you need to do is reset you trip odometer when you fill up and run it till you need to fill again, fill it up and on the recipt from the pump it states how many gallons it took to fill. Divide the miles on the trip odo by the gallons you just put in. That will give exact MPG.
Also Put me on the list for waiters. I am supposed to be getting mine sometime in the next week. Its a DC SR5 TRD in bright red with black int. I cant wait...
Has anyone out there had the factory exhaust for a while and then changed to the TRD Dual exhaust? I just want to know if it is worth the money or not.
DrFill
You'll probably get a better deal, and get the to take advantage of the incentives.
DrFill
I picked up my new tundra last week, with double cab, 5.7L. Its all great and seems to be a great improvement over my old '02. However, the truck shakes very bad whenever I drive over 60, on those cement california freeways, (and we have lots of these out here).
The dealer re-balanced the wheels, changes the tire pressure, and its still the same. I am not sure what to do, and I can not afford a "tire replacement" as some one suggested. I would appreciate any feed back on this..
have a great day.
also are the tires and wheels factory? some dealars will add 20 or 22 inch and they are harder to balance correctly
I am visiting CA this weekend with my 07 Tundra DC 5.7 TRD 4x4, so it will be interesting to see how it does. I'll try to make a post here next week to let you know how mine does.
Good luck with yours.
Wow! Lot's of new comers this week. Sorry for dropping off the board for 11 days.
Here is the latest roll call list:
Owners:
1. doggboys
2. dmorrell
3. usvet92
4. finallyat150
5. a47chuck
6. bugchucker
7. conwaychevy
8. wileetundra
9. cbuellgo
10. lagerman72
11. ackboater
12. iqbaldhillon2
13. danielacosta
14. crazycanuck4
15. pdavido
16. edge45
17. ltdan2
Waiters:
1. joe140
2. abrascal'08
3. bigken
4. neff2k
5. xtacoman.
6. thundertruck
Any word from joe140 or abrascal on when your trucks may come in? You all are oldest on the waiting list.
Snuffy
either you have some problem with your truck, or it's the road. I would get the truck checked for sure. can't believe it's the road. But who knows, I have never driven in CA.
good luck
I have my eye on mine, and like I said, no probs yet.
btw, it's me, wildbiologist. see you on the other forum too, lol.
yer own !
got the long bed.
I thought Ya'll were in a drought this year. thank God our 3 year drought got broke.
Bob
