Also, what about the 2008 model... anybody know when it's coming out, and any new features?
Dan
Cheers
and had to use 20ton press with adapter to press off bearing and lock. Seal then slides right off and on. Then
you must press bearing and lock back on. Also need a heavy
slide hammer to remove axle.
FYI tested mpg on straight interstate driving, calculated 23.5 , but I am not real sure since did't fill up at same station as before plus truck was slanting more on original fill up, I am sure that it at least got over 22mpg. I have the 2007 LWB, auto tranny and was driving aprox 70. My average mpg have been around 19 . Very happy with truck, the only thing that really %^#$ me off was a dent left on my fender from evidently a flung open door, :mad:
That's excellent mileage at 23.5! I have an '06 CC 6-Speed and my best has been 22.5 and my average is 21.5, all at moderate highay speeds matching your 70 mph.
I sure miss the manual floor shift a lot and as you know yo can get better mpgs especially in town, but in reality when I had my floor shift in other vehicles I never got a good mpg as I was tempted to put my foot down on the gas when I didn't have to, so to save my money I went ahead and did away with the temptation of having too much fun.
What kind of mileage are you getting in U.S. gallons?
I like to think that if I had designed my particular fob, that it would have recessed buttons. Makes sense to me. Guess I'll never be able to wear tight jeans ever again.
In the end, if that's the only beef...........lucky us.
My biggest complaint on my 2006 XE auto is that pesky thunk when I stop. At first it almost never happened. Now it happens about half the time when I stop. Way back when someone suggested a leaf spring helper as a cure. That sounds like it would have a negative impact on the ride comfort.
I average 21.5 MPG (US Gallons) Highway with the 6-Speed over only 6,000 Miles. I've received several 22.5 MPG tanks and the average is moving up.
I owe so love to take this truck through it's gears.....all six of them.
I honestly did not see much change if any in my mileage with the above modifications. Some say these items helped increase their mileage, but I did not experience that with mine.
I am having my engine covers painted right now so I am debating whether to leave the Volant CAI on or going back to the painted engine covers. I don't hear the Volant making much if any noise like the CAI I had on my Miata.
I have about 75% suburb driving and 25% highway driving. I drive like the little old man that I am and I walk to any of the destinations that are within a mile of my house. I also avoid rush hour traffic since I am retired. I have had to drive down into the middle of the city a couple of times, but I avoid that when it is at all possible.
The LE gets better mileage than the Nismo, but I can't believe there would be that much difference. Of course not resetting the mpg computer each time makes the system more accurate and less subject to wide swings of the pendulum.
OkieScot
But this granny driving is for the birds. Tweet tweet.
http://www.edmunds.com/advice/fueleconomy/articles/116961/article.html
Honda's Breakthrough Heats Up the Race for Clean Diesel Vehicles
By Dave Chameides
Email
Date Posted 09-28-2006
Honda Motors unveiled its latest development in diesel technology on September 25, putting the carmaker well ahead of the pack in the race to bring clean diesel vehicles to market. Its next-generation diesel engine uses a catalytic converter requiring no additives of any kind and will run cleaner through its new design.
Starting in January 2007, all diesel passenger vehicles sold in the United States will be required to meet the same Environmental Protection Agency Tier II Bin 5 emission standards governing all gasoline vehicles. This will require auto manufacturers to significantly reduce the particulate matter (PM) and nitrogen oxide (NOx) that escape their car's tailpipes. While particulate traps will significantly reduce PM, most manufacturers of diesel engines are still struggling with a way to clean up their NOx emissions.
Until now, most car companies have been working on systems that utilize chemical urea. When sprayed into the hot exhaust of the engine, it creates ammonia. The ammonia then reacts with the NOx and converts it to inert nitrogen.
What sets Honda's new technology apart is that its catalytic converter requires no outside chemicals whatsoever. As the exhaust hits the first layer of the unit, a small amount of NOx is converted to ammonia, which is then absorbed by a second layer. The second layer, now ammonia rich, then reacts with the remaining NOx and spits it out as harmless nitrogen.
Honda spokesman Chris Martin points out that what makes the system better is that the ammonia is generated internally rather than being introduced as an added chemical.
"It's maintenance proof," he said, adding that with urea-based systems, a car owner could either fall behind on maintenance or opt to save money by not replacing the chemical. "It might run just as well, but it would be much dirtier."
With Honda's new technology in place, the car does everything for you; nothing extra to add, nothing to check and nothing to maintain. This should save the owner money, and Honda can rest assured that its diesel engines will continue to drive cleanly as long as they are on the road.
Honda designed the converter for use in its 2.2 iCTDi diesel engine, which has garnered widespread attention since its debut in the current model European Accord. The engine, which is remarkably quiet, is also much cleaner than most diesels right out of the gate. Thanks to a redesigned combustion chamber, a reduction in fuel injection time and other efficiency improvements, the engine already emits significantly less NOx. Add on the new technology the converter affords, and clean diesel could be right around the corner.
While European drivers may be seeing this technology sooner than we will, Honda estimates that their diesel vehicles will start hitting our shores in about three years. Couple this with their recent announcement concerning future diesel hybrid vehicles, and it looks as if Honda is pulling to the head of the clean diesel pack.
Thanx in advance, Steve
The 2008 Nissan Frontier continues to offer tough, bold styling that mimics the larger Titan and an available Utility Bed system that features the Utili-track C-channel tie-down system and a factory-applied spray-in bedliner.
Frontier continues to be built on Nissan’s F-Alpha platform and is available with a choice of a 2.5-liter inline 4-cylinder (4x2 only) or an advanced 4.0-liter DOHC V6, which produces 261 horsepower and 281 lb-ft of torque.
The 2008 Frontier is offered in both King Cab and Crew Cab body styles and in 4x2 and 4x4 driveline configurations. Frontier also features long bed models with beds more than 13 inches longer than the standard models.
Enhancements to the 2008 Frontier King Cab and Crew Cab include:
- New SE trim for inline 4-cylinder models (previously only available as XE grade)
- New Technology Package available for NISMO and LE trims
- Utility Bed Package Standard on King Cab NISMO models
- New finish on 16-inch NISMO Alloy Wheels
- Available Bluetooth® Hands-free Phone System
Has anyone purchased the Westin Sure Grip running boards for thier Frontier. I have an 05 Frontier Crew Cab and thinking about installing running boards.
Toyota Motor Corp. will cooperate with truckmaker Isuzu Motors Ltd. to develop and produce small diesel engines for the European market, both sides announced Thursday.
The agreement, which seals talks that began last November, will allow Toyota, Japan's top automaker, to take advantage of Isuzu's highly reputed diesel technology.
Production of the 1.6 liter diesel engines for use in Toyota vehicles sold in Europe will start 2012, the companies said in a statement.
Demand for diesel vehicles is growing especially in Europe because of worries about global warming. Diesel is widely known for good mileage, and recent innovations have made diesel cleaner.
Toyota already produces diesel engines in Europe, but it has tended to focus more on so-called hybrid technology, in which a car switches between a gas engine and an electric motor for fuel efficiency.
The agreement allows Toyota to get help from Isuzu to compete in diesel technology with rivals such as Honda Motor Co., which is strengthening its diesel lineup.
Toyota and Isuzu said the companies were working out details on development, production and supply of the diesel engine, but Isuzu "will play the leading role."
Toyota owns a 5.9 percent stake in Isuzu. Isuzu formed a capital alliance with Toyota in November after dissolving its tie-up with General Motors Corp. in April 2006.
One word: competition.
That makes no sense at all. This is the Nissan Frontier 2005+ topic, not Tacoma vs. Frontier.
Secondly, Nissan has offered diesel engines in the Frontier (Navarra outside of North America) for greater than 25 years as has Toyota offered diesels in it's Tacoma (Hilux) for greater than 25 years. Both the Toyota and the Nissan diesel engines in their trucks are are excellent and as competitive as any diesel engine offered in their class.
Toyota offering a 1.6L diesel in Euro passenger cars changes competition in what way? :sick:
Oh, yeah, you can't buy the 1.6L in the US just like you can't buy any diesel in the US Frontier and Tacoma.
I have an 06 Nismo CC 4WD. About 15,000 miles on it and no issues with paint chips in any area other than in front of the rear wheels on the flare and quarter panel.
Environmentally friendly paint is not as durable as the old enamels.
I used to drive on interstate near one of the largest quarries in the US and no matter the make of the vehicle they ended up with chipped and damaged paint. They needed a paint job after the first year! Thankfully I moved.
Do you drive where there is a lot of road debris?
I'm not going to tell you the paint is not an issue on the Frontier, I just have not had any major issues.
I've read frequent accounts of paint complaints with the Frontier and the Tacoma.
