Nissan Titan Maintenance and Repair
karlconnell
Member Posts: 14
in Nissan
Thought we should get this started to get some communication going about any issues us owners may be having with the new Titan (which we thoroughly enjoy by the way). I have a couple of small issues and wanted to see if anyone else may be experiencing the same problem (we have 1,500 miles on it and counting):
1. Radio seems to fade in and out of stereo in FM mode (this is even with the SSV setting off which controls the volume depending on the level of road noise detected). It almost seems like the reception is directional.
2. I have a slight valve/lifter noise at around 2,500 RPM during acceleration from a stop.
Again, we are very pleased with our new truck but just wanted to see if anyone else has experienced these or any other issues. This is not meant to provide a "I told you so" from other truck owners as every mfr has issues with every model year.
and suddenly the brake pedal went nearly all of the way to the floor.
The brake, NO VDC, and SLIP dash lights all came on, and I nearly crashed into the concrete barrier that I was parking in front of.
It's ok after cycling the ignition key, but it reoccured twice Sunday,
and again this morning while dropping the truck off at the dealership.
(all faliures occured while moving slowly or already stopped)
The dealer hasn't called be back yet with their diagnosis.
2. The second issue with the truck, is that it rolled off of the delivery truck, it was missing the drivers rear splash guard. It was never installed. The dealership ordered it. Three times. And Nissan cancelles the order, saying that "the part isn't available yet"!
The truck was delivered without the part, and the manufacturer says that I can't get the part that I should have had in the first place?
Well, I'm just hoping that the brake problem doesn't need a part,
as Nissan may/may-not offer that part! I've had the truck for a week, and I'm not impressed with the situation so far.
Point is, it can happen to any vehicle/make. Since the Titan is brand new, there will be issues but I would expect that Nissan will solve them all.
Brakes - I was going about 50 yesterday when granny pulled right in front of me going 10. My wife screamed and I hit the brakes hard. The truck stopped so fast that I looked stupid. I stopped way short of granny.. I was impressed.
They should want to fix their mistake. And more importantly, they should have the methods and procedures to fix those mistakes. The dealer doen't seem to have these methods/procedures, as they seem to be getting the run-around. (me too!)
I agree, the brakes (when they work) are great!
Generally, I'm very happy with the truck. I'm just not too impressed with Nissan's early support for the truck.
My only small criticisms of the truck:
Wind buffetting in all windows. You can't just open one window on this truck, as you'll get the annoying pressure/buffeting in the cab. I always have to open two windows, front or rear to avoid the problem.
I've also noticed that my stereo (6 disk unit) changes volume at odd times. I've tried messing with the VSS setting, but it doen't seem to have changed it much.
(a sensor related to master cylinder brake pressure)
And REALLY unfortunately, the part is currently on "national backorder" from Nissan.
(shared part from the Armada)
No eta.
has anyone had issues with the backup sensor? mine doesn't seem to work at all - i'm bring it in to be checked.
couple other questions. I have the King Cab LE - if anyone esle out there has this model - does your center consol have air vents for the rear passengers? mine doesn't.
Second question - it doesn't have an ash tray - where are you susposed to keep your change?
After swapping the suspect sensor, the problem wasn't fixed.
Finally, they swapped out the master cylinder/booster assembly.
Problem fixed. (they eventually suspected a pressure switch that's inside the master cylinder)
I got the truck back on Friday evening.
I wonder how long that it will take for them to get the parts to repair their truck?
I'm back on the road again!
Still no eta on the splashguard though.
Karl
- Adam
Nick
Nick
The nice thing is it's nice to share info & meet more people. One guy turned out to be a teacher at local community college, his name is Michael also, and he rides mountain bikes & has an Xterra. Saw my utility bed pkg & really liked that for his bikes too!
On the flip side, I drove out in the hill country this weekend & got better reception further than I have with any other vehicle!
Karl
Truck - Titan SE KC
Ride - excellent - once the pressure on tires is spec.
Utilitrack - good - not excellent b/c one of the bed tracks seems a little out of line and it is difficult to slide the accessories back and forth.
Stereo - excellent - just shut off the SSV
Snow Handling - excellent
Gas Mileage - poor - I have checked mileage each fill up and have gotten between 11.2 and 15.4, on pure HWY driving I seem to avg. around 14.5 no where near advertised - this bugs me.
Interior noise - poor - my dash squeeks like crazy and the front seat belt shoulder adjuster rattles endlessly. For $32+ thousand Nissan should do a better job. The toyota was nice and quiet.
Acceleration - excellent - when you need it. Refer to gas mileage, I'm am very easy on the gas pedal so not reason for crummy mileage.
Overall I judge the truck - good - and cross my fingers and knock on wood, that it is nice and reliable. I am still debating on getting the extended warranty. I am not sure I trust the electronics I also had my drivers side window get stuck once.
On the gas milage - your right - pretty poor but it is a 5.6 L engin - should we expect more? On the freeway I average about 15 and city driving around 12 to 13.
1. Has anyone taken their trucks in to have small things adjusted and fixed? If so have the dealers been cooperative?
2. I've noticed that the auto on head lights are extreemly sensitive - when I go under an under pass they come on and i've got it set the the most unsensitive setting.
3. The fan is loud when at setting 3 and higher with AC or Heating.
Steve
Five trips to the dealer sounds like a lemon law calling your name. Then you can go buy the F-150 that has even higher sides to throw the bales over. :-) (just kidding about buying the F-150!) You could then buy another Titan with the power adjustable pedals.
How much does your horse trailer weigh?
I would be really concerned with nissan if you over heated your tranny even w/ the big tow package.
Hope the rest of your owner experience is smooth sailing. My experience with Nissan Dealer's has been mostly negative, but it sounds like you got a good one, how have they treated you so far?
If you are going to regularly tow 10,000 lbs, I would suggest you get a weight distributing hitch, an electronic brake controller for your trailer and I've heard of people adding extra leafs to their rear suspension.
On the other hand, it might have overheated if you weren't using the tow/haul mode. I am just surpised that it overheated b/c the big tow package has a tranny and oil cooler.
Carry on and thanks for the Saturday morning chuckle!!
PF Flyer
Anway it is too late for me to be up, I am going to bed, have a pleasant sunday everyone.
On the gas mileage issue, shouldn't it get better after about 10thousand miles, which no one has acheived yet. No big pick-up does very good on mileage.
1) Valve noise @ idle after engine warms up - dealer says normal
2) intermittent squeak - left side of dash near windshield - parts may fit together too tightly (dealer couldn't hear it on service visit)
3) metal on metal rattle in right rear passenger compartment. Source unknown. (dealer couldn't hear it on service visit)
4) Driver's captain chair armrest had bunched up padding - dealer ordered replacement part w/o question.
Only disapointment so far is squeaks and rattles on a $30K+ vehicle. Guess I'll have to crank the stereo. Subwoofer under heated driver's seat provides a bonus massage
One more thing. Anyone know where to get a tonneau cover that fits over the Utilitrack system?
2. Hasn't been warm enough to use my AC :-( so I can't answer that.
3. I installed the Truxedo Lo Profile. It sits on top of the utilitrac system and clamps with clamps that fits inside the tracks. It took me 20 minutes to install and it looks great. If you plan on using the bed extender, you will have to modify the installation instructions at the tailgate end to allow the extender to work. You can't use the front clamps, you will need to use a screw. If you decide to go with this cover, I could give more info.
Enjoy your Titan!!
