http://www.geocities.com/auto_world_blog/
I cant belive how cheap this seat is. Has anyone else had this problem with their drivers seat?
They are ordering another cover of course,but the 'trim manager' said that IF it rips again...they will 'sow it back together...THAT would be stronger than the factory seam'! And that 'it is such a bi--h to get that cover on the seat frame'! His words not mine. I said then why dont you just sow this seam back if that will be stronger? No reply! So far I have told them that the bottom seat cushion has been sinking since 2 months after I bought it..they didnt care. Then it ripped at the seam, now it is ripping again in the exact same place, and they won't sow it...even though THEY say it would be a stronger seam...and won't give me a reason why.I think the seat is defective...from the factory.
I am NOT a 400lb person bouncing up and down on the seat. I have dialed the seat up as high as possible with that dial on the side. And I now have 2 big towels folded and sitting on them to fill in the 'hole' I am sitting in!
Anyone else having such problems with their CAR seat? :confuse:
AND as I have mentioned, the seat cushion has been going soft since 2 months after I bought the car. And have complained about that to GM ever since,thinking that might be why it is ripping on the back cover. They are FINALLY offering to add foam padding to the bottom seat this time.
I give up on this hatch. This time it is the key AND the handle. So..maybe I will get it totally fixed/replaced this time!?
I complained to GM customer service about the 'pit' I have been sitting in for over a year,..and NOW my dealer is finally going to 'make me happy by the time I pick it up,later today'. So...this should be good! Either a joke or nothing gets done I bet. But I will call GM again and tell them if I am in the 'pits' still! :mad:
The driver's seat in my 04 lost a good bit of the shape and support in the bottom cushion after about 80K miles, but no rips.
Still, nothing like an old Plymouth Satellite I had where you could reach straight through the seat to pick up change that had dropped. It looked like the seat in an outhouse.
Well today,I found out a way to open the hatch when its stuck.
I have to hit the hatch above the lever 2-5 times from the Bowtie emblem to above the lever,and it popped open! Then I closed it again and it wouldn't open. So I hit it again, and it opened. I did it a third time and it wouldn't open and sure enough hitting it ,it opened!
I intend on calling GM and telling the dealer what happened, and how I 'fixed it' and MAYBE this time they can replace whatever is behind the lever and next to the gold Bowtie on the hatch.
Does anyone know what parts are behind that plastic piece above the lever? I know if I keep hitting it, I will eventually break the plastic. Out of anger or just from constantly hitting it. So..IF Chevy can't or won't replace what is behind that plastic above the lever, What is in there?
Is there some locking mechanisms,or what?
http://jalopnik.com/cars/frankfurt-auto-show/frankfurt-auto-show-new-european-ch- evrolet-aveo-has-huge-boot-and-overbite-to-match-298460.php
Hopefully a new car will be out shortly and this will simply be some kind of bad one or two year memory.
However, the new Malibu looks a lot better than the pictures, so I'll wait until I see this in person before I launch any further verbal attacks.
BUT the inside I just cant get rid of that film. And now at 17 months, the 'outgases' that cause the fog is done leaking out of the dash. So what do you use to clean it so it isn't all streaked or fogged? I clean it when it is cold,in the shade,first thing in the morning,I have not used newspaper YET,being in the cleaning business, that is an old wives tale. It just makes for more work to dry the glass! I've used every paper towel I can think of. I can't get rid of the fog.
What do you guys/gals use? HELP!!!
The FIX: You need a good,oil cutting liquid cleaner. A cleaner, not a petroleum based solvent. Wipe down with the cleaner and rinse with clean water every piece of interior plastic and vinyl which includes the door panels, console, seats, vinyl headliner, dash...everything plastic and vinyl. Leave the doors and hatch open to dry. More than one cleaning may be necessary.
..and drive like your life depends on it.
The Wheelman
I would not purchase another GM product because of this, their customer service is not good. :confuse:
The WheelMan
PS. Pets love the taste of antifreeze, unfortunately antifreeze will kill your pets.
T W
The WheelMan
Reading, especially the maintenance section, of the Aveo's Owner manual is critical.
If you have questions about maintenance visit your local Chevrolet Service Department, before a problem arises.
The WheelMan
