let me know, thanks!
But I'll hold off because some lady backed into my left front fender this week so I have to get that fixed first.
I had a weird experience recently in which neither my left nor right turn signals would work. Fortunately, it cleared up on its own but I thought I'd investigage a possible cause...like the flasher being loose in its socket.
I've hunted all over the owner's manual, including the fuse block diagrams, and I can't seem to locate it. Or is this another function that has been turned over to the all-knowing, all-powerful computer?
When I first started it, the electronic range calculator said 71 miles. After driving approx 30 minutes, 10 miles in city traffic and two stops for errands, it was up to the low 90s. After 5 more miles of city traffic and 10 miles of highway traffic, it is now showing ~170.
I think that 170 is still low based on it reading 3/4 of a tank. Also I am concerned that it took almost an hour of driving to get it up to that range. Does anyone else's work react this slowly to a fill-up? PLEASE reply back ASAP to let me know if you get
1) an "instant" read of the new mileage, similar to most Chrystler, Cadillac, and other chevy products I've driven
2) a "quick" read of the new milage within 1-2 minutes, similar to most fords that I've driven
3) a "slow and drawn out" read over 45-60 minutes that still doesn't seem right like me..
Also it would be helpful if anyone with a base or LS can share the approx values that you can remember seeing on the display when it reads at F 3/4 1/2 1/4 and E.
THANKS.
If you take the car onto the highway and reset the trip odometer to zero and then drive at highway speeds, the computer will give an almost instantaneous readout of range and fuel consumption. For convenience there are 2 trip odometers so you can leave one to record your overall mileage and 1 to play around with.
I have the base 4cyl. and my highway mileage at 65mph is 38mpg on a level stretch. This will change rapidly depending if I'm going uphill or downhill. On a very slight downhill stretch I've had an indication of over 40mpg.
I can't at this moment recall the values for different gas tank levels.
When I reset the Fuel Range calculator, I get an almost instantaneous reading of MPG. If I'm at a steady 50-60 MPH, it will briefly run up as high as 40 MPG, then settle down to a more realistic number: 30-35 MPG. The longer I drive since resetting it the longer it will take to update, because it is an average of all the driving done since it was last reset.
OTOH, if I reset it when I'm standing still at a stop light, the numbers will be *very* low, but will then usually rebound into the low 20 MPG range. FYI, my average MPG has been about 23 in all-city driving, 31 MPG on long trips and overall around 27 MPG. Not bad at all.
The miles to go feature can take some time before correcting itself after fill up. No exaggeration, but I have sometimes gone over 100 miles before it corrects itself. Once I fill up, depending on what the gas mileage on computer was, it might read anywhere from 270 to 350 miles, but might correct itself up to as much as 500 miles to go when I have driven up to 100. In other words, I have read the miles to go, added to miles driven after a fill up to as high as 630 total. We know the vehicle cannot go that far on a 16 gallon tank. On my MAXX, the furthest I have gone is 473 miles on a tank at which time I added 15.3 gallons for an average of almost 31 mpg. The computer at that time read that I was getting around 34 mpg. You will find that the trip computer always 1.5 to 3 mpg over actual and other's on this board have the same comment.
so you are the king of mileage on your Maxx..how many so far.....Im approaching 14K on mine at 10 months old......last I say you were over 20K on yours....how is it doing?
Some of my other repairs (poorly cast transmission case that leaked, squeaking radiator fan, etc) were not so straightforward!
As a side note, one collision shop had in their lobby a magazine describing how Body shops should change their charging procedures to make more money.
I'm in the wrong line of work.
I also need the tsb for the "establishing the center" problem. the nhtsa website doesn't give the gm bulletin # out.
thanks.
WRT "establishing center" this is part of procedure in service manual when replacing column so I am not aware of any bulletin on it.
Its a resonance, so maybe an engineer would know about long term effects. I had mine repaired because the noise was too much to bear on a new vehicle. 4500 miles on repair and no problems, I have a top grade dealer when it come to major repairs.
i should have the howl tsb done too, i hear that once in a while.
let me know!
you dont hear the clicking sound until the drivers side window is rolled all the way down and if you keep the button pressed down it starts to click.
any idea of what this is, is this normal?
I've always rebalanced the tires every rotation. My local Chevy dealer told me if I go much past 15k not to rotate at all.
BTW on your 4 cyl crank complaint, sometime next week dealer should have document available to them regarding new calibration we have discussed b4 on board. You can tell dealer that YOU were one of the reasons it got written (LOL). I don't have actual number for it yet though, sorry.
It is best to rotate your tires. I was given free rotation on my 1999 Suburban with OEM Firestones. I let Firestone rotate every 5k miles. Never had them re-balanced in 47k miles. They still had plenty of tread when I replaced them at 47k miles. They were badly weather checked from sitting out in the sun for 6 years, or I would have kept them.
Should I have my dealer do this or ask if they did this already? Maybe why my Malibu is off centered and pulls to the left???
"Sounds like they may not have "zeroed" the torque and/or handwheel sensor after replacing the column. It is a procedure they do using their scan tool."
What does "zeroed the torque" mean and/or "handwheel sensor"??
Let me know.
I'm not sure if Edmunds allows links of this sort to be posted, but this info should get you there. You can select TSB there and go through the vehicles.
The TSB relating to vehicle pulling to the left APPEARS to be nhtsa item number 10008849, or GM service bulletin 3000, dated Jan 1, 2004 It is listed under the SUSPENSION catagory (not steering or steering columm). Unfortunately only a brief summary of the TSB is available without paying a fee for it.
Incidently there are 19 TSB catatories on the Maxx, some of which have been discussed here. By comparison, the HONDA accord has only 3 catagories, one of which is transmission.
One transmission comment (it's had all the cals I know of); it works very smoothly when throttle is moved slowly, but not so great if you have to accelerate hard. Mash the accel and:
1) the tranny takes 1-2 seconds to make up its mind, 2) sometimes it overshoots and abruptly shifts with a lurch.
Would be nice if it were more responsive when you really need it (no, I'm not a hot rodder but in LA there are times one needs to manuever fast to get out of trouble).
Wrt steering? Seems to be a lot of variability here. My columm was replaced and I've noted there is definitely road feel but is "filtered" a bit. There doesn't seem to be any wild variations in steering effort when I turn, and on freeways the car tracks extremely well and isn't nervous at all (my Saturn ION by comparison was hair-trigger - small corrections from center were hair triggerish at best.)
