If you are familiar with NHTSA website they did an investigation on this last year and applicable documents are posted. EA04018
http://www.delphi.com/pdf/s/str_esteer.pdf
Dealerships had better jack up their training on these systems because Delphi will be supplying Ford and Mazda plus many cars in Europe with EPS. More manufacturers will be incorporating them soon in their models. The column mount version (second picture) is the one used on the Malibu.
This is not true. You can add another coolant, but it voids the extended life of the DexCool. There is also not a problem mixing in another coolant. Problems arise when the system is not maintained (people a decieved by GM's marketing into thinking its maintenance free for 5yrs/150k) properly. It needs to be checked regularly like the oil and it should be at or above full.
Besides those items there were some vehicles that did not have good radiator caps from the factory. Poor design on GM's part but it was not other coolants that caused the failure.
http://www.penray.com/bulletins/dexcool.htm
ma_maxx, if the car has been sitting in place for a __long__ time the tires can develop flat spots and then the car will vibrate excessively when driven. Do you feel the vibration/thumping at low speeds? Also, does the vibration change "character" after you turn a corner (turning will make the wheels change position with each other)?
If there's any question about the tires, as for Michelin replacements.
There were problems with rigid bodies and light suspension weight for parts that caused vibrations to amplify on some Devilles, Sevilles, Park AVe, Auroras, and LeSabres. These were fixed by replacing with Michelin Symmetry tires and using road force balancers (Hunter 9700). Most dealerships now have these for correcting problems.
But the vibrations from those are subtle. They are not strong like an out-of-round tire or out-of-balance tire gives. They also seemed to transient. They were there varying with temperature, road surface, full gas tank, in different amounts.
You sound like yours were definite problems.
Now...it looks like, they're no longer allowing us public plebs to monitor the site:
"For security, the TechLink website is being moved behind a General Motors firewall and will no longer be available to the public."
Wonder why?
As far as I can tell, the 97,98,and 05 models all seem to have brake problems or power steering issues. I may be reading more into that than is there. I just want to be thorough.
I think they don’t want us to know what problems they have identified, most owners will not know what problems GM is having.
But rest assured that all knowledge about any car finds its way onto the internet. So I'm not worried. They can keep their precious TechLink.
You don't have any "Check Engine Light" on occassionally, do you? That will prevent remote start from working.
Simple. GM can only gaurantee the protection package in DexCool as long as it remains in the 50/50 mixture from the factory. Start adding regular green coolant, which doesn't contain the same protection package and would you be willing to certify that it goes 150k miles?
Mixing other coolants with DexCool has also been reported to form a crud.
Those reports are incorrect. The crud and sludge is when you introduce air into the system by not keeping it full (and in the case of systems that aren't self burping) and not getting all the air out. Try letting a green coolant go for a few years running low and see what happens.
If you come up with something else let me know.
good luck
Another noisy area in the '04 Maxx is the rear trim on the hatch. If, when you close the hatch, you hear a loud squeak or shriek, the metal fasteners of the plastic trim are grating on the aluminum hatch body. I had to remove all of mine, coat them with plastic tape, and reassemble - the hatch squeaks are pretty much gone now.
The roof rattle is about the only problem our first Maxx didn't have. But in some respects it is the most annoying. I just turn the stereo up but that does not work when you have passengers in the car or my husband.
Does anyone know what size the lug nuts are on the '04 Malibu LT with 16-inch wheels? I need to buy a socket to use with my Torque Wrench to properly torque the nuts. I'm assuming that it takes metric size but am not sure...
Thanks in advance...
Also, is anyone else noticing a lot of driveline lash in their older Maxxes? Is this a symptom of the problematic transmissions that crept into part of the '04 mfr run?
