Ford 2001 Heavy Duty F-250
  • mcgrathmcgrath Posts: 11
    I own an early 2000 F-250SD Crew Cab and got stuck with the non-telescoping power trailer tow mirrors(probably because Ford needed to get rid off all the '99 mirrors). I recently crunched my drivers side mirror and the only replacement Ford has is the telescoping. I am having a heck of a time getting a mirror ordered from my local Ford dealer. I am wondering if anyone out there has either a drivers side non-telescoping mirror or a set of telescoping mirrors for sale....
  • 2001 F 250 v8 4x4,auto.4.10 -14 70 I never tow over 3500lbs. and live in wi. if I had it to due over again I would get 3.73 gears.
  • jay107jay107 Posts: 9
    I have noticed that on some 350 and 250 SD's that the front sits almost level with the back and on others the front sits aboput 2-3 inches lower. Is this a suspension upgrade you can order or are the trucks that sit level using an aftermarket front leveling kit. I have ordered my 350 SD SC SWB v10 with the snow plow prep package that includes the highest front springs. Will my truck sag in the front or will it be level. If it does sag which method or wich leveling kit is most complete? Any info will be appreciated, thanks.
    I was also wondering what are the largest tires I can put on my stock rims. I believe they are 16x7, they are the stock wheels that come on 2002 350 SD Lariat models SRW. I will have the 4.30 ratio. If I put on 285/75-16 will I need to adjust the speedometer or transmision shift points. Will the bigger tire size noticably affect acceleration or will the v10 with 4.30 ratio still pull haqrd?, Thanks
  • modvptnlmodvptnl Posts: 1,352
    I'm running 285's on my 2WD and they're fine. Haven't adjusted anything. I'm assuming you have a 4WD.
    I think I'm getting old because in the past I would have bought the $1500 Fab Tech pre-runner suspension,(extended radius arms, shock hoops etc.) wheels and some 37's and pretended it was a Baja runner. The truck is just too big to hammer off road so I've left it stock with the front end a little lower than the back. The 285's do look better though(black side out)
    The 4WD's in stock form do sit a$$ up also but I don't think I've seen one with the snow plow package. Maybe the stiffer front springs level it out??? I also know the first Super duties were so high in back the dealers would put lowering blocks in the back for free. I think this was to appease the 5th wheel crowd.
  • jcmdiejcmdie Posts: 595
    If you happen to get the PSD the additional weight tends to drag the front end down even more. Some of the PSD guys put Xtra HD springs in the front to help balance out the weight better.
  • bobh12bobh12 Posts: 140
    The VIN will tell you some info, such as if I remember correctly where built, engine, etc, but you need a "codebook" to figure it out. A couple of years ago1999-2000 when this thead was very active, some one posted all of the conversions, but by now it is probably archived away, still wmight bea ble ot do a searcha nd find it though. Someone like "bess", who was around at that time may be able to help.
  • Hope it helps,the VIN contains 17 numbers (sample below is from a Hummer)
    Deciphering the VIN (Vehicle Identification Number):
    Digit Definition Code Definition
    X 6.2 LITER DIESEL - GM - 8CYL
    E 3 SPEED, AUTO/LHD - GM - 3L80
    83 HMC4 - TRUCK-4 DOOR
    89 XLC2 - TRUCK-2 DOOR CAB
    8 G.V.W.R. 3 10,001-14,000 POUNDS
    10 MODEL YEAR N 1992
    P 1993
    R 1994
    S 1995
    T 1996
    V 1997
    W 1998
    12-17 SERIAL NUMBER - -
    The thread I was refering to is "Ford Super Duty Trucks", now part IX. Should be in late 99 or early 00. Good luck
  • Gentlemen: Thanks for the response. I appreciate all the information I am able to get from this site. I check weekly for topics and useful information insight.
    I'll let you know what I think of my 2002 F-250 Super Duty 4x4 with V-10 once it is delivered and I have a chance to put a few miles on her.
    This will be my first owned Ford. My last vehicle was a GMC Suburban 1500.
  • Decided to check back with this forum after being away for about 1-year. The ford-diesel site has a section dedicated to "gassers", where I have been lurking. To re-introduce myself to the new crowd, I have a 2000 F250 XLT 4x4 V-10 Auto 3:73..all options EXCEPT the electronic shift on the fly(esof). Mods I have added are Jet Performance Chip, Borla Cat-back Exhaust, K & N filter, RHINO liner. I have also added a sonnax shift valve and tri-cummulator springs to the transmission. I only have about 15,000 miles on the truck and have had few problems. Replaced 1-steering stabilizer, 1-power steering pump due to leaks. Recently had the IDLE AIR CONTROL VALVE replaced. For you gassers out there, especially the V-10's, if you truck exhibits vapor lock symptons on hot days, or stumbles in reverse backing, this is most likely the problem. Mileage in town averages 9-10 with heavy foot, short trips. Mileage on road 13-15 if speed kept under 75-mph.
    For JAY107, one of the reasons that some trucks sit more level than others is the snow plow package. The snow plow package gives you the highest rated springs(called "X") 6000#'s, and brings the front end up about 1-2". I believe there was a TSB for some of the earlier trucks because of spring sag. Several guys over in the other forum just ordered the "X" springs and had the dealers install them. I have them on mine and have NO problems with the ride. I even keep my tires up around 70-psi and still rides better than wifes car. Now as far as tires on the stock rims, the 265's are about as big as you can go "by the book". I believe the 285's take a .5 size bigger. Many guys over in the other chat room have done it, while others have run into problems with the tire dealers not wanting the liability.
    As far as the auto hub locking feature, there a couple of reasons I decided against it. First, as mentioned before, there were still bugs with them when I ordered my truck 2-years ago. Second, if backing a heavy load/trailer, you can take advantage of the lower gearing without engaging the front end. This can really save the automatic tranny from burning up. However, if you do suspect your tranny is getting hot, there is a TSB for some late 99 early 2000 trucks for extra tranny cooling. The TSB adds a water cooler in addition to the air cooler that is already there. I have had it done and noticed a change in every day in-town driving temperatures. Congrats to all those with new trucks, I already have my next one specked if I can only convince the wife.......
  • Hey everyone... My dad has a 2001 Platinum Edition with the limited slip 3.73 rear and the 7.3 diesel engine.. It's a very sweet truck!!!! Anyhow, what I am wondering, is there any way to find out which number truck this is.. I think they only made so many of this edition truck to commerate the 1 millionth super duty to roll off the lot.. Can anyone tell me any info of this truck?? It is greatly appreciated.. :)
    PS: I have a dicsussion on the 2001 Platinum truck started so you can have a look.. :)
  • Thanks for your valuable info., I found it very interesting about the snow plow package as I will have that on my 2002 F350 that I still have about 5 weeks to wait for. I saw a 2002 on the lot the other day and I saw the new reflector headlights and they do look good. My truck was ordered a Lariat supercab, short bed, V10, auto., 4.30 ls, snow plow prep, and I did get the ESOF, because after my last couple of trucks being Ram 2500's with shift on the fly, I was spoiled as to not having to get out in the snow to engage hubs.
    Gossamer, welcome back, I remember when you were a regular on the Super Duty site. I was lurking around then, didn't have one had an F-150 on order, but used to watch the Super Duty thread for good info and humor, remember "Crazy Elvis" and some of the others?
    As for the Platinum Edition I don't believe it is limited production such as the Lightning, it is an option package that was available on 01s and is still available on the 02s, so I don't think it has specific production numbers, such as 332 of 5000.
  • ...Glad I can share some of the knowledge gained from this site and others, in addition to owning the truck for about 2-years. Has anyone heard from Crazyelvis??? Does he check in from time to time?? If I remember correctly he was down in florida. Yeah, our discussions got pretty comical at times......
    As far as the platinum edition, it is like the "LE" version of the dually. Alot of it depends on the dealer knowledge for these special option groups because most of the time they are not in the regular brochures....then again, I have not yet seen the 2002 brochures to see if the Platinum option is mentioned. I have seen one from a distance, and they had some pictures posted over in the diesel site....looks SHARP!!!
    If any of you are in the Illinois area, I do have a good dealership and salesman that will help make those dreams come true. They are right in the middle of farm country, so they have a high allotment for truck ordering. What is the average time you guys are waiting now?? 2-years ago, it was 8-weeks to the day that I got mine into the garage.
    Speaking of picking up new truck...for those of you doing this....check over the paint VERY carefully for little specks of what looks like dirt. It is actually what is known as rail-dust. There is a dealer TSB on this, but maybe they are protecting the trucks better now than they did in the past. See attatched thread, scroll down to the Z-18 clay bar and happy reading.
     I have been using these products for almost a year now and this stuff ROCKS!!! I thought that I kept a clean truck...but after using the clay bar, I was almost embarrassed. If others have questions, please don't hesitate to ask....
  • bessbess Posts: 972
    Good to see you back.. I've been here the whole time.. I haven't seen elvis in a looong time..
    My SD is as great as ever.. 00 F250 xlt SC 4x2 5.4L 5sp 4.10LS, around 29k miles.
    Which of the Zaino products do you use? just the clay bar, or do you use the Z-02 as well?
  • I just recieved my VIN from my dealer and he said that I could have my truck any day now. I was originally told about 8 weeks wait time, but he ordered my truck on 8-16-01 along with another guys truck and the other truck was delivered yesterday. Does anybody know what the normal wait period is after recieving a VIN? Thanks
  • Bess....glad to see you are still you have like double the mileage I do!! I guess the 1.5 mile drive to work makes a difference!! As far as the Zaino stuff, I used Ajax to strip off the old wax. Then I used the clay bar lubricated with the Zaino car wash solution to go over the whole truck. Then I applied the polish lok, and have now about 5-coats of Z-2 on the truck and maybe one coat of Z-5. I also use the gloss enhancer spray about once per week between coats to keep things looking good. Have you used the products yet?? If not, GET IT!! A little pricey at first, but after you see the results it is well worth it. I am due for another coat this weekend, trying to get a good build up before winter hits. Although the heated garage in the winter time does make it a bit easier to do touch up coats of wax.
    Have you had any issues with your truck?? A friend of mine has a Y2K crew cab 4x4 dually diesel with about 30K and has had zero problems thus far. The only complaint he has is that his front tires are wearing a bit funny, but most of those miles is yanking around a gooseneck horse trailer......
    catch ya later....
    I'll look into the Zaino stuff. Do auto stores carry it? It would be nice if they had a real online order system.. Ya'll make me smile with the mods you do.. My truck is about as stock as they come. The only mods are: Ford Lighted logos in the grille and tailgate and a penda bedmat.
    I've not had it in for any warranty work and the only minor complaints:
    -I sortof wish it sounded better.. The engine still has a air whooshy sound on acceleration, but I'm too cheap to get headers or exhaust mods.
    -On 90 degree+ days where the truck sits out in the sun all day, I will get some cab 'pops'. This is the cab mounting bolts issue that others have had TSB work done on.. It's not frequent enough for me to do anything about..
    - Thinking about aftermarket shocks.. Running with no load on washboard dirt roads does make the rear end a bit lively..I've heard others claim amazing results with Rancho's and Bielstiens.
    Overall my 'likes' far far far outweigh the minor issues I listed above..
    - plenty of room for bikes, gear, kids, wife.
    - Its a great looking truck.
    - I love the power (5.4L 5sp 4.10LS). It really is easy to drive..
    - my AVERAGE mpg is 16.0. And does even better when I'm on the highway..
    - Tires are still in excellent shape, (rotating them every 10k miles)..
    Zaino bros products are only available direct, either by phone or internet. It is not avilable in retail stores.
  • Here's the Ford Truck VIN decode. Hope it helps.
    Group 1: World Manufacturer Identifier
    Group 2: Brake Type and GVWR
    Group 3: Vehicle Line, Series, Body Type
    Group 4: Engine Type
    Group 5: Check Digit
    Group 6: Model Year
    Group 7: Assembly Plant
    Group 8: Production Sequence Number
    Group 1..positions 1-3 - World Manufacturer Code
    1FM - FMC, USA, multi-purpose vehicle
    1FT - FMC, USA, truck, completed vehicle
    1FD - FMC, USA, incomplete vehicle
    1FC - FMC, USA, basic (stripped) chassis
    1FB - FMC, USA, basic (stripped) chassis BUS
    2FM - FMC, Canada, multi-purpose vehicle
    2FT - FMC, Canada, truck, completed vehicle
    2FD - FMC, Canada, incomplete vehicle
    2FC - FMC, Canada, basic (stripped) chassis
    2FB - FMC, Canada, basic (stripped) chassis BUS
    3FC - FMC, Mexico, basic (stripped) chassis
    3FE - FMC, Mexico, incomplete vehicle
    3FM - FMC, Mexico, multi-purpose vehicle
    3FT - FMC, Mexico, truck, completed vehicle
    Group 2.....Brake Type and GVWR POSITION 4
    Don't worry about the codes - you already know if you have air brakes, and whether you have an F-250 or an F-550.
    Group 3.... Vehicle Line, Series, Body Type - positions 5, 6, 7
    F20 - F250 RC 4x2
    X20 - F250 SC 4x2
    W20 - F250 CC 4x2
    F21 - F250 RC 4x4
    X21 - F250 SC 4x4
    W21 - F250 CC 4x4
    F30 - F350 RC 4x2 SRW
    X30 - F350 SC 4x2 SRW
    W30 - F350 CC 4x2 SRW
    F31 - F350 RC 4x4 SRW
    X31 - F350 SC 4x4 SRW
    W31 - F350 CC 4x4 SRW
    F32 - F350 RC 4x2 DRW
    X32 - F350 SC 4x2 DRW
    W32 - F350 CC 4x2 DRW
    F33 - F350 RC 4x4 DRW
    X33 - F350 SC 4x4 DRW
    W33 - F350 CC 4x4 DRW
    F34 - F350 RC (chassis cab) 4x2 SRW
    X34 - F350 SC (chassis cab) 4x2 SRW
    W34 - F350 CC (chassis cab) 4x2 SRW
    F35 - F350 RC (chassis cab) 4x4 SRW
    X35 - F350 SC (chassis cab) 4x4 SRW
    W35 - F350 CC (chassis cab) 4x4 SRW
    F36 - F350 RC (chassis cab) 4x2 DRW
    X36 - F350 SC (chassis cab) 4x2 DRW
    W36 - F350 CC (chassis cab) 4x2 DRW
    F37 - F350 RC (chassis cab) 4x4 DRW
    X37 - F350 SC (chassis cab) 4x4 DRW
    W37 - F350 CC (chassis cab) 4x4 DRW
    ....the F450 and F550 series
    U40 - Excursion XLT, 4x2
    U41 - Excursion XLT, 4x4
    U42 - Excursion Limited, 4x2
    U43 - Excursion Limited, 4x4
    F53 - Recreational stripped chassis (motorhome)
    Group 4....Engine Code - position 8
    A,Z,L - 5.4L Modular, SOHC, EFI, V8,
    S - 6.8L SOHC, EFI, v10,
    6 - 7.3L, OHV, DI Turbo, V8, Diesel F-Series/Excursion in F-650/F-750
    (no listing for 7.3 in a pickup, but apparently it's an F).
    Group 5....check digit
    Group 6....Model Year Code - position 10
    X = 1999
    Y = 2000
    1 = 2001
    2 = 2002
    Group 7....Assembly Plant - position 11
    E - Kentucky Truck (Jefferson County, Kentucky)
    M - Cuautitlan (Cuautitlan, Mexico)
    Group 8....Serial Number - position 12 - 17
    IFT S W31 S 9 1 E B75718
    1FT = FMC, USA, truck, completed vehicle
    S = F350 SRW
    W31 = F-350 Crew Cab 4x4
    S = V10
    9 = check digit
    1 = model year 2001
    E = assembly plant = Kentucky Truck
    B75718 = serial number
  • What a GREAT web site... absolutely love it. You can surely learn more here than from the dealer.
    By the way, from comments I reviewed this week, I ordered some Zaino products yesterday. Bought $50 worth of stuff. Now, if I could only get that call from my dealer advising me my BIG TRUCK was here.
    I'll be back. Thanks for all the info. provided.
    pipesmoker - Dothan, Alabama
  • I got another call today from my dealer who advised me that my new F350 was sitting on his lot and then asked me when I would like to pick it up. It has been 3 weeks and a day since I ordered it! I want to thank "Wpalkowski" for the VIN info. It was usefull in figuring out the VIN the dealer had given me for my new truck. Thanks.
  • Gentlemen: My BIG TRUCK has been delivered. I picked-up my truck from the dealer on 9-14-01, I ordered this truck on 8-02-01.
    Wow, what a truck!! Awesome!!!
    I have not put 500 miles on the truck yet. So far this is a great truck. Fully loaded with all available options, Lariet package, 4x4 shift on fly, V-10, 3.73 rear end, six disc CD, etc., etc.
    I plan on buying accessories, i.e., metal tool box, brush/grille guard, bed liner.
    I'll be reporting back.
    Happy in Dothan, Alabama --pipesmoker
  • Have a shift on the fly F250 SD 2001 4X4. Sat down last night and was reading the owners manual got to the 4wd section and notice on locking front ends that shift on the fly has an "A" vs an "L." position and Ford recommends you leave it in the "A" position. Went out and checked mine for the halibut and guess what it has been in the "L." position ever since I owned it. (15,000 miles). My question is have I done any damage to the front drive? I know I have lost a lot of gas mileage but I can live with that. Any ideas please advise. This had to come from factory this way, there goes the quality control I've heard so much about.
    Thanks ahead
    Frank K.
  • Not Good. Just 15000 miles of unneeded wear and tear. Not likeley to be a problem but you should check them often as the nogoodnicks will sometimes lock one just to mess with it. Haveing one locked is way worse than both.
  • bartc1bartc1 Posts: 4
    I hear these F350 and F250 4X4 PSD are so heavy they sink in serious off road conditions. Anybody ever have that problem out there? I love these trucks because of there size and towing ability and hope to buy one in '02. I am interested to hear how they actually do off-road.
  • Weight is almost always bad in sand but dont panic. I can pull a 6000lb trailer through the little dunes in glamis with a 2wd ford diesel van with an open diff. A little less air in the tires and a little practice and you can wheel anything. Just dont corner yourself, Backing up always got me stuck with that trailer.
  • fordtuffordtuf Posts: 101
    when he goes offroad, and he does it a lot, his friend with a PSD often gets to the point of bogging down. His friend now will not go through everything that he does. They both have some serious mud tires too. My cousin has F150 w/8" lift and 36" or 38" tall tires.
    Most folks with F250 PSD's get the 3.73 rear end ratio.. this coupled with the extra weight of the PSD and the larger tires, it is understandable that it might bog in some situations..
    However your buddy with the F150 and 8" lift, and 36" tires, I would bet has also put in different rear end gears, (like 4.30 or a 4.56).
Ford 2001 Heavy Duty F-250 - Page 19 — Car Forums at
