The bottom of your door is not that wide. It is simply that the wheel well cuts into the bottom of the door. It is very common.
-Michigan/Indiana
:confuse:
Equinox: 20mpg
Santa Fe: 18mpg
Murano: 19mpg
RX330: 18mpg
Honda CRV: 20mpg
Mercedes ML350: 18mpg
Ford Escape: 18mpg
Subaru Forester: 20mpg
You can see it at:
http://www.alldata.com/tsb/General-Motors/1115622000000_1120028400000_05-07-30-014/index.h- tml
Later
The owners manuals for both cars specifically states that lug nuts must be properly torqued to spec when rotating tires to prevent brake pulsation. GM has also issued a 12 page TSB on Brake Warranty Service and Procedures (00-05-22-002E). It has a whole section on brake pulsation issues and how they are caused by Lateral Run Out which is induced by improperly torquing the lug nuts. The LRO causes the brake pads to wear the rotors unevenly. That is why the pulsation does not show up until after 3-10K miles after a wheel service event.
On the Maxx the rumble began about 3K miles after the first time the dealer rotated the tires. They just turned the front rotors and it fixed the problem. However, 3K miles after the 2nd time they rotated the tires the rumble came back again. Will be taking it in next week for service (and 3rd tire rotation). Will ask SA how they tighten lug nuts and hope this time they replace the rotors. They can't keep turning them. If they go below minimum thickness while under warranty, they must replace them.
The Equinox brakes are OK so far, only have 1300 miles and tires have not been rotated yet. A lot of people on Malibu forums have said GM/Chevy just uses cheap rotors and only true fix is to replace with better aftermarket rotors. If I can get the dealer to replace the rotors, I will buy a torque wrench and check it after they rotate them.
On Equinox mileage, we've been getting no better than 19 for highway use. It's only a month old and was built in April 04. I too will have TCM reprogrammed per TSB when it goes in for first service. The shift quality now is quite poor.
Let us know if mileage improve after your TCM is updated.
Also, can't get used to the headrest, they are totally uncomfortable.
(5th gear is not an overdrive also contributes to poor gas mileage). Upshifts are delayed. It can't make up its mind to upshift. The RPMs flare up just before the shift. It also won't go into 5th unless you remove foot from gas above 40mpg.
I noted in TSB 05-07-30-014 that after reprogram, they must clear the transmission adapts and perform the transmission adaptive learn procedure. Perhaps they did not do this on yours.
An earlier TSB 04-07-30-031 issued July 2004, has a lot of info on this transmission including the adaptive learn procedure. It requires a lot of driving under various conditions to retrain the transmission. Each maneuver must be done 5 or 10 time (sort of like a transaxle boot camp). I have my doubts that any dealer would take the time to do this before returning the vehicle. You could at least determine if they drove your Nox if you noted the odometer reading when you dropped if off and picked it up. This should be on your invoice, but I always note this myself as they don't always properly record the mileage each time.
The 06/04 TSB says if the entire learn procedure is not done, "the customer may experience a less than desired or uncharacteristic shift quality for that certain shift point until the adaptive values for that shift are adapted by the TCM". If they did not clear the adapts at all, I'm guessing the trans would behave as it did before. Not sure if you can clear the adapts yourself by disconnecting the battery for a period of time. The TSB says the scan tool is needed.
Good Luck and let us know how the 3rd time works out.
Any help with this issue is much appreciated!
If you have the blower fan turned on to any speed (middle knob not on zero), then the A/C compressor is only controlled by the A/C button (snow flake) when the right mode knob is set to vent, bi-level, or floor. If the indicator light above the snow flake button is on, the compressor will run in vent, bi-level or floor mode. If you don't want the compressor to run you have to push the snow flake button to turn off the indicator light. It was not clear from your explanation if you were turning the compressor on and off using the snow flake button.
If you have the right knob set to defrost/defog mode with the fan on, the system forces the compressor to turn on and you can't turn it off (the light above snow flake button will go on if it was off). You also can't select recirculate mode when right knob is set to defrost/defog mode.
When you go back to vent, bi-level or floor mode from defrost/defog, the system remembers your last setting for the A/C and Recirculate buttons.
I'll have to check my Equinox later (Apr05 build), to see if compressor runs when fan is off. If it does, and the light above the snow flake is on when the fan is off, then perhaps you have to push the snowflake button and turn off the light whenever you turn off the blower fan.
I know on some prior cars I have owned the A/C compressor automatically turns on and off based on your mode selection, there is no separate button for the compressor.
Thanxs...
Which reminds me; I had decided to remove mine and put them in my "trunk" for safe-keeping since there are no garages or car-ports here. But then I went to sleep and forgot
J K F
P. S.: Welcome to Town Hall Meeting. jkf
At my location, little to no difference in price.
Poor grade gasoline effects your emissions and will cause your Check Engine Light to come on.
This is true with all newer vehicles, foreign and domestic, due to stricter emission standards.
Poor gas will also cause deposits and clog fuel injectors.
Check out this link for high quality Gasoline Retailers:
http://www.toptiergas.com
If your Check Engine Light comes on, try a different brand of gas. It may take up to 150 miles before the light resets.(An EPA thing!)
Eric B
Thanks all,
E
Make : CHEVROLET Model : EQUINOX Year : 2005
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 3169 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10010166
Component: ENGINE AND ENGINE COOLING
Summary:
FOUL ODOR FROM HVAC AND/ OR ENGINE COOLANT. *TC
Check to Request Research. Submit below.
Hey, noxguy, did you ever get your Equinox cross bars off?
Now that the Midwest Heat Wave has abated a few degrees, I went out to do what I said I was going to do in the last post to you.
;)I can't get the cross bars off without using a jumbo slotted screwdriver or a battery-operated saber saw to open the rail's tracks. And then arc-welding to military specifications the tracks back together in one piece;)
J K F
Congrats on the better mpg in your vehicle:)
J K F
Eric
Anyone else having this problem?
The problem is intermittant. Each time the engine will not turn over even though the battery is fine (lights, CD/radio, wipers, etc function). Occasionally after multiple attempts turning the key the engine will start (twice required towed). Each time after this occurs and the engine does start about 5 minutes into drive all engine alarms and lights come on, a/c quits, and all indicators on dash go to zero (rpm, mph, fuel, battery and odomoter quits adding miles). Despite all of this, the engine continues to run. Twice the dealership told me 'fuse connections were loose and were reconnected' and most recently they replaced the starter switch. Needless to say the problem repeated itself last weekend and they have no idea what is wrong.
Does anyone have any insight? Thanks.
