Ford 2001 Heavy Duty F-250
1181921232426
  • I just purchased a 99 F250 CC with the PSD. It also has an automatic. I am trying to get some information about the truck, and seem to be going nowhere. The door tag axle code is "C1". From crawling under the truck, I have determined that it has 3.73's, but don't know if it is an open diff or limited slip. Is there a sitet on the 'net that will help me to decode the door tag and vin number? Also, this is the first diesel that I have owned...so am experiencing a fairly steep learning curve. During winter, should I run pure #1 diesel, a 50-50 mix of 1 & 2, or go with pure #2 with an additive? I plan on getting gas from the truck stop nearest my house since I would think their fuel would be "fresher" than in town convience stores. What type of mileage would be reasonable to expect? I did one test, and averaged 11.50 mpg, but that was with the front end locked due to snow and slippery streets. Thanx in advance for any help and tips.
  • modvptnlmodvptnl Posts: 1,352
    You're obviously correct that the higher GVW will carry more weight, but where did you get your curb weight #'s? FTE has the 250 CC 4X4 at 6152. I'm sure that doesn't include the PSD. Add 600# for the PSD still puts you at maybe 6600#'s. Giving you an easy 2200 pounds of payload.
    For sure get the 9900 GVW if needed but 8800 still gives you over a ton, not the 1200 you're saying.
  • hunter98hunter98 Posts: 273
    Two words
    WEIGH ONE!
  • benr0benr0 Posts: 22
    Take it to a scale and check for your self.
    I have 2001, CC, SB, v10 2wd.
    With me, my wife, 2 kids, full tank of gas and suitcases for the weekend. Scale weight is 7200.
    PSD and 4wd will add over 400 lbs.
    Many have scaled at 7600-7800 with CC,LB,PSD,4WD.
    Not much left to go into bed.
    Check out http://www.ford-diesel.com/
    Many others have hit the scales as well.
    Several have found they made a mistake by not getting the 350.
    Re; post 601 you said, no people and gear.
    Your 7200# weight has at least 800#'s already loaded. You've got 250# of fuel 4 people at 500# and a couple hundred pounds(?) of luggage. You've still got 1600 pounds available. Or 1000-1200 available with a 4X diesel.
    I agree the 9900 GVW will carry more, no doubt. I just thought you were selling the 8800 GVW a little short.
    PSD, and 4x4 will add alot more than 400 lbs, a long bed will add probable in the 300 lb range. Plus the weight of toolbox's, steps, ect.
    Believe what you want
    Hunter
    Of course tool boxes weigh something. I'm not sure what you're getting at. The numbers I got were for a long bed.
    The bottom line is I highly doubt a truck that Ford lists @ 6200 pounds(which is the long bed, CC, 4X) is a whole lot heavier then that EMPTY. I gave the PSD 600#. So even if the rig is 7000 pounds EMPTY. It leaves 1800# for cargo which includes toolboxes, fuel, people, luggage etc. I'm just debating the original post that a 250 can only carry 1200 pounds total. I agree if you need more than that after people, fuel etc. get the 350. I don't, and the 250 serves me well.
    PS, I never said a 4X and PSD weigh 400# extra.
  • Have Ford 2000 RV & Trailer towing guide in front of me. (Assuming '02 trucks are fairly close.) It reads as follows:
    Maximum Cargo Weight:
    F-250, 4x4, PSD, CC, Short Bed - 1234 lbs.
    F-250, 4x4, PSD, CC, Long Bed - 1088 lbs
    F-250, 4x4, Gas, CC, Short Bed - 1994 lbs.
    F-250, 4x4, Gas, CC, Long Bed - 1858 lbs
    F-350, 4x4, PSD, CC, Short Bed - 2349 lbs. Single Rear Wheel
    F-350, 4x4, PSD, CC, Long Bed - 2213 lbs Single Rear Wheel
    F-350, 4x4, Gas, CC, Short Bed - 3099 lbs. Single Rear Wheel
    F-350, 4x4, Gas, CC, Long Bed - 2963 lbs Single Rear Wheel
    "Cargo weight rating is the maximum allowable, assuming the weight of the base vehicle with the required camper option content and a 150 lb passenger at each available seating position (7.3L Diesel ratings assume the weight of the engine and standard transmission) The Cargo Weight Rating shown must be further reduced by the weight of the powertrain upgrades and any other options."
    By having a 150 lb passenger in each seating position, I guess Crew Cab is already assuming you've got 600 lbs of human cargo. Doesn't say if the rating includes a full fuel load.
    Looks like PSD weighs about 750 lbs more than Gasser and that's with 6 spd. std. tranny. Assuming Auto weighs more as well?
    That's why I bought the 350 (and I probably should've gotten a dually instead 'cause I tend to overload my srw.)
  • If you can get away without them do it. Most of the people who need them have full sized hard sided campers on or tow huge heavy trailers. The problem they have is that they cannot find a single tire that is rated for this load and it would be down right dangerous to run singles. For the rest of us single is better. They dont get rocks stuck between them off road are cheaper/easier to maintain and replace and I have to say almost half of the duallies I have seen have body damage around the wheel wells from hitting things with those over wide bodies.
  • skv78skv78 Posts: 2
    I ordered a 2002 F-250 Crew cab 6 weeks ago, and was just informed that production has been suspended until Feb. 2002. Does anyone have any information about production problems in the U.S.?
  • ande157ande157 Posts: 23
    For those looking to buy a new Super Duty PSD, you may want to wait for the 2003 model. Check out the blueovalnews.com website. It has info on the new "PowerStroke Super 600" engine to be introduced in the 2003 SD truck. 350hp, 600lb/ft from 6.0 liters. Lighter than current PSD and better mileage. Backed up by new "PowerTorq" 5 spd auto trans. Sounds like one helluva engine/trans combination. I was in the market this year to replace my '99 and now I think I'll wait.
  • jcave1jcave1 Posts: 137
    Caught a glimpse of the "TONKA" on a car show report last night. I really liked the looks of that thing. Guess my concern with the 2003 would be the new engine. However with a quality builder like International, any concern should be mute. Possibly a larger concern would be technical knowledge, or lack thereof, at the dealership. Bet you'll also feel pickpocketed buying one. Can't wait to see the 2003 live and in person. Hopefully it won't force me into owning one.
  • f1julesf1jules Posts: 288
    Pet peeve of mine. Sorry.
    Thanks for the humor and the correction.
  • mullins87mullins87 Posts: 959
    I saw that one too. Usually concepts are soooo far out of reality that they don't interest me. The design of this one looks great, especially the large sides of the body and 22' rims. I don't know about the HLA though. Sounds mighty expensive to build and repair. The kneeling feature seems a little excessive also. But one thing I am interested in is the LED headlights. My brother-in-law recently bought an LED flashlight. I am amazed how much super white light that little flashlight makes. Maybe the aftermarket will make a retro kit for our "older" trucks. I don't know if I can wait for one of these to hit the dealership next year. On the other hand, I'm like jcave1, maybe I better not go.
  • I have a 01' F250 sc 4x4 & I,m looking to soften up the ride a little. Has anyone done anything to their suspension to make this truck ride a little better ?
    Would new shocks/springs make a big difference ?
    I already lowered my tires down to 50 psi .
  • jmg222jmg222 Posts: 1
    I have a '01 F250 psd cc short bed and is a pill to fill with fuel. Does anyone have any experiences with this? It will take the first 20 gal. fast but the next 6 or 7 real slow. I've tried everything. Does Ford have a fix for this or is this something common to all F250's with the short bed? Thanks for anything that you can share with me.
  • I've got an F-350, CC, Long bed, gasser. It's got a bigger tank, but yeah it's maddening because the average pump clicks off when there's still 6 or 7 gallons to go. It takes 2 minutes to fill the first 3/4 of the tank and then 5 minutes to dribble in the balance. When truck was brand new I thought gas gauge was off; I double checked manual to find tank capacity, and finally tried filling it to overflowing. Took 10 minutes, but gauge was correct.
    Found a trick that works - new gas station (for me) has a driveway that slopes away from pump. I pull up to last pump and go a bit beyond it (hose still reaches) so nose of truck is pointed down the hill. As a result gas doesn't seem to bubble up the filler neck as much and I only have to play games with the last gallon or two. It isn't a sensitive pump shut off, it just seems as long as truck is headed down hill there're less bubbles in tank or something so it fuels easier. Still have to be careful trying to totally fill it or I can baptize my feet with unleaded.
    Talked to other SD owner (short bed) who carries a couple pieces of 2x6, drives rear wheel (filler side) over them before fueling. Says it helps. Just a PITA to set up. My best friend with long bed,cc, PSD has absolutely no problems fueling at all. Read about PSD owners modifying filler neck to allow them to use high capacity diesel pumps that big rigs use.
  • No mods necessary. I can use the high capacity fuel pumps at truck stops right from the factory. It also fills all but about 11/2 gallons before clicking off. All the newer powerstrokes can. The older ones had a problem with the fill necks traveling nearly level for over a foot before heading down to the tank. Crawl under your short bed and see if they still do this on gassers. If so you would be doing yourself a favor carrying a block of wood to aid in fueling.
    Did you say the new PSD SD's have the larger opening to accept the larger truck nozzles? Mine is larger than any gasser, but I get so aggravated when I get to a pump only to find out the nozzle has one of those rings on the end that keeps it from going into the filler neck.
    When I fill up, I usually set the nozzle fill rate to the second, or middle, notch. This may take a little longer than running wide open, but it gives me the opportunity to clean the windshield and check tire pressure or check my lights. When the pump shuts off, I can usually just run it up to the next whole dollar. I've checked the amount that I am putting in against the tank capacity and it appears to be full completely full.
  • Sorry boss, they do not have the rings in my neck of the woods so I accidentally misled you. I buy fuel nozzels for my job and when they come with the ring I cut them off with a hacksaw. Then they fit in everything I fill up not just the semi's and heavy equipment.
    @! Sorry about that, just venting a little. I consider myself lucky to have found three truck stops along my usual routes that keep one pump set up for pickups. Only thing is it gets quite annoying to pull into one of these truck stops only to find a single tank OTR tractor filling up at the pickup pump simply because it's closest to the door.
  • I went to a local dealership with my dad today to look at a 2001 psd still new a model year leftover.When the salesman went to start the truck it took two long attempts to start the truck. He said the fuel may have jelled during the time the truck sat at the dealership,but even after the test drive it seemed to take to long to restart. Any ideas. the truck had a total of 22 miles on it.Is this normal.
  • bessbess Posts: 972
    Did you wait until the 'wait' light went out before trying to start? (This is to allow time for the glow plugs to reach tempature).
  • The salesman was first to start the truck and after a ten minute test drive the truck was shut off for about 20 minutes while they talk about prices. My dad then re started the truck it again took a long time to start one try. I did notice that the production date of the truck was early may of 2001 so the truck has been on the dealers lot for some time.
    Don't know if you noticed it, or if the salesman is even aware of it, but there is a little "Wait To Start" light that comes on when you turn the key to the run position. When the light goes off, the truck should start fairly quickly. A ten minute test drive is not enough time to get the engine warm, much less hot.
    Don't know what the weather is like where you are, but I can see where the fuel could have gelled from cold temperatures if the dealership didn't add any conditioner to the fuel. The only problem I can see arising from the amount of time a diesel sits is from water accumulating in the tank. But if that were the case, the "Water In Fuel" light would have come on.
    If this is going to be your first diesel, find a dealership that sells a lot of them. You will have lots of questions.
  • I have a 2001 SC SB PSD. I run the pump at the middle click and then have to nurse in the last 4.5 - 5 gallons. I use the same pump every time and nothing changes. I've finally figured out how much I can put in after it clicks off before it starts spilling over. But yes, it's is a pain that I have to do this. I guess I should have gotten the long bed?
    Mine also has a longer then normal starting IMO. In my car, it's a quick turn to the start position. Every time I start the pickup (after the Wait to start light goes out) I have to crank it about 3-5 seconds. If it's really warm, then it usually starts quicker then that.
    Did you say it takes you 3-5 seconds to crank your PSD? That seems too long to me. Even on cold mornings, mine cranks within 2 seconds and no smoke. When the temps drop below 35 degrees, I plug mine in. Maybe that is not necessary, but I'm sure it helps with the quick starts. Even when my truck sits outside all day when the temps are below 20 degrees, it still cranks within 2 seconds.
    Are there any other PSD owners that might care to comment?
Ford 2001 Heavy Duty F-250 - Page 21 - Car Forums at Edmunds.com
