Mixed reviews on these tires although the reviews cover a variety of car makes.
Whats the best bet fro the MB E300 TD??
Curious, how much does it cost on the Bluetec diesels to refill the urea.
Also, how do you reset the maintenance counter. After tiring of $400 to 600 oil changes with the service A B and whatever, I have the dealer do the oil changes and have other work done elsewhere.
"I have a UK 2003 E320 CDi and the system which worked for me to access the service data is a method which supposedly applies to 2005 models, so I suspect that certain software versions/updates etc. are quite variable so...
Try this: -
• Switch ignition to position one.
• Select Outside temperature display.
• Press the trip odometer reset knob three times in quick succession - the voltage reading should appear (or "Keep the trip odometer reset button pressed for approx 5 seconds until the Service Menu appears in the display").
• press the down arrow - the Service Menu appears in the display.
• Using the + and - buttons, select Confirmation of Service
• Press the system selection button ( lower of page buttons at 6 O'clock position) to confirm.
• Press again to confirm.
• Service Confirmed appears in Multifunction Display
• Press the same button to get to the standard display
• Turn ignition off. The next time you turn it on, the reminder should not appear.
You can search in mbworld forums for other models/model years if this does not work. The maintenance counter reset is known as the "FSS" reset.
Another search suggestion is:
Go to Google and type:
site:mbworld.org FSS reset
I'll try it after my next oil change.
Best car we've ever owned.
ML320 CDI for sale
I too have noticed a somewhat abrupt downshift just prior to stopping - but only when the engine is cold - once the engine warms up this does not happen. Will bring it up at my next stop at dealer to see if this is a problem.
I just recently test drove the e300 turbo with 193,000 mi on it and it drives beautifully. The car is for sale at about $7900. Every switches and buttons works fine. I am a bit concerned about the blower which doesn't blow fast on the centre console but does on the outer sides. I do think the a/c needs a bit more of charging. Rest all is fine. Would like to know your opinion.
(Note: This is my first time on edmunds)
I believe that one of the reasons might be that the car has 19" wheels. According to my local tire guy, the heavier tires cuts down on the mileage. Is there a reason that the 2007 would be worse than the 2005?
Also, driving from Primm, NV to the Las Vegas strip, the 2005 was in the low 40's going the speed limit.
Driving the 2007 from the strip to Primm, NV the mileage was around 28 mph doing the limit. I'm spoiled with the mileage I get on the 2005.
Any comments would be helpful.
if you swap in smaller/16" or 17" factory benz rims and low-rolling-resistance tires similar to factory michelin MXV-"energy" tires, you may see a significant increase in mpg and smoother ride too. also what tire pressure? you can probably bump up the pressure by a couple psi from the cushy factory-recommended setting.
another possible factor is that 05 benz diesel has a significantly different engine and fuel requirements than the 07 benz. I will bet you a DM that by now there are gurus who know how to "tune" the 07 engine to get the increased mpg that it is probably capable of. Forget about dealer service if you go in that direction however...
Went ahead and swapped out the 19" tires on the 2007 to the 2005 since my son won't be putting many miles on the car.
Looks like the2007 V-6 and emission requirements are a drag on the 2007 mileage.
Also can someone advise on how much it costs to replace the urea fluid periodically? Can this be done at home without going to the dealer?
thanks a bunch all.
BlueTec fluid can easily be filled by you for about 1/3 the price of having a Mercedes dealer do the job. You only have to refill the tank every 10K miles or so and you can buy the fluid almost anywhere these days...or just go to a VW dealer to buy it if that's easier or you feel more comfortable.
If it will help your decision, mercedes leasing gives a residual value of about 76% after two years. That's 76% of the MSRP. That's what they think the car will be worth in 24 months. If they're right, you'll drive that car for 24 months for $3000 depreciation. Consider leasing by the way....ask about a 24 month lease on that car and you may be shocked at how little it costs.
Take your best shot
thanks, henry
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
henry
How much does extra maintenance costs and how often it has to be done?
Is the "bluetec" fluid only additional maintenance on bluetec vs regular E350?
The maintenance plan on the diesel might cost more than the gas car because of the filter cost. Lot's of mights, but my dealer was very confused so I just paid the gas maintenance and they residualized it so I only paid about $250 for the A and B service.....a great deal.
We did the european delivery in 2005. It was one of the best vacation ever. You will be treated very well by the MB staff. Touring the MB factory and museum were outstanding. Driving your new MB in the autobahn at speeds over 100 mph is priceless! I would definitely do it again for these experiences. Please check MB european delivery program in regards to 2 for 1 plane fare. Sometimes they offer it. You also get a free night at one of the hotels. No other freebies is included.
Enjoy!
Did anyone ever figure out what this is? Any update or link to a more recent post would be appreciated.
