Kia Rio
Spy Pictures 2006 Kia Rio:
http://www.thecarconnection.com/images/gallery/8288_image.jpg
http://www.thecarconnection.com/images/gallery/8289_image.jpg
Article:
With its camouflage nearly off, here is the first glimpse of the redesigned Kia Rio. The Rio will share a platform with the upcoming Hyundai Accent, although the Accent is expected to reach dealerships months earlier.
Full Article:
http://www.thecarconnection.com/index.asp?n=178&sid=178&a- rticle=7451
Article:
Full Article:
http://www.automobilemag.com/auto_shows/paris_2004/0411_kia_sport- /
The 4door (official)
the 5door concept
along with CGI's of the NEW HONDA CIVIC!!..
http://motoring.asia1.com.sg/cgi-bin/motorbb/ultimatebb.cgi?ubb=g- et_topic;f=7;t=001959
~alpha
http://www.caradisiac.com/php/essai_tun/doss/doss213/pop25.php
http://www.caradisiac.com/php/essai_tun/doss/doss213/pop26.php
Looks great IMHO. It seems to be shorter than the current 5-door Rio though.
Will there be a model available like that, with no options, no air conditioning, with the 5-speed, that I can get new for dirt cheap?
Maybe not THAT cheap, but yes, there will be a strippo model. See the press release. Base has no A/C, no wheel covers, no power steering. I think this is kind of cool, actually. Not many people will buy that version, but there's something neat about a car that comes with absolutely nothing...like a modern Model T or Beetle.
-Andrew L
-Andrew L
You can actually recharge your system with a retrofit R134 Kit.
They run about 50.00, come with a 2 Oz can of oil, and 3 cans Of R134, along with a high and low side connector, and the main Refilling connector that screws onto the can and has the valve on it.
I've redone several R12 Systems over the years.
First step.. Take your rig in and get the old stuff sucked out, (most places will recover and recycle it for FREE).
If you do the re charging (its easy to do im telling ya), but get help from someone you know if you aren't sure where the High and Low Side Ports are, or even if you dont feel comfortable doing any of this.
The Low Side typically is a Larger connector than the High Side... and the High Side is almost always mounted closest to the Radiator.
The replacement connectors screw over the old valves, the Low side becomes a larger one with a Blue Cap, and the High Side Becomes a Slightly larger connector with a Red Cap.
Make sure that when you recharge it, you put the Oil in first, have your AC turned on full blast, and engine running.
Then (this isn't perfect science, but your car WILL blow cold air compared to none at all!)
It needs to be 85% of whatever the amount the Factory originally put in the system.
So, if its say, 23 OZ of R12, that comes out to, 19.55 OZ.
Its VERY important you remember this. if you dont, it can damage your Compressor! I say its "not a science" because each can is 12OZ.. So, you can add one, but only a bit over 3/4 of the other.
Just make sure you keep your finger on the shut off valve for the R134.
Some people say that you should "consider" replacing all your system O-rings.
Honestly, with 99% of the rigs out there with R12 made in the 1980s, you will be just fine leaving it completely stock.
What makes the diff is that the Oil you charge it with in the Kit will have the necessary lubricant, and sealing qualities that work great with R12 Systems.
Just something to consider.
If you know where your Low and High side is, Get your Numbers figured out for the best amount to add of R134, You can have your AC up and running in about 15 minutes.
Just MAKE sure you get your old stuff evacuated, (will help get some of the old oil out) and the R12 is GONE. They Don't mix.
:P
Yeah, I'm aware of the R-134A retrofit, but I've heard mixed reviews. Some people say it works fine, others say it causes all kinds of problems. So I've been reluctant to give it a try. Although the car is 19 years old, it's not a piece of junk, and I don't like to make haphazard repairs.
Well, I guess I dragged this discussion a bit off topic...
-Andrew L
"The new Rio also offers class-leading interior volume and six standard airbags, including full-length side-curtain airbags."
You can find it here
Here's official web page of kia's New Pride ( which is 2006 Rio here in the united states)
I can see your qualms but consider this:
Unless your current compressor is already hosed, I would give it a whirl.
Personally, Ive had perfect luck with 10 different vehicles (asian and domestic) so far, and not a single hitch.
The big thing is to be sure you are as accurate as you can be with the refill.
Always put in slightly less R134.
There are many people out there that dont understand how a R12 Compressor has a different head pressure (piston that compresses the gas) when using R12 Freon and you need to be sure you dont overfill because of the different molecular makeup of R134.
Ive met a couple people that overfilled them, and damaged their compressors from really overdoing it.. (overheated them).
Its really just simple math.
Just be sure to do an 85% fill of R134 to your Recommended Fill of R12, and realize that the only possible component to take a crap on you is a possibility of well worn R12 Compressor.
If your Car is in as good a shape as you say, Im sure you will be fine.
Heres another tidbit..
My most recent R12 to R134 Kit conversion I did recently was in a 1993 Honda Civic CX.
327,000 Miles.. ALL ORIGINAL components!..
Flawless install, and it blows cold.
Be aware that R134 Isnt as cold as R12, (85% the coolness of R12 is accurate, Interesting that its the same as what you have to fill it to. LOL) but its also 10 times cheaper!
Yeah, you can run a risk in anything, but I say go for it.
You have absolutely nothing to loose.
Look at it this way.. If your compressor is on its way out, its better to learn about it with a R134 Retrofit, then to refill with very expensive R12 and find out that way.
I can see your worries, but its really a piece of cake.
Jeff :shades:
New Pride (2006 Rio) Exterior Colors
New Pride (2006 Rio) Interior
New Pride (2006 Rio) Special Red Verion
These are all Korean Models
(I heard that In Korea, price of this car is about 9,000~12,000 U.S. dollars (with all the options we are not getting, like mp3, front heated etc...)
Also - if I choose NOT to deplete my old R12 by a technician, could I simply manually deplete the old R12 in the air at my home by pusing in the nozzle on one or both ports? Is this illegal? I read that this could be dangerous so it would be done in open air, of course if I am legally able to do it this way. Would it remove all the old R12?
Thank you and I look forward to getting cold air again in my Honda.
Brent
I wouldnt recommend discharging your R12 (whatever left) manually.
Mainly because having a "tech" remove it helps get some of the R12 based oil out of the compressor, and helps your system have a "vacuum" in it.
Shops will usually do this removal for free.
Call the shop first and tell them what you are doing and that they can have your old R12, and heard they can remove it for free.
Go to a place that specializes in AC repairs and installs.
About the Legality issue.
It is"illegal" to just dump R12 into the atmosphere so I myself went the route of taking it in and having someone take the old stuff out.
R12 and R134A, when released, can be dangerous if someone was to break the shrader valve (the little "pintle" valve thats inside of the High and low side ports)
Its also used on Valve stems of Automotive tires.. etc etc.
When leaving the system, R12 and R134A will freeze objects that are near the valve as the gas leaves.
Just like when you spray something out of any can.. (spray paint, WD-40..whatever) the can gets cold when you spray enough of the product.
They make it sound almost deadly.. I suppose it could be if you managed to somehow put a can of refrigerant to a High side valve ( which is under "pressure" instead of "vacuum" like the low side is).
The High and Low side valves use different size ports.
The Low side is larger in size than the high side and you will notice that the valves that come in the kit (threaded aluminum units with a valve in them) may or may not have a Blue or a Red Plastic Cap.
The Blue Cap is (blue=cold or "low") meant for the low side, and only fit on the low side valve.
The Red Cap is the High side (red=hot or "high").
You might get stuck with Black caps, but you will see that they are not the same size and are not interchangable.
Make sure when you install the valves over the original valves, you dont reef them down.. Tighten enough to snug.. if you reef, you will bend the pintles on either the new or old valves!
The R-134A connector (that the cans spin on)they give you in the Kit, will only connect to the Lowside port as its sized with safety in mind.
Its totally foolproof.
About refilling,
Be careful of your measurements.
Turn the A/C button on, full cold temp on the slider, set the fan speed to "High" and run at an idle.
Look at your R134A connector hose that came in your kit.
It has a brass fitting, where the cans screw on to.. Make sure your valve is turned out so the sharp metal "pin" isnt going to puncture the can as you screw the can onto the connector.
When you turn the valve to the right, it will screw downward, and eventually puncture the can..
You fill by opening the valve again after you feel the resistance of puncturing, then the gas will start flowing as you turn the valve back out again.
Make sure the can is "upside down" with the cans valve pointing down.
It helps with filling.
You can attach and remove the connector in the same way you do with Airtools.
There is a coupler, and you lift up on the coupler, press the connector down on the port with a small amount of pressure.. and release the coupler to lock.
Using these above steps:
Fill the 2 oz Oil can first.
Then add the First can of R134A.
It will take about 3/4 of a can additional once you have finished filling the first can.
Simply, disconnect the coupler, reset the valve position, (there might be a slight discharge of gas remaining in the can), load your next can.
There is no danger when you do this.
I figured 19oz was the figure for a refill at 85% fill rule for R134A. (its 23 Oz if you refilled with R12 again). On your Honda.
The Cans only hold 12 Oz each, so BE Careful on the 2nd can because you can overfill if you arent paying very close attention.
Once you have partly installed the 2nd can.. turn the valve out to close it again and to prevent further filling.
Be quick about it!
Once disconnected from the Low Side, you will be left with a bit of R134 in your can.
It will probably very slowly leak out of the valve when sitting, so be prepared for that.
Fortunately.. R134A is way cheaper than R12!
Just make sure that you absolutely dont overfill your R134.. Its better to be slightly "low" than too "high".
The cans will go from Full to empty in about 45 seconds when filling.
Keep in mind that R134A is basically 85% of the coldness of R12, so it will never be as cold as R12.
But its much better than nothing.
Turn the valve IN.. to close.
Not Out.
2006 RIO
It's good to see improvement over the current model. But Kia will need to bring a hybrid version of the Rio (supposedly considered for 2007, along with a Hyundai Accent hybrid) to really compete on the mileage front.
Compared to previous Rio, new Rio has more larger dimensions as well as higher power. (I don't know how this new Rio will change in U.S.)
What I felt so far is that new Rio has became economical. Especially diesel version of Rio has really owesome mileage. Somebody ever told he was able to drive approximately over 950 kilometers with his diesel Rio when his car was filled up. (new Rio has 45L gas tank) Unfortunately I couldn't buy diesel one... I just bought gasoline one. However the gasoline one also provides nice mileage.
In addition, its exterior and interior are very handsome. Frankly, I can say it's european style rather than american style. Whatever it looks like, you will meet new Rio soon, then it will be up to you to judge.
Funny you should ask. According to PRNewsWire,
The Rio sedan is available in two well-equipped models - Base and LX. The Base model starts at $10,570 and comes equipped with a five-speed manual transmission. The LX model starts at $12,445 and comes standard with A/C, AM/FM/CD audio system, power/tilt steering and a 60/40 split folding rear seat. It is available with either a five-speed manual or a four-speed automatic transmission.
Rounding out the Rio lineup, the Rio5 five-door comes in a sporty SX trim that includes all of the features found on the LX model and adds 15-inch alloy wheels with 195/55R15 tires, fog lights, rear spoiler, leather-wrapped steering wheel and shift knob, metal-grain interior trim and metal pedals. Starting at $13,500, the Rio5 SX is available with either a five-speed manual or a four-speed automatic transmission.
Estimate about $1000 for the auto trans.
:confuse:
