How much does that hinder the otherwise top condition vehicle. This would be my first Porsche. I've owned several (more than 5) BMW's since '88 andd am no longer charmed. Considered an M3 convertible, but concluded nothing will compare to my old '65 AC Cobra I drove when a bachelor in the 60's. I crave that performance again now that the kids are grown (finally) and I'm recently single again, and feel that a Porsche is my best hope.
The vehicle is listed at around $10K below Edmunds' "value" for its mileage in my zip code. I plan to take it to a Porsche dealer to have it checked out. What should that cost me?
Thanks for the guidance.
Where can I get a "quick study" on the recommendation to stay away from the '90-'92 C2s. I have been looking at one, and I like it. Sounds like I should keep walking, and find a '93-'97, right? Just would like to know 'why'.
Also, what's the 411 on tiptronic? Is it ok on later models, or too expensive to maintain? :confuse:
just so you know, I'm on the East Coast, so the time here is 7:29am (I'm not THAT anal!) :shades:
Clutch -- it's a dual mass flywheel and if the clutch doesn't feel very light and very smooth, you could be in for a major gut-busting repair of maybe $3,000 or so, maybe more.
Engine--if the car was built before June 1991 (look on left door jamb), it may develop oil leaks at the cylinder heads, requiring disassembly of the engine -- that should cost a measly $10,000 or more.
Sooooo, if it's a low miles car, it may not have had these modifications done.
Other stuff that's chronic is rather minor, like rear tail light lenses cracking regularly, and defective fuel tank sending units.
Yeah, you'd better have it checked out. That would cost about $150. You don't want a "manual" top on a car like this. That's mickey-mouse IMO.
What's the mileage on this car?
So the point of what I'm suggesting is that you have to really enjoy the 911 experience---if you don't find it unique or interesting, then go for the Boxster S, which is highly competent and fun, and every inch a Porsche---but IMHO more conventional than a 911.
I'd gladly take either one in a contest I won :P Personally I find the 911 more visceral, especially if I found a cherry 993.
The real reason I am looking for help is the dealer I purchased from (small exotic car dealer) told me that his wife dropped a soda on the floor and it blew out the DME (?) computer under the seat? I am drying out the water that is under the seat and I think the real reason is the drains under the trunk in front of the firewall were clogged and the water was runing in and down through the stearing column opening. I cleared drains and think I resolved the issue. I had to take the seat out and turn up the carpet to dry with a heater. AARGH)
I found out that they had to replace the computer under the seat as well as the one in the back somewhere and the key fob chip (or the whole key fob) The car runs as the chip matches the new computer just fine however the key fob will not operate and open the power locks. Additionally, I am told by the dealer that I can not replace the key which runs the engine and the doors etc. I fear losing a key and having to replace all of the parts mentioned above. BTW.. the dealer bought the new computers and matching chip (key fob) from a used porsche parts place in Oklahoma. I have the VIN number from the Porshce (2000 911) that the computer and DME key chip, came from but the dealer can stil not program the key to open the doors.
My concern is I want the key fob to open the doors and lock the car as well as get another working key with the chip. How can I do that? The dealer say there is no way to erase the codes in the replaced parts to reset to my car. They say I would need to replace those parts again and that seems crazy. They would be $1500. I do not want to replace what is working. I find it hard to believe that there is no master code to completely erase and reset the codes in the new (used replacement) computer under the seat and back of the car. Are there any suggestions as to where I might be able to go to to get this info and get this fixed? I live in IL and really want to get that key fob to work and get a replacement.
I hope that explains my needs for any experts to advise. I really look forward to hearing from anyone.
My email is dbetler@comcast.net if anyone has any info to share.
Thank you in advance.
Darryl
Any advice would be appreciated?
Jason
And if so, that's not a good thing, as Porsche do not like to sit there for years and years. Frozen calipers and galling of the cylinder walls (from accumulating moisture from non-use) are issues. So I would certainly have the engine tested using a Cylinder Leakdown Test (only that test, not a compression test) and also have the brake calipers checked.
A Carrera of this vintage is a long-lived car as a rule and does not require lots of maintenance for the type of car it is.
Presuming you got a very good to start with, I'd think about $1,500 a year in regular maintenance (exclusive of tires of course)---that is, a major service in the Spring and another in the Fall, should do it. Naturally, added to that might be the occasional repairs that come with a used car.
But really the whole thing hinges on a very thorough pre-sale inspection, and a further careful investigation of this low mileage claim---which again, is not an asset to reliability, even if it might be to value.
Autotrader.com has these 911's listed between $18,000 and $22,000. Why such a large discrepancy?
Also, if you're buying a 1991/911, stay away from production dates prior to June '91.
I don't understand all the hype that one needs PASM with 19" wheels. I have 19"/Pirelli Zeros, no PASM and the suspension is less harsh than that of my 2007 328i with sport package.
http://www.edmunds.com/porsche/panamera/2012/#fullreview
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Jeff
