DODGE DAKOTA QUAD CAB
Does anybody know of a screen protector to fit in front of the condenser? Also, does anybody know where the factory mounts a transmission oil cooler on a Dakota? There sure doesn't seem to be much room for one.
Thanks in advance,
Dusty
I will continue to look for the ones I want, and if I find them, I'll tell you where.
link
link
link
Since my last post, I've gotten exactly no where. The dealer flashed my computer yet again. But, the idle is still rough and the mileage has dropped to 11~12 mpg city and 13~14 hwy. (FYI: I've got a 4.7 L V8, auto tranny). Also, my transmission "pops" when shifting at low speeds. (It's so bad, I look in the mirror to see if I've been rear-ended).
The Service Manager supposedly spoke with the Zone Rep.; who supposedly said I should "learn to live with it" because there are no additional "flashes" AND they can't re-install the original "flash" settings. The Service Manager remarked that the Zone Rep had a poor attitude. But, he has no other advice for me.
At this point, I'll have to start the consumer complaint process and hopefully work my way to a "buy-back". If not, I'm prepared to sue under my State's Lemon Law. (FYI: I did not sign an arbitration agreement - otherwise, I'd be out of luck because it is so much more expensive than going to court. Dealers are real big on arbitration as a way to prevent lawsuits because they know the average consumer cannot pony-up the $2,500.00 arbitrator's fee just to start the process; (does not include his/her daily fees).
I don't want to do any of this. I really like my 2001 QC SLT+. It's the right size, right platform and looks great. I special ordered mine to get eveything I wanted (Plus Pkg., HD, etc.).
There's nothing else out there that I would want to drive: The Ram Quad is TOO big. The Tacoma Crewcab is TOO small and ... you get the picture.
** If anyone has any suggestions, please let me know. Otherwise, I'll keep you posted.
Does anyone have any information on how to kill the auto door locks for the '02 quad cab? Whether it be a fuse or anything that I can pull to stop them from continuously unlocking! The dealer hasn't called back with a solution or to tell me the parts are in, and I'm getting sick of pulling the battery cable!!!
Please help!
It really is driving me crazy....
Good luck, Dick
When you say "close to where the drivers seat belt is mounted", your talking the anchor mount on the floor correct? And the "sidewall" is the interior "B" pillar panel?
Were is the cheapest place to buy the service manual?
thanks,
Gordon
There is an order blank in the back of your owners manual to order the Service Manual. The cost is about $100 delivered. I consider it to be a bargain for the information it provides. For quicker service call 1-800-890-4038
Dick
Sometime back I rode in a '01 Dakota with the 4.7 engine and neither did I detect an idle problem, but the owner never commented on having any type of engine performance issue, including fuel consumption. That was at 22,000 miles or so.
After re-reading your post I'm begining to think the problem is something very basic and that the service personnel are unable to detect the cause. Sometimes the computer cannot be totally relied on to supply a fault code. I know of one case (a Toyota) where the computer had failed in such a way that it was masking a sensor failure, so it can happen.
Your service department may be giving valiant attempts but still overlooking something obvious. If it ran well at one time I don't see how a computer flash is going to resolve this issue, unless the computer has lost an algorithm.
Best of luck!
Dusty
Your transmission also sounds familiar as I have seen what your describing many times. What I have done and many of my friends with D/C trannys is by 20k or so miles the tranny will start to bump/shutter. I flushed my tranny with Amsoil Synth ATF and after a couple of thousand miles, drop the pan and change the filter and top off with Amsoil.
There is a warning out by the Filter Association (not sure of the proper name) that if you flush a tranny with a good ATF fluid, it can knock the crud loose and clog up the filter (Detergents I guess). They recommend running a short time after flush and then drop the pan and change the filter like I did.
There could also be another problem with your tranny and engine, but this is my experience, personal and through the grape vine.
Good luck,
Robert
Does anyone have any experience using one of the performance chips like the ones that Jet sells.
Does it really make much difference in performance?
What brands other than Jet are applicable?
Down side?
Is this where everyone hangs out now??
Thanks in advance, Robert
Our Toyota dealer has a poster in the service waiting area also proclaiming that some aftermarket filters are not as effective. Obviously, the point being to buy the "original equipment" (ie: Toyota) filter, but has anyone heard anything about this? Is there a problem in the industry with aftermarket filters?
Thanks in advance,
Dusty
"ATF+3® /ATF+4®
DaimlerChrysler has had their own ATF specifications for many years, but as of 1997, Chrysler owners' manuals no longer list DEXRON as an acceptable replacement. ATF+3 is a readily available mineral oil-based ATF that is suitable in any application calling for ATF PLUS® , ATF+2® , or a Type 7176® fluid. Vehicles manufactured after 1999 require ATF+4® , a synthetic-based ATF only available through DaimlerChrysler."
I have talked to one transmission shop that told me that Chrysler ATF+4 was used by them in Ford truck transmissions to cure torque converter shudder. Interestingly, a fellow worker told me the other day that his 2000 F150 had such a problem and that his Ford dealer installed Chrysler ATF!!!
The above seems to say that ATF+4 is a synthetic material, but I suspect that it also contains some sort of friction modifier. It also implies that ATF+4 is only available through Chrysler.
Dusty
REDLINE offers 5 different types of synthetic ATFs available. For the chrysler-approved lube, please review the RED LINE website and then search for their Synthetic C+ ATF
PS: This may sound like a sales-pitch.... but again... Those of you that are familiar with me know that I am just an educated, technical person that has researched the available lubes and settled on REDLINE.
Myself, I use NAPA/WIX filters. Extensive research on the oil filter study site plus my own disassembly of various oil filters has led me to this conclusion. While I cannot offer filter efficiency ratings and flow rates, I do know that WIX is one of the better filters out there.
I used a FRAM once on the Dakota and I was perturbed at the slight lifter noise on cold startup. Next change, I used a WIX filter. Stayed with same oil (at the time I was using Havoline) and presto, the lifter clatter at cold startup went away. Same thing on the Zuki....although there was an OEM filter on there and its constuction was nothing to brag about.
When I think back, I used Frams quite a bit in my early years and all my vehicles had a bit of lifter clatter on startup.
Pop QUIZ time! Why, on my Dodge Dart, 1975 model year with a slant six, did I have lifter clatter no matter what oil or filter I used?
Hint...its NOTHING to do with a mechanical defect.
There is a REASON why the orange FRAM filters seem to get a "bad rap" Once you see the CARDBOARD internal parts that disentegrate in hot oil... you may choose not to use them either.
Here is is again... the (now famous) OIL FILTER STUDY
Mopar switched to hydraulic lifters for the 1981 model year.
Yes, Fram was once a quality maker of filters but somewhere along the line, in an effort to produce more returns, corners were cut. I totally agree that cardboard has no proper place in an oil filter. I was aghast at the findings by Mr Kinzie so I cut one open myself. To say the least, his pics were stellar compared to the piss poor assembly and the cheapness of materials I found in mine. And a plastic anti drain valve....puleez!
BTW....Where did I buy it? Wal mart!
I've been involved in a number of testing and research studies, and there is one aspect of this one that is completely non-professional. Most authors of research (except in sociological research), while offering conclusions, make every effort to let the facts and evidence of the testing speak for itself, allowing the reader to draw her or his own conclusions. The research, if truly conducted effectively and in an unbiased manner, should be able to stand on its own. This author is clearly opinionated. He may think, and you may be convinced, that this is the result of his testing. But in reality his testing is not complete without actual flow and operational aspect testing. The 'apparent' quality of materials MAY NOT dictate or even influence actual fitness-of-purpose filter effectiveness.
His "please don't buy this filter' is patently unprofessional, in my opinion. He has done himself a disfavor, I think, by including these biasing remarks, even if he is ultimately correct in his conclusions.
Dusty
On the surface this gentlemen's evaluation seems too cursory. For example, the "plastic" bypass valve. Now to many when confronted with two devices, one of plastic another of metal, it might seem to some that the plastic item represents cheap. But plastic is a generic term for a broad range of material. His analysis does not really tell us what the material is. It is possible that a more flexible material in this application actually provides a better sealing function, and there are so many different types of plastics that it is non-revolutionary to find one that could perform this function better than metal.
Likewise, the other criticisms seem all aimed at mere component or assembly comparison. This is a simple and very incomplete way of determining oil filter effectivity and really doesn't give us a picture of performance -- simulated or otherwise -- when used with the engine application for which it was designed.
You know, after giving this some thought I seem to recall (and I could be wrong) that Consumers' Reports did a test of oil filters some years back and I think they determined that Fram filtered out more material 8 micron and smaller, than competitive products.
Dusty
I took one apart and saw exactly what was discussed on the web site.
Re-read the web site. The guy makes no claim to check flow rates, filtering capacity etc. He just took 'em apart and created a web site on his observations.
BTW.....somewhere there is a link to an email from a former allied signal engineer...read that and you might not want to use fram....ever.
Nonetheless, it aroused my curiosity and I did what probably anyone would do. I took a Fram apart and saw the whole deal.
For what its worth, an oil filter is too important for me to rely on shoddy workmanship and cheap materials. My engines deserve better.
......I have read the info that was referenced in post 1573. I realize he never made any evaluations about the actual effectiveness of the various filters. That's my point.
I could not find the "email" from the Allied-Signal person that was refered to in post 1573. The link to the originator's web-site doesn't work, either.
Dusty
I'm assuming that I'm missing something here.
Dusty
Does make it easy to know when the tank is filled completely for gas mileage checks. I guess I'm just have to get use to this.
Dusty
Dusty
A Slant-Six engine is not a vertical in-line six that has been canted in the engine bay. The cylinder inclination is with respect to the crankshaft centerline, or in other words, the oil pan boss. A cut-away diagram clearly shows that the engine was designed to be inclined. In addition, the Valiant/Dart series was in design for almost four years -- get this -- the same amount of time as the engine development!
Let me guess: this came from another Chrysler-Dodge hater, I'll bet!
Best regards,
Dusty
Romes
I haven't been keeping up to date on whats happening.
Update 12,000 + miles and except for defects in paint upon delivery my '02 QC 4.7,3.55lsd,5spd is doing great.
I'm running Chevron 87 octane with no idle problems, avg mpg 16-18 combo- freeway/city. 3" dyna max cat back exh. with KN filter and intake mod with fernco elbows and piece of stainless steel
3 1/2" "duct" instead of the abs.
Still running stock tires and wheels. Looking to change tires and wheels after the New Year.
Hope everyone had a great Thanksgiving Day !!!!
Time to read all the info that I've missed.
Lee
I'm changing oil soon and might as well put 1 on...I like the idea of putting a hose on it...stops the oil from running all over the suspension.
I THINK HE IS RIGHT!
ANYHOW, THAIS HIS 2 CENTS! BY THE WAY, BOOKITTY, I THOUGHT YOU DID ONE HELL OF A JOB ON YOUR SYSTEM. IF ANYTHING, IT GIVES YOU QUICK AND BETTER ACCESS TO WORK ON YOU ENGINE.
THANKS.
KINGQUAD1
Bookitty
You won't be sorry!! Love Mine!
Blue
is FARRRR better than any other on the market.
My dakota is like a whole different vehicle... instead of the rear end jumping around on road... it now sticks like glue... even under hard accelleration ;-)
The nose-dive during braking is almost gone too.
If you do not wish to spend the $$ for the IAS monotube shocks... consider their twin-tube design. It is less expensive but still contains the pantented RICOR IAS design.
Here are some links to order them from.
http://www.shockwarehouse.com/
http://www.shox.com/
trailer. This was before the truck was available with a turbocharger. Coupled to that, was the very small (for me) area with the clutch and brake pedals being so close, that my size 12EEE shoes were tangling. The rear seating area was smallish, and not too comfortable. When my wife mentioned that she saw an advertisement for a Dodge Dakota, and remembered how happy I had been with my 1995 Dodge Dakota with extended cab, V8 and five speed manual. I really didn't have to test drive the five
speed Dakota (none available on the ground), as it felt and drove like my 1995 Club Cab except for the automatic. In that I always choose an American product if possible, I ordered my Dakota truck and used a $500.00 certificate available from the Farm Bureau. I paid at the time, a little less than $100.00 over invoice less my certificate. I have the 4X4, 4.7 V8, 3.52 LSD, HD everything with skid plates, SLT package, tow package, rear slider and much more. I just love this truck! I am sorry that I cannot offer a true comparison regarding the Nissan turbocharger. version, because I never drove one. Hope that this is of some help. Also, much of the information that I gleaned was a direct benefit of subscribing to this site. There are very many knowledgeable and capable members, who can offer much insight and information. A great bunch.
Bookitty
I wanted a truck with enough room to carry 4 passengers and a full size ATV. One of the first trucks I looked at was the Frontier 4-door because I owned a Sentra that was the best car I'd ever owned and had a lot of confidence in Nissan products. But I have to echo much of Bookitty's comments. The Frontier, although adequately powered for daily use, was lacking in the pulling power I would ocassionally want. And although it had four doors, the rear seating is exceptionally limiting. I would not have been able to load my ATV onto the bed and have the tailgate up.
(Now, I couldn't load my ATV onto a Dakota Quad and get the tailgate up, either. This and the fact that the Frontier rear seating was not much larger than the Club Cab, is what made me consider the Dakota Club Cab version. Had the Frontier met both of these criteria, it might've been the one I'd be driving today.)
Other than exceptional durability and reliability, in my opinion the Frontier Quad falls way short competitively in most aspects. I did test drive a Dakota Quad. Even with the 3.9 V6 it felt snappier. It was definitely smoother and more comfortable. And from what I can tell the fuel consumption might be the same (check the EPA ratings of the two trucks).
I ended up buying a Dakota Club Cab 4x2 (4.7, auto) which has the room I need for intermittent use (two kids) and performs very nicely for my needs. The Club Cab version met my basic criteria and I just have to say that I liked the ride, handling, and refinement level of the Dakota better. In fact, even some full size trucks don't match the Dakota in this area, in my opinion. The Tacoma probably comes the closest overall.
Good luck on your decision. I know these aren't easy!
Dusty
