Bluetooth Technology
So now I'm using a 7290, the bulkier one with the full keyboard. Better for typing, but boy does it feel big. My wife says I'm talking into a calculator!
At least it still has Bluetooth.
I may get the new 8700 in a couple of weeks when that comes out for T-Mobile. Anyone use that yet?
-juice
But in Autoconnect mode it will only connect to the last phone that was connected even if both phones are in car before starting. If autoconnect is turned off, one has to go through menus to connect to a specific phone.
Why cann't they offer a choice at startup if bluetooth is in autoconnect mode?
Do other Bluetooth car work same way ?
No flip phones on the list! :confuse:
Anyone experienced a Sprint phone that works great for the 06TL? Thanks.
M
Thank you, Geff
"Whenever I press the HFL talk button to answer an incoming call, the system picks up the call but then immediately switches back to the audio system mode. The caller tells me it feels like I've placed them on hold. To "re-answer" the call, I'd have to press the talk button again, then press the end button. This will alow me to stay on the call. Quite an annoyance, really. I contacted Acura, and they indicated the voice-prompt mode doesn't work with the E815. The HFL system only works properly in the ringer mode, which is what I've done. I rather like the sexy female voice, though."
I tried both fixes and they both work. If course having the car set to ring rather than voice prompt is much simpler.
Hope it helps!
Sometimes it will just start working and pick up a call that comes in, but that is very rare.
Any help is appreciated in terms of other people's expereince or where to go to talk with someone that would know how to fix the problem if it can be fixed.
On a related note, where can a find a list of supported phones and services for the Sienna. I tried Letstalk.com but did not see anything too obvious.
John Simpson
HELP
I have a Bluetooth headset but have not set it up with this device yet, because I just got it and the backlight it defective so I'm replacing it.
Any how, I just looked and on the BBerry it's under Options, Bluetooth, click the Thumbwheel and then Enable Bluetooth. Click again, and choose Add Device.
That's as far as I can help you. At that point it looks for devices to pair up to, but mine isn't with me. Get your Bentley to the same state, i.e. looking for devices to pair up to.
For my headset, the PIN was 0000 from the factory, not sure about the Bentley, a dealer could probably tell you or maybe you can look it up. I'm wondering if they use Audi's MMI system? I'm not familiar with that, either.
-juice
I set up a headset for someone that has a PEBL, the headset's default password was 0000, the PEBL found it right away, and it worked.
-juice
Has anyone ever heard of this? Specific phones not being full featured with Uconnect?
With my 2006 Audi A6, there is a good explanation of setting up Bluetooth cellphones, starting on page 85 of the "Infortainment/MMI" manual -- including (top of page 86): "The Bluetooth PIN is 1234".
I just upgraded to Verizon Treo 700p (from 2+ year-old Treo 600). Here are steps I went through to "pair" the phone and the car:
Tapped "Bluetooth" on phone's "Favorite List" (shows up on phone's opening screen) but could also have gone through "Applications" to get to "Bluetooth".
Selected "on"
Left name of device as it was (my initials) designated by Palm software when I downloaded old info from computer to new phone.
Left "visibility" set to "hidden" (that appears to have nothing to do with Audi being able to detect phone; it seems to only mean that other bluetoothers in the vicinity won't pick up my phone's presence).
Tapped "Setup Devices" and on screen which then appears I tapped "Hands-free Setup".
On "Add Device" screen (after a few seconds) the Audi appeared and I tapped it's name. ("Show pick list" and the "Nearby devices" might have had to be tapped first).
Entered same passkey (1234).
"OK"
Car kept asking for "SIM Card," but phone had none. Gave up. Drive home.
Put in SIM Card I had at home. This might not have been necessary. I was making initial attempt in area where my cell phone is not at its best.
Next day, once I was in decent phone reception area, I turned on Treo 700p. I pressed Telephone button on Audi. Car MMI screen showed that the car system was picking up presence of "Verizon" phone.
First tried voice entry of my home phone (digit by digit) and successfully called home.
Didn't notice if "Phonebook" from Treo had downloaded to car and was a lighted-up selectable from "Memory" menu on car screen. Later, did notice it was and that it had my list of "Favorite" phone numbers. Selected one and called it and talked without problem. Received calls fine all day.
Noticed that I have to turn Treo on (you know, if you have one, it's sort of "on" but screen is blank. Turned it on, hit middle button to keep it on.
This seems critical. Treo, as you know, turns off, if not used. So, it was turned on and car showed "Phonebook" was lit up and available to be selected. But I didn't do anything and Treo turned off and car said it didn't find any phone. Turned Treo on, hit telephone button on car and again car and phone said hello.
Made a call. Now Treo stayed on because it was doing something (connecting with car bluetooth system).
Happiness
Tune-in to your local station - http://www.autoscoop.com/index_map.php or go to the AutoScoop site or listen live on the web https://www.radiomat.com/register.php?action=register&station=KLSXFM
The show is from 8am-1pm EST. Call-in toll-free at 1-877-444-1994 to sound-off about this issue on the radio. Be sure and mention your Forums username!
Google "MDX Nokia 6120i" and see if any tips come up. Hopefully someone else has that exact combination. Did anyone in the Acura threads speak up?
No reply on Acura yet. Good thought on the Google. Will go try that now. You are SOOOOO right that they use BT as a selling point. Once you are done buying they tell you it doesn't work with every BT enabled cell phone AND, as we have learned, it doesn't work perfectly at all. For example, with Acura BT one can NOT dial from their phone. You have to use the Acura BT voice command. Try doing that with a 2 and 4 year old in the car. Not easy! Oh well... live and learn. Thanks!
Your topic should be Brand and Trademark violations, because that is what this is all about: No interoperability or support for it and you should not get the trademark. Please feel free to pass this along to others who may have complaints too as well as any media that have an interest in the story.
What is your reasoning here? Many phones are not properly compliant with Bluetooth standards or have bugs in their software. If they don't work, they don't work. Also, there are different versions of Bluetooth and even the standard itself has various gray areas that leads to implementation differences.
It's not "hostile" to users of Bluetooth phones. It's trying to deal with the real world. Some phones work and some phones don't.
Now, your particular problem of the whole system freezing up is not a Bluetooth issue. A non-supported phone no matter what it does should not cause your entire system to freeze up. That's a software quality issue.
Have the same experience with Mercedes-Benz. We bought 3 luxury SUVs from them. They list "recommended phones" for their "Mercedes-Benz Bluetooth(R) (SAP) Telephone Module, Version 2" in official materials for the Czech Republic: 13 of 20 are NOKIAs, remaining 7 models just to cover-up Mercedes' NOKIA preference as those are out of reality: "VERTU" not sold at all in CZE afaik and, "SIEMENS" which is terminated brand as everybody in the biz knows.
Mercedes representatives end up with indistinct statements or irrelevant excuses and I suspect them that they've explicitly (per-customer) blocked SONY ERICSSONs specificaly (car I've tested doesn't operate with any high-end SE model, including Z610i, P990i, etc.)
It is likely that Mercedes is manipulating its customers and limits their "Bluetooth(R)" support artificially.
I've found the form before your article and sent complaint there. But I wonder if you have identified particular article in Bluetooth member agreements / materials ? Do you have some further tips or experience?
I'm attaching corresponding Mercedes-Benz material in English: http://resource.empyreum.net/temporary/Cradles_1207_en.pdf
I'm about to become an activist in this as well :-) Any message from you to my e-mail karel.panek vortex empyreum.com will be appreciated!
Karel
