Try posting your question in the "Ask the Community" box on the lower right-hand side of this screen too. It's a great place to get a quick answer to a quick question.
In looking at the trunk, it appears that this is a trim piece that can be removed and replaced...( This is the large plastic piece that has PONTIAC on it and also has some red reflectors on it.)
The problem I am having is trying to find this part because I do not have NAME for it. Any one have a name and or a place to buy a replacement.
Thanks all.
I own a 1996 Pontiac Sunfire 2.2L and it has been a nightmare since I bought it from my neighbour. We knew it needed some work, but we didn't think this much. I'm at the point of deciding if it's worth sinking more money into it, or throwing in the towel
When we got the Sunfire, she was running a little rough. Through changing what we knew had to be changed and what came up when we used the code reader, we're still having problems.
So far, we have changed the intake manifold gasket, new plugs and wires, the Crankpositioning Sensor, the MAP Sensor, fuel pump (second hand), fuel filter, muffler (was backfiring and we blew a hole in the muffler so it looked like it had a pacman mouth! LOL). She was still sounding rough and we discovered that the fuel injector for the 4th cylinder needed to be replaced.
We did that and now the car keeps flooding itself. We discovered on the weekend that there was ALOT of gas in the oil pan and my hubby drained all that, checked all connections, checked alot of plugs & sensors for corrosion or damage and things seemed fine. He's obviously changed the oil and filter.
Can anyone help me??? Any ideas of what the heck is going on with this piece of junk?
Thank you!!
:confuse:
How do I remove the front seat headrest?
I haven't taken this back to get fixed b/c it sounds costly. Anyone have an idea of how much it would cost?
I just noticed the second problem this morning. I have the daylight running lamps on my 2002 Pontiac Sunfire. They come on when I put the car in reverse or drive. This morning, the icon came on and then flashed a few times (and made a sound, like when you're turn signal is being used) and then went away and the "service" icon came on my dashboard.
I looked in my driver's manual and it says, "a flashing DRL light indicates a possible burned-out headlamp, or that the vehicle may need service to repair a stuck DRL relay."
Does anyone know how to know which one it is? And if it's a stuck DRL relay, how much would that be?
What could be causing this? anyone out there have the same problem and fix it simply? I cant afford to take this car to mechanic for diagnosis and unecessary repairs. PLEASE HELP!!! ASAP!!!
any help would be nice
plz email me
palekid_04@hotmail.com
For starters, I put 17" Momo rims w/Tsunami N2 tires, a sport (adjustable) strut and coilover package from Mantapart.com, strut bars, beefier front sway, tower bracer (front and back). I've got cold air intake on the engine, 58mm throttle body.
Going to put exhaust/cat convert/header package on it, maybe do a port and polished head, and call it a day. I'll be looking for advice and help from any of you guys in the community.
I won't be doing any sort of body kit mods or any of that garbage, I just want a zippy everyday driver, a sleeper whip.
I recently took some pictures, I'll edit and post them soon on my myspace page.
hasta luego,
andy
I have very weak accelaration.
I have changed
Ignition control module
Plugs and wires
coil packs
throttle sensor 4 times
temp sensor
Can anyone plz help
Due to using my reserve key in the ignition, a problem took place. Its result is the the light is on all the time in spite of turning the ignition switch off. Is that mean i have to replace the ignition module ?
I need HELP and an ESTIMATE , Please
Nice to know my old car is still getting compliments.
