Diesel Questions and Problems in General (non specific makes)
Generally, on modern diesel the injectors are controlled electronically by a direct injection module. I think the only way to diagnose this is with a scan tool.
So can you momentarily start the engine with a squirt of starting fluid? --use very sparingly on a diesel---I'm only asking so that you can double-check your original diagnosis--it should kick right off with starter fluid.
If it doesn't start, you might check your glow plug circuit.
If in fact you aren't overheating, then you might have a clogged radiator. Have you ever put a stop-leak product in it? That'll do it.
