As an aside I also found that my remote hanging from the key ring knocked against the dash. I solved it by buying a two dollar ring/coupling that allows me to release the key quickly and I put the remote in my pocket.
Has anyone noticed how many Hyundai's are out there? It seems that every time I turn around I see another, than another, than another, all the models. :shades:
When I went to pick up my Azera, the wind deflector was not installed -- which was what I wanted. But after it was washed and detailed, I saw the service tech climbing up there and -- sure enough -- he was installing the deflector. When he saw me coming he was just wiping some prints off of it.
"Got the deflector on for you, sir," he said.
"I'm sorry," I said. "Will you remove it, please?"
"Excuse me?"
"I don't want it. It looks tacky and it makes wind noise at high speeds," I explained.
The manager walked up as I was saying this and he was nodding his head. "I agree fully," he said. "It probably the only part on the car I don't like."
So far, the Azera has run very well. I updated insurance today and the leasing terms requires higher coverage than on my last car, so I'm paying slightly higher premiums. But I figured I probably would.
AMICA Insurance: about $800/yr.
Haven't quite figured out what gasoline would be best to use yet. The manual lists 87 octane as the most efficient for the engine, yet regular here in Utah is 85 octane. When I asked the sales rep if mid-grade 87 octane would be better, he had no idea. I'm not sure about this one yet.
I'm getting windows tinted tomorrow. Most recommend 20% (light passage)on the rear and 50% (legal darkness limit in Utah) on the front. I don't know if I want to go that dark. It's already hard to see out back at night. Any suggestions? I was thinking 30% rear and 60% front to let a little more light through, but I have NO experience at all with tinting. Also, I'm nervous putting tint over the rear-heating coils on the back window. Should I worry?
My reasons for tinting are that it would improve the looks of the vehicle and, also, it would reduce the sun heat on the black interior in the summer. But I'm still nervous.
Does tinting increase the liklihood of police attention?
Enough for now. Great car so far. Quite an upgrade over my 2000 Passat, but It'll take me a while to get used to the larger size. Passat was a little more "nimble."
The trunk with the rear seats folded down is big enough to sleep in. a wheel chair or two should fit into the trunk without a problem, less of course lifting it over the bumper is a problem :confuse:
Go to a dealer, give it a try.
I live in FL, and my windows are tinted as dark as legally possible and that's the only way I would go.
The rear view mirror self darkens so if you leave the shade up at night or down it will have impact on seeing out the back, it will take time to adjust to but you can do it.
Reply | E-mail Msg
Replying to: bomar60 (Jan 12, 2006 4:07 pm)
If you don't want anyone seeing who is in your car, then get the darkest film you can get. But safety will be compromised when driving.
Winding mountain road at night... you can't see out your side window because of the dark tint. I had to roll mine down despite the cold and mine are not even very dark. Also, any time at night vision is severely reduced when looking through the dark tint.
Your standard window glass is tinted already, reducing light transmission by about 20% or so. Add film and you are really cutting down your vision, maybe way too much.
The only reason I have medium dark tint on my car is because it was already on it when I bought the car. Otherwise, I would have taken it to a place and had the highest light transmission, all metal (except for the polyester film of course), high heat rejection film installed.
I wish dealers would not install it before the sale. It is time consuming and/or expensive to remove it. Removal costs more than installation.
Check some window film websites.
My dealer says mud guards aren't yet available, but I've ordered them from Hyundaiparts.net (I think) and they're on the way. I'm truly enjoying this car, and I too have started to see one or two more each day on the road here in Albuquerque. That advertising campaign can't be cheap, good thing it's working! BTW mine is sage green and the metalized film used on the windows actually looks remarkably close in hue to the paint color. It's an interesting look.
'Little help?
Also, if you have ever tried (I have) to remove OLD film after baking in the desert sun for a few years, you'll find it VERY difficult to remove. The bond becomes much stronger after baking for so long. And the only solvent I found which would remove the residue after that time, was lacquer thinner. And that is very damaging to upholstery and plastic and painted surfaces you might slop it onto. Old film is nasty stuff to remove.
That said, maybe some brands are easier to remove than others. I've removed several, and none were simple.
If you had a car or truck with the defogger wires actually inside the glass, I'm interested. What was the year, make and model of the vehicle?
Window tint is a polymer film and adhesion to glass is through water and polymer interface adhered by squeegee pressure. Simply stated, the water, polymer interface bonds the material to glass. Heat guns and/or hair dryers are used to shrink and remove 'small wrinkles and ghosts' and loosen tint from windows.
Misting water onto the window above the tint you have started to peel will help the heat and water to loosen the film.
Or you can call your local tint shop and ask how they do it, they might tell you.
In trucks, the glass which is to be tinted is almost always flat, nearly vertical and is usually a simple rectangle in shape too. Cars, on the other hand, have back glass which is acutely angled with compound curves and irregular shapes. The side glass too is often irregularly shaped and may have compound curves.
Also, the hottest rays of the sun strike the back glass of cars at close to right angles during mid-day. This causes a greater build up of heat in the film tinted glass which tends to bake it on and harden the film. In a truck, because the glass is nearly vertical, it never really gets the hot rays hitting it at anything near a right angle. A truck's film tinted glass does not get so hot as a car's back glass.
I looked, and - yep - both my Lexus and her Infiniti have the antenna embedded in the window, but the defroster is a thin grid of lines on the inside of the glass.
My bad folks! I remember this because after about five years the non factory-installed film began to 'craze' on the front windows and I had to remove it because it became difficult to see through after sitting in the 100^ heat one summer day here in South Carolina. As others have commented, heat helps, but except for the rear window, I would just use a scaper to remove the stuff - it's elusive at best depending on the manufacturer I suppose, but I found water, Windex, alcohol and ammonia all were totally useless in releasing the bond...
Getting the film itself off is just half the problem: in my case it was two-layers and there was a sticky mess underneath left by the glue or whatever it is that makes it stick!
Please share more details. Is the aftermarket wood dash you had installed, real or fake wood? How does it fit in with the existing fake wood in the Azera? Where did you purchase the kit? What was the price of the kit and install? Also what was the price of the mud guards and install? Are the mud gaurds black or color coded to the car? I know this is a lot of questions, but these two things are exactly the same things I'd be interested in doing.
Thanks for whatever help you can give.
cn
If so,where, and at what price?
No hard feelings folks but the Sonata appears to be a better value than the Azera. There is nothing in the Azera that stands out to make you feel that your money was well spent. Not bashing, just telling it like it is!
I also agree that the Sonata is a better deal than the Azera. But I would also contend that Sonata is a far better deal than the Avalon. I would also go so far as to say that the Azera is a better deal (on paper) than the Avalon.
I don't exactly know what your point in your post was about. If you're talking about bang for the buck then Sonata wins. If you're talking about refinement, prestige, and not considering your budget, why stop with a Toyota? There are far better vehicles that could separate you from the bunch.
my 2cents.
The mud guards I found at HyundaiParts.net (with freight, $48 and some change, front and rears) are black molded plastic and come with hardware. I'm sure the wheels will have to be removed to install, as there's little clearance, but that's the only thing that you'd have to grunt about. I'm liking the dash kit more every day. I may try to post a photo of the dash. It IS very ES330-like. Keep those cards and letters comin' in, folks!
and no way it's a 'big step' down. azera hold its own very well compared to avalon. hyundai is not toyota yet, but it's getting there.
Consumer reports has indicated in its current issue by ratings etc. that the new Avalon is THE least "reliable" Toyota car products. It has an "average" rating. (albeit they still "recommend" it based on its class and attributes) My guess is that the Azera will exceed the Avalon's initial and long-run reliability and have a lower cost of ownership (EXCLUDING DEPRECIATION) given the number of so-far positive experiences being shared on this board and Hyundai's focus on initial and sustained quality. Also, the Avalon does not come (IN ANY MODEL) with an electrically adjustable tilt/telescope steering wheel, nor does it have an EZ out feature which are important points to certain buyers. Don't know if it has fold-down rear seats. Each buyer has their own criteria and I would not "slam" an Avalon because someone may like its styling or feel that the interior design and touches are nicer (taste...since they have the same plastic wood...) or because you CAN get a Nav and Blue Tooth on the Avalon. Personally, I don't think one would go seriously astray with either car. It will be interesting to see what Consumer's full review is in the future, but their summary review in the auto issue seems quite upbeat.
Windows were tinted yesterday -- 20% on rear and 50% on front (legal limit). Looks good.
I looked at the Avalon before purchasing the Azera. There were many common features. The Avalon's engine appeared stronger and more efficient. But, personally, I just didn't like the styling. In fact, that and the price knocked the Avalon out. There were a few other factors as well. I read reports of some reliability problems. Owners generally were rating the Avalon lower than previous models and lower than new Azera owners.
The Azera for me had better styling. The features for the price were very good. No, it's not the fastest or most fuel efficient car in its class, but it's competitive. The other features, however, make up for that slight shortcoming.
I'd admit that the Avalon and Azera are very close. But I'm glad I went with the Azera. Certainly somebody can say that the Azera is a step down over the Avalon, but that is based upon subjective measures and that's fine. To each his own. For me, the Azera fits the bill.
BTW, the splashguards look like they only come in black. See link.
Splash Guards
In case you're interested, I have an Azera sunroof wind deflector for sale for only $45 plus shipping. (yes, this is a joke).
There's no button that adjusts the brightness?
I also found my Accord's instrument panel was too bright at night. So I adjusted it to the desired setting. It isn't glaring anymore.
And they had an Azera SE! In purple! Now, I don't know if they did this on purpose because this is Minnesota Vikings country, but purple is not the color I would choose for this car. It was quite, uh, striking, however. (Maybe they had the SE to show off because no one would buy it!) The cloth interior was light tan and had an interesting texture. At first sight I thought it looked cheap. Then I saw that it had a suede-like texture, almost like a microfiber, and it had a perforated pattern in the centers of the cushions. It also seemed very durable. Otherwise the interior looked about the same as the Limited except there is no woodgrain on the door handles.
One thing I noticed is that the rear seat didn't seem to have much if any more legroom than the Sonata. So if you are choosing between the Sonata and the Azera for passenger room, that may not be the best reason.
The car had five-spoke alloys that were not as rich looking as the Limited's alloys but were OK and a little sportier-looking than those on the Limited.
The nicest thing about the car was its price. There were no options except mats (strange that there should be a charge for floormats on a car like this, but I digress). The list price was just over $25k including destination. With a rebate or two and a little discounting, this is in the same ballpark as an Accord EX 4-cylinder or an Accord LX V6, or a Camry LE V6. That is, it's a lot of car for the money.
Did you get a good look at the 07 Santa Fe? I am interested in looking at it when it comes out and would like to know what you might think of it?
But this being the Azera discussion, "that's all I have to say about that."
I sat in the back of an Azera when looking at it a while back, I seem to have fit rather comfortable in it. I will admit that i never sat in the back of the Sonata. Now I am around 6 foot 4 and with the Azeras front seat in a comfortable position for me I sat in the back with ease.
Azera, of course, is even more spacious and comfortable
Head room (in.) front/rear
S 40.1/38.2
A 40.2/38.2 +/
D 00.1/00.0
Leg room (in.) front/rear
S 43.7/37.4
A 43.7/38.2 /+
D 00.0/00.8
Shoulder room (in.) front/rear
S 57.4/56.9
A 57.9/57.1 +/+
D 00.5/00.2
Hip room (in.) front/rear
S 55.5/55.3
A 55.5/55.1 /-
D 00.0/00.2
Cargo volume (cu. ft.) (trunk)
S 16.3
A 16.6 +
D 00.3
Passenger volume (cu. ft.)
S 105.4
A 106.9 +
D 001.5
EPA size classification
S large car
A large car
Honestly, I think interior dimensions for the S or A is a wash, but, ease of access to rear seats (getting in and out) for those who care, and if you compare these numbers to the other models, Avalon, Acura, etc., Azera wins hands down, the others are smaller.
Hope this helps resolve those questions.
