The salesperson I bought my Prius and HH from knew absolutely nothing about the cars he sold me, but at least he was very aware of his own shortcomings and didn't BS me. Some salespeople are so proud that they will fabricate information on the spot if they don't know it.
I did come across some extremely knowledgeable salespeople when shopping for my hybrids, but did not end up purchasing from them because they couldn't offer me the best price.
My record is THIRTY clicks after the pump clicks off and I have NEVER overflowed the tank one drop.
Weird.....
I think you're a little confused. You don't have a diesel engine, so no, you can't use diesel or biodiesel. You can use gasoline and gasoline containing up to 15% ethanol, or E15. Regular grade gas is best, but be aware also in the manual Toyota states "recommended use of Premium grade gasoline". They are referring to the "enhanced" gasoline that several auto companies and oil companies have come out with - see Shell commercials for info on this. They are not referring to the octane rating. 85 or 87 octane fuel is just fine in the Prius.
I know the ethanol change is better for the environment etc., but it's too bad it has to come at the expense of the better gas mileage that the Prius can produce on regular gasoline.
What happens is ethyl alcohol can absorb water, either liquid or water vapour from the air. This allows the water to "dissolve" in the gasoline.
The good part of this is it allows the car to "burn" any water that gets into the tank (reasonable quantities of course). It also acts like "gas line antifreeze", which is usually isopropyl alcohol.
The bad part of this is the water can contain oxygen, which can corrode the underground fuel tank. This takes years. BUT, if the underground fuel tank was already perforated by corrosion, then groundwater can get into the tank. A lot of it. This "extra" water promotes the growth of bacteria that make a living of turning iron into iron oxide. So you get fuel with rust dust, chunks of rusted iron, and water in it. Lots of people blame this on the ethanol. It's really the fault of the cheap fuel station owner, not properly maintaining the underground tank system. They will put off replacing the tank, thinking the fuel floats on top of the water, so there's no problem. Then they get caught when the fuel leaks into the ground.
So yes, if you fuel up from one of these effected tanks, you will be changing fuel line filters. But you would also even if you were using "normal" non-ethanol fuel. It just takes a few months longer for those underground tanks to fail.
I fuel up from newer stations only. Ones that get a lot of traffic. That usually ensures the fuel is clean.
When I am at a stop light is it better to depress the break fully (so no energy is flowing, or leave it only partly pressed down (so that energy still flows from the electric engine although the car is not moving)? I have been depressing the break fully, and I was wondering if it would ease the initial acceleration from 0 (which I always do super slowly and get a few honks) which takes a lot of gas. Range was one of my motiviating factors for buying a Prius, and thus far its been an utter disappointment
Use full brake when stopped. There is only about 2 Amps fed from the battery if you don't press fully, but it's still wasted energy. Also, use "D", not "B".
Accelerate normally from lights. It's the slowing down where you can save fuel. Try to anticipate the light and slow a long way before you get there. Don't worry about the nuts who will pull around you so they can wait at the light before you get there. Just keep telling yourself they will be the first at the accident! Once you get up to speed try to "feather" the throttle to just maintain your speed. That will allow the car to save you some fuel (it may even shut down the engine from time to time once it has reached full warmup).
Make sure you have lots of air in your tires. Most of us put in more than the door sticker calls for. I use 40 PSI front and 38 PSI rear. This actually also improves the tire to road traction, yet decreases drag. Check the tires at least once a month.
Be patient. It takes most people a few months to learn how to drive economically. Use your MFD (multifunction display) to help you to learn what actions save fuel.
Thanks for confirming my thoughts on the stop light braking. I guess I'll just have to wait until it warms up a bit before I'll see decent mileage on my commute.
Its good to know you are getting a 50% boost in MPG during the summer. Gives me hope I might get a little better mileage in the summer at least. Where do they get 48 city / 45 highway from anyhow? I can't comprehend how anyone could be getting better mileage in the city given the disparity I'm seeing?
sc
As for MFD accuracy, each car seems to be a little different. My car seems to read a little low on mileage most of the time. However, it's difficult to tell because you can't consistently fill the fuel tank each time, so your checks on mileage are not consistent. Others have reported the MFD reading to be about 10% optimistic. Isn't that why they say "YMMV"?
I also noted that the engine will frequently turn on (after engine warm-up) while I'm going down hill with the break applied for the soul purpose of charging the battery once it reaches blue. This happens at around 60-70% of total battery capacity. Is this just Toyota being obnoxiously conservative again? I mean, I'd rather let the battery use a bit more energy. If I do hit the highway it ramps up for full green pretty quick anyhow. Once it hits blue, it doesn't matter how I drive or at what speed, the gas engine turns on an frequently does nothing more then charge the battery...
I just bought a Prius two weeks ago. I have to say I've been disappointed with the mileage so far. But I like the car. By my own calculations (first tank) I'm averaging about 33. I live in Dallas. In the morning's it's a bit cold now so I have noticed gas mileage is lower than in the evening, where I come out from an underground garage at work (usually close to 60 degrees). So now I know. My commute is 15 miles, 1st mile local, next 12 highway, next 2 local.
pathstar1:
1) My engine charges when it is high blue also. Hate it.
2) Never have hit full green yet
3) I have confirmed coasting always helps, even when the engine is cold. When the engine is warm 99.9 on the display is very possible (I turned the display off after realizing the readings were not accurate. Also too distracting.)
4) I do need to check my air pressure (thanks to someone who mentioned it above) and I will hold the brake down at lights from now on.
5) Today after going to 1 bar I added 3.3 gallons ($10) and the bars suddenly jumped to 6. Still very puzzled by the display.
6) I did accelerate suddenly for a bit, re-read the manual said it was a no-no. Stopped that.
7) My MFD is telling me 41.5, but it did get reset 20 miles ago. Currently I'm at 380 miles. Will let everyone know what I average when I fill up later this evening.
Nice forum. Thanks for the advice.
newpriusowner
ces, good advice. I'm not old enough to know that (this is my first car) so I want to enjoy every aspect of it.
newpriusowner
1. The engine runs to warm up the cat. or to keep the cat warm, which must be kept quite warm to function properly. This is "job 1" for a Prius - keep emissions very low.
2. The engine runs to keep itself warm, so it can stay in the "stage 4" mode, where it can shut off the engine if it doesn't need it. It sounds funny that it has to run the ICE so it can shut it off, but there it is. In the summer this is not an issue.
3. The engine will run if the coolant drops below about 63C if you have the heater on.
4. -IF- the traction battery gets low in charge (below 40%) the engine runs to charge it back up to around 60% charge. The battery is run from an absolute low of about 30%, but usually 40%, to a high of 80% charge. This is to ensure the battery will last a long time. Taking the battery below or above these "setpoints" will increase the chances of fully draining or over charging individual cells, which would damage them. Note that these percentages are not the full green bar/empty red bar indications of the SOC indicator. Those take the set points into account, so full green is actually about 80% charge, and one or no red bars is actually 30-40% charge.
Also keep in mind -you- don't actually control this, the car does. You CAN "influence" the SOC as well as when the engine runs. If you use "Climate control" and leave it in "auto", when you want the engine to not run turn it off on the steering wheel. Then, if you take off from a light turn it back on again. I personally don't bother, but you can slightly improve your mileage by doing this. I'd rather have non-misted windows and be nice and warm.
Thanks for the info.
I definitely didn't know the battery stays in a range of 40-80%. This makes sense from an engineering standpoint. I don't leave my climate control on auto usually.
What's SOC stand for by the way? Also what are the 4 stages the Prius goes through? Which stage is the best?
Learning and confused newpriusowner
I did a similar test on the streets of NYC where I used to live and work. Going across town from stop light to stop light to stop light I was only able to achieve about 35-40 mpg, this with a fully warmed up vehicle. However going south along one of the major Avenues at a constant 25 mph I was able to achieve 70-80 mpg!!!!!! Same trip, same vehicle, same city, same everything excluding the stops.
This is one of the few unknown limitations on driving no matter the vehicle. A good solution would be to replan your route if possible to avoid the stops.
***65,000 mi on my 2005 ( nowhere near carbot's 2004 ) with a calculated fuel economy of 47.9 mpg ( 2.09 gpc ) as per GH database.
Regarding the fuel capacity questions, dont worry. I'm pretty sure that no one explained to you that you have two gas tanks in your Prius???? Huh?
Actually in order to reduce/eliminate evaporative emissions there is a fuel bladder inside your tank. When the vehicle is new the bladder is still stiff and not expanded to its full capacity. This is doubly true during cold weather when the bladder might be stiffer than normal in the cold AMs. As the weater warms up and the bladder breaks in you will find that as you get down to one bar you will put in about 9.0-9.5 gal when the last bar begins flashing. This is intentional, not only with the Prius but with all Toyota's ( e.g. the light on the Camry will come on when you've used about 16 o/o 18.5 gal ).
As carbot noted you can drive a good 50 mi safely before you must refill.
Funny, I looked up -again- the document on the warm up stages, and it appears there are actually five. It's complex and appears at:
http://www.techno-fandom.org/~hobbit/cars/five-stages.txt
These are enthusiast named states of operation. I don't believe Toyota uses this description.
Note that the "EV" (electric vehicle) switch is not installed in the North American models, though the programming to operate the car using it is. If you do want to install this switch, you can purchase a "stock" Japanese one. You will void your battery warranty though. What this switch does is extend the parameters for electric only operation. The car will still start the engine and use it if it needs to.
Stage 4 is the preferred one to be in, as the car is fully warmed up and will have the best chance of getting good mileage.
sc
So don't get mad at anyone but yourself if you run out. The car gives you lots of warning.
I must be of Swiss heritage. I fill up after the car gets below 1/2 tank on the gauge.
Could you please explain to me what the various stages of the ICE are? You mentioned Stage 4 mode to shut the engine off if not required.
Also, should you normally be able to show a battery full charge (all bars)? I haven't seen that happen even once on mine. The best I can get is 1 bar away and only for about 2-3 minutes. However,I do need to bring it back to the dealer as when I'm coasting the blue arrows go from the tires to the motor to the battery, but it doesn't change color when braking. (I test drove another one that does change color under braking and talking to the dealer on the phone they said the other 08's change color also.)
Anyone out there that does alot of highway driving (70% at 70-75mph) that could tell me what kind of MPG they are getting would be much appreciated.
Thank you all.
Lifetime over 65000 miles I'm at 47.9 mpg....but here are the caveats....from a post that I made in the Camry hybrid forum last year here
Factors affecting your FE ( and everyone else's also, btw ) in decending order of importance...
1) Towing anything is a huge penalty possibly as much as a 50% reduction in FE
2) Lots of weight in the vehicle, passengers cargo etc. ( EPA tests are done empty ) deduct up to 20% from your 'Norm'
3) Short trips under 10 min - deduct 20% from your 'Norm'
4) Snow, Rain, sleet - deduct 15%
5) Strong head wind - deduct 10%
6) Cold weather - deduct 5 - 10%
7) High speed driving 0ver 70 mph - deduct 5 - 10%
8) Many starts from a dead stop ( going from stop sign to stop sign to stop sign ) - deduct 5 - 10%
9) Terrain - fortunately 'what goes up..' usually this balances out on a RT
10) Winter fuel - deduct 2 - 5%
11) Low tire pressure - ? How low
In your type of driving you probably won't run into a lot of these like many starts and stops and towing and short trips. But cold weather, wind and slippery surfaces will have a huge cumulative effect of as much as maybe 10-25% reduction from your best results. Pathstar1 who lives in CA would be able to give you a better perspective on these factors.
Afriend who posts here also is at 175,000+ in just over 4 yrs but in the Middle Atlantic region where it's milder. I believe that lifetime he's around 47 mpg also.
Many Prius owners have posted they have only seen green bars after a few months. It -may- take the car that long to be sure of the full capacity of the battery, self calibration so to speak, or it -may- be (my choice) that the NiMH battery needs some charge/discharge before it begins to work fully. At any rate, I didn't see -any- green bars until 2 months after purchase. Usually you won't reach full green unless you descend a long hill, such as a mountain pass, though it is possible if you are really economical in the city. You won't see green on level highway, or at least I don't. The car tries to keep the SOC (state of charge) at about 60%, blue bars. I doubt there is anything wrong with your car.
Once the car is nice and warm, you can get up to 50 MPG on the highway, but that's a summer figure. The faster you go, the worse the mileage. You probably loose 2 MPG to the ethanol in the fuel, another 2 MPG to winter added friction (oil viscosity and stiffer tires). Then there is added loss from heavy winter winds, and snow pushing. Be aware there is a breakin period during which you will not achieve the good mileage figures. This includes breaking in the tires. It seems to take 2000 - 5000 mi. You should be able to achieve 45 MPG in the summer and 40 MPG in the winter with no problem, once broken in. Many do better with practice. The winter warm-up cycle is very hard on mileage. I notice that once my car is fully warm, in winter, it starts to get nearly the same mileage as it did in the summer, but the average really suffers. My summer average, once I learned and the car was broken in was getting up around 53 MPG US. Right now it's averaging around 40 MPG! City only in winter.
However the reason for the E10 addition has nothing to do with the enviornment it only has to do with stretching out the petro-fuel supply by 10%.
2) rule of thumb: each 100 pounds of added weight reduces impact by 1% (depends on car, of course). So a Prius at full capacity--850 pounds would get about 7% worse mileage than a Prius with a 150 pound driver alone. Ex: 46.5 mpg instead of 50 mpg.
7) rule of thumb: each 10 mph faster costs 15% in mpg. This depends on the car. Some cars start paying the penalty at 35mph. Others at 55mph. From my experience my Prius going 55mph gets mid-50s mpg and going 70mph gets mid 40smpg--about 20% difference. Going 80mph will drop your mpg near 40.
9) Hilly terrain will cost you in mpg compared to flat because there are inefficiencies as the transmission finds the sweet spot and due to braking (the regen brakes don't recover all the energy) and high revving (less efficient) on acceleration.
The high-mpg tips:
limit braking, as possible
drive the speed limit
mind the tire pressure
limit short trips (combine errands)
maintain steady speed, as possible
don't tow (voids the warranty!)
use car carriers judiciously (a Prius with a carrier still beats a minivan)
winter in Florida
Talked to a very knowledgable service guy about the battery bars. As the car goes through break-in, it will find the high battery levels and then find the lower battery levels (no more worring about engine charging at 6 bars all the time). After about 10k miles, it should be going through the full programmed range for the battery (and FE will improve also). He also mentioned many of the same items to watch for FE changes as read on this sight. He has one customer that drives the same way, same route all the time and can get pretty close to knowing the outside temp based on his FE display. Also warned about a guy who ran out of gas on the blinking light issue and drove on battery to the gas station. He fully drained his batteries and wound up buying a new battery for about $5k. He also has a customer with 200k on the orignal brake pads.
I did reach full 8 bars on the battery today (have 1260 miles on now) and am getting better mileage by being able to stay in Electric longer when coming of the highway.
Just one side note: My 04 Explorer gets 18mpg avg in the summer and 15-16mpg avg in the winter driving the same routes (thats the same 10-15% drop as the Prius and all others). It's just more noticable when the numbers are larger.
Bought a bright red one last sunday - got the leather seats this time, which are nice.
I'm averagine 53 mpg on my commute. Means one measley gallon of gas a day to go to work and back. I'm very happy. 300 miles this morning total, and it just hit the halfway empty on the tank.
1. It replaces MTBE and Techron, both toxic chemicals that were getting into the groundwater. Ethyl alcohol is a naturally occurring chemical that -can- get into the groundwater, but wouldn't be toxic unless at almost pure concentrations.
2. It reduces the amount (in gallons) of petroleum fuel that will be needed (by 10%).
3. It supports the farm community, which needs support!
E10 will burn cleaner than fuel with other additives, resulting in longer engine life and less cleaning needed (decarboning engine fuel systems/intakes has become a big money maker for dealers and mechanics).
E10 will reduce your mileage by about 3-4%. Not really significant compared to the benefits.
E10 will negate the need in colder climates for "gasline antifreeze".
It's not really a "ripoff", it's the lesser of several evils.
Winter will drop the mileage (lower temps force the engine to run longer to warm up and stay warm).
Interior heater use will drop mileage as the engine will run to keep the heater core warm.
A drop in tire pressures will drop your mileage. Tire pressure will drop with ambient temp drops (as in winter).
Short trips will drop mileage a lot. The car will almost always be in "warmup" mode.
Some places change the fuel in winter and that can drop the mileage a few MPG.
Prius owners are very sensitive to mileage as they can see the results right away. It is, however, very difficult to attribute mileage drops to one thing specifically, and to track it accurately, as there are so many variables. Aerodynamic changes due to small dents will not result in mileage drops that you can measure. Now, if you added a huge wing to the rear, THAT would result in noticeable mileage drops!
My Accord burns about 4/10 of a gallon per hour. I would assume that the prius would burn far less since it would stop the engine periodically. Does anyone have any data on the idle fuel economy of the prius with the heater on on a cold day and/or with the air conditioning running on a hot day?
Is the on board computer at fault?
First fill up was by the dealer, don't know how 'full' it was. My first to fill up was at 530 miles. I know it was full (up to visual on inside ring). MPG on computer was 49.5mpg.
Next fill up was at 926 miles, took 9.3 gals to fill to ring, comp had 46.6 mpg, calculate to 42.6 mpg.
Next fill up at 1327 miles, took 10.0 gals to fill to ring, computer had 45.3 mpg, calculate to 40.1 mpg.
Last fill up at 1644 miles, took 7.6 gals to fill to the ring, comp had 49.4, calculates out to 41.7 mpg.
Is the 'on board' computer normally this far off?
Darned near 10 % average?
Doesn't give me much in the way of confidence in the on board computer.
I've read about the 'bladder' tank, but this much difference? I've had aircraft with bladder tanks and nothing like this.
traffic_tom
Great forum, so helpful
On verge of buying a new car, but am troubled by the 20% hit on mpg on short trips in the Prius which is on my short list. As most of my driving comprises trips under 10 miles and I live in a cold climate, would I do better in a Focus (assuming mpg is only factor considered) ? Would I expect the Focus would pay less of a penalty in mpg, driving cold? This morning (temp 45) I test drove a Focus and got 35mpg on cold start over a 15 mile trip (Great grandmother driving style - airfoot).
Thanks for any help,
Carl
No car does all that well in the cold with winter fuel and even worse on short trips. Your best bet is to drive right away and not warm the car up in the driveway. I fire up my Civic and I'm out the garage door in 20 seconds!
It takes longer if where I am parked i have clear the windows of snow and ice.
Ask yourself how much for the Prius versus the Ford or even a Honda fit or that sort of economical car $22-23K versus $15K That buys a lot of fuel.
Also the battery in the prius doesn't like the cold weather. In fact no battery does that why so many cars need jump starts in the winter.
There were several reasons I didn't buy a Prius, but I like the concept however I live in a hilly area and once the Prius traction control kicks in you aren't going anywhere in the snow. :sick:
If you have no snow you will be ok, but mileage always suffers in the winter in the cold States.
