Infiniti M35/M45 Maintenance and Repair
  • tmartin63tmartin63 Posts: 19
    My dealer wants $750 for the 30k maintenance. My M35 just hit 20k so I have a while to decide if I want to give them $750 for about $200 worth of work. Oil the hinges? Please. Wouldn't a squeaky hinge be covered under warranty? I paid them $340 for the 15k maintenance and they did not even do everything Infiniti recommends at 15k (e.g. did not change the wiper blades). I also let them talk me into a $99 front end alignment I probably didn't need. I know it's my fault and I should have told them where to stick it. Which is what I'll prob do when I get to 30k. I just need to find a reputable shop that won't screw the car up.
    As for oil, my owners manual specifically states NOT to use synthetic. I don't know why and don't really care - an oil change at the dealer is only $35 which is about 1/3 the cost of synthetic.
  • ghstudioghstudio Posts: 970
    Go to the dealer and get the oil changed...with no additives. When they show you the dirty air filter, tell them it's fine :) Get the tires rotated and rebalanced at a reputable tire shop (that tightens the lug nuts by hand...important if you don't want warped brake rotors). Stand back about 15 feet from the car and look it have now done most everything else in the 30K package.
    And don't worry about those wipers they didn't change. You really should change them when needed, not on any mileage/time schedule.
  • njm35njm35 Posts: 7
    I am persoanlly fed up with infiniti and the continued problems with the streering on the car. I have had several coversations with infiniti and their solution has been to give me a $300 service credit and then offer to get me out of the car for a small amount, that small amount turned out to be $8K!
    At this time i am proposing to join together with all other M35/45 owners that have had or are having problems with the steering on their car. If we act together we might be able to get further.
    If you are interested please email me at the email below with the subect of "M35 action". Please include your contact info in the email. If i can get enough people interested i will see how we can act.
  • mdugganmduggan Posts: 1
    I am having this same problem. My phone and car's bluetooth worked fine for about a month and then quit working. Have you found any solution to the problem yet? Have you been able to reconnect your phone to the car as you did originally to get it to work for another month? Thanks.
  • barryendbarryend Posts: 121
    I have a 2006 M35X. Last January my steering rack was replaced and I replaced the OEM POS Goodyear GT-A's and it is fine.
    My problem is wandering all over the road and dangerously loose feel.
    Maybe try a better dealer. Where are you located? What year & model and what symptom?
  • osbornkgosbornkg Posts: 30
    FYI, we don't own a Blackberry but have now owned 2, 2007 M35's with bluetooth and never was there a problem with our cell phones connecting to Infiniti's bluetooth month after month. The bluetooth in both cars performed beauitfully.
  • walounkwalounk Posts: 6
    when I took the car for service last time I mentioned the noise problem AGAIN , the service manager told me that Infiniti is aware of the problem but they don't have a fix for it and that the engineers are working on it, that was almost 2 months ago.
    they replaced the steering gear 4-5 months ago but that did not help.
    I am really frustrated, the noise is really annoying and imbarressing if you have somebody riding with you, I can't believe how they can't fix it, any suggestions?
  • bobicgbobicg Posts: 15
    I had my 06 M35x into the Cincinnati Infiniti dealer on 11/9 to fix this problem.
    Here is what was done and it worked:
    Gear & linkage - 49001-EH11A
    Power steering fluid - 999MP-AG000P
    Check my other posts for more details, basically on slow right turns it made a rubbing/creaking sound especially at slow speeds when cold.
    I had exactly the same job done on my 07M35X but it did not work, it actually made it worse!, and yes this is the same noise that I have.
  • bnkbnk Posts: 3
    I have a 2007 M45 Sport, which I love. The only problem is an intermittent low-pitched whine during acceleration, typically from a stop or going uphill. It is hard to locate, but generally seems to be coming from the rear of the car. It will happen a couple of times during my 45-minute commute. I'm taking it to the dealer soon, but I'm concerned that they won't be able to duplicate the noise. Anyone encounter this or have any suggestions? Thanks.
    If I were to guess, it sounds like the fuel pump which sits in the gas tank is causing the noise. Let me know if I'm right....
    Intermittent problems are very difficult to pinpoint. If it is the fuel pump, it will just get worse over time until one day in the middle of the night in the middle of nowhere in a drenching rainstorm, it will fail. Of course, well before that happens, you will be able to demo the sound to your dealer.
  • bnkbnk Posts: 3
    Thanks. I was assuming the noise was coming from somewhere in the drive train, but if I can localize it at all, it does seem to be from the right rear, which is the gas tank location. Will let you know.
  • bnkbnk Posts: 3
    Took it to the dealer and they couldn't duplicate the noise. Of course now it's back, so we'll see.
    Go back to the dealer and advise them that Infiniti wants to meet your expectations and if they should hesitate, advise them you will write a review to all the magazines that rate Infiniti M the, “Highest Ranked Midsize Premium in Initial Quality.” J.D. Power and Associates. If they suggest not being able to match the color w/ one front seat have them put in two front seats!
    Taken off Infiniti’s website. - Reviews - Awards - Commercials
    Infiniti M Receives Initial Quality Award from J.D. Power and Associates
    read more Read More
    Infiniti Wins ALG 2008 Luxury Brand Residual Value Award
    read more Read More Awards
    Ward's 10 Best Engines for 14th Straight Year read more Read More
    Owners Rate Infiniti #1 in Vehicle Satisfaction read more Read More
    M Wins Popular Mechanics' Automotive Excellence Awards read more Read More
    2006 Infiniti M Named BEST LUXURY SEDAN in MotorWeek's Drivers' Choice Awards read more Read More
    2006 Infiniti M Safety Ratings read more Read More
    2006 M Wins Top 10 Best Resale Value Award
    read more Read More
    Driver's Car (32 sec)
    read more View Commercial
    The J.D. Power and Associates 2008 Initial Quality StudySM has named the Infiniti M the "Highest Ranked Midsize Premium Car in Initial Quality in a Tie"[1]. The study is the industry benchmark for new-vehicle quality measured at 90 days of ownership.
    To view the TV commercial, click the Commercials tab to the right.
    [1] Infiniti M received the lowest number of problems per 100 vehicles among midsize premium cars in a tie in the proprietary J.D. Power and Associates 2008 Initial Quality StudySM. Study based on responses from 81,530 new-vehicle owners, measuring 344 models and measures opinions after 90 days of ownership. Proprietary study results are based on experiences and perceptions of owners surveyed in February-April 2008. Your experiences may vary. Visit
    Automotive Lease Guide (ALG), the standard for Residual Value projections in North America, has honored Infiniti with its ALG 2008 Luxury Brand Residual Value Award – recognizing Infiniti as the luxury brand forecasted to hold its value better than any other[1].
    [1] Based on Automotive Lease Guide's (ALG) 2008 Luxury Brand Residual Value Award. Award based upon projected residual value of MY08 vehicles. ALG uses an econometric model to predict residual value and considers many factors including pricing (including MSRP), incentives, vehicle characteristics, market trends, sales strategies and economic variables. For more information about the ALG Residual Value Awards, see Always wear your seat belt, and please don’t drink and drive. INFINITI, the INFINITI logo and INFINITI model names are Nissan trademarks. ©2007 INFINITI Division of Nissan North America, Inc.
    Hailed as the "all-conquering VQ V-6," the Infiniti M35’s VQ-series V6 has been named one of Ward's 10 Best Engines every year they’ve awarded it. 2008 marks an unprecedented 14th year in a row[1].
    [1] January 2008,
    Infiniti owners are the most satisfied with their vehicles over buyers of any other luxury brand, according to the 2007 vehicle satisfaction data collected by AutoPacific, whose survey objectively measures many aspects of vehicle ownership, including vehicle operation, comfort, safety and overall purchase/dealership experience.[1]
    [1] ©2007 AutoPacific, Inc. Vehicle Satisfaction Award.
    In their October 2005 issue, Popular Mechanics selected the 2006 Infiniti M35 and M45 as winners of their Automotive Excellence Award in the Luxury category. They cited the M's abundant technology and luxury options delivering an array of amenities and personal conveniences, and a build quality that's good enough to embarrass some well-known, old-school European luxury makers.
    A team of 15 judges evaluated more than 150 cars and trucks, focusing on key features of superior performance, technology, practicality and dollar value, resulting in the Infiniti M being named "2006 Best Luxury Sedan." Awarded by MotorWeek, the original automotive magazine series on television, this announcement was part of the 14th Drivers' Choice Awards.
    The Insurance Institute for Highway Safety (IIHS) rated the 2006 M 'Good' - the highest of the Institute's four rating categories - in both the side-impact and 40-mph frontal offset crash tests.
    This year, Kelley Blue Book's placed the Infiniti M among their 2006 Best Resale Value Top 10, along with the Infiniti G Coupe. Aside from these two prestigious awards, Infiniti also won Best Resale Value Awards in the Coupe and Luxury classes.
    The Infiniti M45 still glows after a year with AUTOMOBILE Magazine.
    AUTOMOBILE Magazine, August 2007
    Infiniti M retains crown in Car and Driver Comparison Test for 2006.
    Car and Driver, November 2006
    read more Download the Car and Driver Comparison Test - 5M pdf
    "This M45 isn't just better than the car it replaces, it's arguably in the top three in its class."
    You appear to be responding to a post made in 2005. I doubt the poster really cares about your thoughts now that we are in 2008.
  • art234art234 Posts: 103
    Here is the latest update on my problem. I had the car back several times for the vibration problem. The dealer has tried to be very helpful but they could not identify.
    They arranged for the district technical specialist to drive the car, which he did three weeks ago.
    They have since replaced the transmission, the front and rear drive shafts, with no success. About 45 mph the vibration starts, and it is very pronounced between 50 and 60, particularly on light to moderate acceleration. The rear deck resonates at around 65 when cold, and now there is a constant hum or rumble above 70.
    The vibration is particularly noticeable now on deceleration or gliding, and I even tried putting the car in neutral to decelerate and the problem remained.
    Again--the tires have been replaced, which corrected the tramlining issue, but this problem appears to be getting worse.
    Infiniti has refused to take me out of the lease, although they did agree to reimburse the tires plus a couple of other incentives.
    The problem is distracting to me and sad that they cannot fix it. Except for this I love the car....but would NEVER get another Infiniti.
    Thoughts??? I really need some advice here.
    Invoke the Lemon Law...that will get their attention quickly.
  • Hello all, new to the site and have a quick question. I am purchasing a 2006 M35 with 25k on it. Is the warrenty 4/60 bumper to bumper or is that just the drive train?
    Thanks for you response.
  • bumper to bumper :)
  • I almost put 25K on my M35 in the first year. You will LOVE this car.
  • I am curious to find out what servicing alternatives are available. Does everyone pretty much go to a dealer? Don't know about you but the prospect of paying $979 plus tax for a 30k servicing does not appeal to me. Does anyone have experience with "non-dealer" service centers?
    I live in the bay area and have just purchased a pre-owned M45 sport.
  • The somewhat obvious solution is to ignore the prepackaged 30K service that the dealer has conveniently put together. Look thru the manual and only have the things that are required done. Skip all the "check and adjusts" which they don't do anyway. The most profitable service a dealer does is those prepackaged specials.
    I stopped doing the "prepackaged" services years ago and have never had a problem with any car or with any warranty. I also skip any intermediate prepackaged services. I get the oil changed at the dealer every 3-5K miles and have the tires rotated every couple of oil changes (at the dealer because my hope is that they calibrate their air wrenches and won't warp the rotors) so the dealer can't blame a tire place if the rotors are warped. I almost never do an alignment unless I can tell that the car needs one by looking at the tires or if I am replacing the tires so the tire dealer can't claim that the tires are wearing unevenly due to lack of alignment. I generally don't keep cars long enough to do the brakes but if I do, I always have the rotors checked and rebuild the calipers at the same the dealer. I never have the rotors turned....that just is an invitation to warping no matter what anyone says.
    If you get to the point where the book says to replace the timing chain or belt....don't ignore that one. If that goes, the engine will self destruct. Transmission fluid and coolant changes are also a good investment ignored by too many. I've never replaced brake fluid or power steering fluid in my life.
  • I like your approach however having just bought the car I want the 30K servicing done to give myself some peace of mind.
    Or is there a way to get coupons or discounts to bring the price down? I dont mind paying $500 considering how much must be done in the 30K servicing however one dealer quoted $979+tax.
    Have you tried serving your car with any shop other than an Infiniti dealership?
  • Take it to a good shop. Have them change the oil, gas, air, & hepa filters. Rotate the tires. Look at battery terminals. The rest is BS. $200.00 would be generous.
    Owning an Infiniti=peace of mind. It is the most reliable auto made. Any problems I had we in technology gadgets and garbage Goodyear tires. Warranty replaced the common defective 2006 steering rack looseness.
    Maybe an alignment if you need new tires. If you have the Goodyears (M35X) you probably need new tires. Look at ratings on Tire Rack. New tires not Goodyear will be a huge improvement. OEM tires are garbage. Next Infiniti I get I will not leave the showroom with OEM tires. (Same for most other car brands)
    Dealers want you to believe it needs service like a 1965 Jaguar. That is puffed up nonsense. 60,000 miles is the time to spend money.
    If I go to the dealer for anything I tell them do not do any work not covered under warranty without my prior approval.
  • Now have 30K on our 07-M35. This is our 3rd Infiniti. First was a 04-I35 then a 07-M35, which was totaled, and a replacement 07-M35. They are very dependable automobiles and I believe the M35 saved us from serious injuries.
    I run AMSOIL oil and oil filters. Their 5W-30W is recommended for 25K miles and their new oil filters run the same mileage. As for maintenance on this M35 with 30K, I have only changed oil/filter once and the engine air filter once. I will be considering in 09 changing the other fluids to extended range fluids, as we will be keeping this M35 longer. AMSOIL makes excellent synthetic lubricants for most fluid applications.
    I agree, 60K is the time to spend money. The earlier uses of synthetic lubricants help promote longer mechanical life when someone wants to keep their cars an extended period of time.
    Discount Tires here in the US does the tire rotation for free.
    Only concern I have with our 2nd M35 is we needed to replace the
    Bridgestone tires at 25K. I decided on Michelin Primacy MXV4 replacement tires and they have proven to run much quieter then the Bridgestone tires and have improved steering characteristics to a point that a non-professional person can feel the difference.
    I have to counterpoint those who say the M is reliable. I have had an ongoing problem with the drivetrain which is now headed to arbitration.
    I brought it back again last week for the same problem and they refused to touch it--told me the factory had told them NO MORE repairs on my car.
    Based on that I contacted the BBB and am filing papers this coming week.
    It's one thing to say they won't take the car back--it's completely unacceptable to refuse to repair it.
    They are clueless-the district tech specialist drove the car and acknowledged something is wrong but they have no idea how to fix the vibration in the drivetrain.
    All I can say is caveat emptor.
  • Thanks for the great feedback. I agree dealers tend to overcharge - especially for things like tire rotation, oil changes, transmission fluids, brakes etc. I want to find a good mechanic who can do a good job of this 30K inspection - especially having just bought the car.
    How can I find a good repair shop who will have the necessary Infiniti diagnostic equipment? I am somewhat new to the San Francisco Bay area, and most of my friends are not savvy about using local auto repair shops.
    I found checkbook(.org) has a ranking of auto repair shops in San Francisco they sell for $15. I have also considered calling AAA-certified auto repair shops and asking if they service Infiniti M's - however I am not sure what questions I should ask them.
    I am hoping the experts in this forum will have some good pointers on how to go about finding a mechanic and what questions I should be asking.
  • I don't live there. But I suggest going to an area where there are middle class people so you don't pay "Hamptons" prices. Try a tire chain or oil change chain. Brakes have to be inspected for state inspection anyway. May be worthwhile to have the dealer do the brakes since there are lots of cheap replacement parts being sold. The issue is whether you really need the brakes done.
  • there are some problems with the tire/oil change chains. Every time I go to one of those shops, they show me my air filter and tell me it needs to be changed using their own (cheap) brand. Brake shops are worse because they use the cheapest quality pads. Keep in mind that cheap pads may effect your rotors and then you are talking real money. Additives? Nitrogen in the tires (the latest sales pitch). transmission fluid dirty (probably not your fluid)....Of course it's much worse if my wife takes the car in for service.
    Bite the bullet....go to the dealer for oil changes and get their (overpriced) filters. Also, for brakes, use the dealer...and point out that the rotors aren't warped when you go in.....and have them write that down, because if they overtorque the tires or don't put the pads in right so the rotors overheat, you may develop warped rotors.
    And if the service manager comes and sits down beside you to review all the other things that they've found....thank him and say you'll consider doing them the next time :)
    One dealer kept telling me i needed a new Hep air flow was reduced. I told him that I would replace it myself...The next time I went in, I asked the service guy to check to make sure the air flow was good and the same service guy said it was working great with full air flow. (of course I did nothing).
  • Did a Google and found:
    The Garage - Independent Nissan / Infiniti Service
    340 10th Street
    San Francisco, CA 94103
    (415) 864-0111
    They appear to be highly rated with 33 reviews and more
    Might want to call and see if they have a referral list of people to call. Wishing you well.
Infiniti M35/M45 Maintenance and Repair - Page 32 — Car Forums at
