Honda Pilot Real World MPG
1131416181924
    dfwhondadfwhonda Member Posts: 45
    The 22 mpg is advertised as the hwy mileage with the FWD (20 mgp for hwy for the 4WD).
    My 01 MDX would generally get 16-17 in city driving and 21-24 on the hwy. As another poster mentioned, it probably had as much to do with my driving as anything else.
    justaveragejoejustaveragejoe Member Posts: 268
    Tess,
    Remember that normal (atmosphere) air is 78% Nitrogen and 21% Oxygen, which is perfect for breathing and inflating tires. Don't waste money by using something else in you tires (or breathing something else, either!)
    I try to keep 38 psi in all my tires (they are rated for 44psi). I know that some people frown on anything other than what is on the placard, but I find that this pressure gives me the right ride and saves on actual tire wear. I just turned 10,000 miles on my 2007 4WD and had my tires rotated by Les Schwab (for FREE!). They reduced the pressure down to 32 psi and the Pilot felt like mush to me, so I pumped them back up.
    I have been getting 18-19 mpg on my normal commute (rural/suburban 25 miles one way). I recently returned from a 330 mile, all-highway, round trip down the central valley. The cruise control was set to the speed limit the WHOLE WAY (65 mph for 30% and 70 mph for 70% of the trip)............. Only 21.6 mpg.............There was a slight head wind on the return leg of the trip.
    It seems that my Pilot does not like speeds above 65 mph since I have gotten better mileage driving through mountainous roads at speeds less that 60 mph.
    Joe
    upstatedocupstatedoc Member Posts: 710
    38 PSI !!!!!
    Joe, do you get any center balding on your tires w/ those pressures? I always thought you could ruin tires prematurely with higher than normal pressure.
    BTW, filling your tires strictly with nitrogen is hog-wash. There's an article somewhere on Edmunds about it. Some dealers are charging $300 for it!!!!!!!!!!!!!!!!!!
    I check my tires pressure and their wear pattern very regularly and rotate as needed (I keep them balanced too since I hate vibrations). 38 psi pressure is giving me an even wear pattern. I keep 40 psi front and 38 psi back in our 2004 Odyssey tires and just replaced the original Michelin tires last week at 30,000 miles. They were wearing perfectly. They were not completely out of tread, but we had one with a leak that couldn't be repaired so I bought a whole new set. I think we got good use out of them because it was mostly suburban driving, shuttling the kids around to school and such.
    Keeping the tires at a good pressure will help with the gas mileage a little bit, but unless they are really low, a lower pressure (32 psi) won't hurt your mileage (or your tires). I just like the handling of higher pressures. Some people warn that higher pressures will cause handling/suspension problems, but I have experimented and tend to disagree (I am not liable for stating my opinion, unlike the car manufactures), although I do avoid very bumpy roads and I go very slow over speed bumps and other typical driveway curbs.
    I am not over-inflating the tires above the rating for the tire, just above the recommended pressure from the manufacture. With todays lower-profile tires, wear shouldn't be a problem like it was with bias-ply tires of yesteryear.
    Joe
    slamtazslamtaz Member Posts: 55
    yes, after getting an amazing deal on the 08 2WD VP which i posted on the other thread, i would like to report the equally amazing mileage on my first two fill-ups. after the first 257 miles, i filled up and the pump stopped at 13.35 gallons which translates to about 19.25 mi/glns mixed city/hi-way. and that's the story for mixed driving... :)
    right after filling-up, we went to san diego (i.e. 360 miles including about 20-30 miles city speed driving) with 2 adults, 4 heavy weight kids aged from 15 to 9 and a cargo full of baggage w/ cooler full of drinks!!! (i.e. passenger combined weight alone is about 800 to 850 lbs!!! without the baggages). i used cruise control for most of the trip at about 70 mi/hr (50%) 75 mi/hr (30%) 65 mi/hr (20%). when we arrived here in san diego i looked for a shell station and filled-up again with 87 grade fuel and the pumped stopped at 15.637 glns which translates to 23.022 mi/gln!!! both my father-in-law and i were amazed that with such a full load, we got such great mileage on a not-yet-broken-in Pilot. one thing i noticed is that the VCM (Variable Cylinder Management) was often engaged because of the light indicator "ECO", this must have contributed to such a mileage.
    what else can i say, so far i am really very impressed and happy with our Pilot and i look forward to many many years of the same. :shades:
    ......But I wonder if keeping the tires pressure higher than recommended is causing premature wear. We got just over 40k on the original Michelins that were on the MDX. Just a thought........
    kipkkipk Member Posts: 1,576
    Good post! :shades:
    Kip
    I think that if the tires were over-inflated then I would have seen more wear on the center of the tread than on the outsides, which I didn't. The idea is to have the weight of the vehicle spread out evenly across the tread. Low pressure can put extra heat into the sidewall and damage a tire in no time.
    Joe
    trmend1trmend1 Member Posts: 59
    Joe - thanks for your input on the tires. The gentleman that suggested nitrogen is an engineer. I guess what's good for 747 tires will be good for Pilot tires. I'm sure there are benefits, however is it cost effective? Our local Costco offers nitrogen at 5 bucks a wheel. The key point he was making was the stability and reliability of pure nitrogen.
    Well... with PROPERLY inflated tires, my gas tank had definately a better return! When i was averaging 15-16 mpg beforehand, this time it was 18 mpg. This is 15% highway, 85% stop and go city. I'm impressed and happy... especially since gas is now $3.41/gal!!!
    Cheers,
    Tess
    bigj4bigj4 Member Posts: 2
    My wife and I just returned from a trip to South Lake Tahoe. Our 2006 Pilot 4WD got 25+ MPG going up HWY I5 from Simi Valley, California to Folsom, California, about 420 miles. We drove around Tahoe for a week and decided to return home out the back way using HWY 395 through Bishop and Lone Pine. We filled up in Minden, California and drove non-stop to Simi Valley in 8 hours, about 470 miles. I still had about 1/4 of a tank left so we drove around Simi Valley for another three days before I filled up again. We averaged another 25+ MPG on the return trip. I purposely did not check my mileage while we were driving up and down the mountain or around Tahoe. The average MPG numbers cover over 1,000 miles of Highway and freeway driving with the air conditioning turned off and the cruise control set at 69 MPH. I have all four Good Year Integrity tires inflated to 36 lbs air. There were two people in the car at all times and the back was loaded with the usual luggage needed for a one week holiday in the snow. Considering the size of the vehicle, I am very pleased with the mileage numbers that we are getting. Oh, and one more thing, we did hit some traffic going home down 395 that slowed us to a crawl for about 30 minutes. Not too bad all considering!
    Tess,
    Keep the 20 bucks in your wallet, it is not cost effective. I imaging that the 747 would need Nitrogen since any moisture in those tires could cause problems.
    Do a search on Helium in this thread for some interesting posts. :blush:
    Joe
    Wow, What a grerat trip and great gas mileage! I have always wanted to come back from LA to Sacramento on HWY 395. Can you maintain 70mph on that road? You must have missed the storm that just came through and closed all the roads up there.
    Joe
    Joe,
    Yes, it was a great trip and super mileage as well. We went up on 2/9 and returned on 2/17 right in between two large storms. We have very close friends that have a condo on the south shore and we plan to visit for extended stays with them often now that we are all retired. That's why I got the 4WD, so I wouldn't have to put on any more tire chains! :) I prefer going up and back on interstate interstate 5 but, this time we thought we would take 395 home as it is a more scenic route and it had been over 20 years since I last drove it. You can go 65 to 70 but, there are about 7 or 8 small towns along 395 with speed traps so you must slow to about 35 or 40 for a few miles which I found frustrating. I had forgotten how many small towns there are along the 395 route. Our friends prefer 395 but I will use I 5 from now on. The snow was about 6 feet deep but, all the roads were clean so I was not able to do any "off road" snow driving to check out the 4WD. I was so looking forward to that! Oh well, there will be another time. Talk to you soon.
    John
    We generally use the freeways. But sometimes we just use back roads for the serenity and views. The Small towns along the route can definitely be somewhat of a nuisance. Or they used to be!
    Recently on one of the PBS channels, there was a series that lasted several shows. It took the state, Georgia, by sections and revealed historical areas, as well as places of interest. Many of the interesting places are in and around those small towns. One of the "Voted Best Bar-B-Que" Restaurants, is on one of the routes we sometimes take. We have never stopped there. It doesn't look like much from the road, and it sits in the middle of nowhere. We discovered recently, that their BBQ really is the best we have eaten. Period!
    We are both pretty much semi-retired now. Lots of time for ourselves that we didn't use to have. If a trip that used to take 4 hours, now takes 6 hours, it is OK. There are water falls, state parks, Historical sites, huge swamps, flea markets, battle grounds, and so on for us to discover. Gosh, it doesn't even have to be a "Name Brand" motel to be really nice with home style cooking, nice people and good service! :shades:
    Fuel mileage is usually better, because I can run 60 on the mostly 55mph roads without fear of becoming traction for a big rig. ;)
    Kip
    parvizparviz Member Posts: 484
    Nice road, I just came back from Bishop to Sacramento a couple of weeks ago. Just keep in mind that it will be tempting to step on it but don't, they're all over waiting for speeders!
    kjehlingkjehling Member Posts: 6
    It doesn't sound like there is a noticable difference in MPG between the two. That is main reason why I would buy one over the other. 4wd is 1K more. Has anyone noticed 4wd really helping to stabilize the vehical if you're not in the snow/rough terrian?
    Yes, definitely! If you are going to be in the snow or along a dirt roads that might get muddy, then you will get your use out of the 4WD. If you are just on the paved surfaces that never see snow or ice, get the 2WD. I tested the Stability Control and it works. It is much more fun to turn it off and do donuts, though. :blush:
    Joe
    joeyjoejoejoeyjoejoe Member Posts: 68
    I saw some discussion earlier in this thread about Pilots shifting at high RPM's and wanted to bring the question up again. We purchased our '08 AWD VP in late February and noticed that it consistently hits over 3,000 RPM's before shifting from 1st to 2nd gear. It is Winter in the Midwest, however, so I could see how that could affect the vehicle. The more I think about it though sounds like maybe something is wrong.
    It can't be good on the engine to jack up to 3,200 or 3,300 before shifting each time. I don't notice anything like that in any of the other gears. Just the 1 to 2. Has anyone had a similar experience. I've e-mailed the dealer and plan to bring it in this weekend to have them check. Other than this "problem" we love the thing. It boats around in the snow and looks cool doing so. Cheers!
    dsetrandsetran Member Posts: 1
    I'm having the same exact problem with my 4wd EXL. It's the only thing I don't like about the Pilot, but it drives me crazy sometimes. It only happens between first and second gear, but it definitely seems like something is amiss. I also live in the Midwest, and it does get a little better when the engine warms up, but not much. If I go very light on the gas pedal I can get it to shift at about 2700, but this is hard to do. Let me know if you get any help at the dealer. I'm thinking of bringing mine in as well!
    davidd3davidd3 Member Posts: 582
    That's just the way it is. Newer Pilots rev higher than older Pilots. I don't have the time to dig it up for you and joeyjoejoe, but if you scroll back to 2007, you'll find detailed discussion in this forum about this issue. Someone even posted the technical data.
    carabelcarabel Member Posts: 43
    Yes my 2WD does that. Have it now for 16 days purely suburb driving, paved roads not much highway, 500 miles on the car, MPG 16.129 for real. Only errand driving to schools and supermarkets, or mall shopping. So a lot of short stops. I heard it gets better after a while - am not too optimistic. The Sienna yielded 17MPG to 18MPG for similar driving pattern and 22 to 24MPG on highway.
    Carabel
    last time i reported here when we just got our 2WD pilot, it was 23 mpg to/from vegas/san diego with about 360 miles one way. this weekend we took the exact same route with the exact same 6 passengers (i.e. about 850 lbs) plus baggages & stuffed cooler.
    only thing different was that there was really very strong wind on our trip to san diego (head/cross wind) and i suspected that it will cause our mileage to drop, which it did because i only got a manually computed 20.935 mpg after fill-up.
    on the way back however, the winds were still there but not that strong anymore and as i expected, mileage improved to 24.129 after fill-up and that includes about 20 minutes crawl for 2 miles back here in vegas. :shades:
    on another note, city driving to and from work of about 9.2 miles one-way, yielded 19 mpg.
    current odometer reading of 2,524 miles after 5 weeks of driving :)
    jsmith1975jsmith1975 Member Posts: 22
    We recently took a trip from KC to Copper Mountain, Colorado and averaged 23.4 MPG over the entire trip.
    Here are some details if anyone is interested:
    2004 Pilot EX-L
    73,000 miles
    Mobil1 5W-20
    Tires 40 PSI
    4 adults and 3 kids with most of the gear on a Hitch-Haul rack.
    Round trip of 1,431 miles.
    Average speed of 71.8 MPH.
    Essentially 100% highway.
    Had somewhat of a tailwind on both legs of the trip measured by flags on flagpoles that we passed.
    We have only had one trip that gave better mileage, but that was with less people and gear.
    texaspilottexaspilot Member Posts: 13
    Sorry for the late reply; been traveling alot! Tahoe is 2wd; Pilot was 4wd. Tahoe has 5.2L and 3.42 rearend 25' Airstream pulls fine. Think about 25'; not that much more weight or length (check specs) but room inside, wrap couch, dining area,bed, etc., is worth the extra load and price is not much different; look at Craigs list~ we found barely used 25", 06' Safari Anniversary Edition for $23K. I would like to see GM offer bigger engine (or turbo diesel) with Tahoe...
    Everything considered, your mileage is excellent. :)
    Its your foot.... I know it really takes retraining to lighten the foot for the pilot and with non rush hour traffic my 07 4WD EXL (with almost 5000 miles) shifts at 2500. Its smooth and easy and all other gears shift at that or lower depending on traffic. Now if I am in rush hour traffic and I need to squeeze in at a left or right hand turn, I accelerate faster with shift at usually 3300. No biggie either way other than poorer gas mileage. It has taken me about 8 months to retrain my foot from commuting in my Acura RL which is quick and nimble with a heavier foot. (love the zoom factor) to hauling soccer, football and hockey gear plus players, and Costco runs to feed them all... where I'm left in the dust at the lights. But I love my ride.... My average non highway tank is 16mpg, my highway tank is 21mpg.
    HTH's
    Cheers,
    Tess
    Thanks. I have to think the tail wind components had a lot to do with the high MPG numbers considering the load it was carrying. I had also just changed the oil and air filter before the trip.
    It is my wifes car and she mostly drives it back and forth to work (10 miles round trip) on mostly suburban outskirt roads (less than 40 MPH) and averages 17-18 MPG.
    This is part II of a saving gas series at Edmunds. The calm driving style indeed saves gas.
    Save Gas with Smart Driving and Slick Aerodynamics
    Tess,
    We have discussed this in depth a while back. What we are saying is that it has nothing to do with accelerator pressure. We discussed gear ratios and other transmission information. Some newer Pilots are holding first gear alot longer than they should. My Pilot does not like to shift into second gear under 3000 rpm unless I am barely touching the gas pedal and then it still tachs much higher than what I believe it should. Older Automatic Transmissions had throttle valves and shift valves, but new electronic ATs use solenoids to sense speed, throttle position, fluid pressure, etc. I think that some Pilots have funky solenoids or some funky "logic" programmed into them.
    But that is just my opinion, and I could be wrong.
    Joe
    Thanks for the link, Steve.
    I have a couple comments. First, they mention "farm country" which means a place where there is less traffic and EVERYONE drives fast. (HWY 99 is the oldest North/South route in the California.)
    And Second, It was good to see all of the technical information that we have been discussing in this forum. We all have been right on the money in our discussions. (They didn't go into that F=ma discussion, though. :( )
    This is the same type of road that I have been driving with the cruise set at 65 and 70 (exactly the speed limit) and my Pilot barely gets 22 mpg. :confuse:
    Joe
    right on the dot! calm driving is the way... :shades:
    we did a 358.7 mile trip to san diego from vegas with the same load as i have posted before (i.e. 6 pax aboutt 850 lbs plus baggages). this time the parameters are:
    1. barely any wind factor
    2. entire trip strictly set to cruise control at 70mph, whenever possible
    3. a/c on druing entire trip at 2 clicks before max temp and both blowers set to middle setting.
    refilled with 14.214 glns upon arrival. result is an amazing 25.23 mpg
    same route taken going back but with more stop-overs stretching to 368.5. when we arrived in vegas, refilled with 15.028 glns. result was an equally amazing 24.52 mpg.
    downside: my daughter said that probably thousands of vehicles zipped passed us :sick: and that we're able to overtake only a handful of vehicles, especially those trailer trucks. but it sure was a relaxing, calm driving and almost therapeutic drive :)
    spacedogspacedog Member Posts: 8
    Tess and Joe,
    I drove a 2004 pilot EX-L for 4 years and never experienced any shifting issues. When our 2004 leased ended, we decided to lease another pilot EX-L in January 2008. The driving experience between the two is like night and day.
    1. A light acceleration from a stop yields gear shifts at 3500+ RPMs... great for gas mileage, right? 2nd to third is not much better. Don't even tell me I need to lighten up on the foot.
    2. Driving in the range of 40-50 MPH, with minimal grade changes, the vehicle downshifts, upshifts, tach fluctuates between 1600 to 2500 RPMs. Conveter unlocks/locks. It's driving me crazy. Never had this in the 04
    3. Average of 14.6 MPG combined city/highway driving
    Took the vehicle back to the dealer three times. Each of the technicians said that this was normal. Control systems are not supposed to work this way. I spoke with the Service Manager and he put me in touch with the regional Honda Rep. It turns out that he Honda Rep was experiencing the same low end shifting issues and the gear searching between 40-50MPH in his own 08 pilot, but wrote it off as..."I guess I just have to live with it"
    I asked him how these types of issues get resolved, because clearly this is an engineering/software problem. He stated that there needs to be a sufficient number of complaints to warrant an investigation from Honda Engineering. The only way these complaints are heard is through the regional reps and/or the Honda Tech Line. Once a critical mass of complaints are received, they will start looking at the problem.
    In order to have your complaints heard, insist that your dealer service tech & manager contact the Honda Tech Line to record the complaint. This is crucial to getting these issues fixed
    The door is not shut... Just today, I took the pilot into the dealer and he hooked up the diagnostic PC and we went for a 30 minute drive, recording 1 minute intervals of data. He is sending the data out to Honda Tech Line. Perhaps we will al benefit from this. Will keep you posted
    Hopefully enough complaints will prompt Honda to do some research into this issue.
    My neighbor has an 07 Ridgeline, and we drive about the same style. He averages about the same mileage (maybe a little better) in local driving as our 03 Pilot.
    I asked him about the shift points (RPM) with a warm engine, and he said he didn't know, but would check it out. He got back with me and said, that when the engine is cold and a very light foot, it shifts around 2800 RPM. With a warm engine, on level ground and light foot, it shifts at 1800-2000 RPM. Same with our Pilot on both counts.
    One of our sons recently traded his Mustang GT for an 07 Ridgeline. He says he is getting 17-19 local driving, but hasn't paid attention to shifting points.
    Several people have posted on this forum, excellent mileage with newer Pilots.
    This indicates that the large mileage differences are not a "Gearing" thing. But something else!
    With those Pilots that shift at higher RPM, is it possible that something in the "logic" is not "Understanding" that the engine is warm? If that is the case, the engine could also be continuously running richer, as though it not warmed up to operating temps yet. This may not even show up as an error in the computer.
    Below is a copy of neighbors spread sheet. A couple of items to NOTE:
    1. He normally sets his cruise on 75mph. The fillup on 10/28/07 was the result of setting the cruise on 65 mph for that one 256 mile trip, "just to see what it would do", according to him. Again, it resulted in about the same mileage as our Pilot at that speed.
    2. The last fillup on 03/16/08 was the result of 273 miles. 155 miles of that was towing a 3200# Trail Manor (collapsible) camper and the rest was local.
    Date Odometer $/gal Gallons Cost Mileage Avg
    8/3/2007 30
    8/13/2007 299 $2.579 14.93 $38.51 18.01 18.01
    8/22/2007 424 $2.649 7.74 $20.50 16.15 17.38
    8/22/2007 562 $2.619 6.61 $17.30 20.89 18.17
    8/22/2007 742 $2.529 8.90 $22.50 20.23 18.65
    8/23/2007 961 $2.649 10.76 $28.50 20.36 19.03
    9/3/2007 1196 $2.549 12.79 $32.60 18.37 18.89
    9/24/2007 1507 $2.629 17.50 $46.00 17.77 18.64
    9/30/2007 1619 $2.629 6.09 $16.01 18.39 18.63
    10/12/2007 1775 $2.549 7.45 $19.00 20.93 18.81
    10/12/2007 1871 $2.599 4.58 $11.91 20.95 18.91
    10/16/2007 1971 $2.519 4.45 $11.20 22.49 19.07
    10/18/2007 2075 $2.699 4.63 $12.49 22.47 19.22
    10/18/2007 2372 $2.599 12.50 $32.50 23.75 19.69
    10/26/2007 2582 $2.589 9.35 $24.20 22.47 19.90
    10/28/2007 2838 $2.719 9.64 $26.21 26.56 20.36
    11/2/2007 3136 $2.589 13.75 $35.60 21.67 20.48
    11/2/2007 3406 $2.589 11.59 $30.00 23.30 20.68
    11/15/2007 3673 $2.839 13.70 $38.90 19.49 20.59
    11/23/2007 3743 $2.839 4.93 $14.00 14.20 20.41
    12/2/2007 3829 $2.879 4.52 $13.00 19.05 20.38
    12/5/2007 3878 $2.869 2.37 $6.80 20.67 20.38
    12/11/2007 3969 $2.819 4.82 $13.60 18.86 20.35
    12/27/2007 4289 $2.789 16.13 $45.00 19.83 20.31
    1/9/2008 4436 $2.959 8.28 $24.50 17.75 20.21
    1/20/2008 4557 $2.919 7.78 $22.70 15.56 20.05
    2/12/2008 4783 $2.869 13.50 $38.73 16.74 19.86
    3/16/2008 5056 $3.099 17.59 $54.50 15.52 19.57
    Kip
    Spacedog,
    That is exactly what I have been saying. Our 2004 Odyssey shifts at a much, much lower rpm for a given speed and throttle pressure. I have notified the dealer but since I don't put many miles on the 2007 Pilot (only one oil change in 16 months, 11,000 miles currently) I don't get to talk to them much. I WILL mention it again at my next service, though!
    Kip,
    I don't believe that the transmission shift points are effecting my HIGHWAY mileage at all. I know that the TC stays locked so that should not be an issue, however since the gear ratios are different between the 2004 and 2007, there must be an overall effect (however that may be minimal).
    What some of us have been saying is that OUR Pilots are not delivering the fuel economy that YOURS is. Tess and Slamtaz, This has nothing to do with my foot or driving style. It doesn't matter if you set the cruise control on my Pilot or if I set it, the vehicle will be moving at a constant speed (and on flat ground) and it will not get the gas mileage that your Pilot gets. That has been my point for quite a while, my Pilot is not delivering as expected nor as good as some other Pilots. Please don't take this response the wrong way, I appreciate all of your input and comments but please consider the fact that some Pilots just don't get good gas mileage.
    I have stated before that with so many components that must work together in a vehicle, a few can combine to effect performance or efficiency. I just wish I could figure out what and/or why I don't get better gas mileage. :confuse:
    That Buick Enclave is rated for 22 mpg on the highway, but they were able to get 27 mpg with the cruise control set with that six-speed transmission. I have always been able to exceed the rated mpg in all my vehicles and yet I can barely get the rated mpg in my Pilot
    Joe
    I haven't had a chance to take our Pilot into the shop but am going to this weekend. The dealer offered to let me test drive another model while mine was being checked out to see if I notice a difference. Although I appreciate the gesture, it just sounds like they want to keep me busy instead of actually checking the engine for me. I'll let everyone know how the other model handles, if any differently.
    We actually just took it on our first long road trip of roughly 400 miles. I don't have an exact measurement of our mpg, but hope to get one finished soon. I tried to keep it in cruise as much as possible right around 72 or 73. I also don't feel the need to speed as much as I used to because the ride is more comfortable, quite, safer feeling, smoother, etc... I'm "one of the big guys" on the road now :D I used to drive a little Toyota Corolla.
    I didn't notice the gear switching issue from 4th to 5th though. It did seem to rev high when it changed over right around 65 mph, but otherwise it seemed fine. I'll take this other Pilot out on the interstate and really open it up this weekend. Hope to have something good for everyone. Thanks.
    Joe,
    Exactly, because not all model year Pilots are created equal. Also true that not all drivers are created equal. Pilot owners have different driving styles. City/highway mix is another factor. Etc. But the basic starting point is that not all Pilots are created
    David
    David, et al,
    You are exactly right, but here is my beef... I had an 04 EX-L 4WD and drove it for 4 years. Loved everything about it. Lease ended and decided to get the same vehicle 08 EX-L 4WD in Jan. I believe the 04 and 08 should be similar but not exactly the same. On the 5th model year, you would think the engineers would have it tuned to perfection,....not my experience by a long shot. Gas mileage appears to be much worse in my 08 (so far) I can only surmise that many new pilot owners take all of this high rev shifting, poor gas mileage as normal. I probably would too if I had not driven a pilot for 4 years. Maybe they changed the software in the 08 that does not fit my driving style anymore? If this is the case can somebody please tell me how I must change my driving style in the 08 to get the same gas mileage and performance as the 04?
    FYI.
    Below are the specifications for the model years that show the differences such as gear ratios. Driving for 2 hours with the cruise control on should eliminate any variances in driving styles. Although there are differences in gearing and Hp, some folks can still get great gas mileage with the 2007 and 2008 AWDs. I am just not one of them. I am still poking around trying to find out why not. :confuse:
    2007
    http://www.hondanews.com/categories/889/releases/3635
    (2008 is exactly the same as 2007 except for the new EPA mileage estimate
    http://www.hondanews.com/search/release/4124
    2006
    http://www.hondanews.com/search/release/2943
    2005
    http://www.hondanews.com/search/release/2265
    2004
    http://www.hondanews.com/search/release/1469
    Joe
    Everyone who comes to realize this finds it surprising. Maybe Honda engineers have, in this instance, improved performance at the cost of fuel efficiency.
    I have a 2007 EXL 4WD. Same as the 2008 in this respect. I've considered the high revving to be normal, since many other people have reported it in this forum. But I am interested to see where this discussion is going, in particular some forum contributors taking up this issue with Honda as possibly being a defect.
    minnesnowta1minnesnowta1 Member Posts: 27
    03 Pilot with 60k on it. A lot of factors contribute to the mpg of your vehicle. Type of tires you have, Tire pressure, Winter bend fuel vs summer bend for cold climates. How often the vehicle is using 4 wheel drive, Mechanical condition. One other thing to consider is what type of gas you purchase. From my own tests in my opinion it seems to make a difference. Discount gas or top tier gas. Better fuel, better mileage.
    I average 17 in town and 22 on the hwy. In the winter I get a mile or two less when it's very cold and in the summer a mile or two more.
    You don't mean top tier being premium gas ? Or do you mean discount gas being non Shell/Mobil/BP, etc name brands ? Because premium gas will not make a difference unless you are towing heavy loads. Otherwise, on regular driving, use regular gas - 87 octane and money spent on premium is a total waste.
    I'm no guru when it comes to figuring out how, why or what specifically affects mileage and up to what extent, although i'm quite aware of the following to affect mileage in a certain way:
    1. up to about 260 lbs curb weight difference from the base model 2WD VP to the 4WD EXL/SE models.
    2. regular load on the vehicle (i.e. passengers, baggages, running/step boards, extras, etc.)
    3. tire pressure & over-all vehicle maintenance
    4. how the vehicle was broken-in by the owner and to include the time it's sitting on the dealer's lot(i.e. this is also why i prefer to get fresh-off-the-truck vehicles, as i don't know how those vehicles sitting on the lot were test driven by other customers, if i may say, there are those who trash vehicles during test drives and even push it to the limits).
    5. driving style
    6. driving environment including terrain type, wind factor, weather temp, road quality, etc.
    i also tend to agree that the sum of the individual parts (i.e. which may vary in individual quality) may perform a bit differently together and could explain the apparent difference in mileage or performance or even having a :lemon: .
    i used to have a 1988 pathfinder (yes 1988, not a typo) which i was surprised that the dealer offer to take as a trade-in when i got our pilot. mileage on the 3.0 Ltr 4WD V6 pathfinder was a measly 13.5 to 14.0 mpg city and 15 to 16.5 mpg hiway :sick: . that's why before purchasing the 3.5 Ltr pilot, even just getting a few notches +/- the EPA mpg of 16/22 city/hiway was good enough for me. :)
    just my .02
    >"I don't believe that the transmission shift points are effecting my HIGHWAY mileage at all......I have stated before that with so many components that must work together in a vehicle, a few can combine to effect performance or efficiency. I just wish I could figure out what and/or why I don't get better gas mileage...."
    Joe,
    I don't think the shift points are affecting the HIGHWAY mileage either. I do believe the 3000 RPM minimum shifts points may be an indicator of another problem that could be affecting your mileage.
    I believe most will agree that a cold engine requires more fuel to operate.
    Both our CR-V and Pilot have higher shift points when the engine is cold.
    So we have 2 things in common with a cold engine.
    1. Higher shift points, the driver can see and feel.
    2. A richer fuel mixture, the driver can not see or feel, But knows it must be happening.
    With either of my cars, I understand from 5 years of driving them, that they shift at about 3000 when cold. Once warm they shift much lower.
    There are sensors, smoke and mirrors, and probably some "Voo-Doo" that send information to the computer when the engine reaches operating temperature. Shift points become lower and the fuel mixture leans out.
    If for any reason the computer does not "Know" the engine is "Warm", it could continue to keep the shifts points high and fuel rich. There could be no errors recorded, because all sensors think they are still looking at a cold engine.
    I believe that to be a very real possibility.
    Joe, I agree that some vehicles simply refuse to co-operate. But sometimes the problem can be simple and hidden in plain view.
    I don't believe the slight difference in gear ratios of the older and newer Pilots have that much affect. Many folks have reported "Good" mileage with their newer Pilots. My neighbor and son are getting good mileage with their "Lower geared" 07 Ridgelines.
    Kip
    \PS.. FWIW: the ILP was done on both those Ridgelines.
    E10 Factor - has anyone considered the mpg and performance impact of these blended gasolines ? The state of FL just mandated all gas pumps to have E10's. While reports say little or no impact, I've read them with uncertainty. Any comments will be appreciated.
    Got 19.5mpg from my 2007 EXL 4WD for a 400+ mile trip this weekend. Almost all highway. Used cruise control a lot, set at 70mph. 5 people + overnight bags. Actually I could not make it all the way there and back on the same tank of gas. I had to stop for gas after 380 miles. It took 19.5 gallons. Oh well. Maybe next time. Oh, and by the way, the fill up cost $67! Ouch.
    jay_24jay_24 Member Posts: 536
    As far as ethanol (E10) goes it has very little affect if any. MInnesota has required 10% ethanol for years, Wisconsin hasn't. I see no differrence with my Subaru Outback (28mpg) or our Tahoe (19mpg). For my Outback temperature is the biggiest issue. Below 35F the mpg starts dropping. I have noticed about 1 mpg difference between brands of gas. So far E10 gas at Shell has been the best and I sometimes get just short of 30mpg highway with it. My AWD Subaru was rated for 27mpg highway in 2001 and now has a 25mpg rating.
    Now if you go upto E85, then you will see a difference. I haven't tried it yet in our Tahoe, but it can burn it.
    2007 EXL. Got 21.72mpg for a trip of 290 miles. Almost all highway @ approx 70mph. This is our best ever mpg in any fill-up with our Pilot. :blush:
    My family made this trip in 2 vehicles, with one following the other. The other vehicle, a 6 cylinder sport sedan (and the lead car) got 33.1mpg (about 50% better) for the same trip. Now I don't feel so good about my new mpg record for my Pilot. :(
    importmyrideimportmyride Member Posts: 2
    Spacedog & other fellow '08 Honda Pilot Owners,
    EXACT same situation experienced with my brand new (less than one week old) Pilot--except for gas milage--I get 13 mpg !!!!! The shifting thing is freaking me out and sadly for me a very familiar feel. It's the reason why I had to buy a new car to begin with. My 2000 Ford Windstar minivan started having shifting problems (would not fully shift into higher gears) and the transmission went out complete with engine damage (caused from the transmission shifting problem). To tell you the truth, I wanted to return this bad boy altogether and head back to the mazda dealership, but.....I'm the proud owner of a new Honda Pilot like it or not.
    I've got to see the dealer end of this week to have a wind deflector installed, so I intend to have them drive it with me to check out this "problem". I think we all know they'll tell me, "that's just the way it drives, nothing to worry about, just get used to it--you haven't had a new car in a while, dear".....blah, blah, blah.
    I'm not a techie, so give me the heads up on exactly what to point out to them. IF this is indeed a problem for the new '08's, I'd like to help with identifying it.
    having buyer's remorse.....
    Took my 2007 Pilot AWD in for service. They changed the oil and differential gear oil. They also checked the transmission shifts and the fuel trim. No error codes for the transmission problems or the engine/fuel efficiency. The service writer did say he has driven the new Pilots and they seem "weird" to him, too, but he can't fix a problem that does not show-up on diagnostic. I need to call Honda and report the situation.
    I am still getting around 19 mpg on my regular suburban/rural commute.
    Joe
    On March my March 24th post, explained how I took my 08 EX-L 4WD pilot into the dealer and he hooked up the diagnostic PC and we went for a 30 minute drive, recording 1 minute intervals of data. He sent the data out to Honda Tech Line.
    The regional Honda Rep and my dealership’s service director called me today to discuss the results. The word back from Honda Tech Line is that the data shows that my pilot is just like every other 08 and everything is "normal". While the Rep agrees that there IS something wrong with the shifting in his pilot and mine, Honda will not do anything unless more complaints are received. I asked the Rep “How many complaints will it take?”. He did not know… but indicated that unless the problem is a safety issue, a major defect resulting parts breaking prematurely, or impacting sales, Honda would probably not spend the resources to fix it. The 09’s are rolling off the trucks in mid-May, so there won’t be as many 08’s on the street for owners to complain about.
    Bottom line – we’re stuck with these POS’s. I am going to talk with the GM of the dealership and see what I can do to get out my lease or change to something else. Never thought I’d say it, but I’d even consider a mini-van over this pilot. Now I have 2500 miles, still getting less than 15MPG, and the shifting feels like Mr Toad’s Wild Ride. I have do deal with this for another 33 months? No thank you!!! I feel sorry for those of you that purchased.
    For those of you who are having these same problems, make sure that Honda Tech Line hears your complaints. Don't let the dealer blow you off. Then, maybe in a year or two, Honda will address it… or not. I’ll go crazy before then. Good luck to all of you!!!!
    Spacedog
