Honda Accord Hybrid Accessories
Talk about Accord Hybrid accessories here.
I've added the Kenwood FM Modulator and Sirius Tuner to my OEM Stereo so I can received Baseball on XM and Football on Sirius (best of both worlds)
This is due to the ANC "Active Noise Cancellation" system. The ANC actively supresses exhaust system and other harmonics that would naturally occur when the 6 cyl engine switches to the "ECO" 3 cyl mode.
ANC uses the audio amplifier and speakers to do this, and changing the speakers may effect its response curve and replacing the audio amp is likely to kill it.
Talk to a knowledgeable Car Electronics Geek before doing this.
The ANC system should issue a sound wave 180 degrees opposite of the noise made by the exhaust system and engine when the vehicle cycles between the 6 cyl and the 3 cyl "ECO" mode. Thus any speakers hooked up to the stereo should accomplish this since the ANC counterwave generator is probably wired into the vehicle stereo wire harness, unless a high and/or low pass filter is installed and it happens to block that particular frequency.
As you stated above, I would love to hear from a knowledgeable Car Electronics person who is familiar with the 05 HAH regarding any stereo unit upgrade possibilities.
I have to admit that the original stereo and speakers do not sound that bad. I mostly listen to sports games on XM or Sirius at night and soft/classic rock during the day. Thus I am only looking at future upgrade options before "starting" any type of upgrade project. I generally start working with Crutchfield because their Tech Support is great.
Any advice and shared knowledge from other users and car electronics experts is greatly appreciated.
I'm thinking of purchasing a HAH and would like to know if anyone has investigated how to connect an iPod to the stereo system. There are radio adapters that allow you to tune the radio to a certain station to play from the iPod but the sound quality is lousy. What I'd like to know is whether there is a line (or Aux) input on the stereo system.
many thanks!
--aaron
I AM very upset that Honda did not put in a low tire pressure warning, since the pump will not work if the tire gets low enough to run on the rim. THIS IS A MAJOR HONDA SCREW-UP!!!
I am suggesting that every one do what they can to make Honda put the system into our cars as a factory retro-fit. I have told every dealer and filled out as many forms as I can to get them to do this. I am going to see if there is a NHTSA location for these complaints.
Any one have better luck..
Does anyone know if this radio has an Aux input or Mute relay for a hands-free kit?
I installed Boston Acoustics S95 (6 X 9 inch) speakers in the rear deck and Boston Acoustics S65RC (6 1/2 inch) speakers in the front doors in Sep 05. They both are 35watt RMS speakers.
They sound really good with the OEM stereo, yet are capable of supporting a 4 channel amp if I choose to add on at a later date. (I am hesitant at this time due to concerns with the ANC system) The Boston Acoustics website refers to the door speakers S65RC as being designed for Hondas, though crutchfield does not recommend the S65RC for the front doors. The crutchfield adapter for the front door does allow you to fit the 6.5 inch speakers behind the front door panel. (Only modification was drilling 6 holes for the speaker adapter brackets) The front door panel after the installation does stick out a little at the inner bottom, but allows you to close the door without a problem. I look forward to "turning up the tunes" on my daily commute on Monday.
Purchased both speaker sets from www.crutchfield.com. Their sales and tech support people are excellent and I highly recommend them. They are not the cheapest on the web, but they are the best to deal with for after sales support and returns. The Crutchfield directions are easy to follow...just make sure that the door cable is inserted back into the handle pull or you will not be able to exit the front of the car without using the outside handle.
The original Honda OEM speakers are cheaply made. The speaker magnets are a little bigger than a US Quarter. The front speakers are made of a blue plastic cone and the back speakers appear to be some type of polypropelene material.
Good Luck with any upgrades!
David
Does anyone know whether, when the VSA idiot light (triangle w/exclamation point) is on that means VSA is active or does that mean it's inactive. The manual is no help and the "Off" switch doesn't indicate which position it should be in to activate the VSA. Also, is there any reason why you wouldn't want VSA active at all times?
-Noctis
Your music sets the right tone every time. That's because the Accord Hybrid features a 120-watt AM/FM/6-disc in-dash CD changer audio system with XM® Satellite Radio.*
I'll keep digging and see if we can track this down.
This should be a link to something that I've run across in my search to find some way to connect a plethora of auxiliary devices to a Honda Accord Hybrid. The linked device will NOT work with HAH's Nav system, being this device needs to occupy the space that the Nav system does. Unless, of course, one can do without the Nav sysem connected to the stereo for sound through the stereo, but I don't think that would work very well. I won't really get into the installation, being that I haven't actually purchased this yet. The way it's put though, it "should" be easy enough; along the lines of: Set dip switches on device, pop stereo out, plug wires in, pop stereo in, hit aux button on radio to hear, voila.
Personally, I've been doing some research on the HAH v/s TCH. I'm pretty won over from the facts and the the ride of the HAH, but if I went with this car, being the car doesn't have a tape deck (I still use the tape / 3.5mm connector crossover ^^) and couldn't get one without trouble (cost / would take up that nice compartment), I'd have to find some other way of applying peripheral devices.
My girlfriend and I are always going on road trips, and an mp3 player's / laptops's (possibly a dvd player's in the future) ability to plug into the stereo is wonderful. Being that we abhor I-Pods, both the I-pod and I-pod connector aren't for us. Unlike the Civic and Camry (though there are more), which have an auxiliary port built in, the Accord does not. I had trouble finding information about whether or not the '07 models were compatible with this device, but I called the company, and they clarified that this model does indeed work with the '07 Accord and Accord Hybrid. Also, as far as compatibility goes, Radio Shack sells a crossover to switch a 3.5 mm jack (typical size for most cd / mp3 players and headphones) to the Red/White Rca jacks so one could use it for more typical devices.
Again, I haven't purchased this, nor have I heard anyone's account of this product. I'm open to anyone's opinion about this product if they've tried it / had experience with it.
-Noctis
Not sure if Honda intentionally designed this in - since they are part owners of the satellite radio service.
Anyways I've listened to and am not really interested in the XM stations and want to boost my FM to come in clearer and sound like it does on my old 98 Windstar.
Anyone know of where/how I can add a better radio antenna to this car?.
Mike
I just ordered 1 (Chinese made) wheel ($69) & 1 Fusion tire ($60) plus shipping charge @ Tire Rack to use as a spare tire for my son's HAH '05. I have been desparately checking with various Honda dealers to try buying this spare tire for a long time. Tire Rack is my favorite store to shop for tires & shocks, etc.
Now I can sleep with my peace of mind when my son drives back home from his college campus 450 miles away from home. So he has both the air pump and the spare tire. Are you sure this full-size spare tire will fit in the area underneath the HAH ' 05 trunk. My son will be home next week. By that time, I have the spare tire for him already. Happy holidays to you and yours.
