Ford Freestyle Maintenance and Repair
1568101145
  • pnewbypnewby Posts: 277
    Maybe related-? 500 and Montego noises-
    Printable View (51 KB)
    TSB
    05-22-2 NOISE FROM FRONT WHILE TURNING STEERING WHEEL
    Publication Date: October 20, 2005
    FORD: 2005 Five Hundred
    MERCURY: 2005 Montego
    ISSUE:
    Some 2005 Five Hundred/Montego vehicles built 5/17/2004 to 5/17/2005 may exhibit a noise coming from the front of the vehicle while turning the steering wheel at speeds lower than 10 MPH (16 Km/h). The noise may be coming from the upper strut mount. This condition is not related to noise when hitting bumps, noise at full lock turns or noise in turns when the steering wheel is not being turned.
    ACTION:
    Verify concern. Replace the upper strut mount/bearing and/or spring if required. Refer to the following Service Procedure.
  • I have a similar problem. I see all my instrument panel, dash compartment, anndairbag reflect on my window, Ford Motor Co. and the dealership refuse to deal with the problem. I will probably have to enforce our lemon law to get them to act on it. Has anyone have any solutions?
  • Lemon Law? Because of some glare on the windshield? Gimme a break.
    Did you not test drive the car before purchase?
  • chizchiz Posts: 3
    I have had the CD player replaced two times. Once with unit from local depot and once with a "new" unit from the factory. The last two units have the same defect. The unit forgets where on the CD is was when the car was turned off and instead resets to track zero of the current CD when the engine is restarted. This occurs once every two days of driving the car while playing the CD's. Maybe the car is turned on and off 6-8 times a day.
    I have heard nothing from you folks about this problem. Are you just living with it? This is very annoying to me. The regional Ford representative responded by saying the his personal car has this same "feature". The dealer has strongly suggested that I just live with it.
    Please let me know if I'm alone in the woods!
  • "I have heard nothing from you folks about this problem. Are you just living with it?"
    I haven't had this issue. Not with mp3 files, nor with burned audio-CD's, nor with normal CD's from the store.
    I have the 6-disc changer.
    Which radio do you have? Single-CD, or 6-disc changer?
  • chizchiz Posts: 3
    CD player is Premium 6 disc version
  • nitromaxnitromax Posts: 641
    Tips to cut down glare.
    If it's sunny out, wear polarized sunglasses (or at least wear sunglasses...I see way too many traffic jams on the highway because people refuse to wear sunglasses)
    Remove shiny attributes from dash surface. (i.e. don't use glossy protectant)
    Focus on the road ahead instead of the inside surface of the windshield. (that's right, stop staring at the glass and looking for problems, and watch the road)
    Seems to work everytime.
  • My wife and I purchased a new 2005 Freestyle. The car appeared great until the first rain, 5 days after we picked the car up. Water around the front door (front door seal - passenger side) and throughout the luggage area (around the sides on the plastic and soaking the spare tire cover). The carpet is separating from the glue and the car is gaining a moldy odor. Upon investigating for the source of the leak, I found that the one of the ends of the metal tube that the third seat sits on is rusted indicating a longstanding problem. The car was manufactured in 11/04 and came from a dealer in a neighboring state. The CD6 player skips and the DVD does not always come when a disc is inserted - not recognized by the radio.
    We returned the car to the dealer and because, as they explained, the title had gone to the state they could not trade the car for a nonleaking one. The sales manager then stated that he could not repair it and sell it to someone else in good conscious. They gave me a loaner and told me that the Customer Service Manager would investigate the issues. 5 days later he called and told me that he could not find the source of the leak so they wanted their loaner back and told me to pick mine up. We refused saying that the damage has been done and it is not repairable. I returned his car and pulled our belongings out of the Freestyle. The next day I called the Customer Service Hotline in Dearborn and the CSR was very pleasant. She asked what we wanted to do and I stated that we only wanted a comparably equipped vehicle that did not leak. She said that the request would need to go around the office for signatures and we would hear from the dealer in 2 - 5 days. The next day the dealer called and said that the Area Customer Service Rep helped them and found two areas on the body (in the rear) which were leaking. We could opt for repair, trade the vehicle in which would, as he explained, result in a big loss (no kidding), or have Ford buy the car back. You can guess which one I have opted for...I filed the papers (with pictures) with the BBB this afternoon to bring the issue to arbitration.
    This is really a perfect example of poor customer service on the part of the dealer and Ford. I certainly will never buy another car from the dealer (purchased a 'new 97 Cobra and a new '99 F-150 4x4 from this dealer). The jury is still out on Ford but it doesn't look good.
    I will inform the group as this unfolds. :lemon:
  • Didn't show up in a night time drive test. Or when I picked it up at night Only in bright sun light . Enough to cause distraction and cause a possible accident.
    Ford acknowledged they know about the problem and don't know what to do..Meanwhile I'm stuck with problem
    http://www.godashmat.com/Dashmats.asp
    Buy a dark colored dash mat with a flat finish to it.
  • Did you buy anything to prevent the reflection? Ford acknowledged they know about the problem but, they won't do anything to fix it.
  • Thanks for your help. I'll check the dash mats.
  • dairedaire Posts: 35
    I kept reading about this problem here before we took delivery of our Freestyle with pebble interior, and I must say I don't find it to be a problem. I wsa expecting it to be a big issue, but so far it hasn't been, and we have had the car about a month now. I see it, but I can easily focus my eyes on the road rather than the reflection.
  • Our Freestyle also has a pebble interior. At times the dashboard reflection in the windshield is very pronounced. Generally I hardly notice it. I am focused on whats out on the road and see right through it. I don't need to consciously try and ignore it. I wonder if the degree of reflection varies within pebble colored interiors? Or is is just harder for some drivers to see through it? Just like some repetitive or constant sound (for me squeaks) will drive you nuts but when you mention it to a passenger they didn't notice it until you pointed it out.
    Just musing. :confuse:
  • There are certainly some lighting conditions that make the reflection worse than other times. But I think it's generally an issue of just how easy it is (or not) for the individual perosn to ignore and "look through" the reflection.
    I've certainly never considered it a safety hazard, that's for sure.
    It could also be that some of the vehicles have been "armor-all"-d, making the glare more noticeable. I suspect that some dealers do this.
    To me, the reflections I get in the side mirrors are more annoying . . but I think that's been "enhanced" by the tinting I had done on the windows.
  • I can empathize with your problem. We certainly didn't have the same level of problem, but I was AMAZED at how poor the customer service was at our dealer. Our Freestyle was transferred from another dealer in the same state. I saw it in the lot the day before when signing papers. It looked like it had been sitting on the lot a while. The door had a good sized ding. The sales guy promised me they would clean it up and remove the ding. We were heading out on vacation the next day, so I was time pressured. Miraculously, they did fix the ding. When I picked it up and got it home the next day, I noticed a rattle in the trunk hatch and upon further investigation discovered that the rear window had been broken at some point. Pieces of the glass were still in the hatch and under the spare. So now I'm wondering if the car has been used, in an accident, broken into, who knows. I call the dealer 45 min after picking it up telling him I don't want the car and plan to return it until it's resolved. He gives me the whole "title has left the building" story, nothing he can do. He finally gives me "What do you think this is, KMart?" I would have received better service over a 99 cent gallon of washer fluid at KMart! Anyway, a lawyer friend threatens legal action (more out of spite) over how we were treated, they tell us to sue. That's why they have lawyers he said. End of story, we're driving the same car, we didn't pursue it. But I did learn some good lessons:
    1. Always trust your gut - if it doesn't feel right, it isn't. I should have cancelled the deal when I first saw the car.
    2. When looking for transfer inventory, CHECK the build date before buying. Ours was 1/05. We purchased 7/05. I think 3 month lag is more realstic.
    3. REALLY inspect a new vehicle before accepting.
    4. NEVER buy a vehicle from Country Ford in Levittown, NY!
    Good luck. I hope you win! It will be a victory for all of us who've gotten horrible service.
  • bobw3bobw3 Posts: 2,992
    The title thing was a bunch of crap. I don't know who you talked to. Did you take it up with the business manager? Where I bought our car, we could return it within 7 days if less than 1000 miles. I'd say write several letters to Ford (CC'ing the dealer so they know you sent them) giving names of specific people at the dealer who screwed you.
  • We have spoken with both the Sales Manager (who has avoided us after the Service Manager called and told us they could not find the leak) and the, so-called, Customer Service Manager - he's the one who told us we could trade it in. The car, on delivery, had 429 miles on it. In 5 days I put an additional 700 miles (a 130 mile round-trip commute). Basically those at Regal Ford of Winston Salem, North Carolina are being complete and total jerks about this whole affair. We have tried to be patient and cordial, but it's all worn very thin. Time has come to take it to the next level - arbitration, lawyers, and letters to Ford in Dearborn.
    :mad:
  • bruneau1bruneau1 Posts: 468
    You should have contacted Ford right away. Don't expect anything from a dealer that they are not forced to do. Sound cynical? Yes, based on a lot of experience. Good luck and don't give up.
  • bobb5bobb5 Posts: 3
    I have 2005 Ford Freestyle with 4k miles.
    The vehicle recently over heated on the first long drive I took with the vehicle.
    Per the dealership the headgasket had a pin hole or ? and coolant is now leaking into the cyl. requiring a rebuild or a new engine. Has anyone had this problem or coolant lights check engine light problems?
    Car is now in the shop and ford dealership says no rental car!
    Any ideas or suggestions GREATLY appreciated!
    Bob
    I don't know about the engine, but I do know that when I bought the car I signed a statement to let me know that I would not get a rental car while my car was in the shop for warranty repairs. I was told that geting an extended warranty was the only way to get a rental during repairs. I didn't get the extended warranty and while the rental would be convenient, it wasn't that critical for me. Personally I think that for the cost of $25/day for a cheap rental, Ford may lose more money in the long run by turning off customers with this type of policy.
  • bobw3,
    It's certainly not Ford's policy. The statement you signed was no doubt something your dealer dreamed up. You should have politely declined to sign it. Nevertheless, an easy mistake to make. We have so much paperwork thrown at us when purchasing a car, most of us will sign anything just to get out of there!
  • We have just a tad over 11,500 miles on the vehicle so far. Bought it in April of this year. It has preformed flawlessly so far with just a few, with what would be quirks, I guess.
    Every now and then a single "beep" comes from the dash. Today it did it twice. Both times when braking and coming to a stop for a traffic signal at the bottom of a slight grade. It's done it several times over the past months and today I looked to see if anything was amiss with the info center. Nothing. Just the single beep.
    Another weird thing that has happened on several occasions is that the speedometer needle has dropped below its "zero" position. (In the old days there'd be a pin stop but this meter has none.) It has dropped so low as to almost come in contact with the reset button housing. And it always happens when the motor was just shut off and the key was in the off position. If this gauge works like a voltmeter movement, you'd think you just saw a negative voltage spike. I haven't mentioned this to the service department yet but will at the next oil change. It's done it several times although not recently.
    And the most distressing "intermittent" thing happened this morning. Last night I backed the car out of the garage, washed it, and put it back in the garage so this could have been caused by some fouled plugs from those really short run times. But when I started it this morning, it made such a racket from missing and SERIOUS knocking that I thought the engine would come apart. I shut it down, checked the oil, just in case, and then started it. It continued to miss on just a single cylinder, or so it seemed, and then began to run normally. It ran flawlessly all day today. Just a little early in it's young engine life to start that kind of stuff 'cause it sure puts a little nagging doubt in your mind regarding engine reliability.
    And, lastly, I apologize for the post with no verbage. Hit the enter key after typing in the title and off the post went. Don't know why.
  • explorerx4explorerx4 Central CTPosts: 10,938
    "backed the car out of the garage, washed it, and put it back in the garage ".
    we had a taurus it happened to a couple of times. didn't seem to have any long term effect. we had the car for 78k.
  • tayl0rdtayl0rd Posts: 1,938
    I recommend letting the engine run at least 2 minutes whenever you move it like that. My car would run a little rough and have the most awful exhaust smell when I would turn it on and shut it off like that. I've since started letting it idle for a few minutes for each time I move it out to wash and when I move it back in.
  • i noticed the speedo needle behaviour as well on our 06/2005 FWD and also once experienced the strange engine behaviour but it never happened again.
    ours had a ratteling noise from the dash board. there was something loose in the radio area. was fixed and now it is fine.
    got the car back from this service yesterday and i noticed that it accelerates much better and smoother now. also, at 70mph it revs only 1700 now. before the service it always rev'ed around 2500 at that speed. i did not ask yet but i guess that the CVT was re-programmed (a multipoint inspection is mentioned on the service delivery sheet). very nice and it was all for free :)
    last week i saw the first other Freestyle on the road here in Houston!
    Carsten
    So everyone in this forum gets a rental car when they bring their Freestyle in for repairs. Don't respond if you have an extended warranty...I'm trying to see if people without extended warranties are getting rentals...thanks.
    BTW...I'm at 19K miles and the only thing I've done is 3 oil changes.
  • When you took in your car for service, did you complain about the transmission revving too high at 70 MPH, or did they perform the CVT adjustment on their own? I am wondering if dealers would usually go down the list of service bulletins, and perform these on your car as preventative maintenance. I would imagine that the dealer would perform the minimum amount of work, and would only look at a service bulletin if you brought in a specific complaint
  • No, i did not complain because i assumed everything is as it should be. The car was not in for a service (only 2500 mls on the clock) but to fix a ding and to check the dashboard rattling. We did not ask for anything else but there is a multipoint inspection mentioned on the service slip (for no charge). They even cleaned the car in- and exterior! I would expect that they update a car that is still under warranty anytime it is in. I still need to check specifically for a CVT adjustment but the difference is just to obvious, they must have done something. Now i like the car even more :)
    Carsten
1568101145
Ford Freestyle Maintenance and Repair - Page 8 — Car Forums at Edmunds.com
