I guess they couldn't find a better way to program the beeps and buzzers, like just a panel or something.....
No doubt some kind of federal mandate...can't be having people turn off things that will save them, don't you know.
In my opinion, if the beeper sounded for a moment when you put the car in gear, it would make sense. Having it beep while you're just sitting there is stupid.
I can understand it beeping if someone is in the drivers seat, to remind them. But when unoccupied, its silly, as they already have a sensor in the seat.
-mike
-mike
"Temporary: buckle and un-buckle the driver and/or passenger seatbelt 3 times in 6 seconds after turning the car to either 'accessory' or 'on' (varies by year, model)
Disable the seatbelt beeping: buckle and un-buckle the driver and/or passenger seatbelt 20 times in 30 seconds after turning the car to acc."
Let me know if it works...
Fred
http://www.shopsar.com/SearchResults.asp?Cat=382
2020 Ascent Limited, 2024 Subaru Legacy Sport
Dang, really cheap compared to ordering them with the car! Nice!
-juice
I can take a picture of the interior of my car if anyone is interested and post it. I am very happy with the result.
I hope this helps. Good luck!
Len
Also, when driving down the Interstate on the way to work, I heard the chirp indicating unlock and sure enough, the doors unlocked. This happened on 4 different occasions.
At first I though this was defect in the unit or wiring. But one night I was up late and heard through the house window the unlocking chirp from the Forester parked out in front. Upon checking, I found the doors unlocked. I relocked them, but later I heard the chirp again. As I was getting up to go out, I then heard the the two clicks of it locking again.
Then I realized the unlocking on the Interstate occurred each time in the same approximate location. And the unlocking at night happens only in front of my house. It does not happen at the several work locations I visit and park at each week, nor when out running errands.
I can only conclude that it is some sort of interference, but aren't these digitally coded so that they do not respond to stray signals?
Also, they do make randomizers, that people own, they run through multiple codes very quickly, searching for a vehicle that responds. Those are mostly used by thieves in parking lots of the major malls, parking structures, etc.
Have you checked your mileage? Perhaps someone is joy-riding at night, and putting it back.
Len
-Karen in AZ-
-mike
I myself would not take a Forester XT any other way than with a MT. That turbo motor works best when you keep it in the sweet spot via the MT. The AWD is enough safety for me.
I do wish the MT had it but I would not trade the enjoyment of MT for the added safety of VDC. But that is just me and your choice is valid as well.
Should I disconnect and then reconnect the battery, to try to bring things back to normal?
What filter is right? :confuse:
Note. The Fram website lists the forester as Subaru Truck
-Brian
My driver's seat belt tensioner on my '03 Forester X is a bit slack, which prevents the belt from retracting when released, sometimes allowing the door to close on the buckle, which is not a nice thing to do to a seatbelt, or a B pillar, even one as sturdy as mine! Any ideas on how to restore some needed tension to this area of my world?
Happy New Year to All!
PS - Drove a Malibu Max while on vacation last week - lousy traction, wheels regularly spinning, and even prompting my Dad to mention, "This car rides rough!" Too bad I couldn't have my Forester with me.
One thing I did like about the Max, though: it's good brakes. My own seem mushy at 48K - is this a cause for concern or just a basic difference between the two cars? No problems noted at any service inspections.
-mike
-mike
So, that lift appeared to be intentional to get the "truck" rating for some reason. Cafe (mileage) standards are done on all of your vehicles as a manufacterer, I believe, but sub-categories can affect the whole. No one is sure exactly why they did it as they messed up the suspension, in my opinion, to get that extra half inch of height. The 03-05's were designed as a whole and since they have started tinkering with things, I don't think they are improvements e.g. boosting the power steering...
Thanks, I feel better...
PT Crapper is classified as a truck
OB is classified as a truck
It also allows Factory rear tint on the windows if it's a truck as well.
-mike
I guess my Honda Fit is also a truck
I think it's flat load-floor is the criteria.
-mike
Who classifies vehicles for the purposes of CAFE and how is it done?
Authority to establish vehicle classifications for the purposes of calculating CAFE was delegated to NHTSA. Specifically, the definitions are as follows:
1) Passenger Car – any 4-wheel vehicle not designed for off-road use that is manufactured primarily for use in transporting 10 people or less.
2) Truck – a 4-wheel vehicle which is designed for off-road operation (has 4-wheel drive or is more than 6,000 lbs. GVWR and has physical features consistent with those of a truck); or which is designed to perform at least one of the following functions: (1) transport more than 10 people; (2) provide temporary living quarters; (3) transport property in an open bed; (4) permit greater cargo-carrying capacity than passenger-carrying volume; or (5) can be converted to an open bed vehicle by removal of rear seats to form a flat continuous floor with the use of simple tools
Bob
I think we are talking about different "classifications" NHST v. EPA v. someone else.
I'll see if I can find out what the rules are for CAFE.
-mike
Basically if I read that correctly, any vehicle with a fold-flat floor in the back can be considered a "truck" for the CAFE purposes. Regardless of weight, size etc.
-mike
a flat floor alone is not enough.
