-Sounds and feels like driving on rumble strips at 45-70mph LOUDLY.
-Tranny intermitant shifting problems
-Mild intermitant vibration at 35-70 mph in gas pedal
-Diminished Eng Capacity Light comes on and off
- Intermitant 12mph max speed
-Speed/Power cuts out randomly (no more acceleration regardless of gas pedal pressure)
-Trac light intermitantly on
-Check engine light intermitatly on
-Clock auto resets itself occasionally
-Intermitant power steering
-Gas mpg drop to 10 if I'm lucky maybe up to 12mpg
-CD randomly pops out on startup or shut down or while driving
-Vehicle shakes and chugs worse than a disel pickup on start up occasionally
-Cruise control sometimes quits on its own
-Replaced transmission pump/ignition switch
-Torque converter locking up (tech told me potential problem)
-Starter sometimes has issues, turn key and nothing...no click, hard turnover, nothing then wait 10-15 seconds and without touching the ignition switch the truck starts.
-Continually warping rotors
-Clunk on occasion when shifting from "P" to "R" or "R" to "D"
-After startup while idling sometimes there is a loud clunk from the passenger side sounds like someone is kicking the side of the truck
-Windows intermitantly work powering up
-Transmission "whistles" when rpm's going up to shift occasionally
-Radio/CD sometimes just shuts off
That's about all I can think of off the top of my head I have had it in the shop at least 50 times in the past year and they keep telling me their computer doesn't say anything.....last week it lit up like the 4th of July but they still couldn't figure out why all the problems. If anyone can help with ideas that would be great, I don't know what else to do. It is all still under warrenty thank goodness!!!
deerhunter3
SUVs and Smart Shopper
deerhunter3
Anyway, according to past posts the whining noise comes from a worn idle pulley. My 02 has the same noise but not a big issue. Have not experienced the gas gauge problem. Maybe somewhen else could steer you to the right fix.
Hope this helps.
Thanks for your help.
:mad:
After 2 weeks informed by dealer that no front diffs are available because American
Axle is on strike. Ask about availability of parts to rebuild diff told they are available,
had dealer remove diff from vehicle and ordered parts at my work--A Medium Duty GMC dealership. After most parts are bought and installed told ring gear and pinion are not available. Now I'm out lots of money, have a vehicle I cant put back together. and a Spat case that says we will try to find your parts. I will never park another GM product in my driveway. THE CUSTOMER SERVICE SUCKS. THEY DO NOT CARE ABOUT THE CONSUMER AFTER THE VEHICLE IS OFF OF THE LOT. THIS VEHICLE IS MY WIFES PRIMARY TRANSPORTATION, THE RESPONSE FROM GM IS TOTALLY UNSATISFACTORY!!!! :mad:
Can anyone tell me what type of Fuel/Air Sensors are installed in my 2007-TB with a v8 engine... Narrow-band or High-band....?
Unless your mechanically inclined, I would certainly get some help from a friend, knowledgable in that make and model or have an inspection by a professional. There are just too many "if's" when purchasing a vehicle with 111,000 on it. Very hard to say how it was maintained, if it was, or even when the last time the oil was changed. I would seek local help on that one..... good luck....
Curious to the solution and is it something a home mechanic can take care of.
is there really any difference in the bose speakers from the standard speakers? and does anyone know what models would be compatible with my trailblazer? i have no idea.
help me out guys.
I've had a problem with that speaker going on and off for quite some time.
When it stays off I've noticed this additional sympton - all my indicator chimes won't work. The chime for the low gas level, chime for the turn signal staying on too long, and the chime for turning off the daylight headlamps.
The strangest part of this is that when the car sits long enough in the afternoon
and the temperature in the car gets really hot the speaker come backs on.
So when the chimes all work the speaker works or vice versa.
I truly believe it's a control modlue issue not the speaker. Just have not had the time to get it resolved. You may want to check this out for yourself as well as see if anyone else has had this unusual problem.
