The 2nd issue MAY be loose bolts on the PLASTIC intake manifold. Try tightening the bolts, sometimes these come loose and just need to be retightened. This seems to be the problem when we're dealing with damp or cold issues.
If it's not the same thing, how can I check the level of the tranny coolant and how do I refill it? The little pathetic book in the glovebox says nothing about transmission coolant, only fluid. And all it basically says about checking and changing the fluid is to have a pro do it because it's difficult.
Yes, we say transmission "fluid" not transmission coolant, even though the fluid, while a lubricant, does also take heat away from the transmission.
The vehicle no longer starts by just turning and releasing the ignition switch as it normally would - I have to hold the ignition switch until it starts. After the code is gone this works as normal.
After burning off about about 20% of the fuel everything turns to normal and works fine (may have spurts of erratically jumping around down to the 20% mark). In doing research it is clear that there is a major issue with bad sending units. GM dealer also said in some cases a component in the dashboard causes similar issues and has been warranted. They want to charge me $60-120 to diagnose the issue.
If someone smarter than I can help me isolate the issue to the sending unit with some degree of certainty I will drop the tank and replace myself. I can't fix something in the dash so if I can't be comfortable I will have to go the dealer route. I'd like to save myself the diagnostic dollars but don't wish to go through the effort of replacing a sending unit if it might be something else. Any help would be greatly appreciated!
Could you please email me your VIN? I would like to look further into your situation.
Thank you,
Caron, GM Customer Service
You are correct that GM has an issue here and they have been aware of it for some time, yet no corrective action has been taken on the matter. You are not alone my friend and this will be the last chevy that I will buy as ours has been plauged with other issues. We may have just got a lemon.
I'm still open to suggestions. Again, I'm hoping someone with some degree of certainty can help me isolate this to the sending unit. My feeling is that this is the issue but based on a short discussion with a GM service advisor I was left with some doubt after he stating there have been similar issue related to ECM. Vehicle is just off the full mark now and everything is working fine. I hit a full tank and all hell breaks loose.
1.Instrument guages are showing innacurrate readings (ex: false fuel readings, 10 mph speedometer reading, oil pressure displaying excess pressure)
2. When AC is on the truck will stall out when we come to a stop
3. Ignition Coils are going out every other month
4. Auto Transmision slips during first drive of the day.
I have had the truck looked at and repaired at least three times over the last two weeks!
Upset Chevy Devotee!!!!
Anyone have this problem? I am waiting to hear back from the dealer, but I would like to know myself what is wrong.
You may want to let the NHTSA know - the link is at the top of the discussion header.
Now, if you told me you hit a deer, and that your head bounced off the windshield and the airbags never deployed... then, I would guess there is a problem...
regards,
kyfdx
