Dodge Durango Maintenance and Repair
hernandez1
Member Posts: 1
in Dodge
My 1999 Durango started to turn off while driving. It started about 2 weeks ago and I do not know what it is. I tried moving a few cables around the main computer board (top passenger side of the engine)and all<IFRAME SRC=
Ok. Now I have the exact sound but in the front and it has been getting louder and louder almost to the point that you can't hear anything else. I am assuming it is my front end. The alignment is fine, the wheels are balanced and it has new tires. I have checked fluid levels in both ends and replaced the fluid in the transfercase because it seemed to be scortched.
According to Chilton I tested the vibration, (which starts at about 20mph and continuously gets worse with speed), it starts at 2000 on my tach. Chilton says to change gears and see if it does the same at the same rpm. This does not make any difference. According to Chilton this is supposed to mean it is in my driveshaft.
Between my transfercase and my front end there is about an inch of play in the shaft.
Also after driving, the passenger side of the differential was very warm compared to the other side.
Initially presumed I would have to replace the front end. Now after reading through some threads here, I'm hoping it may not come to that.
Any help or advice would be great, thx
marlea3
Like everyone else's, it only stalled during hot weather and I tried all the solutions suggested on these forums including replacing the various sensors.
The only thing left was the PCM (Power Control Module). The dealer wanted $700 to change it out and wouldn't sell me one. Said I couldn't do it because I had no way to program it.
After months of searching I found one at RockAuto.com and they told me it was already pre-programed and all I had to do was disconnect the battery, take out the old and plug in the new. I did and it's now been six months (including VERY hot weather) and no stalling.
The part number at RockAuto.com is 790147. The cost is $216.79 plus a refundable $70 core charge.
Good Luck!
Dave
Mechanics convinced me a new fuel pump was the problem. $390.00 and two
hours later, it stalled again.
Nearing a grand in labor and parts now, the computer brain was replaced only
to have the darn thing stall yet again. Sensors, coils. gaskets, you name it, all
checked, repaired, replaced. Still stalling.
Shame, because the car isn't worth squat to trade or sell because so many
people are aware of the Durango's lousy engines. Wish I had researched the
internet before buying one. Never another Dodge for this family.
:mad:
As far as I know, although both the US and Canadian transportation authorities are currently investigating the issue, there haven't been any recalls or service bulletins issued in Canada or the US. The Canadian site doesn't provide much info. but the US site does. In fact, I suggest you read the letter from Chrysler to the transportation authority, it's very interesting.
Anyway, I will bring my D back to the shop tomorrow and maybe, just maybe they'll be able to find the cause of the problem. I just hope I don't stall on the highway and get smucked by a tractor trailer on the way to the dealership.
One last note.....it's really important that quality issues which aren't addressed by the dealership or manufacturer are reported to the proper authorities. Especially when safety is a concern. The squeaky wheel gets the oil...right?
have you installed the new PCM at the same place without any changes. I read in a other Durango Forum that you maybe shoud give the unit more air to breath (cooling).
Was there any changes in the preformance or is there no diffence between before and after??
Chris
Very intermittant, dealer "cannot reproduce the problem", have had it in the shop 6-7 times since 9/28, cannot fix. Anyone know a good lawyer??.
Anyone else hear of this??
And yes, my outside temp display is usually wrong...
Anyone heard of this?
Sitting in the waiting room talking to a nice cajun lady about her Dodge Durango. She lowers her rear windows doing Fifthty or more and huge sonmic vibration in the car. Weird I did Mine same symptons. Wow. Dealer says don't row down your windows
Water or moisture in oil gives you that grey milky look.
Also the leak can cause air to aerate the water which won't cool worth a hoot.
Lots a luck
easy6
ideas anyone?
Thanks."
My Durango is doing the exact same thing. Let me know if you find anything out. You also need to realize that the odometer is not working until it the speedometer begins to work at 40MPH. This fact just bit me in the [non-permissible content removed] when I went to sell the car. The dealer would not take the car because the mileage is now "technically" unknown, even though it just started happening. I am having the car looked at today. Will update.
Does any one know the wiring colors of the turn signal switch and where the flasher unit if used is located at .
The problem I'm having is that my truck overheats when I'm driving at low speeds. My heater doesn't work very well on in town driving and when I'm stopped it doesn't work at all. The only way to cool my truck down is to stop and put it into neutral and rev the engine at about 2000 rpm's. When I do that my heater works and my engine cools. The truck stays cool when I'm on the freeway and the heater blows very hot. So it is really making this a head scratcher. I'm stuck it has me thinking water pump, electric radiator fan, radiator fan relay, or possibly a partially stuck thermostat?
Any help with this would be greatly appreciated.
A friend told me if I have lower final drive crown and pinions fitted I would get an easier drive and better economy. The dealer has quoted $4000 for this to be done.
Any thoughts on this?
Denimo
PS Does any one know if a one/eighteen scale model of the D is available?
directly centered on top of diff housing. No problem
to change, had the same problem, i think it only took
about
15 mins. to change. Best i remember about 35.00
dollars give or take.
ben
sensor)in the air cleaner inlet side of air inlet system.
Sure would give it a good looking at.As you probabely know it measures amount of air intering intake weight of air
rate of air desisity of air among other things and replaces
the map sensor used on earlyer models. hope this will help.
ben
If my wife were to have been driving this on the highway it would be of a real SAFETY concern.
There is definitely a problem with this vehicle and Chrysler is not owning up to it and is stating they believe the failure rate is low. I would suggest to this forum that we are but a small percentage of folks who have the wherewithal to actually write in to an online forum to describe the problem. Statistics would then show that with as much discussion as we are having about this, that the problem is MUCH larger, with many more folks experiencing this, but just not writing in to tell us about the “anomaly”.
In fact I point you to the National Highway Traffic Safety Administration’s ongoing investigation EA05-018, which can be found at NHTSA DEFECT SEARCH. Once on the page, use the case number EA05018 to search. Review for yourself, and you will find that there is an estimated 420,000 people who are experiencing this problem, with 17,328 complaints filed as of 11/02/05 regarding the same problem.
A summary of the EA05018 NHTSA report:
ON MAY 16, 2005, ODI OPENED PRELIMINARY EVALUATION PE05-027 TO INVESTIGATE COMPLAINTS OF ENGINE STALLING IN MODEL YEAR 2004-05 DODGE DURANGO SUVS AND RAM 1500 SERIES PICKUPS EQUIPPED WITH THE 5.7L V8 ENGINE. INFORMATION PROVIDED BY DAIMLERCHRYSLER DURING PE05-027 INDICATED THAT A LARGE PERCENTAGE OF THE COMPLAINTS ARE RELATED TO AN IDLE UNDERSHOOT CONDITION THAT MAY CAUSE THE ENGINE TO STALL DURING TURNING MANEUVERS. IN FEBRUARY 2005, DAIMLERCHRYSLER REVISED THE POWERTRAIN CONTROL MODULE SOFTWARE IN PRODUCTION VEHICLES AND ISSUED A TECHNICAL SERVICE BULLETIN (TSB 18-013-05) RELEASING THE NEW SOFTWARE AS A SERVICE REMEDY FOR THE IDLE UNDERSHOOT CONDITION. THE BULLETIN WAS SUPERCEDED BY TSB 18-013-05A IN APRIL 2005. DAIMLERCHRYSLER BELIEVES THAT THE FAILURE RATE FOR STALLING WHILE DRIVING DUE TO THE IDLE UNDERSHOOT CONDITION IS LOW AND THAT THE BULLETIN HAS ADEQUATELY ADDRESSED THE PROBLEM. SINCE PE05-027 WAS OPENED, ODI HAS CONTINUED TO RECEIVE COMPLAINTS FROM OWNERS OF THE SUBJECT VEHICLES WHO ALLEGE EXPERIENCING ENGINE STALL INCIDENTS UNDER ALL TYPES OF DRIVING CONDITIONS. IN SOME INSTANCES THE STALLING HAS CONTINUED AFTER THE VEHICLE RECEIVED THE SERVICE BULLETIN REPAIRS. THIS INVESTIGATION HAS BEEN UPGRADED TO AN ENGINEERING ANALYSIS (EA05-018) TO FURTHER ASSESS THE SCOPE, FREQUENCY, AND SAFETY CONSEQUENCES OF THE ALLEGED DEFECT IN DODGE DURANGO AND RAM 1500/2500/3500 SERIES PICKUP TRUCKS.
thxs.
