You Tube " F250 Blue Smoke"
So far this truck has a new radiator, new turbo, new high pressure oil pump, new exhaust filter. The oil pump was probably the real problem but the dealer replaced the turbo and exhaust filter trying to resolve the noise problem. I purchased new to get some reliability, this truck has been a real disappointment.
As for everyone else and their mileage and power issues, I have none. 18 to 20 Mpg (imperial gal not US) highway (keep it below 2000 rpm) and no power loss.
--four visits for engine overheating
--four visits for exhaust odour in cab
--two recalls
--rear main engine seal replaced twice
--cab removed for repair twice
--replaced drive shaft
--replaced radiator & fan clutch
--engine stripped down to the block once
--left stranded on busy highway towing 5th wheel
This truck would likely qualify for replacement under US Lemon Law, but Canada has no such laws, and we are at the mercy of Ford of Canada. To date Ford has shown NO INTERST in customer satisfaction, let alone any financial assistance. To date I have sent three formal letters of complaint to Ford of Canada, and they seem to think that phone calls from pacifiers who cannot speak English will make me go away. They are dead wrong. The gloves are coming off.
of the cost under a after warranty repair program, The rad leak is a known issue call or better write ford and bi*** to your dealer who was to greedy to tell you other wise.
Love this 08 loaded ford f350 Ford had done more for use the dodge ever has.
Prior to this truck we had chrysler products for 15 plus years they wanted 700 plus for a 150 part....they wanted the fist without lube
Yellowhtrd
.Thanks for your help
Aaron
If you look at how many are on the road compared to the amount of complaints, I would say most people got a good truck. I know I did!!!
Wonder why the same truck has such a big difference. Ford will not even attempt to try and help with the big discrepency in mileage difference. By the 1st year anniversary I have been stranded 2 times on the side of the road again needing radiators replaced in both trucks. My tow bill was $800.00 each time since it was on a turnpike. So now I am up to 4 radiators in a year. In the second year I had a hose blow off causing the truck to over heat leaving me again stranded. Got that fixed and in 3 weeks the radiator cracked again and had to be replaced. After all that, if that isnt enough I lost power and had to have EGR sensor replaced. My business slowed up going into 2010 so they were not getting used very much except small local trips. I have 146,000 on the one truck and 101,000 on the other. The truck with 101K is now in the shop because it has no power and I am having to replace the fuel pump which is costing me $3500. They are telling me the whole cab has to be removed in order to replace fuel pump. Every one of these trucks should be recalled and consumers should get a full refund. I spend $1800.00 a month in payments and cant even get through 6 months without a major repair. Luckily the radiators were under warranty. If this track record continues through 2011 now that I am out of warranty I will go out of business. I will not be able to afford these major repairs over and over again and shouldnt have too. Ford is horrible and they will only warranty the repairs for 1 year or 12,000 miles. I want out and I will never buy another Ford again as long as I live.
Oh ya, I only get about 10-11 mpg at best and 8-9 towing my 7,500 lbs travel trailer. I hope you can see my need for HELP...
