Even though both are runflats, those are two completely different categories of tire type. Don't be surprised if the tires on your '09 328i end up wearing a lot faster than you think... (nice choice in car, though..)
Today I went to the BMW dealer near me and obtained the part number for the spare wheel kit which they describe as LUGGAGE COMPARTMENT EMERGENCY WHEEL STORAGE. part number BM - 51470445340. this part number is the same world wide, and includes the 'donut' tools, storage bag and a false floor panel which covers the top of it. The parts guy said They have ordered two in the last week for people.
I will be interested in hearing if anybody follows this up and what the result is.
BTW I test drove an Accord, a Malibu and a Fusion, before moving up to test drive an A4, LaCrosse, A5, A6, C300, C350, E350, IS250, IS350, and the 328i, ended up with the 328i, nuff said.
Even tho both are Florida cars, it's logical that AWD vehicles would be provided with all-season tires. Didn't need an X version, but that was the only way I could get that car.
You care correct, my '09 has smaller tires in front.
After my previous run-flat experience, I will be delighted if get 20,000 miles.
you sound like me with the testing - I've driven the car dealers nuts doing the same thing. Came to the same conclusion about the Beema. Enjoy.
you sound like me with the testing - I've driven the car dealers nuts doing the same thing. Came to the same conclusion about the Beema. Enjoy :confuse:
I installed four Hancook V12 performance tires to replace the stock runflats BTW. This tire is amazing, could not get it to slip, spin or burn no matter how I try, it bites into the pavement this good.
A Fusion and 328i are probably not on anybody's comparo list on the planet except yours for some reason. And why compare a 2011 Fusion to a 5 year old 325? The Fusion is a good car - enjoy it. But compare it to 328i because the RFTs are harsh on broken pavement?
Anyway, the service guy @ firestone agreed to loolk @ the tire but warned me that they don't fix runflats b/c the tire thickness makes it hard to do right unless its a problem with the valve stem.
From reading posts here, I was already prep'd to leave and go somewhere else, after waiting 10 min he actually said that because my car is an 07, they can fix the flat, which they did.
It sounds fishy that they could fix a RFT on an 07, but not a later model. Comments?
Luckily I can live without AWD, I leased a 2011 328i. I also replaced the stock RFTs with a new set of Hancook V12s, I call it the "best $570 option" for my new toy As mentioned by another member, the 328i auto with DS/manual mode, I then turn the DTC on (I only do so on dry pavement), now the only thing I regret is not buying the sport package, because the soft suspension on my 328i suddenly became the limiting factor Can you say that about a Fusion? I did test drive a Fusion just you know.
It sounds like you, like a lot of drivers, value safety, reliability, ease of use, and economy; handling just does not seem that important to you. Fair enough. But if you believe that you are going to convince anyone that your 175 hp 4 or noise-heavy 6 cylinder Fusion steers, handles, or accelerates similarly to the BMW, you got a tough challenge.
Some say, go to a parking lot with current tires and practice should be fine. some say replace with winter tires and rotate each year.
Others still say get rid of RFTs and replace with a good GFT all season
Any input on driving with the current tires?
Also if I choose to go with GFT"S would I have to purchase new wheels also or can I use my factory wheels?
Anybody?
1) I lived in Chicago (and the surrounding burbs) for over a dozen years. The winter weather they get there really isn't all that severe, and as such, my opinion is that a good set of all-season tires is all you really need.
2) Wheels are equally capable of sporting RFTs as well as GFTs, so no, you don't need to buy a second set of wheels for your winter and/or all-season set.
3) With #2 in mind, if you are inclined to change your tires seasonally, then it will be MUCH CHEAPER over a three to four year period to simply buy yourself a complete winter wheel/tire set as opposed to swapping the tires on and off your factory rims twice per year.
4) Were I in your shoes, I'd buy a set of winter wheels and tires and then when your factory rubber is say, 10,000 miles gone, I'd buy a set of summer GFTs. I would then keep the factory rubber to be remounted on the car just prior to disposing of it (either because you're selling it or turning it back in at lease end).
When is it going to be available for BMW cars...
If your space-saver rim is a 17" rim, then I'm sure that is the correct size..
Be certain that you don't already have a spare... On space-saver equipped cars, there is a plastic tray underneath the carpet, that looks only deep enough to hold a spacesaver tire... Un-screw the wingnut, and that tray comes out, and the space-saver spare is underneath the tray.. When you take everything out, there is plenty of room for a full-size spare tire/wheel in there..
regards,
kyfdx
Took the salesman about 10 minutes to figure it out, himself. I've had two other E46 3-series, but they both had full-size spares..
Your key will have to be initialized by the dealer.. Expect 0.5-1.0 hrs. of labor... So, $60-$150.... :surprise:
Bought new 2006 330i.
First set of Bridgestones lasted 24,000 miles then having hardly any tread.. At the time I was 63 years old and the wife was 61. Do not drive hard!
Bought 2nd set of Bridgestones. Lasted 26,000 miles again hardly any treat.
Then bought Michelin Pilot Sport A/S Plus. Have had on for 10,600 miles. LOVE THEM
225/40R-18 FRONT /// 25535R-18 REAR (Sports Package)
I will NOT RUN RFTs again
I have always carried a "donut" spare + tools etc. so that is no problem.
Far less expensive at $1,094.00 INCLUDING Install / extended warranty / chrome valve stems etc etc.
HAPPY MOTORING
So, what are you looking for in a tire?
2) Yes, you can throw the RFTs away and replace them with GFTs (Gets Flat Tires); the best part is that your factory wheels work equally well with either type of tire.
3) Yes, and No. There is room in the trunk for a spare (and a jack kit), however, there is no room below the floor for even a "Space-Saver" spare.
If I ultimately opt for a new BMW with RFTs, I'll yank the RFTs and replace them with GFTs, and in lieu of a spare, I'll simply put a can of goo and a small air compressor in the trunk.
The one exception in the past 10 years is why I will never own a car with RFTs. I was driving from Lakeview, Oregon, to Winnemucca, Nevada, on one of the most desolate (& beautiful) roads in the U.S. There is one tiny town on the highway in 211 miles -- great fun to drive with almost no traffic. One beautiful Sunday morning I was about 60% of the way through the drive when a rear tire went completely flat. I stopped quickly enough to not damage it, took a 20-minute break to install the matching full-size spare & drove without further drama to Beatty, where I spent the night -- on to Phoenix the next day & got the tire repaired. Absolutely a non-event, but with RFTs it would have taken me half a day to even get to a town, followed by an X-day wait for a new tire & highly questionable mounting of it. Guess I could have shipped the bad wheel-tire assembly to Reno or the Bay Area to have them mount the new tire and ship it back. Anyone want to guess how long that would have taken, or what it would have cost?
RFTs were developed for heavily-populated areas (like the Northeast U.S. or Germany) with a major city every 50-100 miles, not for the other 85% of the U.S. and Canada.
So, next question: What size tires are currently on your car?
I'm running Michelin Pilot Sport A/S tires and cannot recommend them enough, they're $134 per tire and provide all the grip I could ever want in non winter conditions (and even then they're not bad).
Honorable mention also goes to a few other models:
$152 -- Michelin Primacy MXV4
$112 -- Michelin Pilot Exalto A/S
$119 -- Michelin HydroEdge
- No matter what product we are talking about, you will find complaints.
- No matter what brand we are talking about, you will find complaints.
- Sometimes customer's expectations are pretty high, and that will generate more complaints. Certainly a BMW owner will have high expectations - and sometimes that expectation is not realistic.
- The only real way to find out if the complaints are excessive is by comparing against otherwise identical things.
- Run Flat tires have been a source of complaints on BMW's. Part of this, is just the normal problems associated with high performance tires. Part of this is just the normal problems associated with BMW's alignment specs. Part of this is just the normal problems associated with BMW "No Rotation" policy. Part of this is just the normal problems associated with the cost of the tires.
In other words, there are a lot of reasons why folks would normally complain, but because these are unusual tires, the complaints are all being grouped as though they are all unique to RunFlat tires - which they are not.
- But there are some legitimate complaints about RunFlat tires. Sorting this out is difficult for the uninitiated. Just be aware that there are many folks who have BMW's with RunFlat tires who are quite happy with them - some were not aware they had RunFlat tires at all!
Of course these are individual anecdotes.
But the problems with BMW RFT's are not some illusion, like aggregating UFO anecdotal reports as proof. There is a systemic problem that BMW has reacted to with dodge and denial.
In our anecdote, my wife is an extremely conservative driver, and her tires became incredibly noisy at less than 10,000 miles, and BMW would not replace them. Many others had flats and were stunned at a cost they had not anticipated since all the marketing was "No maintenance fees until 50k" Sure, tires can be an exception, but such an exceptional cost of ownership so quickly should be disclosed.
They are forced by law to disclose expected gas mileage as an estimate of ownership cost, just as drug companies have to disclose side effects, even if not extreme. There is no law that requires disclosure of the costs of RFT in the "Some may experience..." category, but they could have been forthright about it.
GREAT WRITEUP!
Experience is a wonderful method of comparison. Have run 45 sets of RFTs in 2 BMWs and after the fifth set, will not run again. 122,000 miles of disappointment (re early wear / rough riding / is enough to make a change. First set lasted 21,000 miles / second 25,000 / third 25,000 / forth 26,000 / fifth 25,000. Pattern here! Now at age 67, I would like some reliability in my life.
John
Specifically, I would think there would be two problem scenarios: 1) where the puncture is big or where the puncture is in the sidewall - a can of foam does not seem like it could repair the tire and you would have to get the car towed. 2) In long journeys in rural areas (as described above in the post about Nevada). How many miles does that foam last?
For instance on Highway 395 in eastern CA, you probably cannot get a BWM tire in the 500 miles in between Santa Clarita and Reno. So you would have to wait in say, Big Pine or Lone Pine or Tom's Place a few days (certainly till Monday) for a garage to get it.
Not that I don't like Big Pine but....
I am NOT saying there aren't problems, I am merely pointing out that many of the complaints aren't caused by the tire's ability to operate without inflation pressure. For example, rapid treadwear is the result of the tire being a high performance tire with a tread cpompound being selected for grip rather than wear. Also, irregular wear is caused by BMW's camber spec.
Put another way, if BMW were to discontinue the use of RunFlat tires, the rapid wear and irregular wear complaints would not be solved.
I hope this clarifies things.
If I am up in the North Georgia mountains, or have a flat headed for the Gulf beaches cutting across Alabama, I will be there for a while.
Sorry BMW, you are out of the running for my next vehicle.
There is no chance the Germans will backtrack on their decision to go to run flat tires.
http://www.tirerack.com/accessories/detail.jsp?ID=38
The downside of course is that you will typically need to either repair the TPMS sensor or replace it after usage of the sealant; however, given the cost of replacing one or more RFTs versus the cost of repairing/replacing GFTs, you'll still be ahead of the game if you buy a new TPMS sensor after each use of the sealant.
