Mazda5 Audio & Entertainment Questions
Check these links for a cheaper price for cassette player. www.finishlineperformance.com or www.mazdastuff.com
David
Has anyoe seen this? Any ideas?
Just want to let you know that I got the Mazda Genuine Parts iPod integration kit hooked up in my 5. It cost a total of $249.00. They put the cable in the glove compartment and that is where the iPod stays during use. You don't control the music through the iPod itself. You control everything through the stereo.
To access the iPod when it's connected, you have to depress the CD button until "EX" (for external) is displayed. Then, it has menu options you go through numbered 1 through 6. Each number represents something different, i.e., 1 representes Artists, 2 represents Albums, etc. You scroll through these numbers until you get the option you want and it will start playing. Then you make your selections using the stereo buttons.
I have to admit that it's pretty tricky getting used to it and using it. I just got it last night, and still have to play with it more to get used to it. But, it has its advantages. #1 - The iPod is charged while it's playing, so there's no need for an additional charger and it will play continuously; #2 - the fact that you only control it through the stereo makes it a lot safer to use while driving as opposed to looking for your iPod, looking at the screen and making your selections all while driving; #3 - the sound is great and it sounds just like a CD; and #4 - it's a Mazda Genuine Accessory/Part, so it's part of the warranty and won't void any other part of the car's warranty.
On the down side, though: #1 - it's tricky to use; #2 - it will take you a while to select whatever Artist or Album you want to hear, unless you select it beforehand on the iPod itself and THEN connect it to the system, but even then if you want to select the following track through the steering wheel controls, it will bring you to the FIRST song on your iPod listed alphabetically by Artist; and #3 - they left two gaping holes in the back of my glove compartment, which takes away from its storage capacity and utility since objects can fall through the holes and into the inside of the dashboard area.
Overall, though, I LOVE my iPod hook up. I'm just sad that the two gaping holes are there inside the glove box and that my glove box door no longer opens in a dampened manner, but just PLOPS open with no resistance whatsoever. I should take it back for that, though I don't know if that can be fixed. What do you think?
In regards to the two gaping holes and the damped glove box, I would take it back, make them replace the glove box and have them install or make the hole up in the shelf area. They basically broke your glove box. I'm sure the installation was not designed like that.
i like the idea of controlling it through the car stereo and steering wheel! That's slick. Specially since I only use the shuffle mode in the car. (it give the whole family a random chance of listening to their music). I also love the idea that when you turn off the car, the iPod turns off. Right now I have a DIY solution in my Subaru, but I have to remember to turn off the iPod otherwise I'll burn out the drive prematurely.
I haven't heard about this one. Do you have any details?
See post#37. It has both the ipod interface & aux input. The ipod interface is better than Mazda's since you can control the ipod thru either the headunit or the ipod click wheel when it is plugged in. I installed one of these and it works great. I believe that the price is now cheaper too. Not too hard to install, just be careful taking off the shifter plate.
David
IPOD control is similar to the factory version. Hit the CD button twice and the IPOD comes up. You can scroll through play lists (made in advance) and advance or back-up a song. Song duration displays on the dash but title/artist does not.
Installation was not difficult but it did take about 3 hours, mostly because I was very cautious about taking apart our new car. I routed the cable to the cup holders between the front seats. This location provides much easier access to the IPOD than the glove box but it would also be very easy to run the cables to the glove box as well.
Sound quality is excellent (or at least up to the quality of the factory radio). This little thing made me wonder why I spend the extra money for the in dash CD changer.
My antenna is on the roof next to the radio antenna. I ran the cable around the rear door seal, over the rear step, and along the floor to the front.
The antenna is held on magnetically. Horror upon horrors, when I lifted it up I found a great amount of rust underneath it. Although I cleaned up most of it it looks like some of it permeated the paint. The magnetic metal strips on the antenna look like over time had vibrated and scored the paint.
I suggest that everyone who has installed a magnetic mounted antenna regularly remove it and clean any rust that is present. Also it would be a good idea to protect the paint with a layer of wax or other treatment that reduces the chance of rust buildup without reducing the magnetic holding strength.
In Canada go to https://activate.siriuscanada.ca/languagesetup.do?langpref=en to get the information on activating/subscribing for new and existing accounts.
klaus
http://www.mazdastuff.com/product.cfm?ProductID=2280
Another message in this thread indicated that the DVD system was installed as the cars came off the boat....
DVD is a must, but seems to be what NO dealers are able to get. None of them (corresponding with 5 dealers so far...) have offerred to put the system in on their own.
Yes, I could go aftermarket... but that is not my preference (and I just got a quote on a Dual screen headrest system that is $400 MORE than the dealer rate for the DVD system).
Thoughts?!
vinnyfast, "Mazda5 Audio & Entertainment Questions" #68, 13 Apr 2007 11:58 am#67
if not it says #68 of 91 title Re:DVD entertainment?
hope that helps. follow the links.
http://cgi.ebay.ch/MP3-Player-for-MAZDA-M6-M5-M3-MX5-RX8-CX7-MPV-Premacy_W0QQite- mZ350013456363QQihZ022QQcategoryZ3293QQcmdZViewItem
This looks like the ticket. I did a money converter and it prices out at a little less than $60.00-US
Finally the speedline is back from chinese new year (www.thespeedline.com) and I have finally gotten to order the double din plate. 145.+ 4.00 insurance and 40 to ship it. Alot of money but will be worth every penny to put my Kenwood 7100 double din in with navigation without having every thing on the windshield, and on the seat. I will update as to my progress. I know these dashes are good to look at but so limited in the functions of the radio.
Link to web site screenshot (in case it does not show up below):
http://www.carspace.com/coolmazda5/Albums/audio/premacy_mazda5_rca.jpg/photo/v./- - photo.jpg
Web Site screenshot (in case it shows up here in this forum):
Source:
www.premacy.mazda.co.jp
Thanks in advance,
MS from IL
My money is on the crack pipe.
