Proof?
Friend's 94 tracker, two timing belts and mobil 1 since 34K now has 175K on it. Compression, amazingly, is still completely within specs. It burns no oil and starts and runs well.
I highly recommend synthetic oil for your rig!
mac24 "Jeep Wrangler" Oct 8, 2003 12:07pm
My wife just bought a 2001 Tracker 4dr. 2.0liter, 4wd. It sounds almost like the defroster is on high, but isnt, and also goes with engine RPM's. Is the intake in the dash? Dealer says its a normal sound. Doesnt sound right to me. Noticed the intake is in the inner/outer fenderwell, just like the trucks. Maybe sucking air in through the firewall.....seems like a K+N kit would solve the sound. Do they really all do this? Its really annoying!!!!
http://www.bfgoodrichtires.com/assets/pdf/all_terrain_ta_kd.pdf
Over all diameter revs@45mph
205/75/15 27.3-Inches 762
215/75/15 27.8-Inches 747
225/75/15 28.5-Inches 731
235/75/15 29.0-Inches 717
2. Cavitation? I think you have some bad fan motor bearings.
COVERS: 1999 Chevy Tracker
J/E PLATFORM". Also a picture of the books for sale shows a big J/E printed on the bottom of the book spines. Maybe this is referring to something else other than a type of tracker??
Anyway, maybe you can help -- are the 1999 Trackers basically the same as the 2000 Chevy Tracker? If this manual will work for my 2000 tracker (with 2.0 liter engine) I'd like to buy it, since it's probably much cheaper than ordering directly from the manufacturer.
Check the engine.....I think the 99 and 00 had the same but if not then the 99 will have the 1.6 L engine which is a lot different that the 2.0 engine.
the Equinox will probably be a better overall value than the rapidly-aging Tracker, or you could wait the the Suzuki-version of the Equinox which comes out in 2005 as a 2006 model...it has a better warranty and, as rumor has it, a 3.5L version of the XL-7's engine making 235 HP
Just do a search and see how many pages of modified trackers you'll find and the stuff that is done with them.
So, when I hear they may drop the Tracker next year, I am very thankful that we got ours this year.
Sorry if this is the wrong board to post this but I couldn't find anything else. Anyway, the X-90 has caught my eye and I was wondering if anybody here has had any experience with them. Any info would be appreciated.
Eric
Go to this page to learn how to start up a discussion.
That's what this Edmunds' site is all about... Sharing information.
I had read somewhere on a previous post at another forum, that a person had purchased a "brand new" really expensive vehicle and the city where he lives had a "big time" HAIL storm and really put some dingers in the vehicle.He went to "Dent Wizard" or whatever and had great results.
I didn't know there were so many "Trackies" out there! Just got my Tracker LT last wk, all options except ABS and leather, out the door for only $24,888 CDN!...I have the following dumb questions, having never owned a truck...
1)When in 4WD mode, and I'm going really slow or coasting, and I try to make a tight turn, the transfer case starts to grumble and vibrate, along w/the vehicle. Is this normal and how to avoid???
2) Does power mode and OD work similarly?
3) For what scenarios would you use 4(H) vs. 4(L) vs. 4(2)?
4) When in 4(H), I notice the transfer case shifter can also move to the left. Is the left motion for anything?
5) If the vehicle is not in motion and in 2WD, is it better to shift to 4WD while in Neutral, Drive, or does it matter?
Thanks! I promise my questions will get better. And don't forget to use ansoil 0-W-30 (just kidding!)
2. The grumbling and groaning you hear is major stress being placed on the driveline.
3. If you continue to do #2 above, plan on forking out lots of canadian $$$ for repairs.
4. Your 4wd setup is ONLY to be used on ice, snow, mud, or wet grass.
5. WHy? Because you don't have a center diff to allow for the different rotational speeds of the front tires when going around a turn. See #1 above.
6. This rig is shift-on-the-fly from 2 hi to 4 hi at speeds up to and including 62MPH with the wheels in a straight ahead position. Doing this while making a turn and you can say goodbye to CV joints, possibly an axle and hello to major repair bills.
7. WHen in 4hi, you move left then fully forward to 4 LOW. ONly use this at a complete stop and when you really need some slow going or lots of pulling power.
8. Only use #7 on ice, snow, mud, or wet grass. Maybe loose dirt once in a while.
9. Not necessary to go to neutral unless you are going from 4hi to 4 low. Then place the tranny in neutral, make your shift, and off you go. Remember also to stop when shifting out of 4 low to 4hi or to 2wd.
10. The power mode is a misnomer. IT does not make your engine produce more power. What it acutally does is raise the shift points of your tranny thus making you "think" there is more power.
I also want to throw on some roof cross bars. Will that significantly increase wind noise or is it only minor?
pulled off the road into field and ran over some small saplings, car immediatly stops and i cannot get it to turnover. batterys' juiced, accessories work. turn key and exclamation symbol comes on dashboard, slight hum sound as i do so.
happened at dusk in out of the way location, nearest town 30 mins away. gotta push it away from bushes tomorrow, as i suspect some wire got ripped out er something ? fuse?
arrrgh,
gc
seats can fold flat with room. And the Tracker gets great miles per gallon also. I sold the stock tires that were on there and put on some BFG tires on there and it handles great on the road and off. I've got 11k miles on the clock and hope to last as long as my samurai. Track on!!
Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil resists breakdown from heat, blowby chemicals and oxygen up to ten times longer than do conventional oils,
Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil resists forming sludge and varnish deposits, which contribute to corrosion, decreased fuel efficiency and increased engine wear.
Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil remains fluid at temperatures as low as-60° F
Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil's higher VI provides a better protective film at higher temperatures than conventional SAE 40 oils, while remaining fluid at subzero temperatures.. and the list goes on. But this is just what i use. I look beyond the store bought shelves. Also don't forget a High Quality oil filter. no frams.. lol
where can i get a manual (or something cheaper) for my '95 sidekick?
