I have a 1993 Accord EX. I have owned it for about 3 years now with very few problems. For the last couple of days I have been having problems with the gear shift. It's very difficult to shift between gears. Moving the shifter from in gear to neutral is fine, but moving from neutral to any gear requires great force. Since owning this car, I've occasionally had a similar problem with shifting into 1st gear, but now it's all gears.
Has anyone had a similar problem who can offer some insight?
Mike
but what you are describing sounds a lot like a mis-adjusted or inoperative clutch. i'm pretty challenged in this area, but I'm thinking there is a hydraulic resevoir (clutch master cylinder) for the clutch next to the one for the brakes. look in your owner's manual and see if it describes where the clutch cylinder and resevoir is located, and see if there is sufficient fluid or if there is water in there.
sorry as to not be of more help.
That's exactly what it was. The hydraulic resevoir for the clutch was almost empty. I filled it to the max with DOT 3 brake fluid and now everything is running smoothly. Now I just have to watch the fluid levels to see if I have any leaks.
Thanks again.
Mike
glad it worked out.
If there is an exhaust leak or a cracked manifold/broken stud, the matting on the hood would do little to dampen the noise.
If it is a rod knock or something serious, I certainly wouldn't waste my money on damping the sound if I needed a new engine or a new vehicle.
IIRC there was a sheet of flame-retardant sound deadening material on my hood already. You might be able to find a factory replacement from Majestic Honda or similar.
I don't ever remember either of them being remotely loud when serviced though. The '91 had quite a racket until the valves were adjusted, the manifold repaired, and the mid-pipe replaced. It had a super-heavy duty high performance aftermarket alternator installed that once adjusted, never made a lick of noise. The '93 was always quiet.
I would be reluctant to add one if it wasn't there initially. If the hood itself is rattling and making noise, there might be a spot weld that let go, or maybe you could use "spray on bed-liner" material to dampen the vibration on the bottom side.
This is after he's had a major tune-up done on it (spark plugs, air filter, etc) and checked the tire pressure.... what could be causing this? Is there anything we can do to increase his gas mileage?
Thoughts?
I would probably check/change the fuel filter and run techron or a similar additive to clean the fuel system and injectors. Some people have had good luck with SeaFoam but I haven't used it. Oh, is the car running cool? Sometimes if the car won't heat up fast enough, it stays in cold start mode longer and uses more gas. That is typically either changing the thermostat or the coolant sensor.
You might also want to check the alignment (if the wheels aren't going straight, it puts a drag on the system) and the brakes (dragging brakes obviously aren't so good).
i'd have a new set of high-quality plugs put in the thing.
i'd run a bottle of injection cleaner.
could be a sticking throttle body or fast idle issue.
yeah short trips, failure to really get the thing to temp, and seasonal changes in fuel could have something to do with the lowered F/E.
is the vehicle bogging going uphill, like perhaps it is underpowered?
if so, it's possible the CAT is beginning to loose efficiency and drastically changing the back pressure on the engine. when that happens the available power and the F/E will start trending downward.
his trips have varied from 2 miles to 20 miles, mostly (80% of the time).
i'll double-check his tire pressure and I'm pretty sure he had a new air filter and spark plugs put in (but i'll double check that as well). not sure about the fuel filter.
will definitely add the injection cleaner this evening.
if we could this thing up to the mid-20s that would be more respectable.
that kind of short tripping in stop-n-go, sounds like that is the major factor. vehicle is mostly hanging out in a rich condition.
I would advise against this. The pressure listed on the sidewall is the MAXIMUM INFLATION PRESSURE. As the car is driven, the tires heat up, and the air inside the tire heats up. When air is heated, it expands. This means the tire pressure is above the MAXIMUM INFLATION PRESSURE. This creates an unsafe condition.
Is the tire going to blow off the rim? Probably not. Is that taking a risk? Yes.
*Would the ride quality suck? Yes*
Isn't that 44lbs? I imagine that would feel like you were riding on the rims. Not worth the extra mileage IMO.
on my '02 with 44psi max, i don't inflate to 32 or 36.
i target 39/40.
Roland
Has microfilm online (exploded parts views) for all models and years of Hondas. You can go there and see if the part numbers are the same. If they are, then you're golden, if not, you might have to do some more trial and error.
My guess would be the spindles, uprights, and axles and bearings would be different since the 93 has ABS and the 90s doesn't. Tie-rods are like $30 on eBay, you might want to just get new ones.
http://techauto.awardspace.com/ignitionswitch.html
Have a 92 Accord with 162K. Car was overheating (no red) and mechanic thought it was the temp. coolant sensor (for the computer) and said I could save some money and replace it myself. Bought the Neihous (sp?) brand as instructed. Couldn't get the sensor out (didn't have right tool) and so I (my bad) drove it for a month or so and used the temp. dial to reduce the temp. Fans didn't want to run consistently - sometimes they would, sometimes not. OK, so new radiator because it split a seam on top and mechanic replaced the temp. sensor at that time.
Just before Thanksgiving, was driving up to Morris, MN and the heater is blowing ONLY cool air (it just started blowing cold air - had heat before that).
Drove home with cool air, called my mechanic and he said it was probably low on coolant. Sure enough, opened radiator cap and saw no liquid, so added to top. But, now I don't have heat and it's COLD in MN and the car is still overheating (well, never reached the red zone, but the gauge goes almost to the red and then the fan kicks on and car cools down some.
Usually, the temp. gauge 'lives' around the D for drive, but now, once it reaches temp., it will climb up to the N (drive, neutral, park, etc.) and stays there, regardless of RPM... however, when I come to a stop sign or light, the engine temp climbs. Once I start moving, the gauge drops down to N again.
The really weird thing, though, is the hotter the engine gets, the cooler the air.
My mechanic has replaced:
radiator
temp. sensor
thermostat
coolant flush
heater core flush
some other valve cleaned out
water pump ) which looked fine, by the way but replaced it anyway along with the timing belt and some offset (?) something-or-other belt since he was there anyway
He doesn't think it's the head gasket, because I haven't noticed any white smoke and when re-filling the system with coolant, the air bubbles are clear (no gaseous smell or look) and apparently the oil looks fine and I haven't noticed any fluid leak on the snow where I park.
After he put in the water pump, we ran the car in his shop for at least 20 minutes and the thermostat opened up fine, the heater was blowing HOT air like crazy and the temp gauge stayed on the "D" and didn't climb. Yea! We thought it was fixed!
I started to drive home and approx. 2 miles along, after going up a steep, curvy incline, the temp. once again started to climb but the heat kept blowing Ok. by the time I had gone approx. 8 miles, the temp was almost up to the "P"ark and heater was blowing cool air. Then the road started going downhill (15% grade) and the temp. started to come down some but still blowing cool air. For some reason, the temp will go down slightly when going downhill.
I know I've gone on and on, but this problem has been going on for a long time.
Anybody have a clue what is wrong? I really appreciate any help.
M
You might want to send an email to Elroy5@carspace.com, from your carspace email. See mailbox in upper right hand corner. I believe this one is right up his alley.
M
http://techauto.awardspace.com/overheating.html
And, as we see, elroy5 is here and helping, as always.
Marcia4, welcome to CarSpace! Glad to have you here. Keep us posted.
