http://techauto.te.funpic.org/mainrelay.php
I have recently bought a 1993 Accord 152,000 miles on it and I have a peculiar problem that started about a week after I got the car.
While on the interstate going about 75mph the car jut starts decelerating while my foot is one the gas pedal. It feels like the engine lost its fire or the fuel wasnt ghetting to the engine. After pumping the gas pedal with no respnse from the rpms or acceleration the engine finally revs and then continues like normal. This happened about 3 times on the interstate and when I finally exit the next complete stop I make the car stalls but then starts immediatly afterwards.
I have gotten the car serviced and they checked the plugs and wires, cleaned the fuel injectors/filter (possibly the pump), among other things done in a standar tune up. The car ran fine for about 6 days anf then it happened again. This time the distributor was replaced and the car test driven but the same problem occurred again and they tell me that they could not pin point the problem.
After keeping a log for about 2 weeks I have noticed that this problem only occurs when the gas tank level is below half a tank. As long as the tank is anywhere above half, the car runs splendidly.
So here is what has been checked to mybe help narrow it down, the distributor, fuel injectors and filter, spark plugs and wires. Also sludge in the tank has been ruled out because the mechanic said the fuel pressure didnt change when the problem occurred.
Any help or suggestions is greatly appreciated
troublesome. I have just discovered this Forum and any
help would be greatly appreciated.
You have to take out the clock and vents. They have screws behind them. One behind the windshield wiper arm. Should be a little square cover. Two on the rounded upper part of the instrument panel One behind the blinker arm. Same little square cover. two in-between the radio and A/C controls. The are also four under the middle console. The connect to the "Dash Brackets". You don't have to remove these. It's not necessary. Just makes it a little easier. There are also two on the outer portion of the dash. Kind of in the Door Jam. with little round caps covering them. I hope that helped. Good luck.
With the car out of gear and the AC off it idles at about 900. In gear with the AC on it idles at about 700 and shakes; this is the problem I am trying to correct.
Should I adjust the idle speed? If so, how? I looked for an adjustment screw on the side of the fuel injection manifold, could not find one. I can change the speed by adjusting the throttle cable housing nuts, but this is not desirable because to make it idle properly in gear, with AC on, it then idles too fast when not in gear.
I'm thinking there is some electronic module that should regulate idle speed and keep it constant under all conditions; right?
Any advice is appreciated. Thanks
When driving in stop and go traffic or in town with the AC on, the brake pedal feels like dookie and feels like the master cylinder is going. The pedal is super soft and I can push it almost to the floor. It doesn't seem to happen without the AC on. When it is really bad, I can feel the car pull to the left making me think the right side hydraulic circuit might be weaker.
Brakes are recent enough and look good (pads, rotors). Lines were bled. Reservoir for brake fluid, clutch, and ABS unit all look good. The ABS unit seems to check more frequently now (kind of a moan under certain driving conditions).
Is there a failed idle-up switch for when the AC is on? Is there a vacuum line that is sucking too much out when the AC is on and not leaving enough for the brake booster? Did the M/C just croak?
Any thoughts?
anyway, both times the branch went thump thump thump.
maybe you picked up something off the road surface and for a while it was stuck in the wheel or wheelwell area.
major leak in the radiator? i doubt connected, but it's possible something got kicked up into the engine compartment. anyway, if there was still adequate coolant in the engine and you got that fixed, you are lucky. loosing the coolant completely and having the engine seize up is nojoy.
When changing mounts, did you use a cherry picker or a support the motor from the bottom?
Replacing the gaskets and the PVC and cleaning out the spark plug cavities seemed to eliminate the problem. My guess is the spark plug wires are compromised after sitting in oil for however long, but the car runs much better and the vacuum appears normal. Did I get it, or is this more likely to be addressing a symptom than curing the problem?
The growling to me seems more like a bearing issue than a oil issue, if axle nut isn't uber tight it can lead to bearing failure so you might want to check the spec on that.
*edit* make sure you can get the fill hole bolt off before pulling the drain plug bolt
IIRC, it is a 3/8" ratchet with no socket attached to remove the bolts.
HTH
The only way to stop it is to unhook the battery. This happens intermittently, like in the morning I come out to the car and the fan is going, and I have no idea how long it's been on. Any ideas/solutions?
Cheers
I did a drain and fill of the cooling system when I changed the thermostat and the heat was better in the winter and car has stayed in the middle all summer including today (95+ degress)
a friend told me, thermostat not a problem in Miami. So it must be the sensor. Already ordered the hayne manual.
thank you!
pull one of the power door relays (check if same part number) and slap it into the fan relay spot, and put the fan relay you just took out in the glove box.
drive it for a while and see if the fan now behaves as it should. if so, replace the power window relay swapped in for the fan relay with a new one and toss the thing in the glove box.
Make sure there is enough appropiate coolant and water in the system in the right mixture, you can check the voltage across the temp sensors (I believe there are 3) and given the age/mileage of the car, you may want to change the thermostat too.
im need to replace my front brakes i have done this job many times on other cars but i really dont want any surprises when i take the front tires off does any one have any tricks or a pic of this ps i lovemy car its 325000 km on it fantastic and many more to come thanx all dice
does any one know whats wrong?
2nd thing is the passenger rear wheel make a loud bang when i hit bumps in the road have replace the strut already
does anyone know whats up with it?
little back ground on it the car has 16" wheels with 215/50 on all 4 corners 4-2-1 header aftermarket cat and 2 1/4 pipe to the muffler (also aftermarket do not know model number) strut brace in the front and cold air intake in the fender
thanx for any help dan
--LEB
It has to be Electrical because when your sitting still, there would be a clicking noise in the shifter between the seats. WHAT"S THE PROBLEM? I'm getting frustrated.
With the headlights on, the rear running lights don't work. With the headlights and left signal on, everything works. With the headlights and right signal on, the running lights don't work. On the running lights setting, the running lights work fine.
Any clues :confuse: ? A lighting relay? Wiring?
HTH,
LEB
i removed mine last year, there were a couple tricky part or spots in order to remove the front bumper.
or you can email me at roclimber@shaw.ca
would like to have it fix before the snow comes but am not sure where the problem comes from. is it the riser bar or is it the windown guide insdie the door.
comments are appreciated.
Thx
