Honda Accord (1998-2002) Maintenance and Repair
13940414244
  • jeneyjeney Member Posts: 9
    I have a 2001 Honda EX sedan. Lately I hae been noticing that when I back out of the garage in the morning and then shift to drive, the gas pedal sticks for a moment and then I get a burst of speed. After that burst the car runs fine. This only seems to hapen the first time I use the car in the morning. I live in Southern California, so it is never very cold in the morning. Any ideas????
  • mrbill1957mrbill1957 Member Posts: 823
    Do you accelerate at all when you back out of the garage and then go forward? What happens if you press/release the gas pedal before you shift in reverse and start backing?
    I've aleady had the throttle stick a little on my 04 Accord which was due to the throttle plate sticking. A bit of cleaning solved my problem.
    Mrbill
  • rtr83rtr83 Member Posts: 1
    I have a 1998 Honda Accord that died while I was driving, now it will crank over but will not fire. Power windows stopped working and nothing lights up on the dash....? Any ideas?
    I tried your suggestion and it worked this morning. Before I put the car in reverse and while the car was in park, I pressed the gas pedal 2 or 3 times, then put it in reverse and then shifted to drive and I did not experience the burst of gas. You mentioned it was probably due to the throttle plate sticking. Can I have the Honda dealer do the cleaning without charging me a fortune?? Thanks for your advice.
    I've always done the cleaning myself so I'm not sure what the dealer will charge. If you only have the throttle body cleaned, I'm guessing it will be $100 or less (but I could be wrong), if you have the throttle body, intake runners, and injectors cleaned, it will be more.
    Mrbill
  • fast_sk8erfast_sk8er Member Posts: 5
    Wow. Works like a charm. Had the exact same issue on my 98 Accord after the battery drained because I left lights on. 15 second fix! Thanks!!!
  • georgew1georgew1 Member Posts: 31
    Your are welcome. Glad to help.
    George
  • nlsnls Member Posts: 65
    Car has 120K miles, clutch was replaced at 45K by original owner just before I bought it in '04, and last year at 110K. It is smooth when engine is cold, but over time there is jerking during shifts, especially lower gears. The shop which did clutch replacement last year is saying that it might be because of leakage into clutch cylinder, another shop is saying that it doesn't seem to be a hydraulic issue, but related to clutch plates or flywheel, so it has to be dismantled to see what is going on, which of course is labor intensive. Any suggesitons would be appreciated.
    you mean a "grabby" clutch---sudden, harsh engagement? Yeah, that could be a rear main seal leak on the clutch, or bad springs in the pressure plate. I only hope they aren't mistaking it for an engine misfire.
    Yes, it is like when one is learning to drive a stick shift car, the abrupt engagement. It is not there when the car is cold, gets progressively worse over time, small jerks initially and a lot of vibrations as the car is driven longer. It is definitely not a engine misfire. Most noticeable from stop to 1st and 1st to 2nd. Entire clutch assembly was replaced last year, but it was probably an after market unit, not a Honda factory original, if that indeed exists.
    yeah well one has to be careful to check the source of parts that a shop is using in your car.
    When it comes to a clutch I have two rules: one, use the best parts you can buy, and two, replace everything---every bushing, seal, spring, etc.
    You don't want to have to be in there twice is my reasoning.
    Supposedly the mechanic replaced the entire clutch assembly rather than individual parts, but it is possible that flywheel was not replaced. What is the most likely issue when the harsh engagement is not there with a cold engine, and becomes progressively worse as the car is driven for longer periods? Can it be anything else which doesn't need dismantling the clutch again?
    I'm thinking as we speak....hmmm....I suppose a fluky hydraulic slave cylinder that's binding in parts of the piston travel???
    I wonder if your car has a little inspection plate where someone could peek in there?
  • mgcoaltermgcoalter Member Posts: 3
    I have recently had some problems with my car starting. The first time it happened the engine would start and then turn itself off. I waited about an hour for AAA to show up and then the car started. The second time it happened the car just went to battery power or, as AAA told me when they showed up, to accessory. They told me to jiggle the key to get it to work. The third time I had the problem I tried the AAA trick and the car started after a few minutes instead of closer to an hour.
    I think the first starting problem is different from the other two, but for both issues I have taken the car to a shop and the mechanics have not been able to reproduce the problem so they haven't been able to figure out where the problem is. I have heard of someone else with the same year and make car with a similar issue, but again mechanics haven't been able to figure it out. Has anyone else out there had a similar problem? I am tired of trying to explain the problem to mechanics and only having the car not work for me.
  • mitchfloridamitchflorida Member Posts: 420
    Sounds like a faulty ignition switch. Honda had a recall for that issue.
    Thanks. Maybe if I tell the mechanics that they will finally find the problem. I don't quite get how the dealership didn't suggest that since I would think they would know about recalls. Really, thank you. A suggestion about what the problem might be is a lot better than my current situation.
  • aepeteaepete Member Posts: 2
    A few days ago my mechanic replaced the ignition switch on my 1998 Accord LX (it had been stalling when I tried to start the car). This fixed the stalling problem, but when I got home from the mechanic and tried to lock the car with the remote, the remote didn't work (although the battery still lights up). The remote was working fine up until this point. I replaced the battery, and no luck. So I brought the car back to the mechanic, who tried reprogramming the remote. Still no luck. The mechanic says that I will need to take the car to the dealer to have it fixed. He says that the remote entry has nothing to do with the ignition switch they replaced and that it's just a coincidence that the remote stopped working when it did.
    Does that seem plausible? Or could this problem in fact be related to the work the mechanic did on the car?
    Thanks for any feedback!
    If the locks on your '98 Accord don't work from the switch inside either and if the passenger windows don't work, try this before you take it to the dealer.
    With the ignition switch off, turn your window wiper switch on, the intermittent speed about half way. Push the odometer button and hold it while you turn the key to ACC. That might fix it and save you some hard earned $$$$'s.
    George in IL.
  • newshiftnewshift Member Posts: 2
    edited May 2012
    Hi, thanks for all contributions to this great form.
    There is 99 Honda accord, when it is shifting at the take off, it makes a clunk noise. This also happens when you make a full stop. I showed it to mechanics and had different opinions. One told transmission should be replaced, inside is bad. Other told one of sensors is not working well, so it is not shifting properly.
    Do you have an suggestion about what is going on, and what is the best way to detect what the real problem is?
    The locks do work from the inside, as do the windows, but thanks for your tip, George.
    I wish I knew if the remote entry problem could be related to the ignition switch so that I could decide whether to keep pressuring the original mechanic to fix it. It's frustrating to have the car come out of the shop with things broken that weren't broken before!
    Amy
    Are you talking about an actual metallic clunk you can hear, or just a harsh shift up and down?
    Amy,
    I'm sorry you are having such a mysterious problem. I can't help but think something is wrong with the remote. I know you replaced the battery but why not see if the dealer has some way to check the remote unit or is there a universal remote or something they have that can prove that your car system is good or bad. There must be some way to prove one or the other is bad. A HONDA dealer can't be that inefficient but many are.
    George
    edited May 2012
    Having a starting problem again. I tried opening and then re-closing the gas cap like a family member suggested, that didn't work. It was almost 90 degrees here today, so maybe that is the problem? I think I read somewhere about people having a similar issue in warm weather. Any other suggestions as to what the issue might be?
  • propwash49propwash49 Member Posts: 38
    Accords are pretty famous for having problems with the fuel pump relays, especially in hot weather. Sometimes you can hear if you have a problem. Open the trunk lid so you can get your head down right over the gas tank. Have someone turn the key to the on position, but do not try to engage the starter. You should hear a short buzzing sound as the fuel pump comes on to build up pressure in the system. The sound should stop after a second or two. If you don't hear this at all, it's possible that the relay is defective and the fuel pump is not operating. If the relay is the problem, it isn't too difficult to replace yourself, or any reputable garage should be able to take care of it for you. Good luck,.
  • andrew27andrew27 Member Posts: 5
    Suddenly my Accord 2000 EX V6 check engine light on (I reset it and it is back on after a few days). And more importantly, mileage suddenly drop to around 9 mpg!
    Any clue?
    Well the clue is the check engine light, so get the car scanned.
    Offhand, could be lots of things---bad 02 sensor might do that, leaking injectors, low compression, faulty timing....
    You might check your oil and if the dipstick is way overfill, that would be a big hint for us.
    But by all means, have a scan done. I think OReilly and Autozone still do them for free for you...and GET THE NUMBER of the code when you come back here.
    Engine code: P0401. Exhause Gas Recirculation Flow Insufficient Detected.
    With very low gas mileage, any educated guess on what goes wrong?
    Bad egr valve, plugged egr tube----sure, that'll contribute to bad gas mileage depending on how the EGR is stuck---if open, that's not so good.
    I can't say that the effect on MPG would be drastic, but it's a good first step. You might also want to check when you had your last tune-up and/or compression test.
    also check your dip stick for signs of overfill--you could be leaking fuel into the crankcase from leaking/dripping injectors.
  • bahaybahay Member Posts: 4
    Have you checked starter?
    I found on Ebay. I had the same problem with my clock. I changed bulb. I purchased on Ebay for about $4.
    I don't know if you tried this...if not, try it...
    Entering the programming mode cancels all learned keyless remotes, so none of the previously programmed remotes will work. You must reprogram all of the keyless remotes once you are in the programming mode.
    You must complete each step within 5 seconds of the previous step to keep the system from exiting the programming mode.
    1. Turn ignition switch to ON (II)
    2. Press the LOCK or UNOCK button on one of the remotes. (An unprogrammed remote can be used for this step.)
    3. Turn ignition switch to LOCK (0)
    4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used in step 2
    5. Turn the ignition switch to ON (II)
    6. Press the LOCK or UNLOCK button on the same remote. Make sure the power door locks cycle to confirm you are in programming mode.
    7. Press the LOCK or UNLOCK button on each remote you want to program. Make sure door locks cycle after you push each remote button to confirm system has accepted the remote.
    8. Turn the igniton switch to LOCK (0) to exit programming mode.
    9. Test remote
    edited July 2012
    Hello to all.
    I'm almost close to change transmission fluid, power steering fluid and brake fluid. I have a 2000 Honda Accord v6 sedan.
    Today I called Honda dealership to know how much they will charge for the service shown above and the person who does that service told me the following prices:
    Transmission fluid service - $99.50,
    Brake fluid exchange - $147.20,
    and power steering fluid exchange - $104.19
    Also he said that those prices include fluid, labor, shop supplies, and tax.
    I need advise. Is it to expensive to do it in dealership or it can be done more less in other places such as Jiffy Lube?
    Thanks in advance.
  • blufz1blufz1 Member Posts: 2,045
    Best to let the dealer do the service,particulary,the transmission fluid drain and fill. Those prices are in the ballpark. I think my dealer charge $75. to do the trans drain and fill.
  • tseverson1tseverson1 Member Posts: 13
    I do not possess the skills to repair much on my 2001 Honda Accord EX.
    On Tuesday my auto repair shop put on new bushing(s) and link(s) on the left front control arm (driver’s side) because of a squeaking noise in that area. On Friday afternoon I heard a strange new noise coming from the motor area of the car. I opened the hood and saw the alternator was not aligned correctly. I drove the car about 20 more miles on Friday and did not hear any more strange noises.
    This morning (Saturday) my serpentine belt on the passenger side shredded when I started the car in the morning. I looked at the alternator and saw a loose bolt which caused the alternator to twist off center and the serpentine belt to shred.
    I can come up with two possible causes for this situation.
    First possibility: The shredded belt is a late result of the work of my brother (a very accomplished do-it-yourself mechanic who has a separate 2 stall garage for auto work) when he and I put on a new alternator over 6 months ago. Perhaps it took 6 months for the bolt to loosen and cause the problem.
    Second possibility and my question: Is it possible the mechanic who put on the new bushing(s) and link(s) on the left front control arm needed to loosen the alternator located behind the radiator on the right front (passenger side) of my car to accomplish his work?
    Your opinions and thoughts are greatly appreciated.
    One shouldn't have to touch the alternator to work on the control arm, no.
    As for your brother--it's pretty hard to trace something like this back to a job done 6 months ago. More likely, just vibration worked it loose, or perhaps the threads on the bolt (or worse, the block itself) are damaged. I'd certainly inspect those things carefully before proceeding with a repair. It's also possible some bracket could have broken.
    Thanks for your reply and your useful information.
  • yusuf1yusuf1 Member Posts: 17
    Greetings all. Supposedly got the ac fixed a month ago, then 2wks later it's blowing ambient air again. The mechanic did install a used compressor though. Took it back to him, he put some freon in and it blew cool just for that day now its back to regular air. Basically I'm tired of putting money in and have started looking at newer vehicles. Could this be an easy fix though?
    Condenser maybe? Is it worth it with 282000 miles on it? Just thinking of cutting my losses. Any opinion would be helpful..thanks.
    Well, if he put freon IN, that means that freon leaked OUT at some point, so...where all leaks repaired and tested, first of all?
    Could be an expansion valve....you should perhaps go to an AC specialist and have the system tested.
    As much as it might cost to fix the AC properly, it's still way cheaper than another car. Presuming yours runs well and looks good, it would be worth the investment. You should be able to run the car up to 225K--250K.
    Thanks so much. I agree it would still be "cheaper to keep her" but its now at 282000 miles and I'm just suffering from car fatigue..we'll see.
  • dcman19dcman19 Member Posts: 4
    Hey so I think I might be having a similar problem with my accord. It's a 2001 Accord ex I just drove it over 200k miles. The problem has been going on for about 6 months now. Although I think mine might be slightly different; the only time the a/c doesn't work is when the dashboard a/c lights won't turn on. But once the a/c lights are on the a/c works great.
    I've spoken with a friend of mine who is great with cars and he thinks it could just be a bad ground behind the dashboard. Problem is if he is right I have absolutely no experience with dashboards and those can be very complicated.
    So question is if he is wrong what is the problem and if he is right where can I get reliable info. on how to remove the dash and fix it?
    Thanks for the help.
    I don't think that's a plausible diagnosis---the AC light won't go on because the AC circuit hasn't engaged the compressor.
  • therivertheriver Member Posts: 70
    02 sedan automatic with 135K. The bulb on the floor shift blew. No big deal, but is there an easy way to replace. I looked on-line and saw some directions but they were not right on for this model/yr.
  • belwah87belwah87 Member Posts: 23
    I've got a 2001 EX-L V6 that I'm about to try to sell. It has 81,000 miles on it. For about the last two years, the odometer often doesn't display the mileage in a readable form -- some of the lines on the readout don't show up, so you can't see the mileage. The miles change properly, it's just impossible to read them on the odometer at times. It doesn't bother me that much, and the problem is intermittant. Unfortunately, the dealer when doing scheduled maintenance one time recorded the mileage in the 90,000 mile range, even though it was really in the 70,000 mile range at the time, and it was reported to Carfax, so now it looks like there's a mileage inconsistency (even though the car really does have only 81,000 miles.)
    Three questions -- any idea how I can fix the odometer display so that it always shows the miles driven? How much is it likely to cost? Can I fix it without making it look like I've played with the odometer?
    Ok thats fine, I'm guessing that also explains why the a/c blows normal air no matter what the speed when the light won't work. Is the compressor working even though a/c isn't then? I get the feeling it's an electrical problem with getting the air cold. Because everything else about the a/c system works great. I've also noticed that the mileage number tends to short out so only the bottom half of the numbers on the odometer show from time to time. Is the problem related?
    yeah even if you have automatic climate control (that is, just dial a number), the AC light has to be on for the AC compressor to be presumed to be working. If you observe the AC clutch on the front of the compressor, you'll see that the front half spins with the belt, but the back half won't turn unless it gets an electrical signal from your controls.
  • sahondabuyersahondabuyer Member Posts: 11
    Anyone know the best (and cheapest) place to buy replacement carpet floor mats for a 2001 Accord? I've seen a few option online but most don't look like the original ones.
  • jodar96jodar96 Member Posts: 400
    The 2001 Honda OEM floor mats at an on line Honda dealer; H and A Accessories in Citrus Heights, CA cost $64. I buoght a set for my old 2001 Accord. Those 98-2002 year mats were top quality and heavy weight mats.
    The newer model Honda mats are thin and cheap and cost the same!
    Joe
  • johhnywalkerjohhnywalker Member Posts: 1
    So my boy had to get his car inspected but it failed due to his SRS light being on so he looked on line and read something that said he could turn it off with a paper clip. He messed up and stuck the paperclip into the SRS fuse port and im guessing it shorted the car because now nothing works. actually his headlights and his inner lights work thats it, he has to use his key to open it....Any suggestions??
    Oh p.s I told him not to jump it because i did not want to cause more problems
  • lll3lll3 Member Posts: 10
    Is there a specific blend of oil required for a 2000 Honda Accord ( only Honda oil) or may any brand oil be used so long as the weight is proper? Thanks.
