Honda Accord (2003-2007) Maintenance and Repair
1189190191193195
  • wise1wise1 Posts: 91
    Thanks. It didn't work when the neg. cable was removed for 12 seconds, but it did work when the neg. cable was removed for 12 minutes!! THANK YOU. ;) ;)
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 52,155
    Well I think I said 2 minutes, so I was only wrong by ten minutes---and what's 10 minutes in a lifetime? :P (unless of course it's your last 10 minutes).
    Good work! Glad to hear this has been squared away! :)
    MODERATOR --Need help with anything? Click on my name!
  • Kirstie_HKirstie_H Posts: 10,989
    Never know, Shifty. We're pretty close to the 21st, end of the world and all, and you're suggesting using valuable final moments on WAITING. :)
    Share your vehicle reviews
  • I had to have my hose replaced in June after noticing smoke coming from the engine. I am told by the company that I will be reimbursed for my costs( remains to be seen) but not provided a new "heat resistant" hose because the repair was not completed by the dealership/ is an "aftermarket" part. My question is this; is my aftermarket part likely to be suitable or Heat resistant? I have been told that the original hose was probably a lesser quality hose and that the aftermarket hose is better quality, which is what they are scrambling to "manufacture" for replacements. Any parts people out there?
  • Too much heat is going to destroy any standard material hose if it gets too hot. I would guess they are installing a hose with a higher temperature rating, or even an insulated one.
    What about insulating the hose you installed? As an example:
    http://www.oreillyauto.com/site/c/detail/DES0/010408/N1808.oap?ck=Search_N1808_-- 1_3276&pt=N1808&ppt=C0379
    Mrbill
  • elroy5elroy5 Posts: 3,741
    When I replaced my hose, I looked at all the aftermarket hoses, and none of them looked like higher quality than OEM.
  • I have have a 2005 Homda accord. About a year ago the stereo stopped working. I've already called Honda to have it fixed, they won't unless I fork out $800, not gonna do that.
    The radio turns on, the display lights up like it should, I can switch stations and turn the volume up and down. I can insert CD's and eject them normally. The only thing I'm getting no sound from the radio, after about 10seconds I get like a static/ white noise sound through the speakers which I cannot turn up or down with the volume control.
    Just looking for answers if anyone has had the same issue or may know if its fixable, what ill need to do to fix it.
  • buyahomebuyahome Posts: 26
    edited February 2013
    Have you tried looking under the radio to be certain the wiring harness is securely plugged in? I'd suggest unplugging and waiting a minute or two and reconnecting the power and the speakers. Be certain to have your radio codes available including Navigation code if applicable.
    You may need a mirror to see the bottom of the radio. There are plenty of video on YouTube showing how easily the radio can be taken out or inspected for loose wires. Good luck.
  • Honda30Honda30 Posts: 16
    Received a coupon from my local Honda dealer offering to replace my Accord cabin air filter for only $69.95. Last year it was $59.95. Inflation I guess!
    For those of you who would rather save your hard earned money, this is a simple 5 min. (yes, even if you haven't done it before) do it yourself job that can be done for less than $20.00. That's a savings of at least $50.00.
    If anyones interested I will post the how to.
    My 2007 I-4 SE is at 20% and soon is due for a oil change. Its been a year now and about 6500 miles. From the first oil change to now I've always used Mobil 1 synthetic, should I go ahead and change when the wrench appears or would waiting till the oil had 8000 or so miles be o.k.?? I've been putting a drop on a white paper towel and it still looks clean. Amber in color not dark at all. Oil prices are continuing to go up and I don't want to needlessly be wasting good oil!! :shades: :shades:
    My two cents is that unless you perform an oil analysis, I wouldn't push past 7500 miles on an oil change.
    Well it turns out it has 5719 miles on it and it still looks clear and amber in color. Where can I get an oil analysis done and how much does it cost?? How reliable would the results be?? :shades: :shades:
    edited April 2013
    Yeah, oil analysis is pretty good. The color of your oil is not a guarantee of its present chemical status.
    Here's one well-known company, along with their pitch:
    http://www.blackstone-labs.com/what-is-oil-analysis.php
    Their FAQ tab is actually rather amusing. :)
  • jmaxejmaxe Posts: 198
    Seems way too soon to change synthetic oil.
  • imidazol97imidazol97 Crossroads of America I70 & I75 areaPosts: 20,174
    edited April 2013
    Like Mr Shiftright says, Blackstone is one. I have used them and they are good. Call and ask for a container free that they send you to use for shipping the oil. Takes 4-7 days by USPS to get to you. Pack it as they say on website and ship the container buying the stamp (sticker) for it by weight at the post office. The label is on the box already. If you go to PO desk, there is a paper on website to show if the clerk questions oil as being flammable--it's not. $2 to ship. $25 for analysis. I would add on the $10 for additive analysis to see how much is left at your mileage when you send the sample.
    Blackstone called me on first one. I don't know if that's typical--mine had a surprise in the analysis showing a slight Na and K increase (sodium and potassium) indicating coolant traces in oil. Turned out to be a seep at the throttle body gasket on 3800--almost a service item.
    They show a sample analysis result page you get by mail on first one and by email on successive tests. http://www.blackstone-labs.com/report-explanation.php
    They do write helpful comments about the analysis just as they did in the sample. Your old test results are kept on their website IIRC under your email. So if you lose the email you can retrieve them later.
    I agree with other post that you might run up mileage more and then change oil, catch sample in middle of drain stream, and it will be worth the $25-35 just to know.
    2015 Cruze 2LT, 2014 Malibu 2LT, 2008 Cobalt 2LT
  • ezshift5ezshift5 West coastPosts: 855
    ...that this 2005 Honda Accord 6M V-6 coupe has been in my garage..........................
    I have been very impressed with the longevity of components......
    At circa 130,000 miles, the factory original elements noted below are still in place............
    1. Brake compoments
    2. Clutch
    3. The Iridiums
    I was at a local bar (eating lunch) and a north valley auto repair shop owner said (I wrote it down on a cocktail napkin (comes with lunch). "Those Iridiums will go 200,000 miles. Who knew? (My OM indicates 105,000 for replacement.)
    I sort of feel guilty (this month I plan to replace my 1982 VW diesel pickup - - - with 'nuther VW oil burner at that)
    all the best, ez
    Might be worth $25 the first time just to see what 7,500 synthetic oil looks like and how far it has to expiration. That way, you'll know in the future how far to push it.
    While I am no fan of wasting money, pushing a synthetic past 7500 seems to me an awfully risky way of saving $75 bucks.
  • dudleyrdudleyr Posts: 3,469
    What oil burner are you getting EZ? They don't make a pickup anymore - wish they did.
    Toureg? Passat? Jetta? Golf? I came pretty close to a Passat diesel recently, but wound up with another Accord (Stick of course). Hard to beat the reliability and durability. I changed the irridiums at 120k and they still looked fine (already had the new ones so I went ahead with it), Still have front brakes original at 161k, same for clutch. I did have to replace rear brakes because I dented the e-brake cable and it rusted shut, keeping the left rear engaged for a while before I got it fixed.
    Only repair in 161k was a new O2 sensor at about 110k. $90 and 15 minutes of my time. Use Mobil one 0w-20 and Pur1 synthetic filters about every 9k.
    VW JSW TDI 6M now alongside HAV-6 6M in my garage.
    Love the wagon/dislike the heavy computer presence (plus attorney-written OM - NOT user friendly)
    Accord continues with factory original plugs, pads, rotors and clutch at 132,000.
    If the TDI can get anywhere close to this Honda from almost any measurement standpoint, I'm one happy (former) sailor.
    all the best, ez
  • smpear1smpear1 Posts: 1
    I recently replaced my battery and the radio code is not working, I get ERR 1, 2 etc until I hit all 10 allowed. I disconnected the neg battery terminal to give me another 10 tries but each time it gives me an error. I have used this code successfully every other time I have replaced the battery so I cannot figure out if I am missing a step or if maybe the radio lost its code somehow.
    Bascially, the radio (non-NAV BTW), will spell C-O-D-E as I enter the 5 digit code. On the 5th digit, it beeps and displays ERR 1.
    Any ideas would be appreciated, this is the same radio and code I have always used.
    thanks!
    Very nice choice with the JSW ez. My mother bought one 2 years ago on my advice and loves it. She has the automatic (her first one), but I can't be too critical, she drove sticks until she was over 70.
    Would have been my first choice, but my 3 sons did not have enough legroom in back. Too bad that chassis does not have the leg room of the new Jetta sedan.
    No problems yet on my '13 Accord. 2,500 miles is kind of pathetic for me in over 3 months. My projects have changed a little so less travel. My oldest son is driving my '07 - still going strong at 161,000 miles and could probably double that.
  • savegassavegas Posts: 26
    Diagnosed and performed software update at dealer last December and has much better fuel consumption until now.
    Again, fuel consumption is back to about ~5 miles less per gallon under the same driving condition and with clean fluids (trans, oil, coolant), clean filters (air filter, cabin filter) and correct psi for tires.
    Really don't know why and could be the vehicle on board computer problem ?
    Any suggestion ?
    Thank you,
    Did you get new tires recently?
    same tires since last year
  • nickjp57nickjp57 Posts: 1
    Honda30, I was just looking for this. My dealer wants $90 to replace the cabin filter and $60 for the engine air filter! I have a 2009 Accord EX. Of course, I live in Brooklyn, NY so things are high but that seems ridiculous. I am no mechanic but I am handy so I am sure if you can give me a bit of advice I can do this - I would really appreciate it. Thanks, Nick P
  • tomfromwvtomfromwv Posts: 2
    You can get the cabin and engine air filters at Walmart for around $20. It's a five minute job to replace either. I've done it on my dad's 2008. The cabin filter sits behind the glove box door. Just release the stops on the door so it tilts down and the CAF will be revealed. For more info go to YouTube and search on accord cabin air filter. There should be multiple videos on how to change it. The engine air filter is about the same cost and about same difficulty. $90 and $60 seems like a pure money maker for the dealer.
  • There's more than one YouTube on this and it's as easy as opening your glove box.
    The filters cost about $11 online and you can get them though Amazon. Very, very easy for either filter. Engine might need an extension for a ratchet wrench. I have a 2005 V6 Accord and shocked myself at how easy it was. My dealer wanted $100 to replace the cabin air filter in NJ.
    Nick:
    The cabin air filter can be found in most auto parts stores and takes maybe 3-5 minutes to replace. That's assuming your glove box is full.
    The air filter for the engine is a little longer. To pay a dealer to do these simple items is way too much. Of course they have overhead and expenses, but it is way too easy. Go to YouTube and search for it. You will be amazed how easy it is.
  • tomjewelltomjewell Posts: 1
    I have a 2003 Honda Accord 4 cyl/5 speed manual with 190,000 miles on it. Purchased 5 years ago with 110,000 miles on it and the oil has been changed every 4-5,000 miles. About 2 years ago I switched to Castrol High Mileage 5w20 oil (partially synthetic). Recently I've noticed the car is using oil, as much as 1+ qt between changes, and there is no evidence of leakage or any residue in the tailpipe. This car still gets 28 mpg around town and 31-33 on longer trips.
  • ahightowerahightower TXPosts: 533
    Most will probably say that 1 quart every 4-5K is perfectly acceptable given the high mileage. (Most manufacturers will probably say a quart every 1,000 miles is acceptable.)
Honda Accord (2003-2007) Maintenance and Repair - Page 193 — Car Forums at Edmunds.com
