Beginner Tuning/Modding
Hi i'm a new driver and recently got my first car, an '05 accord. Im interested in tuning and modifying my car but i don't know anything about it at all. so i was wondering where would be the best place for a new guy like me to start. thanks
I'd probably start off with buying myself a bunch of good magazines and reading through them:
Here's a good source list:
http://www.tuninglinx.com/html/mags.html
As for your car, you have to decide what aspect of it you feel needs improvement.
And best bang for the buck is usually a larger rear anti-sway bar. Less understeer and more throttle control for $300 at most. Any other modification for that price will make a small difference in power or grip.
If you are going to be the one installing the modifications I would definitely buy a technical manual on your specific car. Most times these books will have specific instructions about how to do engine maintenance work, sometimes they'll have wiring specs, etc. You should really understand the stock car before you begin adding extras.
You should try to get as much info as possible about your car and about the products you're interested in. When you consider tuning products look at all the available options for each modification. Sometimes you might have to pay more for something but look at it like if you pay a little more now then you might be saving yourself a lot of work/money down the road. You should keep doing what you're doing trying to interact with people who are already established in the tuning world, try to get as much info about your car and learn about the affects of tuning modifications (the performance gains and negative longterm affects it has on your engine/car), get all the info you can to make sure you select the right modifications at the right time. Most times you need to buy tuning mods in stages to protect your engine and ensure each part will work properly.
Also there are a lot of products you can buy that dont make the car faster but they will make the car drive better. Modifications like coilovers or suspensions, short shifters, brake kits, exhaust, etc. Please dont be like most of these kids with Honda's, taking a stock engine and putting NOS on it and blowing it up after the first week. Dont live up to the stereotype. Good luck with your car and be sure to update the forum on how it is coming along. Again, good luck. Joshua.
-mike
Go to temple of vtec. You can find out tons there.
If the offset is the same as stock, then you can compare the tire size using http://www.miata.net/garage/tirecalc.html
This will show you how much wider and/or higher the new tires/rims will be, given the same offset.
-mike
Thanks In Advance,
~Bogdan
-mike
Thank you,
~Bogdan
-mike
I have a 1992 Mercedenz-Benz 300E 4Matic with the inline straight 6motor and I would like to add more horsepower to it.
I want a whole new exhaust system with new manifold, headers, cadillac converter & muffler.
I want the cold air induction system with all the new hoses and tubing.
And I want the chip for it as well.
So could you please give me some pointers on what i need to do? And the names ad numbers of who I need to contact for all the parts to get?
Thank You So Very Much in Advance...
