My dealer even has little placards on the service desk and on the wall reminding customers about the belt. The damn manuals are so thick these days I put it in PDF on my PC so i can refer to it. I make it my business to abide by their REQUIRED service (but none of that engine flush stuff) just to avoid what you are going thru...I intentionally bought a 2007 SF w/ 3.3L engine since it does not have timing belts (the 2.7L still does) but the good ole timing chains. Did not need all the rest of the stuff...a GLS would have been fine except for that belt!
The catch there is that Hyundai adheres to the 3000 mile oil chg. Clean oil is critical to the timing chain functions. Since I do not drive that much any more, it is no biggie for me...I do think with the higher quality oils and FILTERS today, that 5000 miles is a more reasonable period...but I want that warranty in tact with no wiggle room, should something happen. Repairs on modern vehicles are big bucks ALL BRANDS!
Give a manufacturer some wiggle room in the warranty area and you are fried...I DO hope it works out for you...and so you know...lots of "better" brands (supposedly better) have timing belts and if they break, stretch or the like...it fries the engine
best of luck
I didn't realize that. That's a deal killer for me. My Subaru is marginal enough with a 5,000 mile interval. My Nissan says a 7,500 mile interval is fine and that's worked out good on it for the last 119,000 miles on it.
The belt change at 60,000 miles (like my Subaru) is on the low side too. The Nissan goes to 105,000 miles (plus it's a non-interference engine, so in theory a busted belt isn't going to cause too many problems other than stranding you somewhere).
I understand and thought about that too but I live in the nevada desert...murder on engines so it can't hurt and since i do not drive that much, i do not want the old Dino oil sitting in the crankcase too many months (people do not realize the acid that forms and we can swing 50+/_ degrees an a daily basis!). I sold a mini cooper and their chg was at 15000!!!! that's nuts in the other direction so I always did it myself at 5000 mi.
Just my two cents...
A
You guys know the dealers turn around and sell your used oil for recycling - yet another profit center coming out of your wallet. That's assuming they actually change your oil when you take it in (link).
But I digress.
As you may know, if no one is sitting in the front passenger seat the passenger side airbag is deactivated, and there is a light in the dashboard which tells you it is deactivated.
When someone is sitting in the seat, it activates a sensor in the seat, the airbag is then activated and the light will then go out.
I've noticed on several occasions.....I guess it happens about once a month, that someone will be sitting in the seat and the light will not go out indicating that the airbag is still deactivated.
Only two people really sit in the this seat, my wife and my mother, and it has happened to both of them.
At first I had them get out of the car and get back in which would make the light go out.
Then one day when my wife was in the vehicle, and the deactivated airbag light was on, I pulled over shut off the engine, then turned it on again and the light went out.
I took it to a Hyundai dealer and they said that they couldn't duplicate what happened and that they checked the computer and found nothing wrong.
The next time that it happened I was near the dealer and took it in and showed them that the light was coming on.
The serviceman said that he would check with Hyundai and see if there was any reports of this happening to someone else, of course he never got back to me.
He also suggested that it may be my wife's body shape that was causing the problem and the way she sat in the seat caused the sensor not to activate.
I might consider that a possibility, but like I said it's happened to both my wife and my mother who are two compeltely different body types.
It seems to me that it's either a problem with the sensor not functioning properly when someone sits in the seat, or a problem with the computer not picking up the message from the seat that someone is sitting in it.
The problem wouldn't be quite as bad if, in the daylight hours, when I usually drive, wouoldn't be so hard to see with the sun shining in the car, but I've ridden around for at least a half-hour or so before I noticed that light was still on with someone in the seat. Of course it probably means that the airbag for that seat isn't going to function, and I'd hate to think what might happen if I got into an accident.
Any thoughts of what the problem might be?
I'm making sure that I mention it every time I bring it in for service, becasue if they don't do anything, and so far they haven't.....and I do get into an accident and the airbag dosen't deploy when it should have,,,,,my attorney would be licking his lips in anticipation of a lawsuit.
Thanks in advance.
I went to the second page, but was unable to find anything there pertaining to this problem.....I also didn't get anything back when I put the words that you suggested in search. I eventually did find a couple of posts dealing with the problem but they seemed to be in the 2007 models.
(Of course I'm not familiar with this forum.....as you can see I've only posted once here, so maybe I'm not doing something right :-) )
But I will certainly mention replacing the weight sensor when I take the vehicle back in for service.
Once again let me thank you......and hey......maybe you can answer my next question. :-)
Again, I have a 2006 Santa Fe with 17,000 miles, and noticed this happening a few months ago. I'll try my best to give a complete description of what the vehicle is doing.
What is happening, is when I'm slowing down and the transmission is downshifting..... it seems that when it goes from 4th to 3rd gear the tachometer will jump around 800-900 rpms. It'll then go down to the lower gear. It dosen't jerk the car any when it does go down to the lower gear, and the only way that you'd even notice it is if you were looking at the tach when it happened, or heard the surge in the motor. The only other thing that I can compare it to is if you were driving a stick shift and pushed in the clutch without taking your foot off the gas....if that makes sense to you.
One other thing that I've had happen and of course both things only happen occasionally.....
I'll come to a stop at say a red light, and will be sitting there with my foot on the brake.
All of a sudden the car will lurch a little bit forward and I have to press harder on the brake.....it's almost like another car comes up and taps you in the rear is the best way to describe it.....in fact when it first occurred that's what I thought happened, until I looked in my rearview mirror and no one was there.
The second time it happened, I just blamed it on myself, thinking that I wasn't pressing the brake hard enough.
The third time that it happened I was looking at the tachometer and noticed that the idle speed, when I stopped, was reading about 400-500 rpm's, where it usually reads 700-800 when at idle.
While I was sitting there thinking "hummmm, that's funny" the idle speed jumped back up to it's normal speed, and that's when I got the same lurching movement that I experienced before.
When I took the car for it's 15,000 mile service I told the service rep what the car was doing.
They said that they couldn't duplicate the problem, and that when they put it on the computer it didn't show any problem.
They did say that the vehicle has something in the computer that, (now I know that I'm not going to describe this properly so please bear with me) confroms the vehicle with the way that you drive (again forgive me because I can't recall off the top of my head what they call it), and they reset it.
Since then I haven't really noticed it lurching.....but on two occassions I have noticed that it still reving up the rpms when it downshifts.
Anyone else have the problem?
Anyone have any idea what may be causing it?
Anyone have any idea what they might do to fix it?
Thank you in advance.
P.S......if this helps. I've only noticed it when I've been driving around for awhile and the engine is hot.
As for the 2006 S.Fe transmission problem, sorry, I can't help. It could be umpteen things. You could try using the search again and see what comes up. As for "cannot duplicate" justification from service techs, I swear it's their first line of defense - we've all had that at some point. I assume you are still within warranty so you could try another dealer. Good luck.
I can spend about $11,000. I'm looking closely at an '03 4WD with the 2.7L V6 and ABS. I figure the 4WD might stick to the road better. Is the 4WD better to go with? This Santy has everything I wasnt except a sunroof. It seems the ones w/a sunroof I've seen on the Internet don't have 4WD.
PS. the trade-in value sucks! - depereciated $20,000 in three years
Have you been able to get this resolved?
Bill D.
Any suggestions?
But I think the Lemon Law applies to new cars. I think that time period is only a year or so. I could be wrong though! Doesn't the Kia have a 100,000 power train? I would trade on a Santa Fe - my '02 was bought brand new and no problems at all. Hyundai may own Kia - but the SF and the Sorrento are two totally different cars. The only car Hyundai and Kia duplicate is the Minivan. Hyundai's seem to be made better. Consumer Reports rated the Sorrento poor reliability and depreciation - the Santa Fe had all excellents/goods from 2002-present.
Anacostiaman
1. Mushy feel when turning: solved by using better tires. The stock tires do the vehicle no justice at all. Drives MUCH better on my Yokohama Geolander tires. It even drove better on some General Grabber tires.
2. Repairs - After 120k miles, I've had to replace the spark plug wires, changed the timing belt for the 2nd time (both as scheduled maintenance), changed the spark plugs, replaced two bad wheel bearings (at the same time, right side had gone bad), changed all belts & hoses as per scheduled maintenance, replaced the battery 2x. Have had no mechanical breakdowns whatsoever. The bearings were a little surprising, but that's the only mechanical failure so far.
Problem with the 2006 Hyundai Santa Fe
I was given two Lanzar 6.5 and two Pioneer 6.5 speakers. There is nothing wrong with my stock speakers, I just wanted to add a little more thump and clarity. I took off the front drivers side interior panel, Which wasn't all that bad, but i'm having major problems putting it back together. I'll get into that a bit later. I figured swapping the old for the new would be simple. Being it has two wires (pos/neg) going to the driver/speaker cone and two wires going to the tweeter portion that goes over the lower part, four wires total. The wires are White, Brown, yellow, and Black going into a black clip, then they turn black coming out the other side. I cut the four after the clip. My new speakers have only two posts to accommodate the driver and tweeter. So I left off the two for the tweeter and it sounded awful. I tried combining the two positive and two negative and hooking it up that way. That too sounded awful. The tweeter was squealing and chirping. I tried every configuration. They all sounded like ***. What am I doing wrong. I know people swap out stocks for after market all the time. I wanted to be sure my new speaker wasn't defective, so I tried all four (Both brands) with the same results. So I gave up and put the original back in. It sounds fine, just like it had before. But now I can't put the door panel back on. I know it's just tricky and i need more patience. I'm so bummed. I have these great speakers and have no idea why I can't install them. Do I need some aftermarket clip? It seems so easy, why is it so flappin hard? I've done this with other cars in the past with no issues. This four wire thing is killing me... Please HELP ME!!!!!!!!
I tried contacting Lanzar with no luck. Same with Pioneer. I left messages with tech support.
Simply put, I'm too broke to have it done by a shop.. So any and all help is much appreciated.
Frame rust: covered under recall.
Brakes: Brake slides tend to rust into position.
Timing belt: Should be done at every 60K miles. Cost is about $300 to $600. (It looks like the prior owner never changed ours.)
We replaced shocks and brake pads and lower ball joints on ours when we bought it. It rattled like mad until we fixed that. Then no problems.
If this is an AWD unit then all 4 tires should have the same wear on them. We thought that we could get away with replacing just the two that were bad because it looked like the "good" ones were practically brand new. They were not quite new enough.
Other than that we like the vehicle a lot. Also, the "rust" items mentioned above are primarily in the salt belt (or so they claim). The MPG will not be too great, especially if this is a 3.5L. We got the 2.7L and I have not checked the MPG yet, so I cannot say for sure what we are getting.
TerryMSU
the dealer is no help just spend money as thay try find it so far over 2k new fuelpump
fuel regulator fuelfilter checked for vacume leaks
thay are lost even contaced the factory techs? i am lost i need help has anyone had anything
like this
