Ford Expedition Mirrors and Windows
superq1957
Member Posts: 5
I have a 2004 expedition and swapped out both outside mirror with the one with turn signals. The procedure was quite easy and they just pluged into the harnes. My question is, I went to turn on the turn signal and they won't work on either side of the outside mirror. Is there a step I left off, or something I forgit to do?
dual fold heat/power mirrors,yet they don't fold
check your sticker.... Ford is not answering my inquiries any more. Dealer was sure they folded.
They are as confused as I am. My fifth new Ford suv. Third from this Dealer. Yeah I'm aware that the only broshure I could find states only Limited get power folding mirrors. The description on all other stickers is changed.
Does anyone out there have power folding mirrors asoriginal equiptment on 03,04,05. EB. Exped.
Here's the deal. Ford did not run the additional wire on XLTs for the turn signals. Save money? A little less copper?
You have to hard wire the the wires from the new mirrors to the wire bundle under the dash.
There is an aftermarket mirror company that has instructions that are very similar:
link title
I got the drivers side working right away - first try I probed the correct wire - white/green. I ran a jumper wire through the flex rubber between the door and the door jam and spliced it into that wire. Works great.
What I've been trying to find is the white with blue stripe that is supposed to be the left side wire - no luck. I've probed every wire under there. Does anyone know how to ID that wire or am I looking in the wrong place?
My driver-side window has terrible squeak upon roll-up/roll-down.
Any suggestions I might try at home before I take it in to a shop for servicing?
BackNine29
If you have '05 -'07, please double check to see if you have folding outside mirrors. Please be very careful while trying this. Apply pressure gently and progressively otherwise, you might break the mirror.
j-jones
SUVs and Smart Shopper
Mark.
