Toyota Corolla Audio Questions
http://www.toyotanation.com/forum/showthread.php?t=251982
Good Luck
1. disconnect battery lead because of air bag sensors
2. pop off trim around shifter stick
3. remove center knob on the A/C panel. Remove phillips screw behind the knob. This is the only screw that has to come out (in addition to the 4 radio screws)
4. pull the a/c console forward. It's a tight fit but it's only held by clips. This was the most difficult part for me because I didn't want to break anything. It eventually released after pulling with constant pressure.
5. pull the air vent assembly off around the radio. This is also a tight fit, is only secured with clips. The radio face plate came off with this piece.
6. Remove 4 10mm bolts at bottom of radio. I used putty on a 10mm socket to help hold the bolt from falling down into the dashboard. Lose these bolts and you'll easily add several hours to the job trying to fish them out of the dashboard.
If so how
I went to a big electronics retailer (Store #1) to see about replacing the stock stereo (CD/AM-FM) in my 07 Corolla with one that has both CD/AM-FM and an auxillary plug for an MP3 player. This retailer has a feature on its car audio webpage where you can select your vehicle and see which stereo decks will be compatible with it. I did this -- and found that it had no listings (none) for the Corolla. (Same thing for the Honda Civic and Accord.) I figured this was an error, especially since a competitor (Store #2) listed 12-15 different decks that are supposedly compatible with my Corolla year.
Store #1 said that they're "covering our bases" by not listing anything as compatible, since I have six speakers and most decks won't work with the stock six speakers in the vehicle. They say I'd either have to "lose" two of my speaker connections (undesirable, in my view) or I'd have to buy two new (more "efficient") speakers from them. This would just about double the total cost I planned to pay for a new stereo deck with installation. Obviously, I'm reluctant to go this route. But the scare tactic at Store #1 is that I could "fry" my new deck if it overwhelms the speakers the car came equipped with. (I'm not looking for the thumping bass effect. Maybe a little Led Zepplin on my rockiest days.)
The kicker: The competitor (Store #2) seems just fine with installing the same decks and has indicated no concerns about needing to install additional store-purchased speakers. Basically, I would just have to pay $20 or so for the harnass, plus the deck itself (installation is pretty much free if the deck is over $99). I would much prefer to go with Store #2 and the much less expensive cost involved...but if I do that, am I likely to "fry" my new stereo? In other words, are those two new speakers Store #1 wants to sell me truly necessary? Thanks for any info/guidance.
Steve
Jim
What's causing it and what to do to avoid and solve the problem? Pls. advise. Thanks.
prima donna
I have another issue maybe you know the answer to this. Same car, acting up by stalling ocassionally. Before it does, it jerk first (like a warning) then speed decreases and engine stop. But, when i start, it will start right up. Most parts are new (replaced) with original. Example: starter/distributor/crank sensor/water pump..
Still doing it every now and then. What's causing it and how to solve it. Pls. need your advise/your expert opinion. Thank you so much.
anumrama@aol.com
http://2k7corolla.blogspot.com/2006/12/how-to-remove-rear-speakers-from-2007.htm- l
but I was wondering if it's somewhat similar for an '02 corolla.. If someone has a guide or walk-thru, that'd be awesome.
Dave
- go get a cup of coffee and wait 5 minutes,
- comeback and radio will be out for you.
- don't wait longer than 5 minutes or wheels will be off as well.
Does anyone have instructions and illustrations (pictures) on how to remove the rear deck plastic cover to get to the speakers? It looks like a bear to remove. Your help would be much appreciated.
I suppose if you have tips and illustrations of the front door panel removal with power windows and locks, that would be helpful, too. I will probably replace the front speakers eventually.
My problem was that there appeared to be no power to the audio system. I checked the fuses but they all seem ok and the other itmes that share that fuse (internal lights etc... as I understand it) all worked fine.
I wondered of the power cable was loose (my electrics had been repaired after a previous frying - don't ask) but on removal of the audio the power cable was fine.
So, before I go and buy a new system can any one think of a reason my whole audio unit is not working?
By that I mean no display, no clock, no mpg, no CD playing (and one stuck in the tray), no radio etc... Nada.
Any ideas?
Steve
