Once the instrument cluster is removed, I would recommend that you replace ALL the incandescent light bulbs, because it is too much trouble to remove the instrument cluster every time an incandescent bulb burns out.
They should have made those lights out of LED's.
Busted so it won't open or close. This presents a problem because it will not
Shut all the way leaving the door ajar and my interior lights on for half the night
Which obviously drains the battery. Second my security system is all messed up.
My four ways go off for no apparent reason which is s battery drain also, in order
To start the vehicle I need to turn the key like four times to disarm the system.
This is all killing my battery. My brake lights don't work but I still have turn signals
Among other things these are my most serious problems help please!
Your Oil is too Black, How long did it take to get so black? Change oil and filter right away and monitor it closely. You might need a heavier weight oil or oil additive. Change it every 3000 miles, or sooner if it gets very black. To investigate the noise, you would need to remove the valve covers and check everything you see in there. Rock the engine crankshaft back and forth a little to check to see how much slack there is in the timing chain, Run the engine at idle with the valve covers off and observe to be sure that there is good oil flow to all moving parts, and listen for where the noise is coming from.
Good Luck,
E.D. in Sunny Florida
My parents purchased a 2005 Explorer last year with a V-6. The thing had been having a transmission problem where the transmission wouldn't shift into reverse. That was bad enough.
More recently, it died while driving down the road. It had been bogging down and not accelerating very well prior to this. My mom parked it and when we tried to start it, it made this really loud noise, which I can only describe as being like a jet engine. Currently, it sits at a shop where they really don't know what is wrong with it. It only has about 70,000 miles on it, but I definitely would not buy one.
Thanks in advance. :mad:
PS.. i was previously told it could be the ac clutch seizing up but i checked it and the clutch seemed to be engaging fine but it didnt stay on consistently. i dont know if thats normal or not but it didnt seem to be bogging down the motor when engaging.
Good Luck,
Don
it also was making a whistling noise but me and my dad solved the problem by fixing the IAC we cleaned it with some electronic cleaner and now it doesnt make the noise.
we also replaced the i think its called dpgfe or egr its a lil part that has two lil tubes it cost about 50 dollars we changed it and the check engine light took off but came back on the next day we also cleaned the MAF part and the light is still on. the car sometimes shakes when im at a red light or at a stop sign then once i press the gas it stops shaking what can it be?
Mechanic called and wanted us to road test the vehicle for a few hundred miles to make sure the check engine light did not come on.
However, when we picked it up, all of the guages and the lights on the right side of the console were not working (speedometer, tachometer, odometer, battery, and I think oil are on that side, turn signals) Two guages on left side, and lights on left side (the ones that come on at startup) are working. mechanic says not thier problem.
All were working before we took the car in.
So, two questions ...
1) What could be the probable causes of this? Likely just a fuse (have not had time to check these yet)?
2) given the answers to 1) ... is it possible that the mechanic, in testing for smog and repairing the air intake issue, did something to cause the problem?
Thanks for any thoughts.
My '97 5.0 v8 will not start, there is no fuel at the rail. I found the 20amp mini fuse for "fuel system, anti-theft system" blown. I replaced the fuse, still will not start, no fuel. I can not hear the pump run when I turn on the ignition. I checked for voltage at the inertia switch, if I unplug the switch I have voltage at the dark green/yellow wire from the relay. If I plug the switch back in, the voltage at the dg/y wire disappears. I put a jumper wire to the plug between the dg/y wire and the Pink/Black wire to the pump, but can not read voltage to either wire. The 20 amp fuse has not blown again. I am thinking it is the fuel pump but hate to remove the tank if it is not the pump. Any help or suggestions much appreciated.
Don"
"My '05 XLT is doing the same thing. I haven't gotten a response, have you? Have you solved it? What was it? I need some answers; thanks."
What is said does not make sense, especially the " If I plug the switch back in, the voltage at the dg/y wire disappears". I am doubtful of the troubshooting technique being used. If using a digital multimeter, it may be picking up stray or surface voltages. The best way to trace and test the fuel pump power circuit is using a common 12 Volt light bulb type tester. It has a pointed probe on one end and the other end has a wire with an alligator clip (everyone should have one of these in their car). Connect the alligator clip to grounded metal, and touch the pointed probe to a "hot" wire, and the bulb lights up. Use this tool to check for the presence of voltage coming into and leaving the inertia switch. If you have power leaving the inertia switch, it indicates that power is going to the pump. If this is the case, and the pump still does not run, you will have to lower the fuel tank to check connections to be sure power is going to the electric connector at the pump. If there IS power at the connector, next step is to PULL the pump from the fuel tank and CHECK the pump.
Good Luck,
2. Fix the Leak where water is entering the door. Check the seal of the door to the glass, repair or replace the seal.
Good Luck,
I checked all the fuses, that was not the issue, so I decided to check behind the dash to see if it was a loose connection or something that i could possibly fix.
When I got in there, I saw that eight of the wires connected to the instrument cluster had been cut ... in two places. :mad: Now, for the life of me, I cannot figure out how those eight wires could be cut in two places (one of which was right at the back of the plug) exactly at the same time (as all the instruments were working before). I fixed the problem (instruments wrk now), but I'm following up with the Bureau of Automotive Repair. I took photos and videos of the damage.
2, Repair or replace faulty headlight relay.
Good Luck,
2002 Explorer 4.6L V8.
I'm trying to replace the EGR valve pressure sensor and took me long enough to locate it (it's sitting by the firewall, right in the center). I found it nearly impossible to get to it without removing the black engine cover. I only found 2 nuts to unscrew on the cover (located towards the front of the engine), and after I took the nuts out, I still couldn't remove the cover. There has to be something else holding the cover in place towards the rear on the cover but I couldn't locate it. I didn't want to yank the cover too hard fear that I might break something. Can someone please show me how to remove the engine cover properly? Thanks.
